blur
    553
Everything posted by blur
  1. nope, this is not focus issue - this looks like windows 7 don't like fp very much, of fp doesn't like win 7 and it doesn't let you to draw screens on top of it - that's why menus are not visible, but they are there in background - you can't get to them with alt-tab - because again - win7 and fp won't let you - but you can do ctrl-alt-del, open task manager - and then with alt-tab you can go thorugh fplaunch windows - this is not solved yet focus issue is simply when you exit table and don't get focus on hyperpin
  2. Here is a new version with support for different fp exe put them in fpexetables.txt in settings directory format is one line for table name - without fpt, and next line for fp exe you want to use with this table same format is for vpexetables.txt - name is changed - it was vp908tables.txt before pinemhi is included, fpclose vbs script is also included so you can try it in case you have problems with focus. focus code is improved so i hope you won't need fpclose zip file is on vpu http://vpuniverse.com/forums/index.php/topic/135-hyperpin-hi-scores/?p=1248
  3. Ok so first update is done - dnadisturber's pinemhiscores are in the fplaunch 1.295 wip 9 with hiscores version downloadable from link above. Next thing i wanted to do is to debug loss of focus on exit. This is an old problem that happens on win7 with multiple screens, on xp and on win7 with one screen there is no loss of focus. Focus problems are much more frequent since i changed hyperpin.exe to run in native mode since and compatibility mode produces huge memory leak that kill the machine after few hours. Bill55 reported that on his rig with xp! fplaunch.exe is not closing on uvp tables, and he made patch for that - vbs script that kills fplaunch. Later he found that moving taskbar to backglass screen also solves this problem. But i wanted to test if this will solve my loss of focus problems. Here are test results. I already posted this on vpf - but here it is again: So solution is to move taskbar to playfield - funny since i remember there were some problems when taskbar is on playfield. Now on to the next things to put in - like multple choices of fp exe (just like there is a choice of vp.exe) and other new features...
  4. This looks like you are using different version of b2s exe and vpt table, and some objects called from table script are not in b2s exe. Try to download latest table and b2s exe and also latest b2s.vpt.
  5. yeah, fix is usually to use exactly one specific version of driver, check with rosve - author of b2s, maybe he knows i think directb2s is not using .net because it was too unstable
  6. No problem, my men. Take your time - actually i already have even newer version there. I've changed hiscores so that they are drawn outside of visible sceen and rotated to avoid blinking in the middle of the screen. I didn't put those other features cause i'm putting them one by one - to test it easier and faster without to much bugs. So now i'm putting these small changes and releasing only exe and ahk but they will all be in next full version with images and all.
  7. i never saw this error - it must be some driver incompatibility. you probably get it if you run table outside hyperpin too? checking all the time for windows to close them while you play is not a good idea - it takes too many cpu cycles
  8. Did you tested new version with hiscores?
  9. Here is new version of fplaunch 1.295 wip 9 with hiscores and table name in exit menu http://vpuniverse.com/forums/index.php/topic/135-hyperpin-hi-scores/?p=1142 Try it and report back. For hiscores to work you have to download pinemhi from www.pinemhi.com and put pinemhi.exe and pinemhi.ini in hyperpin dir
  10. Here is a new version of fplaunch 1.295 wip 9 with hiscores and table name. Tnx goes to dnadisturber, bleasby and horseyhorsey for pinemhi and fplaunch scripts. To use this script just copy this code to fplaunch.ahk and recompile (i used basic ahk and ahk_L ANSI version and they both work, i did not test unicode version) and download pinemhi.exe and pinemhi.ini from http://www.pinemhi.com/ and put them in hyperpin dir. Report back bugs if you find some. ; FPLaunch MOD by bbb, samwyze and blur Version := "FPLaunch 1.295 WIP 9 with hiscores and title" /* Check FPLaunch Manual at http://www.hyperspin-fe.com/forum/showthread.php?t=10935 Based on original FPLaunch 1.2 by [email protected] Modified by dumpster.monkey (samwyze) & blur CursorHide by Lazlo Thanks to tic (Tariq Porter) for his GDI+ Library http://www.autohotkey.com/forum/viewtopic.php?t=32238 Includes modified pause code from ManofWars Nuevo FPLaunch 1.2 Includes exit png's based on jpg's from BBB's 'exit feature' thread Includes exit menus by samwyze Includes support for Pause in FP by blur and loafer For pause to work in FP you have to define right mouse button as pause in FP Includes support for saving FP table position (scrolllock) on exit by blur VP nag screen removal by blur B2S backglass exe support by rosve different exe, sound level and hdrender flag support by bigboss http://www.vpforums.org/index.php?showtopic=12906 slamit bigscore pinball support by bigboss http://www.hyperspin-fe.com/forum/showthread.php?t=12198 ledwiz support by darkfall: http://www.vpforums.org/index.php?showtopic=16186&hl= All images should be placed in %HyperPinDir%\Media\HyperPin\Images All settings are added to %HyperPinDir%\Settings\Settings.ini NOTE: This is a wip and is by no means complete or optimized Feel free to disect, mod, clean, optimize, distribute or delete! If you would like to modify this script and share it thats OK, but see if your modification is something that we would like to add to the official version. CODE MAP This is short list of all sections and functions in this script so that you can find and customize them quickly GET PARAMATERS AND SET HOTKEYS reads input parameters from command line GET AND CHECK PATHS gets settings from ini files calculates window coordinates hides taskbar, cursor and desktop RUN SYSTEM FUTURE PINBALL, VISUAL PINBALL commands for launching vp and fp WHEN EMULATOR FINISHES OR IF LAUNCH EXE FAILS error msg key remaps for Slamit pinball KILL COMMANDS this is where all our procedures are! Procedures: CloseProcess - kills process - not used QuickLaunch - launching gui Loading screen CreateLoadScreen - loading screen loop with slider, closes nag messages CheckPlayer - check if player is active CheckVP - checks 3 times CheckFP - checks 3 times WaitPlayer - wait for player to be active WaitVP - waits 3 times WaitFP - waits 3 times CloseProgress - closes loading screen with slider MoveProgress - moves rotating hyperpin ball Exit screen ExitScreen - call exit menu or exit countdown CreateExitScreen - create exiting in 321 screens CreatePauseScreen - show blue PAUSED image CreateBlackScreen - do printscreen of fp table and show it on the screen PrintScreen - save playfield screenshot to media folder PrintBG - save bg creenshot to media folder PauseFP - call pause screen or exit menu PauseVP - call pause screen or exit menu PauseGame - call vp of fp pause ShowFP - close player and show editor on edit key ShowVP - close player and show editor on edit key ShowGame - show vp or fp SetSaveFPNeeded - set flag to save fp table on exit CloseFP - closes fp CloseVP - closes vp CloseGame - close vp or fp Exit menu ExitMenu - draw or close exit menu closeMenus - closes menus MenuSwap - change active menu item selectItem - select active menu item Flyer Flyer - show flyer MoveUp, MoveUp - going up and down in menus flyerSwap - swap flyer Instructions Instructions - show Instructions instrSwap - swap instructions DrawImageBTB - functions for drawing images - used in menus, flyers, instr. External functions (from other people) rosve - support for B2S active backglasses rosveClose - kills B2S backglass bigboss - support for different exe, sound levels and hdrender off bigbossClose - returns sound and hdrender settings SlamitBigScore - support for slamit bigscore from bigboss CloseSlam - close slamit pinball PINemHiScore - hiscores from dna disturber, tnx to blesby and horseyhorsey ExitScript - kills all gui's, activates hyperpin REST OF SCRIPT - scripts for enabling/disabling cursor and reading ini files toLog - logging to screen and log file Gdip_BitmapReplaceColor - replace color - used for swf instructions CaptureScreen - scripts for screen capture - removed, not needed HISTORY 1.295 wip 2 + add sleep after printscreen + add sleep during winactivate of vpinball, dmd and backglass + put winactivate outside of loading screen + enable other exe names + read logical and phyisical key state + win activate of secondary fp window (backglass) - doesn't help + put version in usage - double click on fplaunch.exe to get version + bigboss additions (more exe files, sound mods ...) + support for slamit pinball 1.295 wip 3 + winactivates removed (you have to set exe to nt4sp5 comp mode) + fix runtime error on close (you have to set exe to comp mode) + fix dmd not visible behind playfield (set exe to comp mode) + fps drop - same drop comes from loose of focus so it's not script related + shorter time for esc screens + win activate on nag screens brings them to focus and closes them 1.295 wip 4 + fix dmd not visible behind playfield + put all rosve and bigboss code to functions + write a code map + winactivate of fp after pause and printscreen + fix winactivate on z screen buffer message (msg stays in back) + fgi keys mapped to enter for slamit bigscore pinball if you don't use slamit you can remove them 1.295 wip 5 + save printscreen-a under name taken from description + quick launch gui from HL 2.0 + options do not get overwritten + menus from sam + show instructions and flyer on pause + fix slow down after close (when vp is still closing) - fixed - you have to wait a little till windows free memory 1.295 wip 6 + pauseVPinball key changed to pauseKey since it is not just for VP + pauseKey acts exactly the same as exitEmulatorKey (long press also) so now you can have two keys for opening and exiting menus (Esc and p) and two keys for menu items activation (1 and enter) or you can use some gamepad keys Joy1, 2Joy3, ... + instructions are much, much bigger + flyer is bigger, and if works with different dimensions images for same table + loading menu is merged from sam's version + some parts of the code are optimized (draw image by the book), some are not + lots of work and testing so that you can always use exit, enter, flyer and instr keys for example you can press flyer to open flyer directly or go through menus with enter same with instructions you can also switch from flyer to instructions you can close flyer with exit, enter or flyer key, same for instructions all of this will work in vp and fp + ... what else, uhmmmmm let me think - yes loading menu - something was hiding loading slider (probably vp) and unhiding taskbar - this is both fixed so taskbar is hidden every few secs and slider is unhiden + focus problem with loading screen - while slider is on the screen every few seconds we try to activate vp (avoiding dmd hack) also after aprox. 