Auto Wheel Creator 1.0
hi
this is my first application, or first version
This application automatically creates the wheels of any system. Simply choose a background (background better in 300x140) xml for wheel and automatically created in c :/
is the first version, will try to improve it.
sorry for my english
LINK DE DESCARGA
example:
Thanks but this exists already:
http://www.hyperspin-fe.com/forum/showthread.php?10519-AutoKustomWheels-v1-0
The reason it's not such a needed app is because HS2 does all this on the fly, so we will have no need for a program that creates wheel backgrounds.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
not create a wheel. create the complete set of images with your own background of any system from a xml database. all the games in a xml
No kidding, it's been two plus years - no one should hold their breath at this point! (Not a complaint, I can't see myself putting in the work again when HS 2.0 finally shows up). Keep up the good work.
Putting in what work? The upgrade process will be smoother then you think. Same art, same HL2, same dbs (if you are using the official ones), movie previews will have to be mp4. That's probably the only big change you would need to do.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Well thats cool DJ. I just figured it would be a ton of work. I never really read up on HS2 because it had been delayed so long. I figured why get excited until it was out? Sounds great though, I already have all the mp4 files ready to go that are available so far.
I made a tool that migrates your existing inis over to the new HS2 standard. It will be available when HS2 is here. It will only do HL2 related keys as all the rest are very different. But different in a good way ;)
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 1 year later...
That is the directory you installed the Free Image Magick software into. This is what horseyhorsey's program uses to make the images.
Make sure you have .net installed, make sure you have the folder set for hyperspin. I did not have any problems with it crashing after he fixed it. I just re downloaded it and tested and worked fine. I am on x64 Windows 7. So not sure about other versions of windows. Good luck.
