Yoeddy1 Posted May 24, 2015 Posted May 24, 2015 Hi guys, I have Daphne working fine using the default Dragon's Lair and Space Ace ROMs that Daphne uses. I want to have HS point to the Dragon's Lair and Space Ace "Enhanced" ROMs. Which HS files and what do changes do I need to make to accomplish this? Thanks, Jason
Circo Posted May 24, 2015 Posted May 24, 2015 Set up Daphne to use the ROM you want ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Yoeddy1 Posted May 24, 2015 Author Posted May 24, 2015 I have set up Daphne to use the enhanced ROMs. Within Daphne, it works fine. Within HS, it's using the default ROMs. Is there a config file somewhere that I can change from the default ROM to the enhanced ROM? Thanks, Jason
Yoeddy1 Posted May 24, 2015 Author Posted May 24, 2015 Let me know which files or snippets of files you need and I'll post them up. Thanks, Jason
Yoeddy1 Posted May 24, 2015 Author Posted May 24, 2015 The enhanced Space Ace and Dragon's Lair ROMs play all of the scenes that are embedded on the laserdisc that the standard ROMs don't play.Thanks,Jason
Metalzoic Posted May 24, 2015 Posted May 24, 2015 What? I had no idea that the standard ones weren't complete. Grrrrr... one more thing to spend hours figuring out how to fix. Thanks, I didn't know this.
Yoeddy1 Posted May 24, 2015 Author Posted May 24, 2015 Yeah, hopefully it's just a simple file hack. Thanks, Jason
Metalzoic Posted May 24, 2015 Posted May 24, 2015 Yeah, hopefully it's just a simple file hack. Thanks, Jason Started trying to set up my Daphne an hour ago. Do you have a link to any tutorials to explain the setup, roms to use etc... So I don't waste hours doing simple stuff.
Zeosstud Posted May 24, 2015 Posted May 24, 2015 in Database folder, my Daphine.xml entry for Dragonas Lair looks like this.. <game name="dle21" index="true" image="d"> <description>Dragons Lair</description> <cloneof></cloneof> <crc></crc> <manufacturer>Cinematronics</manufacturer> <year>1983</year> <genre>Adventure</genre> <rating>AAMA - Green (Suitable For All Ages)</rating> <enabled>Yes</enabled> </game> In my media folder, everything is named after the rom.. Wheel = dle21.png Video = dle21.mp4 In my Daphne emulator framefile folder I have a dle21.txt file that looks like this C:\Hyperspin\Emulators\Daphne\vldp_dl\lair 151 lair.m2v That seems to be all the changes I had to make, my goal, was to have the bridge scene play first when I played Dragons Lair because that is how I remember it from my arcade days.. Hope it helps..
32assassin Posted May 24, 2015 Posted May 24, 2015 zeosstud, you really like to complicate your life. 1. leave the official XML AS IS!!!!! 2. use your frame files as your rom path with txt as the extension. 3. change your roms with RocketlauncherUI -Opne Rocketlauncher UI -Select Global emulators - select Daphne Global emulator - select "edit Global Module Settings" - sleect the "Roms Settings" tab -look for the "version" menu -from the pop up menu select witch rom you would like to run. RocketlauncherUI was made for a reason learn how to use it.
Metalzoic Posted May 24, 2015 Posted May 24, 2015 Is that pop-up menu a new, RocketLauncher only thing or is HLHQ the same?
Yoeddy1 Posted May 25, 2015 Author Posted May 25, 2015 I don't think I have RocketLauncherUI. Not sure which solution is best. Should I rename the files and hack the Daphne xml. Jaso
32assassin Posted May 25, 2015 Posted May 25, 2015 I hope everyone knows that you can do this even if you are running HL2. go to the Daphne Module folder and you will find the following files AHK = Module INI = user specific settings. open the INI and you will be able to manually change the rom. HLHQ=RLUI only gave you a nice pretty GUI. The GUI means you no longer have to edit your INIs manually.
Metalzoic Posted May 26, 2015 Posted May 26, 2015 Where is this folder at? Thanks, Jason Sounds like he's talking about the modules folder. Maybe /Hyperspin/Modules/Daphne.ini
Yoeddy1 Posted May 26, 2015 Author Posted May 26, 2015 In that folder I have a Daphne.ahk file and a Settings.ini file. What should be changed? Thanks, Jason
Zeosstud Posted May 27, 2015 Posted May 27, 2015 Simply shared how I got it to work, no claim about being a guru.. I do like easy, I like my eggs over easy, easy chair, certainly prefer my women easy.. So I get where your coming from 32assassin
