evilmurray Posted August 31, 2015 Posted August 31, 2015 Hi, I am running Windows 10 Enterprise, Mac Mini (late 2012, specs listed below) via Bootstrap. Everything runs great so far, except HyperSpin. I have only synced two systems, NES and SNES. But it has become really laggy, and freezes up when I first launch it. Right after the intro video. The wheel pops up, but no other graphics appear for 5-10 seconds. Then when I enter the wheel, it pauses for a couple of seconds again before loading the content. I have run earlier versions of HyperSpin on the same hardware without problems. The HyperSpin is such a beautiful and crucial part of the setup I want, so I am asking the community if you know whats going on? Software specs Windows 10 Enterprise HyperSpin 1.4 (newest) Hardware specs Processor: 2,3 GHz Intel Core i7 Memory: 16 GB 1600 MHz DDR3 Graphics: Intel HD Graphics 4000
Metalzoic Posted September 1, 2015 Posted September 1, 2015 Sounds like you might have the same issue I (and others) had this past week. Sounds like your antivirus is blocking HS from running properly. In your AV software make an exception for Hypespin.exe (I also excepted RocketLauncher.exe, HyperHQ etc...). Try that. Here's my topic on it: http://www.hyperspin-fe.com/topic/11249-did-something-change-with-hs-yesterday/
what2be Posted September 1, 2015 Posted September 1, 2015 Have this same issue driving me crazy, worked perfect in windows 7 and somehow i return from vacation and windows 10 is installed on my arcade cabinet. I only have malwarebytes running and Ive already tried exiting it and running hyperspin and the problem persists. Its not a rocketlauncher issue because it happens before any games are even passed to rocketlauncher. I start hyperspin, the intro video plays fine, the wheels all show up on the screen but no wheel themes for 30-45 seconds and then when I do select a wheel the games are listed but no themes and it takes another 30-45 seconds for them to show up. If i select a game it runs fine and Ive already tried turning off UAC in windows 10 as well as setting all the exe in hyperspin to compatibility mode win 7 and run as administrator. The wierd thing is that sometimes the delay is longer than others and occasionally there is no delay at all when starting hyperspin but its usually after ive been in hyperspin and exited and then re started hyperspin. I checked my HDD speeds and they are fine, in task manager there is less than 10% cpu usage and have plenty of ram free. Not sure whats up but windows 10 can suck it.
evilmurray Posted September 1, 2015 Author Posted September 1, 2015 I am sorry I missed the other thread about this issue. I made exceptions to Windows defender and it works supersmooth again. Even through remote control from another computer. Thank you so much for your input. You saved the day.
what2be Posted September 1, 2015 Posted September 1, 2015 Sounds like you might have the same issue I (and others) had this past week. Sounds like your antivirus is blocking HS from running properly. In your AV software make an exception for Hypespin.exe (I also excepted RocketLauncher.exe, HyperHQ etc...). Try that. Here's my topic on it: http://www.hyperspin-fe.com/topic/11249-did-something-change-with-hs-yesterday/ It ended up being windows defender, I turned that worthless piece of sotware off and all works again. Thanks for the Tip!
evilmurray Posted September 1, 2015 Author Posted September 1, 2015 Have this same issue driving me crazy, worked perfect in windows 7 and somehow i return from vacation and windows 10 is installed on my arcade cabinet. I only have malwarebytes running and Ive already tried exiting it and running hyperspin and the problem persists. Its not a rocketlauncher issue because it happens before any games are even passed to rocketlauncher. Try the solution Metalzoic mentioned. Open Windows Defender and add exclusions to the Hyperspin.exe and HyperHQ.exe. Worked like a charm for me.
what2be Posted September 1, 2015 Posted September 1, 2015 Try the solution Metalzoic mentioned. Open Windows Defender and add exclusions to the Hyperspin.exe and HyperHQ.exe. Worked like a charm for me. Yeah I turned off windows defender and it works great again! Thanks!
MikeyWave Posted May 28, 2016 Posted May 28, 2016 So glad I found this thread...I got this all of a sudden after using HS on Windows 10 for the last 6 months. Thought I was going insane when everything on my computer was working except HS exe. (Even my old backups would take 3 mins to launch.) God forbid Windows defender tell you what it's doing when it's holding up an exe :/
ahmbouth Posted August 23, 2018 Posted August 23, 2018 I turned off Windows Defender .... but still very slow time to time it works fine, but then it's slow again, and i don't have a slow computer.
