Sega CD
shitoken
HI Friends
I have a set of zipped roms with cue and bin file in each. Which emulator would work best for this system?
Million thanks
retroarch!
Retroarch! Once you configure one system you basically have configured 80% of your systems. You just need to change the name of the core in your config files.
Let me try 1 by 1 above mentioned & to find out which is less pain.
Thank you guys
If you haven't given any a go yet it would try retroarch. Once you set it up for one system the workflow is quite simple for others.
I currently use fusion but am thinking of switching to retroarch (which uses the fusion engine anyway) because I am having fade screen issues.
