SteveMo Posted December 18, 2015 Posted December 18, 2015 Looking at getting a light gun for my setup. It seems the AimTrak is the best one out there. Is this still the case? Also read about the EMS TopGun III. The AimTrak seem to have mixed reviews though so I'm not sure which to go for. Is the AimTrak decent for calibration?
C_Wilson009 Posted December 19, 2015 Posted December 19, 2015 I have one, im not sold on it but it gets the job done. I seem to be having trouble with certain mame games, but I don't know if its the guns fault. Like area 51 works great, but terminator is crap. Calibration isn't bad, but just remember when you are setting it up, not to get too close to the sensor bar cuz it screws it up. Really nice look to it though hope that helps..
fire10 Posted December 19, 2015 Posted December 19, 2015 Hi mate terminator will be rubbish until you have gone into the game setup and calibrated in there too, its a game that used fixed guns so although mappable wasnt actually a free gun game. It will still work fine mine does with my act labs guns but took this step to sort it. Operation wolf etc are also the same
SteveMo Posted December 19, 2015 Author Posted December 19, 2015 Thanks for the input guys. Think I'll take the plunge and get 1 for now and see how I get on. Any tips for configuring as accurate as possible?
dougan78 Posted December 19, 2015 Posted December 19, 2015 Calibrate in windows and then calibrate in each machine. If you plan on having 2 guns I personally would do 2 right away So you only need to calibrate all the fun games in mame once. Unless you like doing stuff twice. Good luck.
SteveMo Posted December 28, 2015 Author Posted December 28, 2015 OK so I have the gun now. I ran the initial calibration in Windows and amended the MAME.ini file. I've played Point Blanc and it's working great. The problem I'm having is the games which require you to shoot off screen to reload. Lethal Enforcers for example. It doesn't seem to work. I did change the 'reload off screen' setting to 1. Any ideas?
Turranius Posted December 29, 2015 Posted December 29, 2015 Never did get shooting offscreen to work. Remapped reload to the button on the side of the gun instead. Although, now the gun is in a shelf. Not happy with it at all. Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
SteveMo Posted December 29, 2015 Author Posted December 29, 2015 Got it working. Some more amendments to the Mame.ini file. Off screen shooting working perfectly now! Well happy with the AimTrak so far! Next issue...Time Crisis. It's a stutters quite a bit so is not really that playable. Any ideas? Thanks
Matt68061 Posted December 30, 2015 Posted December 30, 2015 How did you get the off screen reload to work...if you dont mind me asking? Thanks
SteveMo Posted December 30, 2015 Author Posted December 30, 2015 Sure...I followed the guide from user 'what2be' post on here - http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=323122&page=0&view=expanded&sb=5&o=&vc=1
XC-3730C Posted March 17, 2016 Posted March 17, 2016 Old topic, but when I go to the link to fix the off screen reload issue, I get this message: "There was a problem looking up the post in our database." Does anyone have a working link to fix the off screen reload issue? I just got a Hyperspin HDD and Alienware Alpha. Sent from my SAMSUNG-SM-N910A using Tapatalk
albert_c Posted March 18, 2016 Posted March 18, 2016 Are you using a CRT monitor, or LCD? The CRT guns of old were much better. But if you are on a modern display, you don't have much choice. Aimtrak is the best solution out there. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
XC-3730C Posted March 18, 2016 Posted March 18, 2016 Until I figure out how to run an Alienware Alpha with Hyperspin n my CRT (Sony PVM-2530), I will be running it on my older 50" plasma. Sent from my SAMSUNG-SM-N910A using Tapatalk
albert_c Posted March 18, 2016 Posted March 18, 2016 Dunno about your issue. Sucks that you got a HyperSpin HDD too . Aimtrak uses the same tech as the Wii controllers. All the videos I see of them on Youtube seem laggy and inaccurate. If you played with the Wii gun games and they make you happy, you might not be too annoyed by the limitations with the technology. But if you are looking to play those fast twitch gun games of old on MAME, Aimtrak may just leave you wanting. Good luck with this. Since you got that beautiful CRT, I think you can get it going there. Scroll down to page 17 here. It has the pinout for RGB input for your Sony. Get a DB25 connector from here so you can harness and plug into the RGB input on that monitor (can't tell if you need male or female so get the right one). Also get a DB15HD connector from the same auction so you can connect your Alienware to that monitor. Now you just need to get your Alienware to output a 15khz RGB signal. For that, get an older Radeon HD4350 card. Then run Calamity's CRT EMU drivers. For those two breakout boards, you need to run 18 gauge wire from the Red, Green, Blue, Ground, and Composite Sync from each of those breakout boards. Then you can use 3rd party Guncon2's (they were made for the PS2 Namco games). As fate would have it, I have a thread going here laying out my progress on this very subject. Sadly though, you might have to drop down to a 32-bit OS. Maybe even XP 32-bit. Might be a waste of a perfectly nice Alienware. So perhaps just pick up a cheap Core 2 Duo based PC off eBay for $20 so you can get it to work with your CRT. Keep the Alienware on the 50" Plasma. Those arcade gun games of old were awesome. I am working to get them going on my arcade cabs, all with CRT monitors. It's worth the effort. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
XC-3730C Posted March 18, 2016 Posted March 18, 2016 Why does it suck I got a 4TB Hyperspin HDD? The Alienware Alpha doesn't have a removable video card. I got the Alienware Alpha because it looks and feels like a game console, it looks to be able to play every system Hyperspin supports, and it is a great Steam box. I may just do a Core 2 Duo PC and set up a Hyperspin PC that will support working guns on my PVM. Of course, that will significantly limit all the games I can run.
