Sega Model 2 Multiplayer Module
ghutch92
Actually nm, just tested, it still works.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 2 months later...
Someone has the emulator all set up, it too much work hahaha... i need the NVDATA folder for Single and Multi (Player 1)... and the NVDATA for Slave (players 2-3-4)... i know how to make those folders and configs (loading and change the config for each game 3 times :o) but its so much repetitive work :(
if someone already did it please make it public... (The whole Sega Model 2 Emulator folder will be nice)
There should be one in my ftp folder.
  • 2 months later...
  • 4 months later...
Hello and thanx for everything in here.
I need some help.
In this code do i need to change anything inside to it?
Like some adresss for some files or anything?
Or i just copy the code without any change?
I tried everything but I got nothing
I need some steps to enable the separation screen if someone can give.
Thank you!!
Have you got separate emulator folders for each player?
let me understand something. this module is for split screen or play 2 players via link?if is the second option then im ok. i just thought that this one made an option of 2 players into 1 window.
Its via link, its on one screen but you have two emulators running together taking one part of the screen
ok.so its not in two emu windows what is supposed to do.correct?
it connected and you can play via link but in one window.
to help you also.
i have made the 2 player files,emulator.ini file and also i made the config inside the game menu so it can connect.
but im sure im losing something.
ps.sorry for bad english :)
is there anything i have to made in hyperlaunch?
to help you also.
No its two windows as in two emulators running at the same time, you link the emulators together as if you were linking two arcade machines together.
Maybe this help
  • 3 months later...
I'm having an issue with the select number of players menu, it seems like there is a problem when drawing the menu it doesn't show the options. I'm able to launch the game. I'm able to play it however if I move the keys down and then press enter, it seems related to a resolution set in the ahk module.
  • 3 months later...
I think there are some issues for some games. For example Wave Runner, they can't link. If I happen to enter service menu and exit, then they connect and after a moment throws a network error warning. I guess some games only work with the previous version (v1.0)?
These are the ones I can't link. Indy500 (only 2P), ManxTT (only 2P), Ski Super G, Von, Wave Runner, Sega Touring Car. Aside from sgt24h, skytargt and segawski. All listed in OP.
