wardiz Posted May 6, 2012 Posted May 6, 2012 Im trying to get hyperlaunch to work properly, ive followed all the steps to set it up, my mame emulator works fine with it, but my nes emulator "fceux" wont load up , i think ive set it up properly but every time i test it in hyperlaunch it says Cannot find D:\hyperspin\settings\fceux r2263.ini can any body help me with this ? thanks.
djvj Posted May 6, 2012 Posted May 6, 2012 The module has to be named the same as the system name: Nintendo Entertainment System.ahk Then HS will look for: Nintendo Entertainment System.ini not fceux r2263.ini Also in your main menu.xml you shoild have an entry for: Nintendo Entertainment System not fceux r2263 "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
RonMcDon Posted August 1, 2014 Posted August 1, 2014 The module has to be named the same as the system name:Nintendo Entertainment System.ahk Then HS will look for: Nintendo Entertainment System.ini not fceux r2263.ini Also in your main menu.xml you shoild have an entry for: Nintendo Entertainment System not fceux r2263 I am having the same problem. Please forgive my ignorance, but how do you make sure the module is named the same as the system? Any help would be greatly appreciated
rfancella Posted August 1, 2014 Posted August 1, 2014 I am having the same problem. Please forgive my ignorance, but how do you make sure the module is named the same as the system? Any help would be greatly appreciated For all the official names, look in ...\HyperSpin\HyperLaunch\HyperLaunchHQ\Media\Icons Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
RonMcDon Posted August 1, 2014 Posted August 1, 2014 For all the official names, look in ...\HyperSpin\HyperLaunch\HyperLaunchHQ\Media\Icons Thanks for the fast response. I'm having this problem with three systems (Game Boy, Game Boy Colour, and Game Boy Advance). They are all named the same as in the folder you mentioned. And yet, the problem persists, alas.
Fromlostdays Posted August 1, 2014 Posted August 1, 2014 I have this problem with DICE. I just so happened to be messing around last night, and I noticed there are still inis in the settings folder in the main hyperspin directory. I also noticed I didn't have a DICE ini in there. In truth, I'm not sure if with the new hyperlaunch that folder even matters, but tonight I was going to try duplicating one of the other inis in there and then just naming it DICE to see if it fixed the error. IF you're at your computer, Ron, could you try that? Edit: you may have to open the ini and set the right paths etc within the ini, but just having one in there might get rid of that particular error even if you get another one. I don't know where the hell that dice ini went in my case. I certainly didn't delete it intentionally. Edit edit: I just noticed that all of those systems are named wrong for you, Ron. Look at the icons folder as directed above again. They should be named like Nintendo Game Boy, Nintendo Game Boy Color, Nintendo Game Boy Advance (I think, double check me). You'll have to go into HyperHQ and make new systems for each, and delete those. Walter:beerglass:
RonMcDon Posted August 2, 2014 Posted August 2, 2014 I have this problem with DICE. I just so happened to be messing around last night, and I noticed there are still inis in the settings folder in the main hyperspin directory. I also noticed I didn't have a DICE ini in there. In truth, I'm not sure if with the new hyperlaunch that folder even matters, but tonight I was going to try duplicating one of the other inis in there and then just naming it DICE to see if it fixed the error. IF you're at your computer, Ron, could you try that?Edit: you may have to open the ini and set the right paths etc within the ini, but just having one in there might get rid of that particular error even if you get another one. I don't know where the hell that dice ini went in my case. I certainly didn't delete it intentionally. Edit edit: I just noticed that all of those systems are named wrong for you, Ron. Look at the icons folder as directed above again. They should be named like Nintendo Game Boy, Nintendo Game Boy Color, Nintendo Game Boy Advance (I think, double check me). You'll have to go into HyperHQ and make new systems for each, and delete those. There are ini files for Nintendo Game Boy, Nintendo Game Boy Color, and Nintendo Game Boy Advance in the HyperSpin/Settings folder. What do you mean "set the right paths etc within the ini"? I think the systems are named correctly (Nintendo Game Boy, Nintendo Game Boy Color, and Nintendo Game Boy Advance). The symbol for each system shows up next to each name in HyperLaunch HQ. This wouldn't happen if they were named incorrectly, or would it? I added these systems the same way that I added others. I'm not sure why I'm having this issue. I very much appreciate everyone's ongoing support HyperSpin is insanely awesome! I'd love to get it up and working for all my systems.