25 secs. we just close loading screen unconditionally also on exit key (or pause key) we close loading screen unconditionally and after close of loading screen there is a one sec sleep and winactivate in a loop so now you should get perfect focus on every vp game + debug mode - lot's of things was written to log file, I also added tool tip on top of the screen - but nothing is written anywhere by default only if you enable it with this option in settings.ini 1.295 wip 7 + fixed memory leak + swf draws in same resolution, not double, faster, better image + support for many instructions cards swf, bmp, png, jpg, gif format 1.295 wip 8 + fixed b2s close bug + ledwiz support added, for more info check: http://www.vpforums.org/index.php?showtopic=16186&hl= + support for different names for hyperpin.exe 1.295 wip 9 + fixed vp doesnt close bug (detect hidden windows on) + capture screen code removed (not used any more) + printscreen for backglass added (o saves pf, u saves bg) + code map updated + reorg - all procedures moved up and down a bit + #winactivateforce added (didn't help much - actually made some wierd problems and freezes - removed) + fix focus on table close in win7 with triple checks + lots of triple checks added (ifactive, waitactive, ...) + taskbar shown on exit if there is no hyperpin process + cursor shown on exit + show vp/fp editor on error and close loading slider + activate commands moved to functions + file and screen debug modes added + toggle taskbar on t key (it was always shown, now it is hiden also) + fix blackscreen gui (no need for black screen if useloadscreen is true) + remove all detect hidden windows off + remove double exitscreen - it is executed on exit, no need to call it + find why hyperpin freezes sometimes ??? (activate force maybe) - add toLog to every function - test fp activate and errors, change fp run code to use functions - fp sometimes doesn't show loading slider - test it 1.295 wip 10 - add toLog to every function - error handling should be removed - wait from reply from user - test fp activate and errors, change fp run code to use functions - fp sometimes doesn't show loading slider - test it TO DO: - read keys from hyperpin (keyboard and joystick) - dodati highscores od leasby-ija - ima ahk u hyperpin diru, ime roma staviti u xml ili naći neku metodu za otkrit koji mame se vrti trenutno??? - dodati opciju triplecheck on exit - ili ubaciti više sleepova da se ne freeza stalno - dodati opciju disable service menu - make loading screen resolution independent? - read settings.ini into memory - change key names to exitkey exitkey1 and startkey startkey1 for simplicity - remove usepause useexitasapuse useexitmenu options for simplicitiy - use prerotated menu images for simplicity - always use draw image by the book function for simplicity - put every repeating code to subroutines for simplicity - change instruction card menu item to instructions - enable png instructions - compile a set of png instructions and replay score cards and helps for setting replay levels, and tactics help, and ... (hopefully somebody will do this eventually) - test service menu - fix late printscreen in fp - fp auto positioning */ #SingleInstance force ;Prevent multiple instances #InstallKeybdHook SetTitleMatchMode 2 ;Use relaxed title matching ;#InstallMouseHook ;#UseHook ; this one breaks long press functionality for gamepad button mapped to Esc!!! ;#KeyHistory 500 #MaxThreadsPerHotkey 1 #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. DetectHiddenWindows on #WinActivateForce OnExit onExitScript SoundPlay menu.wav GlobalListLines("Off") #Include, Gdip.ahk #Include, Com.ahk ;------------------------------------------------------------------------------; ; Start gdi+ If !pToken := Gdip_Startup() { MsgBox, 48, gdiplus Error!, Gdiplus failed to start. Please ensure you have Gdip.ahk In Hyperpin dir ExitApp } toLog("GDI+ Initialised") ; start com COM_Init() COM_CoInitialize() COM_AtlAxWinInit() toLog("COM Standard Library Initialised") ;******************************************************************************* ;* EDIT BELOW THIS POINT AT YOUR OWN RISK * ;******************************************************************************* ;------------------------------------------------------------------------------; ; GET PARAMATERS AND SET HOTKEYS ; ;------------------------------------------------------------------------------; hyperini = %A_ScriptDir%\Settings\Settings.ini picDir = %A_ScriptDir%\Media\HyperPin\Images\ GoSub, CheckINI IniRead, lastSystem, %hyperini%, LastLoad, system IniRead, lastTable, %hyperini%, LastLoad, table iniKeys = ( [FPLaunch] ; default settings, if you don't have them they will be added to your settings.ini file ; ***** don't change them here - edit your settings.ini file!!! ***** exitScriptKey = q & s ; kill script key exitEmulatorKey = Esc ; main exit key, can be joy key also (Joy1) toggleCursorKey = t hideCursor = true hideDesktop = true hideTaskbar = true ; new settings useExitScreen = true ; show exit321 countdown on long press usePauseKey = true ; if used pause key works same as exit key useLoadScreen = true ; show loading slider useExitAsPause = true ; open pause window on exit key or exit directly useExitMenu = true ; use exit menu instead of pause window pauseKey = p ; former pauseVPinball key, works same as exit key fadespeed = 25 exitEmulatorKey2 = 1 ; key for entering into menus exitEmulatorKey3 = Enter ; and another one pauseFPKey = RButton ; pause in FP saveFPTables = true ; save fp table position on exit editTableKey = !F4 ; close table and go to vp/fp editor printScreenKey = o ; save playfield printBGKey = u ; save backglass pfScreenNum = 1 ; playfield Screen Number (used for print screen) bgScreenNum = 2 ; backglass Screen Number (used for print screen) upKey = LShift ; left flipper goes up in menus downKey = RShift ; right flipper goes down in menus instructionsKey = i flyerKey = f hyperScale = 0.75 debugMode = false ledwiz = false hyperpinexe = hyperpin.exe ) Loop, parse, iniKeys, `n,`r`t" " { StringSplit, iniKey, A_LoopField, =;, %A_Space%%A_Tab% if (iniKey0 > 1 And iniKey1 != "") { IniRead, %iniKey1%, %hyperini%, FPLaunch, %iniKey1% If (%iniKey1% = "ERROR" Or %iniKey1% = "") { %iniKey1% = %iniKey2% IniWrite, %iniKey2%, %hyperini%, FPLaunch, %iniKey1% } } } toLog("Ini files parsed") GlobalListLines("On") ;CHECKING FOR 2 PARAMS, IF NOT THEN OPEN QuickLaunch dialog box if 0 < 2 { GoSub QuickLaunch } Else { systemName = %1% tableName = %2% } If (systemName != lastSystem OR tableName != lastTable) { IniWrite, %systemName%, %hyperini%, LastLoad, system IniWrite, %tableName%, %hyperini%, LastLoad, table } databaseFile = %A_Scriptdir%\Databases\%systemName%\%systemName%.xml ;------------------------------------------------------------------------------; ; GET AND CHECK PATHS ; ;------------------------------------------------------------------------------; IniRead, iniEmuPath, %hyperini%, %systemName%, Path emuPath := GetFullName(iniEmuPath) IniRead, iniTablePath, %hyperini%, %systemName%, Table_Path tablePath := GetFullName(iniTablePath) IniRead, executable, %hyperini%, %systemName%, Exe IniRead, iniTableImagePath, %hyperini%, %systemName%, Table_Image_Path tableImagePath := GetFullName(iniTableImagePath) IniRead, iniBackglassImagePath, %hyperini%, %systemName%, Backglass_Image_Path backglassImagePath := GetFullName(iniBackglassImagePath) if (systemName = "Future Pinball") romExtension = fpt else romExtension = vpt GoSub, CheckPaths Hotkey, %exitScriptKey%, ExitScript Playfield_Rotation := 270 StrX( H, BS="",BO=0,BT=1, ES="",EO=0,ET=1, ByRef N="" ) { ; | by Skan | 19-Nov-2009 Return SubStr(H,P:=(((Z:=StrLen(ES))+(X:=StrLen(H))+StrLen(BS)-Z-X)?((T:=InStr(H,BS,0,((BO <0)?(1):(BO))))?(T+BT):(X+1)):(1)),(N:=P+((Z)?((T:=InStr(H,ES,0,((EO)?(P+1):(0))))?