PCSX2 - Minimum Requirements / Spec - Help!
barrica
Hello all,
Ive been trying to add PCSX2 to my hyperspin cabinet, but am struggling with performance issues.
The PC is a Dell Optimplex dual core 3.7Ghz, 4Gb RAM, 250Gb hardrive, but does not run games anywhere near playable.
Ive tried following numerous PCSX2 setup guides but to no avail.
The first game I tried ran OK, "LOTR, Aragons Quest", but other games such as "Baldur's gate, dark alliance", "the getaway" and "GTA" all run choppy and/or extremely slow.
I guess I have a few questions, firstly, is my computers spec up to running PCSX2 at all (according to the minimum requirements section on the site it should be?!) , if not what is a good spec to be looking for to play the majority of games.
I'd like to add this to an existing cab, which already has most systems up to PS1 running fine, so am prepared to spend a bit on a higher spec PC if requried.
Thanks in advance!
Hi, I'll tell you what I think and it doesn't have much to do with PC requirements to run PCSX2 emulator.
First of all, the 6th generation consoles, i.e., Dreamcast, PS2, Xbox and Gamecube (PC also, but you'll understand the point later) share multi plataform titles, GTA is one of them.
PCSX2 is a great emulator, besides being plugin dependent, it needs a high-end PC to run most games, but even though, it probably won't run all games as smoothly.
A friend of mine here in the forums has a core i7 and a good GPU, believe it or not, most games didn't run quite well.
Note that PCSX2 runs better in OGL than DirectX, Dolphin, on the other hand runs better in DirectX than OGL.
Now, what I decided regarding PS2 in my setup:
1 - I filtered PS2-only games in wikipedia, and selected those that interested me
2 - All titles that PS2 has that GameCube/Wii and PC also has, I chose these, because, we all know Dolphin is far more solid for emulation and PC is "native", so for me, there was no point keeping GTA's, Guitar Heroe's and lots of other games that GC/Wii/PC or even PSP has, why?
Because if you want a smooth setup, with games running smoothly, don't keep laggy games for PS2 in your setup, PCSX2 is very demanding and even if you have a killer machine, there are possibility of glitches, etc.
3 - Once these games were filtered, I ran these exclusive titles, for example, Grandia 3 is a PS2 exclusive and I love the original Grandia, it ran smoothly in OGL at 60 FPS, no lags at all, and lots of other titles ran smoothly, so I put them inside a folder like "X:\Hyperspin\Roms\PS2\OK", and I was filling this folder with titles that ran fine, the other exclusives, in my machine didn't run well, sadly, Gran Turismo 3 and 4 is slow as hell, God of War too, probably I'd need a killer CPU to run than better, but my core i3 can't handle such titles. It's sad because, see, Dolphin emulates N64 for roms in wad format, it runs GameCube that is superior than PS2 in some ways and Wii that is part of the 7th console generation, that is basically a GameCube and a half, i.e., even more superior than a PS2, and these systems run faaaar better in Dolphin, that isn't a emulator dependent of plugins, and I believe that Dolphin will also emulate wiiu soon.
Now, back to PS2, basically I removed all titles that other platforms also has because this emulator is heavy and it's behavior changes from title to title, I left exclusive titles that runs smoothly in OGL without messing much with configs, just moving the hacks bar to number 2 or 3, safe/balance, something like that. There's no much point (for me) messing with this settings much because it can ruin other game that was running fine without messing with that.
So this is my point, get rid of GTA's for PS2, install versions for PC, play Vice City Stories from PSP, etc.
I didn't want a setup that, if me or anyone else opens up a PS2 game and see that running laggy and slow, that would be a shame.
Hope this helps.
Aorin
Sure, I didn't finish this setup, but so far I got this working smoothly in OGL without messing with configs inside PCSX2.
Sadly, most games that I'd like didn't run well in my setup, basically a core I3 3120, 4GB ram and Gforce 9400 GT, so I left those games in another folder for future use, when the emulator gets better or when (and if) I upgrade my PC, but I'm not planning on upgrading my PC in the near future, and I wouldn't do it just for playing PS2.
GameCube and Wii games are running fine, just fine.
Aorin
Yeah I know that PCSX2 is a CPU killer, but you know, there's no point for me to spend any money now just to play PS2 in my PC, being that I can find the real console almost for free here, but yeah, a i7 can almost run Gran Turismo 4 for PS2 at full speed, sad but true.