Polemicist Posted August 2, 2014 Posted August 2, 2014 You are using HyperLaunchHQ to change things for each system aren't you? The post you are referencing is very old and back in the days where people had to manually edit stuff in INI files. Now we have HyperLaunchHQ and it does all the nasty work for us.
RonMcDon Posted August 2, 2014 Posted August 2, 2014 You are using HyperLaunchHQ to change things for each system aren't you? The post you are referencing is very old and back in the days where people had to manually edit stuff in INI files. Now we have HyperLaunchHQ and it does all the nasty work for us. Yes, I used HyperHQ to add the systems, and configured them in HyperLaunchHQ. Thanks for clarifying. I was unaware of the history and what things are/aren't relevant any more.
Polemicist Posted August 2, 2014 Posted August 2, 2014 Everything has relevance just have to filter out the old practices that have changed now and if they are used have to be used wisely. Manual editing is fine but the GUI makes life so damn easy. I actually find it strange that the Nintendo systems are giving you issues. For me they happened to just fall into place. The emulators do run outside of HyperLaunch? And you aren't turning on any fancy features such as HyperBezel support and stuff?
RonMcDon Posted August 3, 2014 Posted August 3, 2014 Everything has relevance just have to filter out the old practices that have changed now and if they are used have to be used wisely. Manual editing is fine but the GUI makes life so damn easy. I actually find it strange that the Nintendo systems are giving you issues. For me they happened to just fall into place. The emulators do run outside of HyperLaunch? And you aren't turning on any fancy features such as HyperBezel support and stuff? All sorted now. HyperSpin was looking for vbam.ini whereas the file in the folder was named vba.ini. I simply renamed it, and it now launches. Too easy. Thanks very much for your help rfancella, aletterfromthelostdays and Polemicist! I appreciate it
rfancella Posted August 3, 2014 Posted August 3, 2014 All sorted now. HyperSpin was looking for vbam.ini whereas the file in the folder was named vba.ini. I simply renamed it, and it now launches. Too easy. Thanks very much for your help rfancella, aletterfromthelostdays and Polemicist! I appreciate it Hi, The reason it was looking for that file is that VisualBoyAdvance (the emu you have) and VisualBoyAdvance-M (the emu the module is for) are two different emulators. If you make any changes in the emu, you will have to delete the file and rename again. Open up the module and there is a url for VBA-M in there. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
evh347 Posted June 1, 2015 Posted June 1, 2015 Okay, I'm a little closer to solving this, but this is bugging me. Because I updated the name of my VisualBoyAdvance folder. I can launch the emulator fine if I highlight my emulator and click "Launch Emulator" under the RL Emulator tab, but when I go to launch a game, RL continues to look for my emulator in the older named version of my folder.I've deleted and re-added the emulator over and over. Does anyone know where I need to look to update the path? 10:35:07:779 | RL | INFO | +N/A | Main - RocketLauncher v1.0.0.1 (www.rlauncher.com) 10:35:07:849 | RL | INFO | +62 | Main - System Specs: RocketLauncher Dir: H:\Program Files\Hyperspin\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 16270.91 MB Free Memory: 10522.49 MB Used Memory: 5748.422 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: Intel(R) HD Graphics 4000 GPU 1 RAM: -1984.00 MB GPU 1 Driver Version: 9.17.10.2932 GPU 2 Name: NVIDIA GeForce GTX 660 GPU 2 RAM: 1536.00 MB GPU 2 Driver Version: 9.18.13.5286 Sound 1 Device: Intel(R) Display Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 3 Status: Enabled Sound 4 Device: Realtek High Definition Audio Sound 4 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1050 work) Monitor #2 (\\.