supermodel 3 question
snstay
Trying out sega model 3, when i try and run the emulator out of hyperspin a black box pops up then gose away real quick.
Why is this? If the emulator dosent run out of hyperspin it certainly wont run in it.
Help appreciated!!
Thanks
That's probably the command window your seeing flash up. There is no default gui for SM3 unless you use the Supermodel UI, with that you can run a game.
So your statement about it not working from Hyperspin is not true unless you haven't set it up in HyperLaunch. If you have set up the system to be launch by HyperLaunch then it will send the correct command line parameters to the SuperModel 3 emulator.
Have a go at launching from HLHQ.
Here is what i get when the emulator wont fire up.
OpenGL information:
Vendor: Microsoft Corporation
Renderer: GDI Generic
Version: 1.1.0
Shading Language Version: (null)
Maximum Vertex Array Size: 256 vertices
Maximum Texture Size: 1024 texels
Maximum Vertex Attributes: 1024
Maximum Vertex Uniforms: 1024
Program settings:
XResolution = 496
YResolution = 384
FullScreen = 0
WideScreen = 0
MultiTexture = 1
Throttle = 1
ShowFrameRate = 0
InputSystem = dinput
FlipStereo = 0
DirectInputConstForceLeftMax = 100
DirectInputConstForceRightMax = 100
DirectInputSelfCenterMax = 100
DirectInputFrictionMax = 100
DirectInputVibrateMax = 100
XInputConstForceThreshold = 30
XInputConstForceMax = 100
XInputVibrateMax = 100
MultiThreaded = 1
GPUMultiThreaded = 1
PowerPCFrequency = 50
EmulateSound = 1
Balance = 0
EmulateDSB = 1
SoundVolume = 100
MusicVolume = 100
ForceFeedback = 0
VertexShader =
FragmentShader =
Audio device information:
Frequency: 44100
Channels: 2
Sample Format: 32784
OpenGL 2.x does not appear to be present. Unable to proceed.
Program terminated due to an error.
Thanks for that link but my pc couldnt handle the update lol. Guess i need to upgrade my pc before i can use model 3.
Its weird because my pc can play blu rays, seems like it should have an alright graphics card anyways.
  • 2 months later...
i continue to get this error 03:38:37:667 | MD | ERROR | +31653 | There was an error waiting for the window "Supermodel ahk_class SDL_app" to become active. Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
if i have normal fade on i get the erro and then the emulator crashes. If i turn off fade, i see a hyperlaunch background for a bezel but it never actually starts.
Does anyone have an issue with picking courses? The games that emulate steering wheels I think are doing this. Say there are 3 courses and you press right, if you release it goes back to course one, if you hold left you can get to course 3 but u can't easily get to course two unless you time it right quickly. Is this because I don't have a steering wheel?
