Creezz67
    1,323
    23
Everything posted by Creezz67
  1. Version 1.0.0
    6 downloads
    Enjoy !!
  2. Server error when using EmuMovies Sync for Microsoft XBOX 360 (02-10-2025) All other systems work except this one.
  3. FYI, MAME (working games only, no clones) videos still missing as of MAME 0.280 (108 in total) : 119 alienfev backybbs barbpet bbust2 big10a blockfvr buriki carled99 dblagent digimon digimonv2 digimonv3 disppal epo_tetr fastdrwp fatfurwa fruitpc gigapets gon100 honktonk hotwhls hrthouse icproul jak_1vs jak_5thg jak_avtr jak_cind jak_ctah jak_dond jak_dpma jak_dwa jak_gdg jak_hm1m jak_hmbb jak_hsm jak_jpdy jak_marv jak_ntsc jak_pacg jak_rapm jak_sdoo jak_sesa jak_shrk jak_slpb jak_spac jak_spdv jak_wof2 jubileep kingsran kingyosu letsgof lpetshop mgames mjxysl mpntball mpntbalt mylpony nor6007a nor6007b ouipdc pdc30p pdcj pengpaydx pex0126p pex2001p pex2133p pex2278p rcirulet roadedge rocksock roul sams64 sams64_2 shuifeng songjang soulbird spidm2 ssh2000 ssh2000wf ssh2001 sshot supr200 thundhrt topgear toratora touryuu trapeze trktreat trspacadv trtreisl tshs tsururin turbosub typo240 uchitari venusdm vesarif vjpp1 vjpp3 vjpp4 vparadis2 vpoker wafrica whacmole xorwflat xorwldms xrally
  4. Version 1.0.0
    12 downloads
    Evil Mario Backgrounds
  5. Hi all, Here are a few images I created for the Fade screen in Rocketlauncher (Game Over) Just drop them into you RocketLauncher Default Fade folder (png's may need renamed) Layer -1 (1) , Layer -1 (2) etc ...
  6. One word .... ChatGPT
  7. No they are all still there , they are just useless with 24H2
  8. For anyone now using Windows 11 (242H) Just a heads up .... If you have any PC games that are cracked, I suggest you check if they are working as I have gone through mine since updating and found at least 20% of them don't, mainly due to RocketLauncher now being unable to load them or the crack no longer working (all Empress ones now fail) ALL WORKED FINE ON 23H2. I knew it was too good to be true that everything would work and I am now sifting through 700+ PC games to see what now works and what doesn't.
  9. By re-sizing all the logos to 400x175 you have ruined them. Do you have the original sized logos ? Thanks
  10. Nobody wants to see Launchbox here on the Hyperspin forums. If you want something that looks like Hyperspin, but actually works .... use Hyperspin 1.5
  11. All working fine here too on Windows 11 Pro - 24H2 Build 26100.4202 (fully updated)
  12. MAME software naming is literally the only one EmuMovies doesn't use. Just download any set of roms for NES, SNES , Sega Master System etc and point EmuMovies Sync at them and it will download all the media with correct names. Same for the MAME Arcade set. Only problem it will have is missing media as even to this day a lot are missing, but 70-80+% will be available.
  13. I am only annoyed because it's trash. If you want a working Hyperspin 2.0 use Launchbox, because that's all it is ever going to be. Launchbox has a 8 year head start on Hyperspin 2.0 and has literally everything you could ever want built into it ... Trouble is, it's still useless because it runs like a one legged horse (I should know, I have it all setup with 250,000 games on it. Hyperspin on the other hand runs as smooth as silk (in conjunction with RocketLauncher) and that's why it will NEVER be surpassed. Enjoy Hyperspin 2.0 ... in about 5 years when they finally get it working. Also, you do know you can use EmuMovies on your desktop to download all media per system ? There has been no need for HyperSync for years. Only things you can't get are themes, but they are all on these forums anyway.
  14. Hyperspin has not been updated for a decade, yet still works perfectly. You have obviously never used it or you wouldn't be asking. They have been saying it's dead for years, yet still it is the best Frontend out there. If you want to use Hyperspin 2.0 then go for it, but if you ask anyone in here what's the best, 99% will say Hyperspin 1.5
  15. I have been using it (23H2) for 6 months+ and no sign of forced upgrade. Also, I am sure you will have the option of installing it or not if and when it finally (if ever) appears.
  16. To fix Supermodel games running too fast in HyperSpin, you can try adjusting the emulator's CPU frequency or enabling VSync in the game or graphics card settings. You might also need to configure HyperSpin or your graphics card to limit frame rate or refresh rate
  17. And even worse they (Hyperspin) will never fix it and are ecstatic about it not working, because it means nobody can sell Hyperspin anymore (Unless you use Windows before Windows 11 24H2 update). They hate their customers so much they would rather stop everyone from using it, just so Chris Shaw can't sell a couple of drives
  18. Creezz67
    XML2PNG
    Hi, The problem was I chose a jpg by mistake. used png and all working fine
  19. Creezz67
    XML2PNG
    Was trying to use a jpg instead of a png. All working now. Thanks
  20. Creezz67
    XML2PNG
    fyi, Background, Options and image not working.
  21. Version 1.0.0
    21 downloads
    Sonic Unleashed Recompiled is an unofficial PC port of the Xbox 360 version of Sonic Unleashed created through the process of static recompilation. The port offers Windows and Linux support with numerous built-in enhancements such as high resolutions, ultrawide support, high frame rates, improved performance and modding.