Maybe a new PS2 emulator can arise and be as solid as Dolphin is, not needing that much of a CPU to emulate a system.
Man, it's crazy that a console from 15 years ago eat up 70% of a core i7, but I remember quite well that SSF just ran at full speed when a core2duo was released.
Aorin
To put it simple, it wants ghz. It's wants cpu ghz on 1-2 cores.  OC I5 or a hight end I7 do this. But it's overkill as expensive and no emus use all those cores.
To get it working perfect you need 2 cores running over 4ghz. Cheapest and best way is a Intel Pentium anniversary edition dual core.
Comes sec 3.2 as standard, runs 4.3 OC on a stock cooler on full burn no problem. Same pwrformace than a current gen  I7 running to same standards.  Except this cop costs 43 pounds brand new hehe
Yeah, you're all right, my core i3 2120 has 2 physic cores and two running in hyper threading, it's clock runs or reaches 3.30 Ghz and some games run quite well at 60 fps, the problem setting up PCSX2 into Hyperspin is that if you (me) just throw games inside roms folder and direct PCSX2 to open them that won't work for most games, for example, I can use some speed hacks for a specific game or other and that can work better but, on the other hand it can ruin those that run fine without messing with configs, I researched about PCSX2 emulation methods and I found that PCSX2 runs well in OpenGL, opposite to Dolphin that runs better in Direct3D.
So what I did was putting all exclusives that I wanted in roms folder (because there was no point keeping games that GameCube/Wii and PC has and runs better without eating up all PC resources and running slow, like GTAs for example, they don't look good in PCSX2 and runs slow in PCSX2 in my setup), set PCSX2 in OpenGL and run one by one to see how they behave. In a range of  115 titles, exclusive ones, 35 titles ran smoothly in OpenGL without messing with any speed hacks, the other ones that were slow I put in a separate folder for future use when a better emulation is achieved or when I upgrade my PC.
So the deal here is just leave these titles that runs at 60 fps active in HS setup for now.
Aorin
Nice topic guys. I always donate my old main PC to my cab when I upgrade so my cab runs a 1st gen i7 2.8 with 12 GB ram - gtx 770. I was shocked to find ps2 games lagging. Problem is they take a good while to load up to test. Perhaps a working min spec list would be a good idea. ?
Do we have a ps2 exclusive game list anywhere?
I used this wikipedia page as a source for my PS2 in HS > https://en.wikipedia.org/w/index.php?title=Category:PlayStation_2-only_games&pageuntil=Herdy+Gerdy#mw-pages
Here is the list you'll find there, games released only for PS2, for my setup, using this exclusives list, I selected those that interested me, once I got them I tested one by one using the default PCSX2 config in OpenGL, about 35% of these filtered games worked at 60 fps in my setup, so these will be active in my setup, the others that lagged I put in another folder for future use.
I just rechecked this list and didn't find God of War as an exclusive, wikipedia has some info about it, it's not a PS2 exclusive because it was re-released for Ps3 in a remastered version and there's a port for Vita as well.
