Metalzoic Posted May 15, 2015 Posted May 15, 2015 Anyone know any good tricks to launch AHK scripts before a game, rom or emulator launches? In PC launcher there's a pre-launch place, but it doesn't launch the script soon enough to take effect before the game kicks in (post-exit script launch works great though). I also don't even see a way to pre-launch/load scripts for non-PC games. Is there any good way to do this? Any tricks? I need to be able to launch a small script automatically when I launch a game from Hyperspin, but it needs time to actually run before the game launches. I've been working on this for days and it's really, really starting to piss me off. Any help would be appreciated.
Metalzoic Posted May 15, 2015 Author Posted May 15, 2015 Anyone? It also seems that setting a startup .AHK script in the HyperHQ settings doesn't actually enable the script... I have to minimize Hyperspin first before I can get it to work. The scripts work, but how in Gods name do I get Hyperspin/HyperlaunchHQ to register them?
ninja2bceen Posted May 15, 2015 Posted May 15, 2015 I think you have to go to hyperlaunch hq, go to pc games, go to the module tab, edit module settings, snap the window so you can see the game list and +button, go to the pc game that needs the prescript, enter in the path to you ahk. This is what I'm going to do if someone knows the ahk script I could use to press enter or spacebar so the pop up message is pressed automatically before the game starts (megamanx7) Man that's sick! I love what you made here and would love to add it to my set up! Don't forget to upload it to the download page! (Tapatalk signature) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted May 15, 2015 Author Posted May 15, 2015 I think you have to go to hyperlaunch hq, go to pc games, go to the module tab, edit module settings, snap the window so you can see the game list and +button, go to the pc game that needs the prescript, enter in the path to you ahk. This is what I'm going to do if someone knows the ahk script I could use to press enter or spacebar so the pop up message is pressed automatically before the game starts (megamanx7) Man that's sick! I love what you made here and would love to add it to my set up! Don't forget to upload it to the download page! (Tapatalk signature) That's exactly what I'm doing. Problem is it doesn't work. The scripts don't seem to trigger that way (except the PostExit one. That one works perfectly) When I get home Ill try to write a couple scripts that might help you with MegaMan.
ninja2bceen Posted May 15, 2015 Posted May 15, 2015 I know the prescript works because I got it working with mind craft. I think it's in the default root. Off the top of my head it's in the hyperlaunch folder, module extensions or maybe in the pclauncher module folder you should see pre and post scripts Man that's sick! I love what you made here and would love to add it to my set up! Don't forget to upload it to the download page! (Tapatalk signature) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted May 15, 2015 Author Posted May 15, 2015 So you got a script to work by manually placing it in the correct folder/path? I haven't tried that, I've only tried entering it into the options box within hyperlaunchHQ. I'll try it your way to see if it works for me. What is it you got to work there? An AHK script file?
ninja2bceen Posted May 16, 2015 Posted May 16, 2015 Ya it was mind craft. The git by default has everything in there. Check out the pclauncher folder and I think it's called extensions or something folder. You should see the extra folder. It's a start up script Man that's sick! I love what you made here and would love to add it to my set up! Don't forget to upload it to the download page! (Tapatalk signature) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted May 17, 2015 Author Posted May 17, 2015 Might have figured out why my script runs and works but doesn't seem to activate for the game. From looking at the log it appears when you launch a game the HL VJoy Keymapper settings are loaded almost first thing. However whatever you have set to run under Prelaunch settings don't kick in for another 46 lines or so. My guess is HL is loading the Keymapper settings long before it loads the actual drivers those settings need. So it never works. You would think a setting called prelaunch would actually run sooner. Maybe User Functions.ahk can work around this, but so far I can't get it to work at all. I'm really starting to hate all of this.
connorsdad Posted May 17, 2015 Posted May 17, 2015 Have a scipt running at hs launch that listens for emulator/game.exe to launch.
Metalzoic Posted May 17, 2015 Author Posted May 17, 2015 Have a scipt running at hs launch that listens for emulator/game.exe to launch. Yeah. It will have to be set up like that. Turns out that the User Functions Init.ahk settings actually run even later than the Prelaunch settings by a couple lines. I don't know how to write a script as complicated as what you suggest. I can try to set my script as the Prelaunch script and then try to set the VJoy Keymapper enable code to happen afterwards. Maybe. So far I haven't gotten that to work. I've tried the AHK syntax as it is in the log file & module but no luck yet. I may just give up on this being an automatic process for now and just keep it manual like I have it now (on my control panel I hold the P1 Start button and hit two Player 2 buttons to anable the drivers). It works, but automatic would be worlds better.
connorsdad Posted May 17, 2015 Posted May 17, 2015 I will post my script tomorrow and you can adapt it to suit you.
Metalzoic Posted May 17, 2015 Author Posted May 17, 2015 That would be awesome thanks. What do you use this script for on your cab?
connorsdad Posted May 17, 2015 Posted May 17, 2015 That would be awesome thanks. What do you use this script for on your cab? Switching between monitors (shutdown lower monitor and display on upper monitor for light gun games) and rotating my lower monitor.
connorsdad Posted May 17, 2015 Posted May 17, 2015 It's too late to switch my cab on now or I would share, I will post when I finish work tomorrow. It's basically a list of; If exe1 exists do this, when it closes do this. If exe2 exists do this .... And so on.
