mikekim Posted April 8, 2013 Author Posted April 8, 2013 Did you print the CP? Not on this one.. The artwork was printed by Lucian. Sent from my Samsung Galaxy Note II.
Unstupid Posted April 13, 2013 Posted April 13, 2013 Not on this one..The artwork was printed by Lucian. Sent from my Samsung Galaxy Note II. Bump for Progress update request!
mikekim Posted April 13, 2013 Author Posted April 13, 2013 Bump for Progress update request! nothing so far... had to do the whole "social thing" last weekend, so had no time to do anything... hopefully there will be some updates tomorrow... (if i get time to work on it)
mikekim Posted April 14, 2013 Author Posted April 14, 2013 update really had an issue with the control panel and the button placement.. must be the ocd kicking in as i get older, the start button was slightly off center and was bugging me, so i cut a new panel. other bits i did today... finalized how the control panel underside is going to work with the small panel.. had to build layers to pad out the panel to accommodate the joystick and buttons. (don't even mention the c64 in the picture... i think i have more retro stuff now than i ever owned the first time it was around...) rear shot of cp showing cut out of layers to allow buttons and joystick. rear lock for hinged door rear door open for access to MVS Motherboard rear power connector installed joystick port installed for player 2 AES joystick. stuff left to do.. sand down cab and apply wood primer to screw holes. prime and paint apply graphics apply t-molding install internal electrics install screen play lots.
monkeychunkuk Posted April 15, 2013 Posted April 15, 2013 Wow youve been busy,were do you buy your locks?
mikekim Posted April 15, 2013 Author Posted April 15, 2013 That one I had lying around.. no idea where it came from. I've just ordered some more from ultracabs Sent from my Samsung Galaxy Note II.
monkeychunkuk Posted April 16, 2013 Posted April 16, 2013 Ultracabs locks are good and easy to fit etc but you only get one key
ebarlow99 Posted April 17, 2013 Posted April 17, 2013 nice work!!! I love it......makes me want to build one http://www.bartop-arcades.com
mikekim Posted April 18, 2013 Author Posted April 18, 2013 Ultracabs locks are good and easy to fit etc but you only get one key had 4 arrive this morning.. (both sizes).. you are correct on the 1 key per barrel, but all the barrels are keyed alike, so one key fits all 4
mikekim Posted April 18, 2013 Author Posted April 18, 2013 status update started the first coat of primer, ready to be sanded, before the second coat is applied will not be able to do any more on this until next week.. more "family/social stuff" looming over the weekend..
monkeychunkuk Posted April 18, 2013 Posted April 18, 2013 status updatestarted the first coat of primer, ready to be sanded, before the second coat is applied will not be able to do any more on this until next week.. more "family/social stuff" looming over the weekend.. great work can i be a pain and ask why folks are priming their wood before putting vinyl onto it?
mikekim Posted April 25, 2013 Author Posted April 25, 2013 update started spaying the cab black today, hopefully it should be ready for the Vinyl to be applied on Saturday. on a side note... this is what happens when the collector in me takes over.. current MVS titles owned: Super 138 in 1 161 in 1 Metal Slug 1 Metal Slug 2 Soccer Brawl Viewpoint Magician Lord at this rate i'll probably end up getting a 4 or 6 slot motherboard and build a fullsize cab
Agrajag Posted April 25, 2013 Posted April 25, 2013 great work can i be a pain and ask why folks are priming their wood before putting vinyl onto it? Most people seem to prime their cabs and paint them black before applying vinyl. I presume the vinyl goes on & stays on a painted surface better than on bare wood. Plus if the vinyl is ever removed, the cab will still look good without it. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
mikekim Posted April 27, 2013 Author Posted April 27, 2013 update slow progress on the cab, i just cant get a good finish with spraying, so its a case of sand it down and start again... will have to look at changing the paint i'm using as well, it was supposed to be all purpose wood paint... have managed to install the vinyl on the CP and attach the red t-molding though
mikekim Posted May 6, 2013 Author Posted May 6, 2013 update some progress made this weekend.. put on the side art and t-molding. started to put it all back together. (Loose fit at the moment as i have to do some tidying up, and all the internal wiring) also fitted the 15" monitor and Bronze polycarbonate screen. ... one item i didn't take into account when designing this was that the back access door is flush to the sides, and after the t-molding has been installed there is a slight overhang, so ive had to trim the door and will need to pack out the sides with some wood... a job for next week.. also i'lll have to touch up some of the black paint thats been scraped when re-installing parts additional edit quick test fit of the internal components, as a couple of people have asked how all the components are going to fit inside.. Jamma PSU SLG3000 and cga2vga Scaler PCB installed.. very tight but it all fits..
Unstupid Posted May 6, 2013 Posted May 6, 2013 ... one item i didn't take into account when designing this was that the back access door is flush to the sides, and after the t-molding has been installed there is a slight overhang You could take a flat razor and run it along the edge to trim off any excess t-molding, but this is this is easier to do before you assemble the cabinet. Your cab looks real good!
mikekim Posted May 6, 2013 Author Posted May 6, 2013 You could take a flat razor and run it along the edge to trim off any excess t-molding, but this is this is easier to do before you assemble the cabinet. Your cab looks real good! thanks for the compliment on the cab.. as for the t-molding, i looked at running a blade down the side to trim it flush, but the t-molding used is a red PVC coating over black base, so it doesn't look right when trimmed, as the black shows through, as shown in the photo below..
Unstupid Posted May 6, 2013 Posted May 6, 2013 Wow.. I have never seen that before... Where did you get that type of t-molding?
mikekim Posted May 6, 2013 Author Posted May 6, 2013 Wow.. I have never seen that before... Where did you get that type of t-molding? Got it from gremlinsolutions.co.uk. it was the only place in the uk where I could get 12mm in red Sent from my Samsung Galaxy Note II.
Frosty Posted May 6, 2013 Posted May 6, 2013 Looks great! Really like the design. Sent from my iPhone using Forum Runner
mikekim Posted April 21, 2014 Author Posted April 21, 2014 update what a surprise... another one of my projects that remains unfinished to the standard it should be at.. the cabinet was working ok, but inside it looked like a "dogs dinner", so i've decided to rip it all out and start to wire it properly. cable wrapped the jamma cables into the correct bundles (power, A/V, player 1 & 2, service and sound) shortened the player 1 leads and crimped on a 12pin Molex connector. player 2 connections are going to be soldered onto a db15 connector (so i can plug in an AES joystick for 2 player gaming) re-wired the control panel and made new cables for the leds. these cables will attach directly to the +5v and ground on the PSU. crimped on the connecting end of the 12 pin molex. the molex connector will allow me to easily remove the control panel if required. picked them up from ebay link - Molex connectors close up shot of the wiring.
mikekim Posted May 16, 2014 Author Posted May 16, 2014 update jamma psu was causing issues, (kept crashing the neo games due to fluctuations in power levels), so swapped it out for a 550w pc unit removed the molex connectors and replaced with a single 12pin connector. will probably remove the 24pin connector and all of the unused cables (and just solder the green and black cables together) - you can see the paper clip linking the cables in the picture not much else done on this due to lack of time, but managed to create a new label for the cart that matches the cab designed in photoshop, printed on glossy white adhesive paper @300dpi