10,000 Bullets
24: The Game
2nd Super Robot Wars Alpha
3rd Super Robot Wars Alpha: To the End of the Galaxy
7 Blades
Ace Combat 04: Shattered Skies
Ace Combat 5: The Unsung War
Ace Combat Zero: The Belkan War
Air Ranger: Rescue Helicopter
AirBlade
Airforce Delta Strike
Akira Psycho Ball
All Star Pro-Wrestling
All Star Pro-Wrestling II
All Star Pro-Wrestling III
Altered Beast (2005 video game)
Amplitude (video game)
Another Century's Episode
Another Century's Episode 2
Another Century's Episode 3: The Final
Ape Escape 2
Aqua Aqua
Aqua Teen Hunger Force Zombie Ninja Pro-Am
Ar Tonelico II: Melody of Metafalica
Ar tonelico: Melody of Elemia
Arc the Lad: End of Darkness
Arena Football: Road to Glory
Armored Core 2
Armored Core 2: Another Age
Armored Core: Nexus
Armored Core: Nine Breaker
Astro Boy (2004 video game)
Atelier Iris 2: The Azoth of Destiny
Atelier Iris 3: Grand Phantasm
Atelier Iris: Eternal Mana
ATV Offroad Fury
ATV Offroad Fury 2
ATV Offroad Fury 3
ATV Offroad Fury 4
Bass Strike
Beatmania IIDX 15: DJ Troopers
Beatmania IIDX 16: Empress
Berserk: Millennium Falcon Hen Seima Senki no Sho
Bleach: Blade Battlers (series)
Blood Will Tell
Bloody Roar 4
Boken Jidai Katsugeki Goemon
Bombastic (video game)
Bomberman Hardball
Bomberman Kart
Bomberman Land 3
The Bouncer
Brave: The Search for Spirit Dancer
Breath of Fire: Dragon Quarter
Bujingai
Buzz! Junior: Ace Racers
Buzz!: The Big Quiz
Buzz!: The Hollywood Quiz
Buzz!: The Mega Quiz
Buzz!: The Music Quiz
Buzz!: The Pop Quiz
Buzz!: The Schools Quiz
Buzz!: The Sports Quiz
Cabela's Monster Bass
Call of Duty: World at War – Final Fronts
Champions of Norrath
Champions: Return to Arms
Chaos Wars
ChoroQ (video game)
City Crisis
Clock Tower 3
Code Age Commanders: Tsugu Mono Tsuga Reru Mono
Code of the Samurai
Cold Winter
Colosseum: Road to Freedom
Cool Boarders: Code Alien
Cowboy Bebop: Tsuioku no Serenade
Crimson Tears
Crisis Zone
Cy Girls
D1 Grand Prix (video game)
Dance Dance Revolution Extreme (2004 video game)
Dance Dance Revolution Extreme 2
Dance Dance Revolution Party Collection
Dance Dance Revolution Strike
Dance Dance Revolution SuperNova (2006 video game)
Dance Dance Revolution SuperNova 2 (2007 video game)
Dance Dance Revolution X2 (2009 video game)
Dance Dance Revolution: Disney Channel Edition
Dance Factory (video game)
Dancing Stage Max
Dancing Stage MegaMix
Dancing Stage SuperNova (2007 video game)
Dark Angel: Vampire Apocalypse
Dark Chronicle
Dark Cloud
Dawn of Mana
DDR Festival Dance Dance Revolution
DDRMAX Dance Dance Revolution
DDRMAX2 Dance Dance Revolution
DearS
Death by Degrees
Destruction Derby Arenas
Digimon World Data Squad
Dino Stalker
Dirge of Cerberus: Final Fantasy VII
Disaster Report
Disney Golf
Dog's Life
Downhill Domination
Dragon Ball Z: Infinite World
Dragon Quest: Shonen Yangus to Fushigi no Dungeon
Dragon Rage
Drakan: The Ancients' Gates
Driving Emotion Type-S
Dropship: United Peace Force
Dynasty Tactics
Echo Night: Beyond
Elvandia Story
Enthusia Professional Racing
EOE: Eve of Extinction
Ephemeral Fantasia
Eternal Poison
Eternal Ring
Everblue
Everblue 2
Evergrace
EverQuest Online Adventures
Everybody's Golf 3
Everybody's Golf 4
Everybody's Tennis
Extermination (video game)
EyeToy (video game series)
EyeToy: AntiGrav
EyeToy: Chat
EyeToy: Groove
EyeToy: Kinetic
EyeToy: Monkey Mania
EyeToy: Operation Spy
EyeToy: Play
EyeToy: Play 2
EyeToy: Play 3
FantaVision
Final Fantasy XII
Firefighter F.D.18
Fishing Fantasy: BuzzRod
Fist of the North Star (2005 video game)
The Flintstones in Viva Rock Vegas (video game)