(T-P+Z +(0-ET)):(X+P)):(X)))-P) ; v1.0-196c 21-Nov-2009 www.autohotkey.com/forum/topic51354.html } q = " FileRead, XML, %databaseFile% ;load database xml for parsing temptableDescription := StrX( XML, q . tableName . q ,1,0,"</description>",1,14) tableDescription := StrX( temptableDescription, "<description>" ,1,13,"",1,1) shortDescription := StrX( tableDescription, "" ,1,1,"(",1,0) pfName = %tableImagePath%%tableDescription%.png bgName = %backglassImagePath%%tableDescription%.png loadspeed := fadespeed * 10 if (ledwiz = "true") Run, "%A_ScriptDir%\ledclear.bat",,hide ; loading screen gui, 99:add,picture,hwndloadpic, %picDir%loading.png controlgetpos,,,hLoad,wLoad,,ahk_id %loadpic% gui, 99:destroy wLoad := Round(wLoad*A_ScreenWidth/1920) xLoad := Round(A_ScreenWidth/2-(wLoad/2)) hLoad := Round(hLoad*A_ScreenHeight/1080) yLoad := Round(A_ScreenHeight/2-(hLoad/2)) wLoadProgress := Round(20*A_ScreenWidth/1920) xLoadProgress := Round(145*A_ScreenWidth/1920) hLoadProgress := Round(194*A_ScreenHeight/1080) yLoadProgress := Round(288*A_ScreenHeight/1080) ; old flags ProgBar = 0 Paused = 0 Exiting = 0 ; new flags menuOn = 0 menuItem = 1 serviceMenuOn = 0 instructionsOn = 0 flyerOn = 0 loading = 1 ; flyer images flyerpages = 0 Loop, %A_ScriptDir%\Media\HyperPin\Flyer Images\%shortDescription%*, ,1 { flyerpages++ flyerPic%A_Index% := A_LoopFileFullPath } If (flyerpages > 1) { flyerPic := flyerPic2 flyer = 2 } Else If (flyerpages = 1) { flyerPic := flyerPic1 flyer = 1 } Else { flyerPic1 := picDir . "FlyerMissing.png" flyerPic := flyerPic1 flyer = 1 flyerpages = 1 } toLog("Flyer Pages Parsed") ; instructions images instrpages = 0 Loop, %A_ScriptDir%\Media\HyperPin\Instruction Cards\%shortDescription%*, ,1 { instrpages++ instrPic%A_Index% := A_LoopFileFullPath } If (instrpages > 0) { instrPic := instrPic . instrpages instr := instrpages } Else { instrPic1 := picDir . "instructMissing.png" instrPic := instrPic1 instr = 1 instrpages = 1 } toLog("Instruction Pages Parsed") if (hideCursor = "true") { ;MouseMove 960, 540 MouseMove %A_ScreenWidth%/2, %A_ScreenHeight%/2 Hotkey, %toggleCursorKey%, ToggleCursor SystemCursor("Off") } taskbar = 1 if (hideTaskbar = "true") { WinHide, ahk_class Shell_TrayWnd WinHide, Start ahk_class Button taskbar = 0 } if (hideDesktop = "true" AND useLoadScreen = "false") { Gui, Color, 000000 Gui +AlwaysOnTop -Caption +ToolWindow Gui, Show, x0 y0 W%A_ScreenWidth% H%A_ScreenHeight%, BlackScreen } ; WinClose, cmd.exe ; what is this? ; if somebody needs it uncomment it ;------------------------------------------------------------------------------; ; RUN SYSTEM ; ;------------------------------------------------------------------------------; ;**********************************FUTURE PINBALL*********************************** if (systemName = "Future Pinball") { if(tableName = "BigScore") { ; bigboss slamit bigscore support GoSub SlamitBigScore } else { if (useExitScreen = "true") exitmeth = ExitScreen else if (useExitAsPause = "true") exitmeth = PauseFP else exitmeth = CloseFP ; fp needs $ or it will not get the key ; * enables any modifier (shift, ctrl, alt) ; * breaks long press functionality - removed Hotkey $%exitEmulatorKey%, %exitmeth% if (usePauseKey = "true") Hotkey, $%pauseKey%, %exitmeth% Hotkey, $%editTableKey%, ShowFP Hotkey, $%printScreenKey%, printScreen Hotkey, $%printBGKey%, printBG Hotkey, $%instructionsKey%, Instructions Hotkey, $%flyerKey%, Flyer if (saveFPTables = "true") { Hotkey, $ScrollLock, SetSaveFPNeeded Run, "%emuPath%\%executable%" /open "%tablePath%\%tableName%.fpt" /play /arcaderender,,Min UseErrorLevel } else Run, "%emuPath%\%executable%" /open "%tablePath%\%tableName%.fpt" /play /Exit /arcaderender,,Min UseErrorLevel If (useLoadScreen = "true") ;Draw the loading Gui with wrapped Progress bar Gosub CreateLoadScreen Else { WinWait, ahk_class FuturePinball WinHide, ahk_class FuturePinball } loading = 0 ; ************ use acrtivate functions ***************** WinWait, ahk_class FuturePinballOpenGL WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Gui, destroy WinWait, ahk_class FuturePinballOpenGLSecondary,,1 WinActivate, ahk_class FuturePinballOpenGLSecondary WinWaitActive, ahk_class FuturePinballOpenGLSecondary,,1 WinActivate, ahk_class FuturePinballOpenGL ; pinemhiscore FileDelete hiscore.txt FileAppend %tablename%`n, hiscore.txt RunWait, %comspec% /c PINemHi %tablename%.fpram>>hiscore.txt,,hide Process, WaitClose, %executable% } } ;**********************************VISUAL PINBALL*********************************** else if (systemName = "Visual Pinball") { GoSub bigboss ; bigboss support for different exe, sound levels and hdrender off GoSub rosve ; rosve support for B2S active backglasses Run, "%emuPath%\%executable%" /play -"%tablePath%%tableName%.vpt",, Min UseErrorLevel ;Run, "%emuPath%\%executable%" /play -"%tablePath%%tableName%.vpt",, Min UseErrorLevel ;Run Minimized was the best way I could hide the vp editor and ;play loading screens as WinHide didn't seem to find them sometimes If (useExitScreen = "true") ; * breaks long press functionality exitmeth = ExitScreen Else If (useExitAsPause = "true") exitmeth = PauseVP Else exitmeth = CloseVP Hotkey, $%exitEmulatorKey%, %exitmeth% If (usePauseKey = "true") Hotkey, $*%pauseKey%, %exitmeth% Hotkey, $%editTableKey%, ShowVP Hotkey, $%printScreenKey%, printScreen Hotkey, $%printBGKey%, printBG Hotkey, $%instructionsKey%, Instructions Hotkey, $%flyerKey%, Flyer If (useLoadScreen = "true") ; draw the loading Gui with Progress bar Gosub CreateLoadScreen Else { WinWait, ahk_class VPinball ; winhide doesn't work sometimes WinHide, ahk_class VPinball } ;dj loop loading = 1 Loop { WinActivate, ahk_class VPPlayer,,DMD Sleep 100 Gosub CheckVP if (loading = 0) Break } Gosub WaitVP ;bring cursor to center DllCall("SetCursorPos", int, A_ScreenWidth//2, int, A_ScreenHeight//2) ;bring dmd to front ;don't click on dmd if it is hidden (uvp table) DetectHiddenWindows off WinActivate, ahk_class MAME WinWaitActive, ahk_class MAME,,0 Sleep 100 ;dj click on dmd SetControlDelay -1 ControlClick,, ahk_class MAME WinWaitActive, ahk_class MAME,,0 Sleep 100 DetectHiddenWindows on ;dj loop again loading = 1 Loop { WinActivate, ahk_class VPPlayer,,DMD Sleep 100 Gosub CheckVP if (loading = 0) Break } Gosub WaitVP Gui, destroy ; pinemhiscore FileDelete hiscore.txt FileAppend %tablename%`n, hiscore.txt ; get rom title WinGetTitle, romnice, ahk_class MAME if (romnice != "") { ; get romname IniRead, romname, pinemhi.ini, romfind, %romnice% if (romname = "ERROR" or romname = "") { FileAppend ROM title %romnice% not found in pinemhi.ini`n, hiscore.txt } else { ; get the hiscore from nvram and put it in hiscore.txt RunWait, %comspec% /c PINemHi %romname%>>hiscore.txt,,hide } } Process, WaitClose, %executable% } else { MsgBox,48,Error,%systemName% is an invalid System Name or %executable% isnt supported yet,6 } ;------------------------------------------------------------------------------; ; WHEN EMULATOR FINISHES OR IF LAUNCH EXE FAILS ; ;------------------------------------------------------------------------------; ;************PROBABLY DO NOT NEED TO EDIT THIS AREA************* if (ErrorLevel = "ERROR") { MsgBox,48,Error,Failed to run executable check your paths,6 } Goto ExitScript ; Exits script and returns to frontend ; You should never come here ; bigboss Slamit support remaps ; - this has to be here, not in procedures, not in normal code ; - ahk stops on first #ifwinactive command ; Remap keys: ; enter to down arrow for plunger ; 1 to s for start, 5 to 1 for insert coin ; magnasave, flyer, genre or instructions to enter for menus ; change it to what you have on your cab and recompile ; or remove it if you don't use slamit pinball #IfWinActive ahk_class SlamIt Pinball - Big Score RControl::Enter LControl::Enter f::Enter g::Enter i::Enter Enter::down 5::1 1::s #IfWinActive ;------------------------------------------------------------------------------; ; KILL COMMANDS ; ;------------------------------------------------------------------------------; ;************PROBABLY DO NOT NEED TO EDIT THIS AREA************* CloseProcess: Hotkey, %exitScriptKey%, Off Process, Close, %executable% Process, WaitClose, %executable% return ;------------------- QuickLaunch gui ------------------- QuickLaunch: ListLines Off Gui, Add, ComboBox, x12 y100 w266 gsetSystem vsystemName, Visual Pinball|Future Pinball Gui, Add, ComboBox, x12 y150 w266 h20 r10 vtableName Gosub getSystem Gui, Add, Text, x12 y10 w430 h20 , Usage: FPLaunch.ahk/exe "System Name" "Rom Name" Gui, Add, Text, x12 y40 w350 h30 , Select system name and table name and click the Run button. Gui, Add, Text, x12 y80 w80 h20 , System Name: Gui, Add, Text, x12 y130 w220 h20 , Table Name (file name without extension): Gui, Add, Button, x290 y100 w60 h70 gtestdone vrun, Run Gui, Show, Center h185 w365, %Version% GuiControl, Focus, run While (Test != "done") { sleep 500 } ListLines %gListLines% Return GuiClose: Gosub exitScript Return testdone: Gui, Submit Test = done Return getSystem: GuiControl, ChooseString, systemName, %lastSystem% Gui, Submit, NoHide Gosub getTables Return setSystem: Gui, Submit, NoHide Gosub getTables Return getTables: Tables = ArrayCount = 1 systemsFile := A_ScriptDir . "\Databases\" . systemName . "\" . systemName . ".xml" Loop, Read, %systemsFile% { Pos := RegExMatch(A_LoopReadLine,"name=""(.*)""", SubPat) If(Pos > 1){ Tables%ArrayCount% := SubPat1 ArrayCount += 1 } } ArrayCount -= 1 elements := "|" Loop %ArrayCount% { elements .= Tables%A_Index% . "|" } GuiControl,, tableName, %elements% If (systemName = lastSystem And lastTable != "") GuiControl, ChooseString, tableName, %lastTable% Else GuiControl, Choose, tableName, 1 GuiControl, Focus, run Gui, Submit, NoHide Return ;------------------- End of QuickLaunch gui ------------------- ;------------------- Loading screen ------------------- CreateLoadScreen: GlobalListLines("Off") SetTitleMatchMode 2 ;Use relaxed title matching Gui, Destroy ; kill Gui blackScreen toLog("CreateLoadScreen Called") Gui, 1: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 1: Show,, Loading hwLoad := WinExist() loadPic = %picDir%loading.png pBitmap := Gdip_CreateBitmapFromFile(loadPic) pWidth := Gdip_GetImageWidth(pBitmap) pHeight := Gdip_GetImageHeight(pBitmap) scale := ((A_ScreenHeight*hyperScale)/pWidth) sWidth := Round(pWidth*scale), sHeight := Round(pHeight*scale) Gdip_GetRotatedDimensions(sWidth, sHeight, Playfield_Rotation, rWidth, rHeight) Gdip_GetRotatedTranslation(sWidth, sHeight, Playfield_Rotation, xTranslation, yTranslation) xLoad := Round((A_ScreenWidth-rWidth)/2), yLoad := Round((A_ScreenHeight-rHeight)/2) hbm := CreateDIBSection(rWidth, rHeight) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_SetInterpolationMode(G, 7) Gdip_TranslateWorldTransform(G, xTranslation, yTranslation) Gdip_RotateWorldTransform(G, Playfield_Rotation) Gdip_DrawImage(G, pBitmap, 0, 0, sWidth, sHeight, 0, 0, pWidth, pHeight) Gdip_DisposeImage(pBitmap) Gdip_ResetWorldTransform(G) UpdateLayeredWindow(hwLoad, hdc, xLoad, yLoad, rWidth, rHeight) SelectObject(hdc, obm), DeleteObject(hbm), DeleteDC(hdc) Gdip_DeleteGraphics(G) Gui, 2: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 2: Show, NA, Loading hwLoadprog := WinExist() progPic = %picDir%loadProgress.png pBitmap := Gdip_CreateBitmapFromFile(progPic) pLWidth := Gdip_GetImageWidth(pBitmap), pLHeight := Gdip_GetImageHeight(pBitmap) sLWidth := Round(pLWidth*scale), sLHeight := Round(pLHeight*scale) Gdip_GetRotatedDimensions(sLWidth, sLHeight, Playfield_Rotation, rLWidth, rLHeight) Gdip_GetRotatedTranslation(sLWidth, sLHeight, Playfield_Rotation, xTranslation, yTranslation) xLoadProgress := Round(rWidth/6*5+xLoad-rLWidth),yLoadProgress := Round(rHeight/3*2+yLoad-rLHeight) pinend := Round(rHeight/3*2+yLoad-rLHeight),pinstart := Round(rHeight/3+yLoad) hbm := CreateDIBSection(rLWidth, rLHeight) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_SetInterpolationMode(G, 7) dir = 2 pinrot := Playfield_Rotation DetectHiddenWindows off ; why is this here? - to avoid detecting hidden error windows ;;;Gui, 99:Destroy ??? no need for this? SetTimer, MoveProgress, %fadespeed% Loop { Sleep %loadspeed% ; nag screens removal toLog("Loading Loop "A_Index) ifWinExist, Please { ; first time run nag screen WinActivate, Please IfWinActive, Please { ; dj SetControlDelay -1 ControlClick, Button2, Please answer AHK_class #32770 ; Click Yes I am ControlSend, Button1, {Enter}, Please answer AHK_class #32770 ; Click the OK button } } else ifWinExist, Game Info { WinActivate, Game Info IfWinActive, Game Info { Send {Enter} Send {Enter} } } else ifWinExist, Notice { ; sound warnings (antar) WinActivate, Notice IfWinActive, Notice { Send {Enter} Send {Enter} } } else ifWinExist, VBScript { ; errors in vb script WinActivate, VBScript IfWinActive, VBScript { Send {Enter} } } else ifWinExist, Error { ; open editor on serious errors ; (z buffer, script error, rosve bg - line 0, ...) ; old error treatment was to show msg and close vp ; hm on some errors vp crashes, we will test for that in waitplayer toLog("LoadScreen Closed - Error") Gosub CloseProgress if (systemName = "Visual Pinball") { WinRestore, ahk_class VPinball WinActivate, ahk_class VPinball WinWaitActive, ahk_class VPinball } else { WinRestore, ahk_class FuturePinball WinActivate, ahk_class FuturePinball WinWaitActive, ahk_class FuturePinball } SystemCursor("On") WinShow ahk_class Shell_TrayWnd WinShow Start ahk_class Button taskbar = 1 Suspend, On WinActivate, Error WinWaitActive, Error Gosub WaitPlayer Suspend, Off SystemCursor("Off") WinHide, ahk_class Shell_TrayWnd WinHide, Start ahk_class Button taskbar = 0 ;WinMinimize, ahk_class VPinball Continue } ; check if player is active Gosub CheckPlayer ; try to get focus every ~five seconds if (Mod(A_Index, 20) = 0) { WinActivate, ahk_class VPPlayer,,DMD WinActivate, ahk_class FuturePinballOpenGL } ; after ~25 seconds close unconditionally if (Mod(A_Index, 100) = 0) { toLog("LoadScreen Closed - 25 sec") Break } ; close loading slider unconditionally on exit key if (loading = 0) { toLog("LoadScreen Closed - Esc?") Break } ; hide taskbar again (vp unhides taskbar ; only if auto hide taskbar is set windows ; so disable auto hide taskbar in windows!!!) ;if (hideTaskbar = "true") { ; WinHide, ahk_class Shell_TrayWnd ; WinHide, Start ahk_class Button ;} } Gosub CloseProgress DetectHiddenWindows on GlobalListLines("On") Return CheckPlayer: ; check if player is active ; toLog("CheckPlayer Called") if (systemName = "Visual Pinball") Gosub CheckVP else Gosub CheckFP Return CheckVP: ; check three times cause player can be ; active for a sec and then throw an error ;toLog("CheckVP Called") IfWinActive, Visual Pinball Player,,DMD { Sleep 100 IfWinActive, Visual Pinball Player,,DMD { Sleep 100 IfWinActive, Visual Pinball Player,,DMD { toLog("CheckVP - VP is active") loading = 0 } } } Return CheckFP: ;toLog("CheckFP Called") IfWinActive, ahk_class FuturePinballOpenGL { Sleep 100 IfWinActive, ahk_class FuturePinballOpenGL { Sleep 100 IfWinActive, ahk_class FuturePinballOpenGL { toLog("CheckFP - FP is active") loading = 0 } } } Return WaitPlayer: ; wait for player to be really active!!! toLog("WaitPlayer Called") if (systemName = "Visual Pinball") Gosub WaitVP else Gosub WaitFP Return WaitVP: ; sometimes player is active just for a sec ; then it throws an error, this loop fixes that!!! ; it will not go on untill player is active three times in a row toLog("WaitVP Called") waitagainvp: ; if vp doesn't exist (crashed or closed) - exit IfWinNotExist ahk_class VPinball ExitApp MouseMove 88,130 WinWaitActive ahk_class VPPlayer,,1,DMD Sleep 100 IfWinNotActive ahk_class VPPlayer,,DMD Goto waitagainvp WinWaitActive ahk_class VPPlayer,,1,DMD Sleep 100 IfWinNotActive ahk_class VPPlayer,,DMD Goto waitagainvp WinWaitActive ahk_class VPPlayer,,1,DMD Sleep 100 IfWinNotActive ahk_class VPPlayer,,DMD Goto waitagainvp Return WaitFP: toLog("WaitFP Called") waitagainfp: MouseMove 88,130 WinWaitActive, ahk_class FuturePinballOpenGL Sleep 100 IfWinNotActive, ahk_class FuturePinballOpenGL Goto waitagainfp WinWaitActive, ahk_class FuturePinballOpenGL Sleep 100 IfWinNotActive, ahk_class FuturePinballOpenGL Goto waitagainfp WinWaitActive, ahk_class FuturePinballOpenGL Sleep 100 IfWinNotActive, ahk_class FuturePinballOpenGL Goto waitagainfp Return CloseProgress: ; closes loading screen with slider toLog("CloseProgress Called") SetTimer, MoveProgress, Off SelectObject(hdc, obm) DeleteObject(hbm), DeleteDC(hdc), Gdip_DeleteGraphics(G) Gdip_DisposeImage(pBitmap) Gui, 2:Destroy Gui, 1:Destroy Return MoveProgress: ; moves rotating hyperpin ball ListLines Off yLoadProgress := (yLoadProgress - dir) If (yLoadProgress > pinend) Or (yLoadProgress < pinstart) dir := -(dir) Gdip_TranslateWorldTransform(G, xTranslation, yTranslation) Gdip_RotateWorldTransform(G, pinrot) Gdip_DrawImage(G, pBitmap, 0, 0, sLWidth, sLHeight, 0, 0, pLWidth, pLHeight) Gdip_DisposeImage(pBitmap) Gdip_ResetWorldTransform(G) dif := (rLHeight-sLHeight)/2 dif := -dif movedyLoadProgress := Round(yLoadProgress+dif) movedxLoadProgress := Round(xLoadProgress+dif) UpdateLayeredWindow(hwLoadProg, hdc, movedxLoadProgress+1, movedyLoadProgress, rLWidth, rLHeight) SelectObject(hdc, obm), DeleteObject(hbm), DeleteDC(hdc) Gdip_DeleteGraphics(G) pinrot := pinrot + dir*5 Gdip_GetRotatedTranslation(sLWidth, sLHeight, pinrot, xTranslation, yTranslation) Gdip_GetRotatedDimensions(sLWidth, sLHeight, pinrot, rLWidth, rLHeight) pBitmap := Gdip_CreateBitmapFromFile(progPic) hbm := CreateDIBSection(rLWidth, rLHeight) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_SetInterpolationMode(G, 7) ; this had to be added cause vp would hide loading slider during load ; remember we are waiting for vp to take focus so slider must not take focus Gui, 2: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 2: Show, NA, Loading Return ;------------------- End of Loading screen ------------------- ;------------------- Exit screen ------------------- ExitScreen: ; call exit menu or exit countdown toLog("ExitScreen called") if (loading = 1) ; just close loading slider loading = 0 else if (Exiting = 0) { ; check for long press Exiting = 1 LoopVal = 0 Loop { ;Sleep, 10 ; check if we need this - nope state = 0 ; check for logical and physical state of the exit key GetKeyState, statel, %exitEmulatorKey% if statel = D state = 1 GetKeyState, statep, %exitEmulatorKey%, P if statep = D state = 1 ; also check for state of the pause key GetKeyState, statel, %pauseKey% if statel = D state = 1 GetKeyState, statep, %pauseKey%, P if statep = D state = 1 if (state) { if (loopVal = 10) { if (Paused = 1) { ; close pause window before going to countdown Gosub PauseGame } Gosub CreateExitScreen if (systemName = "Future Pinball") GoSub CreateBlackScreen Gui, 3:Show } else if loopVal = 25 Gui, 2:Show else if loopVal = 40 Gui, 1:Show Sleep, %fadespeed% if (loopVal = 60) { Gosub CloseGame break } } else { Exiting = 0 if (LoopVal < 10 && useExitAsPause = "true") { ; short press Gosub PauseGame } else { ; long press but not long enough Loop, 6 Gui, %A_Index%: Destroy WinActivate, Visual Pinball Player,, DMD WinActivate, ahk_class FuturePinballOpenGL } Transvalue = 0 LoopVal = 0 break } LoopVal += 1 } } Return CreateExitScreen: ; create exit321 screens toLog("CreateExitScreen Called") Gui, Destroy Loop, 4 { ExitPic = Exit_%A_Index%.png Gui %A_Index%: Destroy Gui %A_Index%: Color, EEAA99 Gui %A_Index%: Margin, 0, 0 Gui %A_Index%: Add, Picture, w%wLoad% h%hLoad%, %picDir%%ExitPic% Gui %A_Index%: +AlwaysOnTop -Caption +Lastfound Gui %A_Index%: Show, AutoSize Center Hide WinSet, TransColor, EEAA99 } Return CreatePauseScreen: ; show blue PAUSED image toLog("CreatePauseScreen Called") Gui, Destroy Gui, Color, EEAA99 Gui, Margin, 0, 0 Gui, Add, Picture, w%wLoad% h%hLoad% vPausePic, %picDir%pause.png Gui +AlwaysOnTop -Caption +Lastfound Gui, Show, AutoSize Center, pauseScreen WinSet, TransColor, EEAA99 ;Gui, Show Return CreateBlackScreen: ; do printscreen of fp table and show it on the screen toLog("CreateBlackScreen Called") pBitmap := Gdip_BitmapFromScreen(pfScreenNum) Gdip_SaveBitmapToFile(pBitmap, "screen.bmp") WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL,,2 Gui 9: Destroy Gui 9: Color, 000000 Gui 9: Margin, 0, 0 Gui 9: Add, Picture, W%A_ScreenWidth% H%A_ScreenHeight% vScreenPic, screen.bmp Gui 9: +AlwaysOnTop -Caption ;+ToolWindow Gui 9: Show, x0 y0 W%A_ScreenWidth% H%A_ScreenHeight%, BlackScreen Return PrintScreen: ; save playfield screenshot to media folder toLog("PrintScreen Called") pBitmap := Gdip_BitmapFromScreen(pfScreenNum) Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, pfName) Gdip_DisposeImage(pBitmap) return PrintBG: ; save bg creenshot to media folder toLog("PrintBG Called") pBitmap := Gdip_BitmapFromScreen(bgScreenNum) Gdip_SaveBitmapToFile(pBitmap, bgName) Gdip_DisposeImage(pBitmap) return PauseFP: ; call pause screen or exit menu toLog("PauseFP Called") if (Paused = 0) { ; we are enetering pause menu Paused = 1 WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} WinWaitActive, ahk_class FuturePinballOpenGL Gosub CreateBlackScreen ; we draw printscreen first if (useExitMenu = "true") { Gosub ExitMenu ; draw menus - nothing else! Hotkey, %UpKey%, MoveUp, On Hotkey, %DownKey%, MoveDown, On Hotkey, %exitEmulatorKey2%, selectItem, On Hotkey, %exitEmulatorKey3%, selectItem, On } else { Gosub CreatePauseScreen Hotkey, $%exitEmulatorKey2%, CloseFP, On Hotkey, $%exitEmulatorKey3%, CloseFP, On } } else { ; we are exiting pause menu Paused = 0 if (useExitMenu = "true") { Gosub ExitMenu ; close menus or