mrstaun Posted May 15, 2015 Posted May 15, 2015 When I spin the MAME wheel and select a game I sometimes loose focus on the Mameuifx64 emulator, which means the game runs behind Hyperspin. The only way to continue is to use ALT+TAB keys (keyboard) to the emulator. Any idea how to avoid this as the Arcade doesn't have a keyboard attached (only buttons+joysticks.) Is there a way to combine some buttons with JoyToKey, so I can simulate ALT+TAB?
Metalzoic Posted May 15, 2015 Posted May 15, 2015 That's weird. You shouldn't have to do that at all. Are you using Hyperspin as your front-end and a backend manager like HyperlaunchHQ or Rocketlauncher? It's possibly just a setting hidden somewhere that is set wrong.
mrstaun Posted May 16, 2015 Author Posted May 16, 2015 That's weird. You shouldn't have to do that at all. Are you using Hyperspin as your front-end and a backend manager like HyperlaunchHQ or Rocketlauncher? It's possibly just a setting hidden somewhere that is set wrong. Using Hyperspin as Front-end and HyperLauch as Laucher. (tried to upgrade to Rocketlauncher, but that screwed up my entire setup, so that will be another day to setup)
Metalzoic Posted May 16, 2015 Posted May 16, 2015 ISo you reverted back to HyperlaunchHQ from Rocketlauncher? If so it's possible that something got renamed/moved/changed in that process that's screwing it up. I'm dreading having to change to Rocketlauncher.
Aorin Posted May 16, 2015 Posted May 16, 2015 It's probably because the emulator is swithing screen resolution to 640x480, or any other than your desktop's. If that's your case, put your video mode to GDI, that could solve this issue. Aorin