Forbidden Siren 2
Forever Kingdom
Formula One 04
Formula One 05
Formula One 2002 (video game)
Formula One 2003 (video game)
Frequency (video game)
Front Mission 4
Front Mission 5: Scars of the War
Fullmetal Alchemist 2: Curse of the Crimson Elixir
Fullmetal Alchemist 3: Kami o Tsugu Shojo
Fullmetal Alchemist and the Broken Angel
Fullmetal Alchemist: Dream Carnival
G-Surfers
Gadget & the Gadgetinis (video game)
Gaelic Games: Football
Gaelic Games: Football 2
Gaelic Games: Hurling
Genji: Dawn of the Samurai
The Getaway (video game)
The Getaway: Black Monday
Ghost in the Shell: Stand Alone Complex (PS2)
Ghosthunter
Glass Rose
Global Defence Force Tactics
Go Go Golf
Godai Elemental Force
Golden Knight Garo
Gradius III and IV
Graffiti Kingdom
Gran Turismo 3: A-Spec
Gran Turismo 4
Gran Turismo Concept
Gregory Horror Show (video game)
Growlanser Generations
Growlanser II: The Sense of Justice
Growlanser III: The Dual Darkness
Growlanser VI: Precarious World
Guilty Gear X2
Guitar Hero (video game)
Guitar Hero Encore: Rocks the 80s
Gunbird Special Edition
Gunfighter II: Revenge of Jesse James
Gungrave
Half-Life: Decay
Hard Hitter Tennis
Hardware: Online Arena
Harukanaru Toki no Naka de 3
Harukanaru Toki no Naka de Hachiyo Sho
Haven: Call of the King
He-Man: Defender of Grayskull
Heavy Metal Thunder (video game)
Herdy Gerdy
Heroes of Might and Magic: Quest for the Dragon Bone Staff
Hidden Invasion
Home Alone (2006 video game)
Hunter: The Reckoning: Wayward
I/O (visual novel)
Ichigeki Sacchu!! HoiHoi-san
Ikusagami
Inspector Gadget: Mad Robots Invasion
Inuyasha: Feudal Combat
Inuyasha: The Secret of the Cursed Mask
J-League Winning Eleven 2007 Club Championship
J-League Winning Eleven 2008 Club Championship
J-League Winning Eleven 2009 Club Championship
J-League Winning Eleven 2010 Club Championship
Jak X: Combat Racing
Jet Li: Rise to Honor
Kamiwaza
Keroro Gunso: Meromero Battle Royale
Keroro Gunso: Meromero Battle Royale Z
Kinetica
King's Field IV
Klonoa 2: Lunatea's Veil
Kujibiki Unbalance: Kaicho Onegai Smash Fight
Kuon
Kya: Dark Lineage
Le Bizzarre Avventure di GioGio: Vento Aureo
Legaia 2: Duel Saga
The Legend of Alon D'ar
Legion: The Legend of Excalibur
Let's Make a Soccer Team!
Lifeline (video game)
Love Story (video game)
Lucky Star: Ryoo Gakuen Otosai
Lupin the 3rd: Treasure of the Sorcerer King
Magic Pengel: The Quest for Color
Mars Daybreak
McFarlane's Evil Prophecy
Metal Saga
Metal Slug (2006 video game)
Metropolismania
Michigan: Report from Hell
Mister Mosquito
Mobile Suit Gundam: Encounters in Space
Mobile Suit Gundam: Journey to Jaburo
Mobile Suit Gundam: Lost War Chronicles
Mobile Suit Gundam: Zeonic Front
Moeyo Ken (anime)
Mojib-Ribbon
Monster Hunter 2
Monster Rancher 3
Monster Rancher 4
Monster Rancher EVO
MotoGP '07 (PS2)
MotoGP (2000 video game)
MotoGP 3 (video game)
MotoGP 4
Motor Mayhem
MS Saga: A New Dawn
Musashi: Samurai Legend
My Street
Myself ; Yourself
Namco × Capcom
NamCollection
Nano Breaker
Naval Ops: Warship Gunner
NCAA Basketball series
Neo Geo Online Collection
Neopets: The Darkest Faerie
The Nightmare of Druaga: Fushigi no Dungeon
Nightshade (2003 video game)
Nogizaka Haruka no Himitsu
NRA Gun Club
Okage: Shadow King
Onimusha 2: Samurai's Destiny
Onimusha Blade Warriors
Onimusha: Dawn of Dreams
Oretachi Geasen Zoku Sono
Orphen: Scion of Sorcery
Paparazzi (video game)
PaRappa the Rapper 2
Pipo Saru 2001
Princess Princess (manga)
Pro Evolution Soccer Management
R-Type Final
Radiata Stories
RahXephon
Rakushou! Pachi-Slot Sengen
Raw Danger!