flyer or instr. Hotkey, %UpKey%, Off Hotkey, %DownKey%, Off Hotkey, %exitEmulatorKey2%, Off Hotkey, %exitEmulatorKey3%, Off } else { Gui 1: Destroy Gui 9: Destroy Hotkey, $%exitEmulatorKey2%, Off Hotkey, $%exitEmulatorKey3%, Off WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} } } return PauseVP: ; call pause screen or exit menu toLog("PauseVP Called") If (Paused = 0) { ; entering pause menu Paused = 1 if (useExitMenu = "true") { Gosub ExitMenu ; draw menus Hotkey, %UpKey%, MoveUp, On Hotkey, %DownKey%, MoveDown, On Hotkey, %exitEmulatorKey2%, selectItem, On Hotkey, %exitEmulatorKey3%, selectItem, On } else { Gosub CreatePauseScreen Hotkey, $%exitEmulatorKey2%, CloseVP, On Hotkey, $%exitEmulatorKey3%, CloseVP, On } } Else { ; exiting pause menu Paused = 0 if (useExitMenu = "true") { Gosub ExitMenu ; close menus Hotkey, %UpKey%, Off Hotkey, %DownKey%, Off Hotkey, %exitEmulatorKey2%, Off Hotkey, %exitEmulatorKey3%, Off } else { Gui, Destroy Hotkey, $%exitEmulatorKey2%, Off Hotkey, $%exitEmulatorKey3%, Off } WinActivate, ahk_class VPPlayer,,DMD } return PauseGame: ; call vp of fp pause toLog("PauseGame Called") if (systemName = "Visual Pinball") GoSub, PauseVP else if (systemName = "Future Pinball") GoSub, PauseFP Return ShowFP: ; close player and show editor on edit key toLog("ShowFP Called") if (Paused = 1) Gosub PauseFP WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {Esc} WinWaitClose, ahk_class FuturePinballOpenGL WinShow, ahk_class FuturePinball WinRestore, ahk_class FuturePinball WinActivate, ahk_class FuturePinball WinWaitActive, ahk_class FuturePinball SystemCursor("On") WinShow, ahk_class Shell_TrayWnd WinShow, Start ahk_class Button taskbar = 1 Suspend, On MouseMove 200,200 WinWait, ahk_class FuturePinballOpenGL Suspend, Off SystemCursor("Off") WinHide, ahk_class Shell_TrayWnd WinHide, Start ahk_class Button taskbar = 0 WinHide, ahk_class FuturePinball WinMinimize, ahk_class FuturePinball WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL return ShowVP: ; close player and show editor on edit key toLog("ShowVP Called") if (Paused = 1) Gosub PauseVP WinActivate, ahk_class VPPlayer,,DMD WinWaitActive, ahk_class VPPlayer WinClose, ahk_class VPPlayer WinWaitClose, ahk_class VPPlayer WinShow, ahk_class VPinball WinRestore, ahk_class VPinball WinActivate, ahk_class VPinball WinWaitActive, ahk_class VPinball SystemCursor("On") WinShow ahk_class Shell_TrayWnd WinShow Start ahk_class Button taskbar = 1 Suspend, On MouseMove 200,200 WinWait, ahk_class VPPlayer Suspend, Off SystemCursor("Off") WinHide, ahk_class Shell_TrayWnd WinHide, Start ahk_class Button taskbar = 0 ;WinHide, ahk_class VPinball WinMinimize, ahk_class VPinball WinWaitActive, ahk_class VPPlayer ;WinActivate, ahk_class TBackglass ;WinActivate, ahk_class MAME ;WinActivate, ahk_class VPPlayer return ShowGame: ; show vp or fp toLog("ShowGame Called") if (systemName = "Visual Pinball") GoSub, ShowVP else if (systemName = "Future Pinball") GoSub, ShowFP Return SetSaveFPNeeded: ; set flag to save fp table on exit toLog("SetSaveFPNeeded Called") saveFPNeeded = true Send {ScrollLock} return CloseFP: toLog("CloseFP Called") ;close all gui's except black screen (gui 9) Loop, 3 Gui, %A_Index%: Destroy ;hide and minimize fp editor WinHide, ahk_class FuturePinball WinMinimize, ahk_class FuturePinball ;Future Pinball must be closed this way instead of killing process ;or it wil not save your last game information.i.e score/credtis WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {Esc} WinWaitClose, ahk_class FuturePinballOpenGL ;saving fp table position, black screen hides fp window if (saveFPTables = "true") and (saveFPNeeded = "true") { ;WinRestore, ahk_class FuturePinball WinActivate, ahk_class FuturePinball WinWaitActive, ahk_class FuturePinball WinMenuSelectItem, ahk_class FuturePinball,,File,Save Sleep, 1000 } WinClose, ahk_class FuturePinball WinWaitClose, ahk_class FuturePinball GoSub, ExitScript return CloseVP: toLog("CloseVP Called") Hotkey, %exitScriptKey%, Off GoSub rosveClose ;Visual Pinball must be closed this way instead of killing process ;or it wil not save your last game information.i.e score/credtis DetectHiddenWindows on ;Or next line will not work Loop, 4 Gui, %A_Index%: Destroy ;This line fixes where the VP Window flashes real quick ;when closing the window for a cleaner exit ; win hide removed cause vp should be minimized, not hidden ;WinHide, ahk_class VPinball ;WinShow, ahk_class VPinball WinMinimize, ahk_class VPinball WinClose, ahk_class VPinball WinWaitClose ahk_class VPinball GoSub bigbossClose GoSub, ExitScript return CloseGame: toLog("CloseGame Called") if (systemName = "Visual Pinball") GoSub, CloseVP else if (systemName = "Future Pinball") GoSub, CloseFP Return ;----------------------------------Exit Menu-----------------------------------; ExitMenu: toLog("ExitMenu Called") If (instructionsOn = 1) ; close instruction card Gosub Instructions Else If (flyerOn = 1) ; close flyer Gosub Flyer Else If (Paused = 1) { ; show menus SoundPlay menu.wav menuOn = 1 menuItem = 1 serviceMenuOn = 0 DMDon = 0 Gui, 2: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 2: Show, Hide hwExitInfo := WinExist() Gui, 2: +Lastfound WinActivate exitInfoPic = %picDir%exitMenu1b.png iBitmap := Gdip_CreateBitmapFromFile(exitInfoPic) iWidth := Gdip_GetImageWidth(iBitmap), iHeight := Gdip_GetImageHeight(iBitmap) ;If (Playfield_Rotation = 90) Or (Playfield_Rotation = 270) { iscale := A_ScreenHeight/iWidth sWidth := A_ScreenHeight+1, sHeight := iHeight*iscale yExitInfo := -1 ;} Gdip_GetRotatedDimensions(sWidth, sHeight, Playfield_Rotation, brWidth, brHeight) Gdip_GetRotatedTranslation(sWidth, sHeight, Playfield_Rotation, xTranslation, yTranslation) xExitInfo := A_ScreenWidth-brWidth+1 ihbm := CreateDIBSection(brWidth, brHeight) ihdc := CreateCompatibleDC() iobm := SelectObject(ihdc, ihbm) iG := Gdip_GraphicsFromHDC(ihdc) Gdip_TranslateWorldTransform(iG, xTranslation, yTranslation) Gdip_RotateWorldTransform(iG, Playfield_Rotation) Gdip_SetCompositingMode(iG, 1) Gdip_SetInterpolationMode(iG, 7) Gdip_DrawImage(iG, iBitmap, -1, -1, sWidth+2, sHeight+2, 0, 0, iWidth, iHeight) Gdip_DisposeImage(iBitmap) UpdateLayeredWindow(hwExitInfo, ihdc, xExitInfo, yExitInfo, brWidth, brHeight) Gui, 1: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 1: Show, Hide, ExitMenu hwExit := WinExist() Gui, 1: +Lastfound Winactivate exitmenuPic = %picDir%exitMenu1.png pBitmap := Gdip_CreateBitmapFromFile(exitMenuPic) pWidth := Gdip_GetImageWidth(pBitmap), pHeight := Gdip_GetImageHeight(pBitmap) pscale := ((A_ScreenHeight*hyperScale)/pWidth) dWidth := pWidth*pscale, dHeight := pHeight*pscale Gdip_GetRotatedDimensions(dWidth, dHeight, Playfield_Rotation, rWidth, rHeight) Gdip_GetRotatedTranslation(dWidth, dHeight, Playfield_Rotation, xMTranslation, yMTranslation) xExitM := (A_ScreenWidth-rWidth)/2, yExitM := (A_ScreenHeight-rHeight)/2 hbm := CreateDIBSection(rWidth, rHeight) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_TranslateWorldTransform(G, xMTranslation, yMTranslation) Gdip_RotateWorldTransform(G, Playfield_Rotation) Gdip_SetCompositingMode(G, 1) Gdip_SetInterpolationMode(G, 7) Gdip_DrawImage(G, pBitmap, 0, 0, dWidth, dHeight, 0, 0, pWidth, pHeight) Gdip_DisposeImage(pBitmap) UpdateLayeredWindow(hwExit, hdc, xExitM, yExitM, rWidth, rHeight) Gosub PinEmHiScore Gui, 1:Show Gui, 2:Show } Else { ; close menus SoundPlay menu.wav menuOn = 0 serviceMenuOn = 0 DMDon = 0 GoSub closeMenus if (systemName = "Future Pinball") { Gui, 9: Destroy WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} } } Return closeMenus: toLog("closeMenus Called") Gdip_SetCompositingMode(G, 0) SelectObject(hdc, obm) DeleteObject(hbm) DeleteDC(hdc) Gdip_DeleteGraphics(G) Gdip_DisposeImage(pBitmap) Gdip_SetCompositingMode(iG, 0) SelectObject(ihdc, iobm) DeleteObject(ihbm) DeleteDC(ihdc) Gdip_DeleteGraphics(iG) Gdip_DisposeImage(iBitmap) Gui 6:Destroy Gui 5:Destroy Gui 4:Destroy Gui 3:Destroy Gui 2:Destroy Gui 1:Destroy return MenuSwap: toLog("MenuSwap Called") ;SoundPlay menu.wav If menuItem = 0 menuItem = 5 If menuItem = 6 menuItem = 1 If (serviceMenuOn = 0) { ; main menu exitmenuPic = %picDir%exitMenu%menuItem%.png exitInfoPic = %picDir%exitMenu%menuItem%b.png toLog("Exit Menu Swapped - Item " . menuItem) } Else If (serviceMenuOn = 1) { ; service menu exitmenuPic = %picDir%serviceMenu%menuItem%.png exitInfoPic = %picDir%serviceMenu%menuItem%b.png toLog("service Menu Swapped - Item " . menuItem) } pBitmap := Gdip_CreateBitmapFromFile(exitMenuPic) iBitmap := Gdip_CreateBitmapFromFile(exitInfoPic) Gdip_DrawImage(G, pBitmap, 0, 0, dWidth, dHeight, 0, 0, pWidth, pHeight) Gdip_DrawImage(iG, iBitmap, 0, 0, sWidth, sHeight, 0, 0, iWidth, iHeight) Gdip_DisposeImage(pBitmap) Gdip_DisposeImage(iBitmap) UpdateLayeredWindow(hwExit, hdc, xExitM, yExitM, rWidth, rHeight) UpdateLayeredWindow(hwExitInfo, ihdc, xExitInfo, yExitInfo, brWidth, brHeight) clear("exitmenuPic,exitInfoPic") Return selectItem: toLog("selectItem Called") If (serviceMenuOn = 0) { ; main menu If (menuItem = 1) { ; close menu Gosub %exitmeth% } Else If (menuItem = 2) { ; instructions ;Gosub %exitmeth% toLog("Exit Menu Closed - Instructions") Gosub Instructions } Else If (menuItem = 3) { ; flyer ;Gosub %exitmeth% toLog("Exit Menu Closed - Flyer") Gosub Flyer } Else If (menuItem = 4) { ; service menu SoundPlay menu.wav serviceMenuOn = 1 menuItem = 1 toLog("Exit Menu Swapped - Service") Gosub MenuSwap } Else If (menuItem = 5) { ; exit Gosub %exitmeth% toLog("Exit Menu Closed - CloseGame") Goto CloseGame } } Else If (serviceMenuOn = 1) { ; service menu If (menuItem = 1) { ; back serviceMenuOn = 0 toLog("Service Menu Swapped - Exit") Gosub MenuSwap } Else If (menuItem = 2) { ; reset vp - send f3 Gosub %exitmeth% toLog("Service Menu Closed - F3") toLog("Attempting to reset Visual Pinball") If (systemName = "Visual Pinball") { Send {F3 down} Sleep 100 Send {F3 up} } } Else If (menuItem = 3) { ; resize fp - send scroll lock in case you don't have one Gosub %exitmeth% toLog("Service Menu Closed - Size FP") If (systemName = "Future Pinball") { Send {ScrollLock down} Sleep 100 Send {ScrollLock up} } } Else If (menuItem = 4) { ; focus - not tested!!! wip wip wip wip - should be a function ; should be executed on every exit from menu - not just here ; (if it is needed - if it is not it can be removed from menu) Gosub %exitmeth% toLog("Service Menu Closed - Focus Windows") If (systemName = "Visual Pinball") { toLog("Attempting to Focus Visual Pinball") DetectHiddenWindows off IfWinExist, Ahk_Class MAME { WinActivate, Ahk_Class MAME WinWaitActive, Ahk_Class MAME,,2 ControlClick,, Ahk_Class MAME toLog("Attempting to Focus Visual Pinball DMD") } DetectHiddenWindows on WinSet, Bottom, ,Form1 WinSet, Bottom, ,HGlass1 WinActivate, Ahk_Class VPPlayer,,DMD WinWaitActive, Ahk_Class VPPlayer,,2 ControlClick, X5 Y5, Ahk_Class VPPlayer,,,,,DMD } Else If (systemName = "Future Pinball") { toLog("Attempting to Focus Future Pinball") WinActivate, Ahk_Class FuturePinballOpenGLSecondary WinWaitActive, Ahk_Class FuturePinballOpenGLSecondary,,2 toLog("Attempting to Focus Future Pinball DMD") WinActivate, Ahk_Class FuturePinballOpenGL WinWaitActive, Ahk_Class FuturePinballOpenGL,,2 } } Else If (menuItem = 5) { ; go to editor Gosub %exitmeth% toLog("Service Menu Closed - Drop to Editor") If (systemName = "Visual Pinball") Gosub ShowVP Else If (systemName = "Future Pinball") Gosub ShowFP } } Return ;------------------------------End of exitmenu -------------------------------; ;----------------------------------Flyer---------------------------------------; Flyer: SoundPlay menu.wav toLog("Flyer Called") If (flyerOn = 0) { ; show flyer If (menuOn = 0) And (instructionsOn = 0) And (systemName = "Future Pinball") { WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} WinWaitActive, ahk_class FuturePinballOpenGL Gosub CreateBlackScreen ; we draw printscreen first } If (menuOn = 1) Gosub closeMenus flyerOn = 1 paused = 1 instructionsOn = 0 toLog("Flyer Create") ; put hotkeys in a sub !!! Hotkey, %UpKey%, MoveUp, On Hotkey, %DownKey%, MoveDown, On ; start and plunger will close flyer Hotkey, %exitEmulatorKey2%, %exitmeth%, On Hotkey, %exitEmulatorKey3%, %exitmeth%, On ; show footer first, then flyer ; show footer image in gui 2 flyerInfoPic = %picDir%flyerb.png iBitmap := Gdip_CreateBitmapFromFile(flyerInfoPic) Gdip_ImageRotateFlip(iBitmap,3) ; rotate image for 270° iWidth := Gdip_GetImageWidth(iBitmap) iHeight := Gdip_GetImageHeight(iBitmap) iScale := A_ScreenHeight/iHeight tWidth := iWidth*iScale tHeight := A_ScreenHeight Gui, 2: Show,, Footer DrawImageBTB(2, iBitmap, iWidth, iHeight, tWidth, tHeight, A_ScreenWidth-tWidth+1, 0, 1) ; show flyer in gui 1 Gosub flyerSwap ;msgbox } Else { ; kill flyer flyerOn = 0 menuOn = 0 serviceMenuOn = 0 paused = 0 toLog("Flyer Close") Hotkey, %UpKey%, Off Hotkey, %DownKey%, Off Hotkey, %exitEmulatorKey2%, Off Hotkey, %exitEmulatorKey3%, Off Gui, 2: Destroy Gui, 1: Destroy ; wip wip wip wip !!!!! one unique focus function!!! IfWinExist, Visual Pinball Player,, DMD { WinActivate ControlClick,, Ahk_Class VPPlayer ;WinSet, Bottom, ,Form1 ;send to back b2s backglass so mame dmd is on top ;ahk_class is impossibly long! ;WinSet, Bottom, ,HGlass1 ;then backglass image from hyperpin as above ;ahk_class ThunderRT6FormDC clashes with HyperPin } Else IfWinExist, Ahk_Class FuturePinballOpenGL { If (systemName = "Future Pinball") { Gui, 9: Destroy WinActivate, Ahk_Class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} } } toLog("Flyer Closed") } Return MoveUp: ; used for exitmenu as well, probably will be used for instr. also SoundPlay menu.wav toLog("MoveUp Called") If (flyerOn = 1) { flyer-- Gosub flyerSwap ;Gui, 1: Show } Else If (instructionsOn = 1) { instr-- Gosub instrSwap } Else If (menuOn = 1) { menuItem-- Gosub MenuSwap } Return MoveDown: ; used for exitmenu as well, probably will be used for instr. also SoundPlay menu.wav toLog("MoveDown Called") If (flyerOn = 1) { flyer++ Gosub flyerSwap ;Gui, 1: Show } Else If (instructionsOn = 1) { sleep 1 instr++ Gosub instrSwap } Else If (menuOn = 1) { menuItem++ Gosub MenuSwap } Return flyerSwap: toLog("flyerSwap Called") If (flyer = 0) { flyer := flyerpages if (flyerpages = 1) return } If (flyer > flyerpages) { flyer = 1 if (flyerpages = 1) return } flyerPic := flyerPic%flyer% pBitmap := Gdip_CreateBitmapFromFile(flyerPic) Gdip_ImageRotateFlip(pBitmap,3) ; rotate image for 270° OriginalWidth := Gdip_GetImageWidth(pBitmap) OriginalHeight := Gdip_GetImageHeight(pBitmap) Ratio := OriginalWidth/OriginalHeight ; we want flyer to be as big as possible if (OriginalWidth/(A_ScreenWidth*0.8) >= OriginalHeight/(A_ScreenHeight*0.96)) { Width := A_ScreenWidth*0.8 Height := Width*(1/Ratio) } else { Height := A_ScreenHeight*0.96 Width := Height*Ratio } xCoo := (A_ScreenWidth*0.85-Width)//2 yCoo := (A_ScreenHeight-Height)//2 Gui, 1: Show,, Flyer DrawImageBTB(1, pBitmap, OriginalWidth, OriginalHeight, Width, Height, xCoo, yCoo, 0) ;Gui, 2: Show ;Gui, 1: Show toLog("Flyer Page Turned") Return ;--------------------------------End of flyer----------------------------------; ;-----------------------------Instruction Cards--------------------------------; Instructions: SoundPlay menu.wav toLog("Instructions Called") If (instructionsOn = 0) { ; show instructions If (menuOn = 0) And (flyerOn = 0) And (systemName = "Future Pinball") { ; no menus, print screen and send pause ; put this in sub !!! WinActivate, ahk_class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} WinWaitActive, ahk_class FuturePinballOpenGL Gosub CreateBlackScreen ; we draw printscreen first } If (menuOn = 1) Gosub closeMenus instructionsOn = 1 paused = 1 flyerOn = 0 toLog("Instruction Card Create") ;Gui, 2: Destroy Hotkey, %UpKey%, MoveUp, On Hotkey, %DownKey%, MoveDown, On ; start and plunger will close instructions Hotkey, %exitEmulatorKey2%, %exitmeth%, On Hotkey, %exitEmulatorKey3%, %exitmeth%, On ; show footer first, then instructions ; show footer image in gui 2 flyerInfoPic = %picDir%instructb.png iBitmap := Gdip_CreateBitmapFromFile(flyerInfoPic) Gdip_ImageRotateFlip(iBitmap,3) ; rotate image for 270° iWidth := Gdip_GetImageWidth(iBitmap) iHeight := Gdip_GetImageHeight(iBitmap) iScale := A_ScreenHeight/iHeight tWidth := iWidth*iScale tHeight := A_ScreenHeight Gui, 2: Show,, Footer DrawImageBTB(2, iBitmap, iWidth, iHeight, tWidth, tHeight, A_ScreenWidth-tWidth+1, 0, 1) ; show instr in gui 1 Gosub instrSwap } Else { ; hide instructions instructionsOn = 0 menuOn = 0 serviceMenuOn = 0 paused = 0 toLog("Instruction Card Close") ; up and down not needed for now (it will be after we extend instructions) Hotkey, %UpKey%, Off Hotkey, %DownKey%, Off Hotkey, %exitEmulatorKey2%, Off Hotkey, %exitEmulatorKey3%, Off Gui, 2: Destroy Gui, 1: Destroy ; wip wip wip wip wip focus code should be subroutine !!! IfWinExist, Visual Pinball Player,, DMD { WinActivate ; winactivate what??? WinWaitActive, Ahk_Class VPPlayer,,2 ControlClick, X5 Y5, Ahk_Class VPPlayer,,,,,DMD } Else IfWinExist, Ahk_Class FuturePinballOpenGL { If (systemName = "Future Pinball") { Gui, 9: Destroy WinActivate, Ahk_Class FuturePinballOpenGL WinWaitActive, ahk_class FuturePinballOpenGL Send {%pauseFPKey%} } WinActivate, Ahk_Class FuturePinballOpenGL } toLog("Instruction Card Closed") } Return instrSwap: toLog("instrSwap Called") If (instr = 0) { instr := instrpages if (instrpages = 1) return } If (instr > instrpages) { instr = 1 if (instrpages = 1) return } instrPic := instrPic%instr% StringRight, ending, instrPic, 3 if (ending = "swf") { ; we have swf image Width := A_ScreenHeight*0.95 Height := A_ScreenHeight*0.95 SysGet, VirtualWidth, 78 SysGet, VirtualHeight, 79 ;Gui, 1: Destroy Gui, 1: +LastFound -Caption +AlwaysOnTop -SysMenu +E0x80000 Gui, 1: Show, w%Width% h%Height% x%VirtualWidth% y%VirtualHeight%, Instruction Card ;Gui, 1: Margin, 0 ,0 ;Gui, 1: Color, EEAA99 ;Gui, 1: Add, ActiveX, w%Width% h%Height% vpwb, ShockwaveFlash.ShockwaveFlash Gui, 1: +LastFound WinActivate getInstructFromDisk = %instrPic% ;pwb.wmode := "direct" ;window/opaque/direct/transparent/gpu ;pwb.scale := "Default" ;noborder/default/exactfit/noscale ;pwb.bgcolor := "#EEAA99" ;pwb.Movie := "file:///" . getInstructFromDisk SwfWnd := WinExist() hCtrl := COM_AtlAxCreateContainer(SwfWnd, 0, 0, Width, Height) COM_AtlAxAttachControl(psf := COM_ActiveXObject("{D27CDB6E-AE6D-11cf-96B8-444553540000}"), hCtrl) COM_Invoke(psf, "Menu=", "0") COM_Invoke(psf, "Movie=", "file:///" . getInstructFromDisk) COM_Invoke(psf, "bgcolor=", "#EEAA99") pBitmap := Gdip_BitmapFromHWND(SwfWnd) ;Gdip_GetRotatedDimensions(Width, Height, Playfield_Rotation, rWidth, rHeight) Gdip_GetRotatedTranslation(Width, Height, Playfield_Rotation, xTranslation, yTranslation) hbm := CreateDIBSection(Width,Height) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc), Gdip_SetInterpolationMode(G, 7) Gdip_TranslateWorldTransform(G, xTranslation, yTranslation) Gdip_RotateWorldTransform(G, Playfield_Rotation) Gdip_DrawImage(G, pBitmap, 0, 0, Width, Height, 0, 0, Width, Height) pBitmapOut := Gdip_CreateBitmap(Width, Height) E := Gdip_BitmapReplaceColor(pBitmap, pBitmapOut, 0xFFEEAA99, 0x00000000, 1) Gdip_GraphicsClear(G) ;make note of this - prob needs to be added to Menu And countdown Gdip_DrawImage(G, pBitmapOut) Gdip_DisposeImage(pBitmap) Gdip_ResetWorldTransform(G) Gdip_DisposeImage(pBitmapOut) UpdateLayeredWindow(SwfWnd, hdc, (A_ScreenWidth-Width)//2, (A_ScreenHeight-Height)//2, Width, Height) SelectObject(hdc, obm) DeleteObject(hbm) DeleteDC(hdc) Gdip_DeleteGraphics(G) COM_Release(psf) } Else { ; show instructions not found or some other image ; new flyer code pBitmap := Gdip_CreateBitmapFromFile(instrPic) Gdip_ImageRotateFlip(pBitmap,3) ; rotate image for 270° OriginalWidth := Gdip_GetImageWidth(pBitmap) OriginalHeight := Gdip_GetImageHeight(pBitmap) Ratio := OriginalWidth/OriginalHeight ; we want instr to be as big as possible if (OriginalWidth/(A_ScreenWidth*0.8) >= OriginalHeight/(A_ScreenHeight*0.96)) { Width := A_ScreenWidth*0.8 Height := Width*(1/Ratio) } else { Height := A_ScreenHeight*0.96 Width := Height*Ratio } xCoo := (A_ScreenWidth*0.85-Width)//2 yCoo := (A_ScreenHeight-Height)//2 Gui, 1: Show,, instr DrawImageBTB(1, pBitmap, OriginalWidth, OriginalHeight, Width, Height, xCoo, yCoo, 