Dolphin Triforce - MarioKart GP2 - JVS I/O Error
dougan78
All 3 of the working games (Mario Kart GP 1, Mario Kart GP 2 and Virtua Striker 3 Ver.2002) run perfectly in Dolphin Triforce v4.0-309. There is no need to use the 'broken' v4.0-315
You need the correct .ini files and to have the correct names for the Game ID's.
EDITING\RENAMING THE GAME ID FOR MARIO KART GP 1 STOPS THE 'THROW' BUTTON WORKING!
Use a Hex editor like HxDen to update the game ID's as shown below:
Game Name | Game ID
Mario Kart GP 1 RELSAB (It HAS to be named this)
Mario Kart GP 2 GGPE02
Virtua Striker 3 Ver.2002 GVSJ8P
Here are my .ini's, all working fine:
RELSAB.ini
[OnFrame_Enabled]
$Disable crypto
$Loop fix
[OnFrame]
$Disable crypto
0x8023D828:dword:0x93A30008
0x8023D82C:dword:0x93C3000C
0x8023D830:dword:0x93E30010
0x8023E088:dword:0x4E800020
$Loop fix
0x800790A0:dword:0x98650025
0x8024F95C:dword:0x60000000
0x80031BF0:dword:0x60000000
0x80031BFC:dword:0x60000000
0x800BE10C:dword:0x4800002C
0x8009F1E0:dword:0x60000000
0x800319D0:dword:0x60000000
[EmuState]
EmulationIssues = AM-Baseboard
GGPE02.ini
[Gecko]
$Button Activator for L and R Trigger [CosmoCortney]
28858D32 0000XXXX
*L = 0200
*R = 0100
*L + R = 0300
$Infinite Time in Races [CosmoCortney]
046D0F8C 447A0000
[OnFrame]
$99 credits
0x80690AC0:dword:0x00000063
$DVDInquiry Patchok
0x80286388:dword:0x3C602100
0x8028638C:dword:0x4E800020
$Ignore CMD Encryption
0x80285CD0:dword:0x93A30008
0x80285CD4:dword:0x93C3000C
0x80285CD8:dword:0x93E30010
$Disable CAM
0x80073BD8:dword:0x98650025
$Seat Loop patch
$Stuck loop patch
0x8002E100:dword:0x60000000
$60times Loop patch
0x8028B5D4:dword:0x60000000
$GameTestMode Patch
0x8002E340:dword:0x60000000
0x8002E34C:dword:0x60000000
$SeatLoopPatch
0x80084FC4:dword:0x4800000C
0x80085000:dword:0x60000000
$Disable Commentary
0x801B6510:dword:0x38800000
[OnFrame_Enabled]
$99 credits
$DVDInquiry Patchok
$Disable CAM
$Seat Loop patch
$Stuck loop patch
$60times Loop patch
$GameTestMode Patch
$SeatLoopPatch
[EmuState]
GVSJ8P.ini
[OnFrame]
$DI Seed Blanker
0x80000000:dword:0x00000000
0x80000004:dword:0x00000000
0x80000008:dword:0x00000000
[OnFrame_Enabled]
$DI Seed Blanker
Just copy/paste those into your .ini's and place in your Dolphin\User\GameSettings folder
-Make sure AM-Baseboard is selected for SP1 and Port 1 under Configuration/Gamecube
-Make sure 'Enable Cheats' is enabled under Configuration/General
-Make sure you configure your Gamecube controls
Play!
Interesting. Thanx. How do you change the game ID?
  • Replies 72
All 3 of the working games... run perfectly...
Uh, I would say one of the main mechanics of the game being 100% broken is not running perfectly unless you meant something else.
Its only broken if the Game ID is renamed. Now I've tested further It seems to stop the throw button working on MKGP2 too. They both have RELSAB as the ID by default. If yours is different, you just need to open the ISO's with a hex editor and edit the first line. Trouble is that now both games need the same ID you can't have 2 separate configs, forcing you to use 2 versions of the emulator. But my point is, MKGP1 'throw' button works perfectly in v4.0-309 with RELSAB as the ID.
I'm confused now. So using only v4.0-309 will not make any difference apart from just using one emulator instead of two? I thought you meant that you had gotten the throw button to work.