RC Revenge Pro
Rec (manga)
Reel Fishing III
Resident Evil Outbreak
Resident Evil Outbreak File 2
Resident Evil: Dead Aim
Rise of the Kasai
Risk: Global Domination
Road Trip Adventure
Robot Alchemic Drive
Rogue Galaxy
Rosario + Vampire
RPG Maker 2
RTX Red Rock
Rugby League 2: World Cup Edition (video game)
Rule of Rose
Rumble Racing
Rumble Roses
S.L.A.I.: Steel Lancer Arena International
Sacred Blaze
Saint Seiya: The Sanctuary
Samurai Champloo: Sidetracked
Samurai Western
Seaman 2
Sega Classics Collection
Sega Rally 2006
Sega Superstars
Seven Samurai 20XX
Shadow Hearts: From the New World
Shadow Man: 2econd Coming
Shadow of Rome
Shadow Tower Abyss
Shaman King: Funbari Spirits
Shaman King: Power of Spirit
Shifters
Shining Force EXA
Shining Force Neo
Shining Tears
Shining Wind
Shinobido: Way of the Ninja
Silpheed: The Lost Planet
The Simpsons Skateboarding
Sky Odyssey
SkyGunner
Smash Court Tennis Pro Tournament
Smash Court Tennis Pro Tournament 2
Smuggler's Run 2
SOCOM II: U.S. Navy SEALs
SOCOM 3: U.S. Navy SEALs
SOCOM: U.S. Navy SEALs
SOCOM: U.S. Navy SEALs Combined Assault
The Sopranos: Road to Respect
Soulcalibur III
Space Battleship Yamato: Iscandar e no Tsuioku
Space Battleship Yamato: Niju Ginga no Hokai
The Space Sheriff Spirits
Spectral Gene
Spy Fiction
SSX
Star Ocean: Till the End of Time
Star Trek: Encounters
Star Wars: Super Bombad Racing
State of Emergency 2
Steambot Chronicles
Strawberry Marshmallow
Strawberry Panic!
Street Fighter Alpha Anthology
Street Fighter EX3
Stretch Panic
Suikoden IV
Suikoden V
Suikoden Tactics
Summer Heat Beach Volleyball
Sunny Garcia Surfing
Super Dimension Fortress Macross (PlayStation 2 game)
Super Robot Wars Original Generation Gaiden
Super Robot Wars: Original Generations
Super Trucks Racing
Surveillance Kanshisha
The Sword of Etheria
Tales of Legendia
Taxi Rider
Thomas & Friends merchandise
Thunder Force VI
Thunderhawk: Operation Phoenix
Time Crisis 3
Time Crisis II
TimeSplitters
Tokimeki Memorial 3: Yakusoku no Ano Basho de
Tokyo Majin Gakuen Gehocho: Keppuroku
Tokyo Xtreme Racer 3
Tokyo Xtreme Racer: Drift
Tokyo Xtreme Racer: Drift 2
Tokyo Xtreme Racer: Zero
Tourist Trophy (video game)
Transformers (2003 video game)
Transformers (2004 video game)
Tribes Aerial Assault
Tsugunai: Atonement
UFC: Sudden Impact
Ultraman Fighting Evolution 2
Ultraman Fighting Evolution 3
Ultraman Fighting Evolution Rebirth
Ultraman Nexus (video game)
Under the Skin (video game)
Underworld: The Eternal War
Unison: Rebels of Rhythm & Dance
Unlimited Saga
Urban Reign
Ururun Quest: Koiyuuki
Valkyrie Profile 2: Silmeria
Aorin
That list is definitely a good start for exclusives. I tend to just scroll through the database and check to see which ones I want, I had around 300 games back in the day on PS2 so I already have a pretty good idea of some games I want for my setup. The only downside to that list is that it doesn't list games also released on the original Xbox (which is quite a few) and since Xbox emulation is basically non-existent right now you'd be missing a bunch of good games. Just something to be aware of.
Yeah, also, we should cross check with Xbox and see what could be added to our setup, that will be something if we sort this.
Aorin
Well I was a little bored tonight and decided to start compiling that list. I scraped the list of Xbox games and matched them to the PS2 database to find the common games between those 2 systems (about 690). So now it's just a matter of going through that list and removing any games that are available on other systems. Once that's done I'll have a list of the games exclusive to the PS2 and Xbox but only playable on PS2 since Xbox isn't emulated yet. I'll probably start eliminating some games from the list tonight.