Metalzoic Posted May 17, 2015 Author Posted May 17, 2015 Awesome. That sounds like it might do the trick. I ran across your cab over 3 months ago just before I started to build mine. Very awesome what you did there. Super impressive work.
connorsdad Posted May 18, 2015 Posted May 18, 2015 Here you go. Loop { ;Demul Lightgun Process, Wait, demul_lightgun.exe, 0.1 If (ErrorLevel != 0) { run C:\Windows\System32\DisplaySwitch.exe /external Process,WaitClose, demul_lightgun.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ---------------------------------------------------------------- ;Playstation Lightgun Process, Wait, pcsxr-lightgun.exe, 0.1 If (ErrorLevel != 0) { sleep, 2000 run C:\Windows\System32\DisplaySwitch.exe /external sleep, 1000 WinGetActiveTitle, title WinMinimize, %title% WinMaximize, %title% Process,WaitClose, pcsxr-lightgun.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ----------------------------------------------------------------- ;Playstation 2 Lightgun Process, Wait, pcsxr-lightgun-PS2.exe, 0.1 If (ErrorLevel != 0) { run C:\Windows\System32\DisplaySwitch.exe /external Process,WaitClose, pcsxr-lightgun-PS2.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ------------------------------------------------------------------- ;Pinball FX2 Process, Wait, Pinball FX2.exe, 0.1 If (ErrorLevel != 0) { run smccmd --resume --speed 2050,,Hide Process,WaitClose, Pinball FX2.exe run smccmd --resume --speed -2250,,Hide } ------------------------------------------------------------------- ;Nintendo DS Process, Wait, DeSmuME_0.9.10_x64.exe, 0.1 If (ErrorLevel != 0) { run C:\HyperSpin\HyperLaunch\Module Extensions\hide idle mouse.exe ;sleep, 1000 ;sleep, 1000 run smccmd --resume --speed 2050,,Hide ;run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=90 Process,WaitClose, DeSmuME_0.9.10_x64.exe ;run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=0 /exit ;Process close, swapscreen.exe ;sleep, 1000 Process close, hide idle mouse.exe run smccmd --resume --speed -2250,,Hide ;run C:\HyperSpin\HyperLaunch\Module Extensions\qres.exe /x:1920 /y:1080 } ------------------------------------------------------------------- ;Sega Model 3 Lightgun Process, Wait, Supermodel2.exe, 0.1 If (ErrorLevel != 0) { sleep, 2000 run C:\Windows\System32\DisplaySwitch.exe /external Process,WaitClose, Supermodel2.exe run C:\Windows\System32\DisplaySwitch.exe /extend } -------------------------------------------------------------------- ;Sega Model 2 Lightgun Process, Wait, emulator_multicpu.exe, 0.1 If (ErrorLevel != 0) { run C:\Windows\System32\DisplaySwitch.exe /external Process,WaitClose, emulator_multicpu.exe run C:\Windows\System32\DisplaySwitch.exe /extend } -------------------------------------------------------------------- ;Taito Type X Vertical Games Process, Wait, gamevertical.exe, 0.1 If (ErrorLevel != 0) { run smccmd --resume --speed 2050,,Hide run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=180 Process,WaitClose, gamevertical.exe run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=0 /exit run smccmd --resume --speed -2250,,Hide run C:\HyperSpin\HyperLaunch\Module Extensions\bring back focus.ahk sleep, 3000 Process, close, iRotate.exe } --------------------------------------------------------------------- ;Demul Vertical Games Process, Wait, demul_vertical.exe, 0.1 If (ErrorLevel != 0) { run smccmd --resume --speed 2050,,Hide Process,WaitClose, demul_vertical.exe run smccmd --resume --speed -2250,,Hide } --------------------------------------------------------------------- ;PopCap HeavyWeapon Process, Wait, HeavyWeapon.exe, 0.1 If (ErrorLevel != 0) { run C:\Windows\System32\DisplaySwitch.exe /clone Process,WaitClose, HeavyWeapon.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ---------------------------------------------------------------------- ;PopCap Hammerheads Process, Wait, HammerHeads.exe, 0.1 If (ErrorLevel != 0) { run C:\Windows\System32\DisplaySwitch.exe /clone Process,WaitClose, HammerHeads.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ----------------------------------------------------------------------- ;android vertical Process, Wait, androidvertical.exe, 0.1 If (ErrorLevel != 0) { Process, Wait, androidvertical.exe run smccmd --resume --speed 2050,,Hide run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=270 sleep, 3000 run C:\HyperSpin\HyperLaunch\Module Extensions\inverse mouse.ahk Process,WaitClose, HD-Frontend.exe run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=0 send !z run smccmd --resume --speed -2250,,Hide sleep, 3000 Process, close, iRotate.exe } ----------------------------------------------------------------------- ;android vertical alternative Process, Wait, androidverticalalternative.exe, 0.1 If (ErrorLevel != 0) { Process, Wait, androidverticalalternative.exe run smccmd --resume --speed 2050,,Hide run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=90 sleep, 3000 Process,WaitClose, HD-Frontend.exe run C:\HyperSpin\HyperLaunch\Module Extensions\irotate.exe /1:rotate=0 run smccmd --resume --speed -2250,,Hide sleep, 3000 Process, close, iRotate.exe } ----------------------------------------------------------------------- ;PopCap Chuzzle Process, Wait, Chuzzle.exe, 0.1 If (ErrorLevel != 0) { sleep, 1000 run C:\Windows\System32\DisplaySwitch.exe /internal Process,WaitClose, Chuzzle.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ----------------------------------------------------------------------- ;PopCap PeggleNights Process, Wait, PeggleNights.exe, 0.1 If (ErrorLevel != 0) { sleep, 1000 run C:\Windows\System32\DisplaySwitch.exe /clone Process,WaitClose, PeggleNights.exe run C:\Windows\System32\DisplaySwitch.exe /extend } ----------------------------------------------------------------------- } Have a play with this
Metalzoic Posted May 19, 2015 Author Posted May 19, 2015 Cool thanks. I'll mess with it and see if I have any luck. Appreciate it!
