acko64 Posted March 12, 2015 Posted March 12, 2015 hi everyone im hoping you can help me, i bought a 4tb external drive with hyperspin on it and had no trouble with it,however i copyed it to a internal 4tb harddrive and started having problems, i tried everything i can think off, i took external drive out and turned the internal harddrive letter to h, but i click on a game and get cannot find hyperlaunch.exe and hyperlaunch hq doesnt work, i get this error when i click on it couldnt find hyperlaunch exectuble c:hyperspin\hyperlaunch\hyperlaunch.exe, please select your hyperlaunch folder, please help kind regards martin
rfancella Posted March 12, 2015 Posted March 12, 2015 hi everyone im hoping you can help me, i bought a 4tb external drive with hyperspin on it and had no trouble with it,however i copyed it to a internal 4tb harddrive and started having problems, i tried everything i can think off, i took external drive out and turned the internal harddrive letter to h, but i click on a game and get cannot find hyperlaunch.exeand hyperlaunch hq doesnt work, i get this error when i click on it couldnt find hyperlaunch exectuble c:hyperspin\hyperlaunch\hyperlaunch.exe, please select your hyperlaunch folder, please help kind regards martin Hi, Give this post a read. http://www.hyperspin-fe.com/forum/showthread.php?33201-Launching-a-game-quot-Could-not-find-hyperlaunch-exe-quot&p=310032&viewfull=1#post310032 Let us know if this doesn't help. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
acko64 Posted March 12, 2015 Author Posted March 12, 2015 hi ron thanks for info, but still getting error messages, please help regards martin
gigapig Posted March 12, 2015 Posted March 12, 2015 From your opening post. Did you copy and paste this "c:hyperspin\hyperlaunch\hyperlaunch.exe" or type it? It's missing a backslash after the colon. "C:\....."
acko64 Posted March 13, 2015 Author Posted March 13, 2015 hi i tried all you said i think i might have made things worse, please help, id love to get this running properly, regards martin
gigapig Posted March 13, 2015 Posted March 13, 2015 Have you tried contacting the person who sold you the drive? They usually have good customer support. It can be tricky for us to troubleshoot something we didn't put together.
acko64 Posted March 13, 2015 Author Posted March 13, 2015 when i bought the external drive, he said id have to look on forums or google it, the external drive still works, but i copyed it to internal 4tb drive, so i could use the external drive if ever my internal drive broke so im having problems with internal drive, kind regards martin
gigapig Posted March 13, 2015 Posted March 13, 2015 Your seller is very much mistaken, he should have his own support forum. HyperSpin is free and should not be sold, we can't really support sold drives due to the nature of the software. With that out of the way and because the guy who sold you the drive clearly sucks, we may be able to help. So you probably have this issue because the drive letter has changed. So going back to the original error, you need to change the path to HyperLaunch. Navigate to the HyperSpin \settings folder and open the settings.ini file. Look for the HyperLaunch path and change it. Please read the stickies on the forum so you understand how to post, and give as much detail as possible.
acko64 Posted March 13, 2015 Author Posted March 13, 2015 hi i think i must of deleted the path somehow, i cant see hyperlaunch path there regards martin
gigapig Posted March 13, 2015 Posted March 13, 2015 This is what you should have, change it accordingly. [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Sony PSP Minis [b]Hyperlaunch_Path=[/b]C:\HyperSpin\HyperLaunch\ [Resolution] FullScreen=true Width=1024 Height=768 Scanlines_Active=true Scanlines_Image=scanlines_ag Scanlines_Scale=1 Scanlines_Alpha=0.1
acko64 Posted March 13, 2015 Author Posted March 13, 2015 hi tried changing letter same result cant find hyperlaunch, regards martin
rfancella Posted March 13, 2015 Posted March 13, 2015 hi tried changing letter same result cant find hyperlaunch, regards martin What version of HyperSpin.exe are you using? The older version you cannot specify where HyperLaunch.exe is. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
SIMPLYAUSTIN Posted March 13, 2015 Posted March 13, 2015 Sounds like the same kind of drive as last time... using HS version 1... no Hyperlaunch. This is an uphill battle Simply Austin's YouTube
gigapig Posted March 13, 2015 Posted March 13, 2015 Sounds like the same kind of drive as last time... using HS version 1... no Hyperlaunch. This is an uphill battle That's why I said to go back to the source. If it's old I can't offer any support anyway.
acko64 Posted March 13, 2015 Author Posted March 13, 2015 im pretty sure its the new hyperspin, as ive had the old one before and still have it regards martin
acko64 Posted March 13, 2015 Author Posted March 13, 2015 yes definately the new one as hyperspin works on the external drive i used for hyperspin before i copyed onto this drive
acko64 Posted March 13, 2015 Author Posted March 13, 2015 and hyperlaunch hq works on the drive i copyed off regards martin
gigapig Posted March 13, 2015 Posted March 13, 2015 Remember what I said about detail? At the moment it's a guessing game.
acko64 Posted March 13, 2015 Author Posted March 13, 2015 ok thanks , i have team viewer if you want to have a look at the drive, regards martin
acko64 Posted March 13, 2015 Author Posted March 13, 2015 i now got the external drive plugged in as well, it will work great if i change letter to H . at the moment its E
relic Posted March 13, 2015 Posted March 13, 2015 acko i have team view i can try help you out need you to talk to me first brother so we can sort this out if you need any help let me know 100%
acko64 Posted March 13, 2015 Author Posted March 13, 2015 hi relic hows things just put 2 inis together and i got them identical still no luck im thinking ive deleated somthing. help me now relic martin
eezetee Posted March 13, 2015 Posted March 13, 2015 While I appreciate helping those who purchased ready made options and expected their purchase to work, i'm wondering if the forums would be better with some "funded" approach for support. Some people are making a <insert local grammar here> load of money selling drives and the team here supports them and for what? Most (not all) of the posters are one hit wonders.
relic Posted March 13, 2015 Posted March 13, 2015 all sorted all done turns out paths were set wrong 100%