Great buddy! If you need help, let me know!
Aorin
Thanks buddy, I'm checking the list now.
I was expecting some Japanese titles to appear on this list, like Metal Slug (despite the same name of the original game, it's a 3D metal slug exclusive for PS2 in Japan). I know it's not the ultimate list, but I'll tell what I'm missing here.
Castlevania - Lament of Innocence (USA)
Fatal Frame II - Crimson Butterfly (USA)
Fatal Frame III - The Tormented (USA)
Grandia Xtreme (USA)
King of Fighters 2006, The (USA)
Tekken 4 and 5 (USA) I'm not sure if these are emulated elsewhere
Twisted Metal - Black (USA)
Some others from another folder here
Berserk - Millennium Falcon Hen Seima Senki no Shō (Has english patch)
Cool Boarders - Code Alien (Japan)
Metal Slug (Japan) (The text in this game in in Japanese but the speech are all in English, and the game seems to be pretty fun)
Shining Wind (Japan)
.Hack Series
King of Fighters XI (For me it's better emulated in PS2 than the arcade version)
Maximo - Ghosts to Glory (Kinda Ghouls and Ghosts in 3D)
Maximo vs. Army of Zin (USA)
NeoGeo Battle Coliseum (Works perfectly in PS2 emulator, for me, better than in Demul)
RPG Maker 3 (Just for the sake of being an exclusive, I wouldn't play it for sure)
Syphon Filter - The Omega Strain (USA)
Time Crisis - Crisis Zone
Soulcalibur III (USA) Not sure if it's emulated elsewhere
From the ones I have here, these where the ones that I missed in the list, but it's a good start, I'll add Japanese titles as I test some.
Thanks for your efforts!
Aorin
Yeah I knew it would miss some, it's just the nature of the beast. Without manually researching every title it's bound to happen. I also limited my scope to the games that were in the HyperSpin approved database here so I knew they were compatible or legit which is why I missed some you mentioned.
When I was manually verifying after cross-checking databases if it said Arcade as a system I just assumed it was released for MAME or TTX or something which is why some KOF and the Tekkens slipped through. There are quite a few I found manually searching as well that were in different systems under a different name which is why they are/aren't included. For example, you mentioned Fatal Frame II: Crimson Butterfly which was released on the Wii as Project Zero 2: Wii Edition. Which I never would have found if I didn't research it.
That's why I wanted to get a decent start with the list; I knew that people would remember/find games that weren't found in the lists I used or be able to find more information about the games. Thanks for pointing out the ones you did. The more people that read and add to it, the better it will become!  :thumbsup:
Thanks!
Project Zero 2: Wii Edition? OK I'll get it! (Maybe coz I don't like scary games)
I just remembered a game that I thought that was a PS2 exclusive, it's Metal Gear Solid 2, it ran really bad in my PC, so I found a PC version of this game.
Aorin
Yeah I read that Substance actually is an upgraded version, and as PCSX2 needs far higher specs to run some games, the PC version was the one I chose to keep.
Aorin
  • 4 weeks later...
Unfortunately I haven't really had time to put in this. I just finished my degree so the job search is taking up all my time now (and entry level positions seem to be non existent). I've filtered the PS2 list from the other system databases and added the PS2 exclusives from the wikipedia listing so really all that's left is to go through game by game in the database to verify or eliminate titles, and right now I have nowhere near that amount of free time. The one I posted should be a great starting point if anyone wants to work on it in the meantime. Sorry for the lack of progress.
Don't apologise...life comes first!
  • 4 months later...
I'm only interested in adding 2 PS2 games to my cabinet, Maiximo 1 & 2, but I need to know if they can even be played without analog controls.
Anyone know or can check? 6 button arcade control panel.
I run it on a i3 (first generation) and have the hacks setup just right I guess.. I only play one game so they are setup perfect for GTA San Andreas... I'm sure it's not 100% speed but seriously during game play I don't even notice it.. definitely nowhere near the lag I get on WII and or gamecube emulation so on my i3 it gets it done... but like I said I play one game.. I tried playing a basketball game and it was SLOW but again perhaps I needed to change the settings which I don't plan to so I'm happy.
