Administrator
    1,259
    27
Everything posted by fr0stbyt3
  1. We're reworking the cache system in the next build coming out in the next few days. But the suggestion from @Davenzd is the current workaround
  2. - HyperHQ uses multiple processes within a single instance. This is common for multi threaded multi process applications. Chrome, Slack, and discord look and work the same way for example. When you close the app, it minimizes to the tray. This is also fairly normal for modern applications. In our case, it leaves a process running to accept downloads from HyperTheme. In the future is will act as a plugin host as well. To close the app, right click on the icon in your task bar and select quit. - The rom matching process is CPU/Disk bound. So slow hard drives and older CPUs may have slower performance. But I believe the issue you are having is download speed for new media. A release coming out in a few days has an update for download speed. - Shaders in HyperSpin/HyperTheme are coming very soon. We're going to implement them in the same way other features have already been added to the theme builder with a full UI for configurable settings.
  3. We're working on ways to make it more portable, but it can't be zip portable like HS1. I'll outline more with my wrap up post this week
  4. We should have an update for this in the coming days. Stay tuned!
  5. Yeah this is absolutely part of the roadmap at this point. After some update to the themebuilder to take themes to the next level, the event system will be the next feature I would like to focus on. This one thing will enable a ton of customization and new features for us in the future.
  6. I can add that for sure. Moving this to feature requests.
  7. So the default logic is that the overrides folder acts purely as an override. Meaning if it exists there it replaces the media being presented to you. However, I can see it being interesting to allow users to: not download files if they exist in overrides give downloaded media priority and fill in the blanks with overrides As for it downloading even when not selected, I will both add logging for this and double check this week during testing. Thanks @Creezz67
  8. I'm moving this to feature requests. This is doable for sure - but we would probably like to hold off until we enable our new event system.
  9. I like that box set! Noted on the enhancement list
  10. please use the "snap" folder for this
  11. Search is not ready volume up and down should be in a version at the end of the month
  12. Changed Severity to 3 - Medium Priority Changed Current Status to In Work
  13. Changed Severity to 2 - High Priority Changed Current Status to In Work
  14. This is related to the cache engine fix due at the end of the week. For now, force updates via changes in the wheel manager
  15. Changed Severity to 2 - High Priority Changed Current Status to In Work
  16. please post your log files. I think you might be dealing with HS (hyperspin core) not updating properly. A quick way for you to test. Restart your machine (or force close all HS instance. Restart HQ. Then go to plugins and reinstall HS.
  17. Changed Severity to 2 - High Priority Changed Current Status to In Work
  18. Changed Severity to 5 - Lowest Priority Changed Current Status to Working As Designed
  19. This is correct, we designed the entire interface with transparence in mind. If there is a solid use case, please open this as a feature request!
  20. Changed Severity to 2 - High Priority Changed Current Status to In Work
  21. Changed Severity to 2 - High Priority Changed Current Status to In Work Changed Development Feedback to This has an ETA of next week or so. I'll update the ticket here
  22. Minor changes were made, but we're not complete just yet.
  23. Changed Severity to 2 - High Priority Changed Current Status to Investigation
  24. Changed Severity to 2 - High Priority Changed Current Status to Investigation
