Future Pinball BAM w/ HS
Frosty
Wanting to update my future pinball setup to use the new zedpinball physics. Is it as simple as pointing the hl module to the BAM fp launcher? Wanting to know what Ill be getting into from someone who's done this already...
Ok, so here is what I did. Probably not needed, but it's the way I do all these alternative setups.
Create a new GLOBAL emulator and called it "Future Pinball-BAM".
Pointed it to FPLoader.exe
and Use the standard Future Pinball module.
That way I can easily switch back and forth. Also allows you to still use Future Pinball as an alternate emulator for some games. ;)
Thanks,
Ron
And has anyone tried using Wiimotes or a camera with Bam? I was going to try, but have not had time. Some of those youtube vids look pretty cool.
I bought a Kinect to use on my vpin build. I wasn't that impressed with it so sold it. The effect is impressive for the first 10 minutes and then it just becomes a pointless gimmick.
sig2.png?raw=1sig.jpg?raw=1
Just to confirm, I can use bam solely for the updated pinball physics and lighting right? Not interested in head tracking or rotated full screen mode.
Affirmative!
Thanks,
Ron
BAM setup/install was simple enough. Love the night/day sliders. Good stuff.
Is BAM able to completely remove the FP splash screen? I see mine pop up whenever I first use it, then it doesn't other times...
  Quote
Are you talking about the tables loading screen? If so I believe you can't remove that. Sent from my iPhone using Tapatalk
Nah I'm referring to the future pinball splash that pops up for like a second or two. Does your bam setup show it?