\DISPLAY2): 1604x0 (1604x0 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 10:35:07:849 | RL | INFO | +0 | CheckFile - Checking if H:\Program Files\Hyperspin\RocketLauncher\RocketLauncher.exe exists 10:35:07:849 | RL | INFO | +0 | CheckFile - Checking if H:\Program Files\Hyperspin\RocketLauncher\Plugins\HyperSpin.plugin exists 10:35:07:849 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 10:35:07:849 | RL | INFO | +0 | Main - RocketLauncher received "Nintendo Game Boy Color" and "007 - The World Is Not Enough (USA, Europe)" 10:35:07:849 | RL | INFO | +0 | Main - Did not find a "H:\Program Files\Hyperspin\RocketLauncher\Settings\Nintendo Game Boy Color\Game Options.ini" file, skipping any game-specific options. 10:35:07:849 | RL | INFO | +0 | Main - 007 - The World Is Not Enough (USA, Europe) is using the default emulator: VisualBoyAdvance-M 10:35:07:849 | RL | INFO | +0 | Main - Checking for a [VisualBoyAdvance-M] section in H:\Program Files\Hyperspin\RocketLauncher\Settings\Nintendo Game Boy Color\Emulators.ini 10:35:07:849 | RL | INFO | +0 | Main - Checking for a [VisualBoyAdvance-M] section in H:\Program Files\Hyperspin\RocketLauncher\Settings\Global Emulators.ini 10:35:07:849 | RL | INFO | +0 | Main - Found [VisualBoyAdvance-M] in H:\Program Files\Hyperspin\RocketLauncher\Settings\Global Emulators.ini 10:35:07:849 | RL | INFO | +0 | CheckFile - Checking if H:\Program Files\Hyperspin\RocketLauncher\Modules\VisualBoyAdvance-M\VisualBoyAdvance-M.ahk exists 10:35:07:859 | RL | INFO | +16 | Main - CRC Check - CRC matches, this is an official unedited module. 10:35:07:859 | RL | INFO | +0 | Main - 007 - The World Is Not Enough (USA, Europe) will use module: H:\Program Files\Hyperspin\RocketLauncher\Modules\VisualBoyAdvance-M\VisualBoyAdvance-M.ahk 10:35:07:859 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Mode_Rotation_Angle" in section: "Settings" in "H:\Program Files\Hyperspin\RocketLauncher\Settings\Nintendo Game Boy Color\RocketLauncher.ini" 10:35:07:869 | RL | INFO | +15 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 10:35:07:879 | RL | INFO | +0 | CheckFile - Checking if H:\Program Files\VisualBoyAdvance-1.7.2\VisualBoyAdvance.exe exists 10:35:16:110 | RL | ERROR | +8237 | Could not find your emulator\application: "H:\Program Files\VisualBoyAdvance-1.7.2\VisualBoyAdvance.exe" 10:35:16:110 | RL | INFO | +0 | ExitScript - Started 10:35:16:120 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 10:35:16:120 | RL | INFO | +0 | ExitScript - Ended
evh347 Posted June 2, 2015 Posted June 2, 2015 Nevermind. I deleted and re-added the systems in RL. In the GUI to add a new emulator, I named it, then clicked on the "+" to "Add new Emulator". I filled in all the fields (Name, Path, Rom Extensions, and then selected the appropriate Module). Inputted in the path to the Roms and tried to launch. It worked. I am now officially up and running with everything on RL and it only took 48 hours. Sheesh. There are lots of Wiki's out there, but you need at least 2-4 hours to sit down and read through it all before you start or you're bound to make a mistake along the way. And when your Hyperspin stops working after all the work you've put into it, the thought of ending it all does cross one's mind (kidding of course).
rastan Posted November 2, 2015 Posted November 2, 2015 Well thanks to this post because I was just scratching my help trying to figure out why VBA-M worked perfectly outside of rocket launcher but when I tried to test it within rocket launcher.. I got the missing VBAM.ini error.... definitely thought about renaming the VBA.ini but seemed so simply that it was just a thought until I read this post. #thanx
