Problem creating theme
Hey guys, I put together a simple theme but for some reason it behaves iradically most of the time when I load it through HS. Basically the different images end up in random places and I have to select another game and come back to it a few times until it loads correctly. Any idea what could cause this behavior? It works fine in HT.
Never seen this problem before, is your background 1024x768? did you crop the background when you created it? so that i wont overlap the 1024x768 canvas.
It's actually just a black background. I created a new 1024x768 image in PS, filled it in with the paint bucket and saved it as PNG.
Just chechked it out, it doesn't do that in my setup. went back and forth more then 10 times and it works. so it isnt theme related. try giving the theme a different name. like fix it felix just for testing and see what it does
it could be your using an old hyper theme and need to update it
No, otherwise it would do the same in my setup as well, it isn't theme related. theme works fine here.
Just tried this, got excited because it seemed to have worked until about the fifth time then it happened again. Ugh, I don't get it. I've never had this problem, other themes are ok. I also reassembled the theme together from scratch but that didn't fix it.
I placed it in the mame wheel, give it a rom name i didnt have, and it kept working.....wierd
Very weird, thanks for the help.
