Trackball not working in Games in Hyperspin using XArcade Tankstick
marcdaddy
Guys im running Hyperspin 1.0 With a XArcade Tankstick. I can play games in mame with the trackball Outside of hyperspin just fine with the trackball ( Also if i use Maximus Arcade as a FE it works fine with that but who wants that crap ) Inside Hyperspin it will move the wheel to select emulators and games but when i fire up a game it doesnt respond. I have tried in the Mame INI enabling multi mouse support just as a thought but this is the only mouse on the system. In the Device Manager it shows up as 1 device it says HID Compliant mouse. Within Hyperspin im playing a game e.g. Crystal Castles i hit TAB and try to map the trackball but what the trackball does is actually move the cursor around to highlight other options and does not respond to the acyual setting up of the controls. Did i miss something in the Hyperspin setup somewhere since its only conflicting in there? I have enabled trackball support in the options. Thanks guys im just pulling my hair out over this :hmmmm2:
Howdy, you need to have 'xarcade' set in the ctrl entry in your Mame ini file. Just add xarcade to the right of the ctrl line in the CORE INPUT OPTIONS & resave the file using notepad.
Your Mame should have the latest ctrl file for xarcade, if not go the their website and download it. Add it to the ctrl folder in mame but if it worked outside of HS you should be good to go.
I use to map the keys using the Tab function in mame until I learned the setup. I'm using the Tankstick and I no longer have to map keys for Mame or any of the emulators that allow me to map keys in the Config settings for each system.
Here is an example, I'm not at home but this is what it looks like. The mouse should be set at 1:
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr xarcade
mouse 1
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0[/font]
Give it a try, if you're still stuck I can send my ini settings from home later in the week. Good luck!
Thanks, Ill double check MAME but i have added the Xarcade profile in Mame before, ill triple check everything it just sux that it only acts up in Hyperspin.
coin_lockout 1
ctrlr xarcade
mouse 1
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
natural 0[/font]
Well mine looks exactly like yours, With the latest File from X-Gaming and the trackball still wont work inside of Myperspin ( It works fine outside of Hyperspin while running Mame ) So hitting the Tab key while inside of Hyperspin the Trackball still wont register in there. So the problem is somewhere inside of hyperspin and im stumped.
Ya i get the same results with it On or Off? Just stumped, im not running another mouse either. Its a confliction once hyperspin is running since the trackball works outside in mame. What can it be? Something in the Script maybe?
I am having the same problem with my trackball (not an xarcade) it works as the mouse and in wheel but not in any games
coin_lockout 1
ctrlr xarcade
mouse 1
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
natural 0[/font]
this worked for me thanks
Well, What MAME Version Are You Using? The Older MAME versions always had mouse support enabled, but if You're using one of the newer versions (Built In GUI) you're going to have to generate an INI file and enable mouse support in the games. Run this in the command line MAME...
mame.exe -cc
And then go into that file. When You see...
mouse = 0
change it to
mouse = 1
You just enabled mouse support in MAME. Thus, trackball should be working now.
The Mame generated ini file makes perfect sense. I'd say that may be the last of it.
2 more things to be certain of:
1) Make sure the switch on the back of the tankstick box is all the way to the right in postion 1 (while facing your cab). You can read about the switch settings on the Xarcade website. Make sure it's 'loaded' as position 1, something like pressing back program button twice and seeing the LED go on and off once.
2) 'Numlock' needs to be on.
Because it works outside HS these 2 options may not be necessary but if it's doesn't then you know what to do next.
I'll check back in over the weekend to see if your good. Good luck!
Wow nothing has worked so far, Made sure Numlock was on and verified the posistion of the switch. So i put Maximus arcade Front End on the machine to check it out and when i run Mame from there the Trackball works, When i run Mame on its own from windows the Trackball works, When i run it in Hyperspin the trackball lets me selscts games but once the game starts the trackball no longer works. Even hitting tab inside of mame in Hyperspin the the trackball doesnt register. Escape out back to the game menu and it works. Wow gotta be close to figuring this out.
Hmmmm... was hoping we had all the options covered. If it works in HS as a menu contoller then someone smarter than me must know what's up?
I must of fired up Centipede a dozen times until finally I got it working. Love Capcom Bowling. Try a few of the classic trackball games just to be certain it's not working correctly.
Kids are vaca this week from school so I'll hope to mess around in the Mancave this week. Let me do some more research and I'll get back to you. You couldn't be any closer so I have faith we'll get it going!!
Ya i must admit there are a few games id like it to play in Hyperspin with the trackball that wont work, Crystal Castles, Shuzz, Bowling, Centipede and Millipede just to name a few. Im about as stumped as i ever was hehe. One more thing im running Windows 7 on this machine. I did dissconnect the tankstick and try it on a windows XP setup with Hyperspin installed and it did the same thing GRRRR! :puke:
Here's my cab's Mame.ini file with my working Tankstick (I run mame64). Make sure the Xarcade (ctrlr line) doesn't have any uneeded spaces - hard to see here but you get the idea. The X of Xarcade should be under the coin_lockout 1 entry above the ctrlr entry:
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath .;ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
coin_lockout 1
ctrlr xarcade
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 0
uifont default
ramsize
confirm_quit 0
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 0
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 0
syncrefresh 0
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion 9
filter 1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 1
switchres 0
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
hide_cursor 1
dual_lightgun 0
  • 2 years later...
Did you guys have any luck with this? I am having the same issues. Please let me know. Would love to play Golden Tee
  • 3 months later...
I can get it to work within MAME directly with the Core Input Options as mouse. Works a treat.
However, when I launch Golden Tee via Hyperspin, doesn't work. Still looking around for a solution
