Deezdrama Posted November 15, 2015 Posted November 15, 2015 Sorry for blasting the board with so many questions been following simply austins YT videos and about 4 hour long videos into it and ran into an issue. Ive already figured it out but wondering whats up with it. In the video he is using hyperlaunch....Im using rocketlauncher When running a mame rom in HS it gave me an error that rocketlauncherui/databases/mame.xml was missing. I knew it was in my HS database folder so just copied the folder into rocketlauncher and things are working. Did this database location change with RL? will all future systems I set up need the databases moved to RL? thanks
Yeuxkes Posted November 15, 2015 Posted November 15, 2015 There was an update of Rlauncher a day or two ago, you need to set Hyperspin as default frontend and plugin on the general settings page. And like Jeremey said, it wouldn't do any harm having a look at the RL forums also. Tons knowledge is to be found there.
gobluemike21 Posted January 24, 2016 Posted January 24, 2016 FYI I had the same issue and came here first to see responses before heading to RL. Thanks for the heads up Yeuxkes.
Metalzoic Posted January 24, 2016 Posted January 24, 2016 Like Jeremy said. Best rule of thumb is to always go check the RocketLauncher update notes before updating.
balderdashian Posted February 13, 2016 Posted February 13, 2016 Searching that forum for anything always generates a cacophony of unrelated multi-page threads. I searched this problem in google and it led me here.
Metalzoic Posted February 13, 2016 Posted February 13, 2016 Searching that forum for anything always generates a cacophony of unrelated multi-page threads. I searched this problem in google and it led me here. True (same here a jumble of disorganized madness). But you don't have to search at all for the update notes. They're announced right on the RL forum, with all changes and instructions listed, every time they update.
dieselboss78 Posted February 22, 2016 Posted February 22, 2016 Why answer with a jerk response? GO LOOK HERE YA STUPID DUMBY... is pretty much what you are saying. Let's just say, Go the General Settings in RocketLauncherUI. Go to RocketLauncher tab (if not there already, the tabs are RocketLauncher, Controls, and Third Party) Click on the down arrow in the DEFAULT PLUGIN (Base Settings) from RocketLauncher to HyperSpin. Then under Paths, change DEFAULT FRONTEND PATH to your HyperSpin.exe (eg. d:\arcade\hyperspin\hyperspin.exe) location rather than the RocketLauncher.exe. Problem solved... ENJOY!
r34turbo Posted March 7, 2016 Posted March 7, 2016 Thanks for a straightforward answer dieselBoss. You'll find that most of the time people who know the answer, will not tell you the answer, yet take the time to tell someone to look somewhere else or search blah blah. So your answer was a breath of fresh air. I had this same problem, will try your fix. thank you. First time trying Hyperspin + RL. Seems there are 'emulator', 'roms' and 'database' folders everywhere (don't know where to put stuff...and saying "copy in both isnt a worthwhile solution), and the setup instuctions said to create 'emulator' and 'roms' folders in the root directory, to make things more confusing.
Metalzoic Posted March 7, 2016 Posted March 7, 2016 Thanks for a straightforward answer dieselBoss. You'll find that most of the time people who know the answer, will not tell you the answer, yet take the time to tell someone to look somewhere else or search blah blah. So your answer was a breath of fresh air. I had this same problem, will try your fix. thank you. First time trying Hyperspin + RL. Seems there are 'emulator', 'roms' and 'database' folders everywhere (don't know where to put stuff...and saying "copy in both isnt a worthwhile solution), and the setup instuctions said to create 'emulator' and 'roms' folders in the root directory, to make things more confusing. Just think of them as separate programs. A single Hyperspin folder, with all it's files and folders inside. And a separate Rocketlauncher folder with all its associated files & folders. Databases for Hyperspin go in the Hyperspin Database folder (you probably won't ever need to use the RL Database folder) You can keep your emulators and roms wherever you like. Personally since there is already an Emulators folder in the Hyperspin folder I just put them all in there and then I keep all my roms for each emulator in the same emulator folder so they're all together. Some people like to keep a Roms folder separate from the Hyperspin and RLauncher folders. Really the thing to remember is not to mix them together.
monkey666 Posted March 18, 2016 Posted March 18, 2016 Why answer with a jerk response? GO LOOK HERE YA STUPID DUMBY... is pretty much what you are saying. Let's just say, Go the General Settings in RocketLauncherUI. Go to RocketLauncher tab (if not there already, the tabs are RocketLauncher, Controls, and Third Party) Click on the down arrow in the DEFAULT PLUGIN (Base Settings) from RocketLauncher to HyperSpin. Then under Paths, change DEFAULT FRONTEND PATH to your HyperSpin.exe (eg. d:\arcade\hyperspin\hyperspin.exe) location rather than the RocketLauncher.exe. Problem solved... ENJOY! Dude thank you so much mate !
klg642002 Posted March 20, 2016 Posted March 20, 2016 Why answer with a jerk response? GO LOOK HERE YA STUPID DUMBY... is pretty much what you are saying. Let's just say, Go the General Settings in RocketLauncherUI. Go to RocketLauncher tab (if not there already, the tabs are RocketLauncher, Controls, and Third Party) Click on the down arrow in the DEFAULT PLUGIN (Base Settings) from RocketLauncher to HyperSpin. Then under Paths, change DEFAULT FRONTEND PATH to your HyperSpin.exe (eg. d:\arcade\hyperspin\hyperspin.exe) location rather than the RocketLauncher.exe. Problem solved... ENJOY! thank you u rock bro!
mamestig Posted July 30, 2016 Posted July 30, 2016 Why answer with a jerk response? GO LOOK HERE YA STUPID DUMBY... is pretty much what you are saying. Let's just say, Go the General Settings in RocketLauncherUI. Go to RocketLauncher tab (if not there already, the tabs are RocketLauncher, Controls, and Third Party) Click on the down arrow in the DEFAULT PLUGIN (Base Settings) from RocketLauncher to HyperSpin. Then under Paths, change DEFAULT FRONTEND PATH to your HyperSpin.exe (eg. d:\arcade\hyperspin\hyperspin.exe) location rather than the RocketLauncher.exe. Problem solved... ENJOY! cannot find C:\rocketlauncher\rocketlauncherui\databases\mame\ mame.xml Thanks Champ, now my hyperspin works without errors.. also here, make sure you look and follow screenshot.. http://www.rlauncher.com/forum/showt...ncher-v1-0-1-4 same solution different way of getting there..
