xbboyx101 Posted February 15, 2016 Posted February 15, 2016 Hello guys i want change this module it should run cd Rom Not load ISO i know this module has deamon tools but I dont have all Cue Files for all games so i have a psx plugin that make bin Files to cd Rom so i think this is the best way ... In this module There is loadiso i think this should be changed run cd Rom or something ive allready try this but it dosent work i dont know the exactly commando ..
JoyStickKilla Posted February 16, 2016 Posted February 16, 2016 Ask on the rocketlauncher site. It is their program and modules. They might be able to help you out
Spawk Posted February 16, 2016 Posted February 16, 2016 The module doesn't need any changes. His problem is not having the cue files for the bin's. Sent from my SGH-I337M using Tapatalk
JoyStickKilla Posted February 16, 2016 Posted February 16, 2016 Yes but he wants to implement a different method of loading them which he says works. So the module could be updated most likely to do it which is why I said he should talk to them
progets Posted February 16, 2016 Posted February 16, 2016 Why not just create the .cue files? You could also use RetroArch which will play the .bin files without needing the .cue files. I think there are a bunch of options.
gigapig Posted February 16, 2016 Posted February 16, 2016 Doesn't ePSXe also just run PSX without using DT?
JoyStickKilla Posted February 16, 2016 Posted February 16, 2016 I agree with Spawk, there's no reason for them to spend time modifying the module because he has a bad set of images. I imagine they'll tell him the same thing. