Taito Type X issues
kenshutt97
I will have to add new profile in xpadder for this game and name of the profile I can assign as Otomeduis am I right bro?
Do I need to do anything else in rlauncher for this profile to work?
KOF Max you have any idea why the SNK! Screen come up after goes black?
  • Replies 63
HI gigabro,
I have set the xpadder and is working now with OT outside the RL.
Since I have different xpadder profiles created when I launch the game thru RL,  how will I set so that my xpadder will pick the correct profile for this game?
You will create a profile for that game only, not the system. You can select the game from the list when you select "Game Profile"
Hi Giga
When I choose full screen in xb-config the screen just blink and close . But if untick it then the game can run.
this happen with AHeart 3 , D.Bride.
Contra How can I change it to full screen?
Million thanks
I will look into the xb config, perhaps there one that works with windows 8.
Contra. Just use the full screen exe which is in the folder.
hi all
 this mite help I made this for mine just point to this exe in ur game folder.  and edit the ahk to match ur keys.
For those using the 360 controller, player 1 controls are supported out of the box and player 2 also to a degree.
hi all
Thanks will try this with Contra.
Thanks bro will wait your good news.
Nope full screen exe gives SECURITY ERROR
hi all
Andy, where will I put this 2 files & how to point to them?
This is my first time adding a game mapping profile of xpadder .  I am little confused how to get it working.
I went into RL and then selected my system Taito from the top Keymapper and selected the game Wacky Races after how to do? In this choose the controller colume it is Xbox360 wireless.
When I try to test from the below nothing happen.
The profile which I have created within xpadder saved as P1.xpadderprofile inside the HS/Utilities/Xpadder profile.
I copied this profile and paste it inside H:\HyperSpin\RocketLauncher\Profiles\Xpadder
When I launch the game still cannot use . am I doing something wrong here?
You can copy and paste it but it would need to go in profile six passerby auto Type X\wacky Races.
When you create the game profile in RL it should appear in the bottom window, you can then create it and it should save in the correct place.
Giga I also have the problem with xbloader crashing all the time.
Is it because I am running win 8.1 and is there a workaround?
I have used your files and the gameloader but no success.
It's possible, I can't check it as I still use Windows 7 and maybe I'll see all these problems when I get the free copy of Windows 10 :(
You could give GameLaoder All RH a try instead. https://www.mediafire.com/?wix803bszhyxr
Thanks Giga,
I had tried the gameloader all RH but I always get an error then the gameloader config interface which shows only garbage.
Concerning the xbloader.exe and the other files, they are all showing a command prompt for a second and then nothing.
I also have a small hope in Windows 10 but we should probably not expect much.
I had previously all the games running on an other machine running Win7 but my current setup for Hyperspin is running 8.1 and I don't want to revert back just for those games.
Hi bro
I have already setup one profile for it for my DS4 joystick which run as xbox360.
Now I have another question is how can I set up more than one profile for same game, if I pick up arcade stick or steering wheel as second option to play and the game should recognize this automatically. [emoji4]
Thanks Giga,
Have you tried setting up exclusion list for all the Taito games in your antivirus?
I have tried that and even uninstalling the antivirus but I only get crashes after crashes for all the games that requires xbloader and some others (battle gear 4, deathsmiles 2,...)
After disabling the antivirus try to unzip the loaders again and paste it into the game directory. Some games work with xbloader and some with typexloader.
I have tried that but it doesn't work.
I have also tried again those problematic games on an other machine running Win7 and they all work perfectly.
I have unplugged all my controllers but same result and I don't have a bluetooth dongle.
I am a bit at a loss now but thanks for your help anyway Shitoken.
I will wait for Win10 in a few days to see if it does change something.
Can you remember which version of GameLoader you tried? I have older versions which may work?
I have used the version you are sharing and yes I could try with older versions as well.
In the meantime I have made some progress since I can play most games when I unplug all the controllers (Aimtrack gun, wheel, ipac, XBox360 joypad, dolphinbar) but it crashes again as soon as I plug back anyone of them.
So the problem comes obviously rom the way Win8.1 handles the controllers but I wonder if anyone else with about the same configuration has the same problems (mostly with the Examu games, arcana heart, daemon bride,..,and also battle gear 4 and deathsmiles 2)?
I didn't realise you had a Dolphin Bar as that will definitely cause trouble. The fix for that I think is to set it to one of the other modes when playing TTX.
But you do say the game crashes when you plug a controller in, which is odd, there's plenty of people running these on 8.1.
Thanks Giga,
The trick with the Dolphinbar doesn't work for me.
The games work only if I unplug the bar and the same thing for the other controllers (joypad, aimtrack, wheel).
Maybe my win8.1 installation or registry is a bit messed up after all that time fiddling around...
I am also thinking whether or not to upgrade to WIn10 ,  if xpadder will still work or other new problems arise which is really headache.
Let gigapig try first hehe :whistling:
