wahoobrian Posted May 13, 2015 Posted May 13, 2015 On 5/12/2015 at 7:47 PM, klizine said: The crc's of the missing ones from the database dont seeem match the ones from gamebase. Not every game was sourced from GameBase, just most of them....
Turranius Posted May 13, 2015 Posted May 13, 2015 Thanks everyone. We're getting closer. I removed "Helistad (Europe)" since it was apparently wrong. Need to find a replacement. Found: Cowboy Duel - Live Your Dream! (Europe) (Disk 1) (Unl) Cowboy Duel - Live Your Dream! (Europe) (Disk 2) (Unl) Runners - Greenrunner, Redrunner, Retroskoi+ (Europe) (Unl) Ultimate Cops (Europe) (Disk 1) (Unl) Ultimate Cops (Europe) (Disk 2) (Unl) On FTP, moved into folder "Wrong in XML": Shoot 'Em up Destruction Set (Europe) (Disk 1 Side A) - (Renamed correctly) Shoot 'Em up Destruction Set (Europe) (Disk 1 Side - (Renamed correctly) Single Extreme Freedom (USA) (Disk 1 Side A) Single Extreme Freedom (USA) (Disk 1 Side So missing right now is Helistad (Europe) - Just need to find it. Shoot 'Em up Destruction Set (Europe) (Unl) - Either find the one disk version that the XML wants or change the XML to use the 2 disk version from the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side A) - Find this particular 4 disk Hungary version or change the XML to use the 2 disk USA version in the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side Single Extreme Freedom (Hungary) (Disk 2 Side A) Single Extreme Freedom (Hungary) (Disk 2 Side Trivial Pursuit - Commodore Genus Edition (Europe) - Not sure which of the files in the Genus collection this is and can not test right now. Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
potts43 Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 6:20 AM, Turranius said: Thanks everyone. We're getting closer. I removed "Helistad (Europe)" since it was apparently wrong. Need to find a replacement. Found: Cowboy Duel - Live Your Dream! (Europe) (Disk 1) (Unl) Cowboy Duel - Live Your Dream! (Europe) (Disk 2) (Unl) Runners - Greenrunner, Redrunner, Retroskoi+ (Europe) (Unl) Ultimate Cops (Europe) (Disk 1) (Unl) Ultimate Cops (Europe) (Disk 2) (Unl) On FTP, moved into folder "Wrong in XML": Shoot 'Em up Destruction Set (Europe) (Disk 1 Side A) - (Renamed correctly) Shoot 'Em up Destruction Set (Europe) (Disk 1 Side - (Renamed correctly) Single Extreme Freedom (USA) (Disk 1 Side A) Single Extreme Freedom (USA) (Disk 1 Side So missing right now is Helistad (Europe) - Just need to find it. Shoot 'Em up Destruction Set (Europe) (Unl) - Either find the one disk version that the XML wants or change the XML to use the 2 disk version from the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side A) - Find this particular 4 disk Hungary version or change the XML to use the 2 disk USA version in the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side Single Extreme Freedom (Hungary) (Disk 2 Side A) Single Extreme Freedom (Hungary) (Disk 2 Side Trivial Pursuit - Commodore Genus Edition (Europe) - Not sure which of the files in the Genus collection this is and can not test right now. Would you mind updating your c64 file on your FTP. You have done an excellent job that it defeats purpose for everyone to attempt to do it all over again? Many thanks
Turranius Posted May 13, 2015 Posted May 13, 2015 They are updated already. I update there when I update the post here =) Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
wahoobrian Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 6:20 AM, Turranius said: So missing right now is Helistad (Europe) - Just need to find it. Shoot 'Em up Destruction Set (Europe) (Unl) - Either find the one disk version that the XML wants or change the XML to use the 2 disk version from the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side A) - Find this particular 4 disk Hungary version or change the XML to use the 2 disk USA version in the "Wrong in XML" folder. Single Extreme Freedom (Hungary) (Disk 1 Side Single Extreme Freedom (Hungary) (Disk 2 Side A) Single Extreme Freedom (Hungary) (Disk 2 Side Trivial Pursuit - Commodore Genus Edition (Europe) - Not sure which of the files in the Genus collection this is and can not test right now. Shoot 'Em up Destruction Set (Europe) (Unl) is one disk. The two disks in GameBase are two different versions, not Disk 1, Disk2. @Turranius - Sent you a PM.
dougan78 Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 9:34 AM, wahoobrian said: Shoot 'Em up Destruction Set (Europe) (Unl) is one disk. The two disk version in GameBase are two different versions, not Disk 1, Disk2. @Turranius - Sent you a PM. I do this all the time. Check the version .info file in the zip it generally tells you what is what. If it has multiple versions.
Turranius Posted May 13, 2015 Posted May 13, 2015 wahoobrian kindly uploaded the missing files: Trivial Pursuit - Commodore Genus Edition (Europe) Helistad (Europe) Single Extreme Freedom (Hungary) (Unl) (Disk 1 Side A) Single Extreme Freedom (Hungary) (Unl) (Disk 1 Side Single Extreme Freedom (Hungary) (Unl) (Disk 2 Side A) Single Extreme Freedom (Hungary) (Unl) (Disk 2 Side They are updated on the FTP The only missing rom is Shoot 'Em up Destruction Set (Europe) (Unl) - Either find the one disk version that the XML wants or change the XML to use the 2 disk version from the "Wrong in XML" folder. Edit: If someone wants to make a HyperSpin ready torrent from this, I do not mind at all. Grab it, share it! Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
Turranius Posted May 13, 2015 Posted May 13, 2015 wahoobrian also got the correct version of Shoot 'Em up Destruction Set (Europe) (Unl), so we are complete! Thanks! If you find anything wrong and correct it, please let me know and I'll throw you an upload account =) Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
Turranius Posted May 13, 2015 Posted May 13, 2015 In the "/Commodore 64/Roms for offical XML" folder. If your're using FlashFXP, press F5 to refresh (local dir cache is enabled by default). Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
potts43 Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 10:43 AM, Turranius said: In the "/Commodore 64/Roms for offical XML" folder. If your're using FlashFXP, press F5 to refresh (local dir cache is enabled by default). Brilliant all sorted!!!!!
Turranius Posted May 13, 2015 Posted May 13, 2015 Now to get the HyperSpin FTP back so we can match all of dougan78's hard work on graphics for the set matched up =) Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
dougan78 Posted May 13, 2015 Posted May 13, 2015 Oh that stuff is matched up afaik. Ftp is not current for anything. Check post 1 on that thread as it was all matched up so I submitted stuff to emumovies and keep the wheels updated on the download section on the website.
Turranius Posted May 13, 2015 Posted May 13, 2015 Oh, neat. Is it just me that can't log on to the HS FTP then? Says my password is wrong but I have not changed it. Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
potts43 Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 11:15 AM, Turranius said: Oh, neat. Is it just me that can't log on to the HS FTP then? Says my password is wrong but I have not changed it. Mine seems to be ok
dougan78 Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 11:15 AM, Turranius said: Oh, neat. Is it just me that can't log on to the HS FTP then? Says my password is wrong but I have not changed it.I don't use it. See post 1 on my unofficial c64 thread for the latest.
Turranius Posted May 13, 2015 Posted May 13, 2015 Thanks! Derailing the thread a bit but its because I was changed to App Developer that I can no longer access the FTP or HyperSync. Support Issue ... issued ! Got the wheels from the download section at least =) Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
Raziel2k6 Posted May 13, 2015 Author Posted May 13, 2015 Turranius, Would it be possible to compress the roms on your FTP into 1 file again like before? I accidentally permanently deleted (remote connection acting up) all the roms I had, and downloading them 1 by 1 from your FTP seems to take ages! I would (and maybe others) really appreciate if you could. Another note for Dougan, Where exactly can I find all your matching wheels? I looked for the said post #1, but cannot locate it. OK I do have my noob moments! lol Again everyone, thanks a million for all the hard work. I didn't think the thread I started with a simple question would end up so far. Happily surprised! Regards, Raz
dsync89 Posted May 13, 2015 Posted May 13, 2015 On 5/11/2015 at 1:34 AM, Raziel2k6 said: potts43, I got the GameBase64 v13 set, and matched it almost flawlessly using Don's Rom Renamer, as the XML included CRC's to make thing easier. Only missing 316 games, and I doubt I'll bother fetching them, since with 7920 games I feel I'm sitting pretty right now. Still working on gathering more artwork, going through Dougan's FTP folder, there seems to be quite a few thing available there that HyperSync does not have. This is also awesome! Thanks everyone for the input, greatly helps! Raz out I've gotten the set from GameBase64 too and ended only with 216 missing. I agreed that with that amount of found ROMs would make those missing ones seemed minute in comparison
Raziel2k6 Posted May 13, 2015 Author Posted May 13, 2015 dsync, Turranius has the complete set now fully matching the xml on his ftp. Check his sig
Turranius Posted May 13, 2015 Posted May 13, 2015 On 5/13/2015 at 12:31 PM, Raziel2k6 said: Would it be possible to compress the roms on your FTP into 1 file again like before? Certainly. Packing it up now =) Here is Dougan78s package (well, the wheels anyway. heh): http://www.hyperspin-fe.com/files/file/7940-commodore-64-wheels-05122015/ Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
Raziel2k6 Posted May 13, 2015 Author Posted May 13, 2015 Thanks a million for this Turranius! FYI, I am currently trying to mix and match different wheel sets, and hopefully will end up matching even more. Basically I downloaded your wheels from your FTP, as well as Dougan's set of wheels from here, and finally synced my empty C64 HyperSpin wheel folder with HyperSync against the official XML. Yours has 2486 wheels, Dougan's has 2444, and HyperSync gives me 2402. Then when I append them together, I notice that each has few unique files in them, so all three combined add up to 2607 wheels altogether. Then when I inspect these for matching using Don's List Generator and filtering out the games without wheels, I end up with 2458 matching png's. I tried using Don's Rom Renamer tools to match the remainder, I had hoped for all of them, turn out it matches the same amount, 2458. Now I am in the process of doing the same operation using your TurMatcher app, which takes a very long time to run, and hopefully, I will get most if not all the 2607 wheels from the combined sets tp match up. Maybe this is all in vain, and a waste of time, but meh! I am enjoying this stuff!! :-D Raz
Turranius Posted May 13, 2015 Posted May 13, 2015 Excellent =) Yeah, Tur-Matcher with an ~8000 games XML will take a long time, but be patient. I noticed the official XML has a lot of ' signs in it. I filter that out as well in Tur-Matcher 1.4 (yet unreleased) but I can put a beta of it on the FTP if you want it. It helps. Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
relic Posted May 13, 2015 Posted May 13, 2015 i have sorted out 0-9 - to A-S for commodore 64 game wheels dougans set so it matches the offcial c64 xml 100%