0) ;Gui, 2: Show ;Gui, 1: Show } toLog("instr Page Turned") Return ;---------------------------End of instruction card----------------------------; ; draw image by the book - destroys bitmap also DrawImageBTB(guiNum, pBitmap, origWidth, origHeight, tgtWidth, tgtHeight, xCoo=0, yCoo=0, CompMode=0) { toLog("DrawImageBTB Called") ;Gui, %guiNum%: Show, Hide, Flyer Gui, %guiNum%: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, %guiNum%: Show hwnd1 := WinExist() ; why is this ??? ;Gui, 1: +LastFound ;WinActivate ; no need for bitmap since we have it already ; if we need to rotate bitmap calling script can to it also ;pBitmap := Gdip_CreateBitmapFromFile("background.png") ;Width := Gdip_GetImageWidth(pBitmap), Height := Gdip_GetImageHeight(pBitmap) hbm := CreateDIBSection(tgtWidth, tgtHeight) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_SetCompositingMode(G, CompMode) Gdip_SetInterpolationMode(G, 7) Gdip_DrawImage(G, pBitmap, 0, 0, tgtWidth, tgtHeight, 0, 0, origWidth, origHeight) UpdateLayeredWindow(hwnd1, hdc, xCoo, yCoo, tgtWidth, tgtHeight) SelectObject(hdc, obm) DeleteObject(hbm) DeleteDC(hdc) Gdip_DeleteGraphics(G) Gdip_DisposeImage(pBitmap) } ;------------------- "External" functions ------------------- ; rosve support for B2S active backglasses rosve: toLog("rosve Called") ;-------------------------------------------------------------- ;------ check if an active backglass shall be started ----- ;-------------------------------------------------------------- StringRight, ending, tableName, 3 if (ending = "B2S") { Run, %tablePath%%tableName%.exe, %tablePath% sleep 200 } return rosveClose: toLog("rosveClose Called") ; rosve ; -------------------------------------------------------------- ; --- Close the animated backglass ----------------------- ; -------------------------------------------------------------- ; b2s close bug fix StringRight, ending, tableName, 3 if (ending = "B2S") { WinKill, Form1 } return ; bigboss support for different exe, sound levels and hdrender off bigboss: toLog("bigboss Called") ; bigboss ; Array examples: http://www.autohotkey.com/docs/misc/Arrays.htm ; Read config file for vp9.08 tables vp908count = 0 ; This loop retrieves each line from the file, one at a time. Loop, Read, %A_ScriptDir%\Settings\vp908tables.txt { vp908count += 1 ; Keep track of how many items are in the array. vp908array%vp908count% := A_LoopReadLine ; Store this line in the next array element. } ; Check if table is in the vp908tables array. Loop %vp908count% { ; The following line uses the := operator to retrieve an array element: element := vp908array%A_Index% ; A_Index is a built-in variable. if(tableName = element) { TableIndex = %A_Index% vpExeIndex = %TableIndex% vpExeIndex += 1 executable := vp908array%vpExeIndex% break } } ; Read config file for disable HD rendering tables since this is a global setting now. HDRenderOffCount = 0 HDRenderOffChanged = 0 ; This loop retrieves each line from the file, 1 at a time. Loop, Read, %A_ScriptDir%\Settings\hdrenderofftables.txt { HDRenderOffCount += 1 ; Keep track of how many items are in the array. HDRenderOffArray%HDRenderOffCount% := A_LoopReadLine ; Store this line in the next array element. } ; Check if table is in the no hdrender array and write the VP hardwarerender key to off. Loop %HDRenderOffCount% { ; The following line uses the := operator to retrieve an array element: element := HDRenderOffArray%A_Index% ; A_Index is a built-in variable. if(tableName = element) { HDRenderOffChanged = 1 RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Visual Pinball\Player, HardwareRender, 0 break } } ; Read config for sound volume hard codes SoundModCount = 0 SoundChangeAmount = 0 Loop, Read, %A_ScriptDir%\Settings\soundmodtables.txt { SoundModCount += 1 SoundModCountArray%SoundModCount% := A_LoopReadLine } ; Check if table is in the vp908tables array. Loop %SoundModCount% { ; The following line uses the := operator to retrieve an array element: TableIndex = %A_Index% SoundIndex = %TableIndex% SoundIndex += 1 TheTable := SoundModCountArray%TableIndex% TheSoundAmount := SoundModCountArray%SoundIndex% if(tableName = TheTable) { ; Set the new sound change amount. Should be a + or - number otherwise it needs a , SoundSet, absoluteamt ; SoundSet: http://www.autohotkey.com/docs/commands/SoundSet.htm ; SoundGet: http://www.autohotkey.com/docs/commands/SoundGet.htm ;SoundSet, %TheSoundAmount% Send {Volume_Down %TheSoundAmount%} break } } return bigbossClose: toLog("bigbossClose Called") ; bigboss ; Restore hdrender original value if (HDRenderOffChanged) RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Visual Pinball\Player, HardwareRender, 1 ; Restore master volume original value if (TheSoundAmount) Send {Volume_Up %TheSoundAmount%} return ; big boss slamit bigscore support SlamitBigScore: toLog("SlamitBigScore Called") Hotkey, $%exitEmulatorKey%, CloseSlam ;setworkingdir, "..\SlamIt\BigScore.exe" Run, "..\slamit\go.bat", "..\SlamIt" WinWait, ahk_class SlamIt Pinball - Big Score Gui, destroy Process, WaitClose, BigScore.exe goto ExitScript return CloseSlam: toLog("CloseSlam Called") WinClose, ahk_class SlamIt Pinball - Big Score goto ExitScript return PinEmHiScore: ; show hiscores on screen Fileread, contents,hiscore.txt ;msgbox %tablename% ;pToken := Gdip_Startup() ;Gui, Destroy ;vertical distance of Hiscore window HiScoreTopDistance := 10 ;Gui 4 - hidden horizontal Gui Gui, 4: Color, 0b40e4 Gui, 4: Font, s15, Quartz Gui, 4: Add, Text, Cffffff Center, %contents% Gui, 4: +AlwaysOnTop -Caption +Lastfound hwnd := WinExist() Gui, 4: Show, NA, hiscoreshidden WinGetPos,scorex,scorey, scorew, scoreh, ahk_id %hwnd% pBitmap := Gdip_BitmapFromScreen("hwnd:" hwnd) Gui, 4: Show, Hide ;Gui 5 - hiscore background image imageW := scoreh+20, imageH := scorew+40 Gui, 5: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 5: Show, NA, hiscoresback hwnd1 := WinExist() shbm := CreateDIBSection(imageW, imageH) shdc := CreateCompatibleDC() sobm := SelectObject(shdc, shbm) sG := Gdip_GraphicsFromHDC(shdc) Gdip_SetSmoothingMode(sG, 4) pBrush1 := Gdip_BrushCreateSolid(0xff0ffffff) pBrush2 := Gdip_BrushCreateSolid(0xff00C32A5) pBrush3 := Gdip_BrushCreateSolid(0xff0b40e4) Gdip_FillRoundedRectangle(sG, pBrush1, 0, 0, imageW, imageH, 20) Gdip_FillRoundedRectangle(sG, pBrush2, 5, 5, imageW-10, imageH-10, 15) Gdip_FillRoundedRectangle(sG, pBrush3, 10, 10, imageW-20, imageH-20, 10) Gdip_DeleteBrush(pBrush1) Gdip_DeleteBrush(pBrush2) Gdip_DeleteBrush(pBrush3) UpdateLayeredWindow(hwnd1, shdc, HiScoreTopDistance, (A_ScreenHeight-imageH)//2, imageW, imageH) SelectObject(shdc, sobm) DeleteObject(shbm) DeleteDC(shdc) Gdip_DeleteGraphics(sG) ;Gui 6 - rotated vertical Gui Gui, 6: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 6: Show, NA, hiscores hwnd2 := WinExist() bitmapW := scoreh, bitmapH := scoreW shbm := CreateDIBSection(bitmapW, bitmapH) shdc := CreateCompatibleDC() sobm := SelectObject(shdc, shbm) sG := Gdip_GraphicsFromHDC(shdc) UpdateLayeredWindow(hwnd2, shdc, HiScoreTopDistance+10, (A_ScreenHeight-bitmapH)//2, bitmapW, bitmapH) Gdip_ImageRotateFlip(pBitmap, 3) Gdip_DrawImage(sG, pBitmap) UpdateLayeredWindow(hwnd2, shdc) Gdip_DisposeImage(pBitmap) SelectObject(shdc, sobm) DeleteObject(shbm) DeleteDC(shdc) Gdip_DeleteGraphics(sG) Return ;------------------- End of External functions ------------------- ExitScript: toLog("ExitScript Called") ExitApp return onExitScript: toLog("onExitScript Called") if (ledwiz = "true") Run, "%A_ScriptDir%\ledset.bat",,hide Gdip_Shutdown(pToken) toLog("GDI+ Unloaded") COM_AtlAxWinTerm() COM_CoUninitialize() COM_Term() toLog("COM Unloaded") Loop, 5 Gui, %A_Index%: Destroy if (hideCursor = "true") SystemCursor("On") Process, Exist, %hyperpinexe% PID := errorLevel if (PID) { ; activate hyperpin ;WinActivate, ahk_pid %PID% ;ExitApp loading = 1 waithp: toLog("waithp 1") if (loading = 0) break Sleep 400 WinActivate, ahk_pid %PID% ;MouseMove %A_ScreenWidth%/2, %A_ScreenHeight%/2 ;ControlClick,, ahk_pid %PID% Sleep 400 IfWinNotActive, ahk_pid %PID% Goto waithp toLog("waithp 2") Sleep 400 IfWinNotActive, ahk_pid %PID% Goto waithp toLog("waithp 3") Sleep 400 IfWinNotActive, ahk_pid %PID% Goto waithp } else if (hideTaskbar = "true") { ; show taskbar if there is no hyperpin WinShow ahk_class Shell_TrayWnd WinShow Start ahk_class Button taskbar = 1 } ; show cursor SystemCursor("On") ;to debug script uncomment the pause ;Pause ; final exit toLog("Exiting...") ;Run, "cscript %A_ScriptDir%\FPClose.vbs",,hide ExitApp return ;------------------------------------------------------------------------------; ; REST OF SCRIPT ; ;------------------------------------------------------------------------------; ;************PROBABLY DO NOT NEED TO EDIT THIS AREA************* SystemCursor(OnOff=1) ; INIT = "I","Init"; OFF = 0,"Off"; TOGGLE = -1,"T","Toggle"; ON = others { ListLines Off static AndMask, XorMask, $, h_cursor ,c0,c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c11,c12,c13 ; system cursors , b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13 ; blank cursors , h1,h2,h3,h4,h5,h6,h7,h8,h9,h10,h11,h12,h13 ; handles of default cursors if (OnOff = "Init" or OnOff = "I" or $ = "") ; init when requested or at first call { $ = h ; active default cursors VarSetCapacity( h_cursor,4444, 1 ) VarSetCapacity( AndMask, 32*4, 0xFF ) VarSetCapacity( XorMask, 32*4, 0 ) system_cursors = 32512,32513,32514,32515,32516,32642,32643,32644,32645,32646,32648,32649,32650 StringSplit c, system_cursors, `, Loop %c0% { h_cursor := DllCall( "LoadCursor", "uint",0, "uint",c%A_Index% ) h%A_Index% := DllCall( "CopyImage", "uint",h_cursor, "uint",2, "int",0, "int",0, "uint",0 ) b%A_Index% := DllCall("CreateCursor","uint",0, "int",0, "int",0 , "int",32, "int",32, "uint",&AndMask, "uint",&XorMask ) } } if (OnOff = 0 or OnOff = "Off" or $ = "h" and (OnOff < 0 or OnOff = "Toggle" or OnOff = "T")) $ = b ; use blank cursors else $ = h ; use the saved cursors Loop %c0% { h_cursor := DllCall( "CopyImage", "uint",%$%%A_Index%, "uint",2, "int",0, "int",0, "uint",0 ) DllCall( "SetSystemCursor", "uint",h_cursor, "uint",c%A_Index% ) } if (gListLines) ListLines %gListLines% } ToggleCursor: SystemCursor("Toggle") Gosub ToggleTaskbar return ToggleTaskbar: if (hideTaskbar = "true") { if (taskbar) { ; taskbar is shown WinHide ahk_class Shell_TrayWnd WinHide Start ahk_class Button taskbar = 0 } else { WinShow ahk_class Shell_TrayWnd WinShow Start ahk_class Button taskbar = 1 } } return IniRead(Filename, Section, Key, Default = "") { FileRead, text, *t %Filename% text = `n%text%`n StringTrimLeft, text, text, InStr(text, "`n[" . Section . "]`n") Loop, 8 { sp := sp . " " StringReplace, text, text, %Key%%sp%=, %Key%= If ErrorLevel Break } start := InStr(text, "`n" . Key . "=") If !start Return, Default start += StrLen(Key) + 2 StringMid, Value, text, start, InStr(text, "`n", false, start) - start Return, Value } ini_getValue(ByRef _Content, _Section, _Key, _PreserveSpace = False) { If (_Section = "") _Section = (?:\[.