Yes I have got the Throw button to work. Rename the ID for Mario Kart 1 to RELSAB and run it on v4.0-309
Great. Thanks. I guess another way to make it work would be to use the actual version of the game that has that Game ID. That would be the spanish version.
Oeh can i get that link. I had set it up before. But im in the middle of setting up a 2nd system and skipped this one because i always have to read up how to do it
So to clear things up (hopefully)
Dolphin Triforce Emulation in a nutshell...
Requires:
Dolphin-Triforce v4.0-309 and v4.0-315
Basic Emulator Configuration:
-Put the Emulators into 2 separate folders
-Make a blank .txt file in both of your Dolphin-Triforce Emulator folders called portable.txt (This will make the emulator read settings from it's own folder)
-Run the Emulator and set a ROM directory
-Select AM-Baseboard for SP1 and Port 1 under Configuration/Gamecube
-Enable Cheats under Configuration/General
-Configure Gamecube Controls
-Configure Graphics
-Put the required .ini files for each game into your GameSettings folders (see below for details)
-Ensure each of your games are using the correct Game ID (see below)
Notes/Problems:
-Both Mario Kart GP games use the same Game ID RELSAB. Both games need their own RELSAB.ini and x2 config files of the same name cannot exist on the same emulator.
-Renaming the Game ID's for Mario Kart GP 1 & 2 to anything other than RELSAB results in loss of the 'Throw' function.
-Mario Kart GP and Virtua Striker 3 Ver.2002 do not work on v4.0-315 (The latest version of the emulator at the time of writing) but work fine on v4.0-309.
-Mario Kart GP 2 also works fine on v4.0-309 but use v4.0-315 to get around the problem above.
So Basically...
Use v4.0-309 for Mario Kart GP & Virtua Striker 3 Ver.2002
Use v4.0-315 for Mario Kart GP 2
Required Game IDs:
Mario Kart GP 1 - RELSAB
Mario Kart GP 2 - RELSAB
Virtua Striker 3 Ver.2002 - GVSJ8P
Check the properties of each game and confirm they have the correct ID.
If your ROM's do not have these ID's, re-download them or rename the ID's using a Hex Editor (Open the ROM with the Hex Editor and replace the ID on the first line)
Also, If your ROMS are in .bin format, just rename the extension to .iso to make Dolphin 'see' them.
Controls:
Mario Kart GP 1 & 2:
Left Stick = Steering
A Button = Throw
B Button = Throw
X Button = Coin
Z Button = Coin
Y Button = Test Menu (Causes Crash on Mario Kart GP 1)
Right Trigger = Accelerate
Left Trigger = Jump
Virtua Striker 3 Ver.2002:
DPad = Movement
B Button = Short Pass
A Button = Long Pass
X Button = Shoot
Z Button = Coin
Start = Start
Right Trigger = Service
Game Settings:
Create .ini files with the following information and put them in your 'Dolphin\User\GameSettings' folder
RELSAB.ini (Mario Kart GP 1) - put this in v4.0-309
[OnFrame]
$Disable crypto
$Loop fix
[OnFrame_Enabled]
$Disable crypto
$Loop fix
RELSAB.ini (Mario Kart GP 2) - put this in v4.0-315
[OnFrame]
$Emulation Bug Fixes
0x80073BF4:dword:0x98650023
0x80073C10:dword:0x98650023
$Disable Commentary
[OnFrame_Enabled]
GVSJ8P.ini (Virtua Striker 3 Ver.2002) - put this in v4.0-309
[OnFrame]
$DI Seed Blanker
[OnFrame_Enabled]
$DI Seed Blanker
Extras:
Hyperspin/Hyperlaunch HQ Setup:
1.) Add a new wheel to Hyperspin and name it Sega Triforce
2.) Create 2 new Emulators on Hyperlaunch HQ
-Name them Dolphin-Triforce 4.0-309 & Dolphin-Triforce 4.0-315
-Make them use the latest Dolphin-Triforce module
-ROM extension is ISO
3.) Set your Sega Triforce ROM path in Hyperlaunch HQ
4.) Set your Default Emulator for Sega Triforce to Dolphin-Triforce 4.0-309
5.) Go to the Sega Triforce\Games tab then Alternitive Emulators and click the + (add) button
Game = Mario Kart Arcade GP 2 (use the magnifying glass icon to choose the game)
System = leave this blank
Emulator = Dolphin-Triforce 4.0-315
Save before closing
Now when you launch the games via Hyperspin/Hyperlaunch the correct version of the emulator will be used!