*])? Else { _Section = \[\s*?\Q%_Section%\E\s*?] } ; Note: The RegEx of this Function was rewritten by Mystiq. RegEx = `aiU)(?:\R|^)\s*%_Section%\s*(?:\R\s*|\R\s*.+\s*=\s*.*?\s*(?=\R)|\R\s*[;#].*?(?=\R))*\R\s*\Q%_Key%\E\s*=(.*)(?=\R|$) If RegExMatch(_Content, RegEx, Value) { If Not _PreserveSpace { Value1 = %Value1% ; Trim spaces. FirstChar := SubStr(Value1, 1, 1) If (FirstChar = """" And SubStr(Value1, 0, 1)= """" Or FirstChar = "'" And SubStr(Value1, 0, 1)= "'") { StringTrimLeft, Value1, Value1, 1 StringTrimRight, Value1, Value1, 1 } } ErrorLevel = 0 } Else { ErrorLevel = 1 Value1 = } Return Value1 } ;Get Full Path from Relative Path GetFullName( fn ) { static buf, i if !i i := VarSetCapacity(buf, 512) DllCall("GetFullPathNameA", "str", fn, "uint", 512, "str", buf, "str*", 0) return buf } CheckINI: IfNotExist, %hyperini% { MsgBox,48,Error,Cannot Find %hyperini%,6 hyperpinexe = hyperpin.exe Goto ExitScript } ; check images ;for i in %picini% ... ; check com and gdi libs return CheckPaths: romFound = StringRight, emuPathBackSlash, EmuPath, 1 StringRight, tablePathBackSlash, TablePath, 1 If (emuPathBackSlash != "\" || tablePathBackSlash != "\") { MsgBox,48,Error, Make sure your paths contains a backslash on the end ,6 Goto ExitScript } If (executable = "") { MsgBox,48,Error, Missing executable in Settings.ini ,6 Goto ExitScript } If (tablePath = "") { MsgBox,48,Error, Missing rom path in Settings.ini ,6 Goto ExitScript } If (emuPath = "") { MsgBox,48,Error, Missing emulator path in Settings.ini ,6 Goto ExitScript } IfNotExist, %A_ScriptDir%\%hyperpinexe% { MsgBox,48,Error, Must be in same directory as %hyperpinexe%,6 Goto ExitScript } IfNotExist, %EmuPath%%Executable% { MsgBox,48,Error, Cannot Find %EmuPath%%Executable%,6 Goto ExitScript } IfNotExist, %tablePath%%tableName%.%romExtension% { MsgBox,48,Error, Cannot Find %tablePath%%tablename%.%romExtension%,6 Goto ExitScript } return toLog(data, filename="log.txt", dtype="string") { ListLines Off Global debugMode, paused, menuon, flyeron, instructionson, gListLines if (debugMode = "true" OR debugmode = "file") { FormatTime, timenow ,, hh:mm:ss tt | FileAppend, %timenow% %data% p%paused% m%menuon% f%flyeron% i%instructionson%`n, %filename% } if (debugMode = "true" OR debugmode = "screen") { CoordMode ToolTip ToolTip %data%, 10, 40, 3 } ;msgbox %gListLines% ListLines %gListLines% } Clear($) ; Clear("VarName1, VarName2,...") { Loop Parse, $, `,, %A_Space%%A_Tab% %A_LoopField% := "" } Gdip_BitmapReplaceColor(pBitmap, ByRef pBitmapOut, Color, ReplaceColor, Variation) { global G global Width global Height global SwfWnd global hdc static BitmapReplaceColor If !BitmapReplaceColor { MCode_BitmapReplaceColor := "83EC248B4424388B4C243C995683E2038BF103C28B542438C1FE10C1F90881E6FF00000081E1FF000000C1F8028" . "9742408894C244085D20F8E0A010000538B5C2430558B6C245033C903C0578B7C243C03C0894C241C89442430897C241889542420837C2440000F8" . "EB90000008D43018BD32BD083C202895424282BF5894C244403C88BD32BD08B442440897424248954242C89442410EB0B8DA424000000008B74242" . "48B5424280FB6140A0FB6013BD67E0A8B74241403F53BD67C268B74244C2BF53BC67E248B5C244C03DD3BC38B5C24387C0E3BC67E128B74244C03F" . "53BC67D088B4424508907EB228B7424440FB6741E03C1E6080BF28B54242CC1E6080BF00FB6040AC1E6080BF08937834424440483C10483C704FF4" . "C241075828B4C241C8B7424148B7C2418037C2430034C2448FF4C2420897C2418894C241C0F851EFFFFFF5F5D5BB8010000005E83C424C3" VarSetCapacity(BitmapReplaceColor, StrLen(MCode_BitmapReplaceColor)//2) Loop % StrLen(MCode_BitmapReplaceColor)//2 ;% NumPut("0x" SubStr(MCode_BitmapReplaceColor, (2*A_Index)-1, 2), BitmapReplaceColor, A_Index-1, "char") } If (Variation > 255 || Variation < 0) Return -2 E1 := Gdip_LockBits(pBitmap, 0, 0, Width, Height, Stride1, Scan01, BitmapData1) E2 := Gdip_LockBits(pBitmapOut, 0, 0, Width, Height, Stride2, Scan02, BitmapData2) If (E1 || E2) Return -3 E := DllCall(&BitmapReplaceColor, "uint", Scan01, "uint", Scan02, "int", Width, "int", Height, "int", Stride1, "int", Color, "int", ReplaceColor, "int", Variation) Gdip_UnlockBits(pBitmap, BitmapData1), Gdip_UnlockBits(pBitmapOut, BitmapData2) Return 0 } GlobalListLines(OnOffLines) ; sets ListLines On/Off and updates global variable gListLines { global gListLines := OnOffLines ListLines %OnOffLines% }
  11. Yes run minimized is possible to do only on links. But since from the ahk script I'm running fp minimized and it doesn't work i want to see how it works on a link. Bad printscreen is an old problem of FP, when you do printsceen in windows fp screen is saved as black screen - you can see image from last printscreen in your HP directory - it is named screen.bmp If print screen doesn't work - you have to find better (newer/older) driver. You can find here and on vpf which drivers are good and which have known bugs in vp and fp. There are also a two numbers in settings.ini for playfield and backglass screen: pfScreenNum = 1 bgScreenNum = 2 You have to set them according to your setup or you will get wrong image on screen (backglass instead of playfield) As for freeze - you have to set all exe's to native mode if you are on win 7 (speccialy hyperpin, fplaunch, ultravp and hglass) In compatibility mode hyperpin has memory leak (every comp. mode) and it kills comp after some time. Some people get better results with vp and fp in xp sp3 comp. mod so you can try that also
  12. never had that problem with FP it is started minimized on my rig and menu is drawn over full table image. try to set startup mode to minimized to fp exe (or link to fp exe) - when you click fp it should open minimized from latest fplanch fp is started minimized so should be invisible on screen for menus - menus are drawn over printscreen image - try to do print screen of fp and check if image is ok, maybe print screen doesn't work good with fp
  13. do i see a tone here? i tried new ahk_L for few weeks, i wanted to use it cause it makes com objects and drawing swf easier - but all the time i was getting some small window on exit one by two cm out of nowhere that had to be closed manually with mouse - i posted finds in this thread, never found what it is - i was testing on win7 so for me it is incompatible, there is also a backslash problem which every one bumps into if they try to compile with new ahk same keys are used for both vp and fp check fplaunch manual on first page of this thread - fp has to be configured specially
  14. that's normal for esc - you have to use e instead of esc (or p) to avoid pinmame splash screen you have to use cabinet pinmame latest ahk version is not compatible with the fplaunch script
  15. I could add it to next release - did you posted code somewhere?
  16. Looks like ahk decided to remove basic version from their site, maybe you can find it somewhere on internet, search for ahk basic or exact version from the manual 1...48 or something like that
  17. that's normal, when you are in fp you get menu over high scores but i wouldn't say over cause high scores are on top of the screen and menu is on lower part of the screen so you can see both there is no option to remove menu except maybe to use pause screen instead of exit menu (useexitmenu = false) any way i didn't think someone would have anything against high scores up, and menu down on the screen so there is no support for that in script
  18. flipper and exit combo? there is no any flipper and exit combo feature, there is no quick exit on that keys on flipper and exit you should get exit menu, on long press of exit you should get exiting 321 screens, so none of them is quick maybe you have some non standard options for example disabled menus?
  19. Pause in vp is just lost of focus, there is no any key sent to vp, or any special code. I don't send Esc cause esc opens dialog box. I think that you can make vpm stop animations and what it is doing with some changes in table, but don't remember what. Something like init me on some object in vb script in table.
  20. yup, true, just put something else for that keys in fplaunch section if you put nothing fplaunch will probably put default - so it's better to put some key you don't use for anything else
  21. fplaunch supports only 270 degrees rotation, same as VP full screen tables. Since vp doesn't support anything else it makes no sense to support it in fplaunch either. 270 is standard. fp should be easy to rotate all 100 tables since it is just ONE setting in preferences and it applies to all tables. if fp doesn't work in 270 degrees that's fp problem, not fplaunch problem, right?
  22. i always have taskbar on backglass screen on the bottom - easier to work on backglass then on pf if you have to fix something in tables or hp no wonder i'm not familiar with this bug
  23. not possible, genre is not accessible from in game menu, but any way - you don't need genre when you play some game - only game instructions and flyer which are accessible
  24. Exit focus problem is not related to uvp, it happens randomly on all tables, uvp, non uvp, b2s, non b2s. It is explained few posts before why it happens - and few ideas to fix it. you can always set debug mode to file and check in log file what is happening. by the way i will try your idea - to kill fplaunch.exe from vbs script and activate hyperpin.exe. maybe that will work better then triple checks in a loop that can freeze fplaunch.