Requires:
-Make a blank .txt file in your Dolphin-Triforce Emulator folder called portable.txt
-Configure Graphics
-Put .ini files for each game into your settings folder (see below)
Notes/Problems:
-Both Mario Kart GP games use the same Game ID RELSAB. Both games need a RELSAB.ini and x2 config files of the same name cannot exist on the same emulator.
-Renaming the Game ID's for Mario Kart GP 1 & 2 results in loss of the 'Throw' function.
So Basically...
Required Game IDs:
Controls:
A Button = Throw
B Button = Throw
X Button = Coin
Z Button = Coin
Left Trigger = Jump
DPad = Movement
X Button = Shoot
Z Button = Coin
Start = Start
Game Settings:
[OnFrame_Enabled]
$Disable crypto
$Loop fix
[OnFrame]
$Disable crypto
$Loop fix
[EmuState]
[OnFrame]
$Disable Commentary
[OnFrame_Enabled]
[OnFrame]
$DI Seed Blanker
[OnFrame_Enabled]
$DI Seed Blanker
awesome
followed this guide
got mario kart 2 working in about 1/2 hour
thanks!!
now got all 3 working! thanks!!
http://www.hyperspin-fe.com/forum/downloads.php?do=file&id=5238
I need game videos if anybody has them??
thanks :) :) :) :)
Craig. Look in my folder. There is an excel file. Search for triforce in that file and you will find some stuff
"Virtua Striker 2002" is actually "Virtua Striker 3 Ver.2002". It's confusing but you do have the right ROM. (You have the wrong theme though! :) )
Those 3 are the only playable ones. You can launch the Intro for F-Zero AX but can't progress much further than that. I will post a tutorial for anyone who is interested...
Also, where did you get that Mario Kart GP 1 theme? can't find it anywhere...
thanks everyone!
nsMiSDDKhH4
oops wrong theme for VS3
might have wrong rom as well
oops
Hi craig,
Can you please tell me where you found the MAriokart arcade GP 1 theme? Can't find it anywhere on the FTP...
Thanks ;)
EDIT: I asked it in the same time that Urbangangsta... we are looking for the same thing in the same time :)
F-ZERO AX (Unplayable) Instructions
F-Zero AX really isn't worth the effort as its completely unplayable and buggy but if you must see it here goes...
You need Dolphin-Triforce v4.0-312 and the F-Zero AX ROM (The ROM shows up as VirtuaStriker2002 on the browser for some reason). Do all the same setup as the other games (Cheats, AM-Baseband etc...).
You don't need a specific .ini for this one - This time you need to right click the Game->Properties->Gecko Codes->Download Codes. This will provide you with cheats that you can select (by ticking the boxes) so you can see part of the game.
-Tick the box "access title sequence instead of the test menu" then launch the game. You will get an "Error12 JVS board does not fulfil the game spec." message. Press the Test Menu button (S key on the keyboard or whatever the GCPad Y button is mapped to) this will allow you to see a buggy title screen that eventually fades to black and freezes.
-Tick the box "access GX-like menu instead of the test menu" then launch the game. You get the same error as above - press the Test Menu button again. This time it will show a menu like the one on F-Zero GX. If you keep hitting Start it will take you to a race but it's not really controllable and the graphics are screwed.
That's all folks...
The Mario GP1 theme is in my ftp. I did not make it but I will share it as long as THK does not care. If he does I will delete it. The theme is just a .png of his unreleased THEME with the video window cut out.
i am happy to share what i am using but if he wants it gone, i will erase it
here is the pic i used from THK's theme
when his real theme is release, i will use the real one obviously
http://newscentral.exsees.com/item/228df71ba47ee4a308cea60031ab0551-4c6d60fed1d18b62b854070e833465e5
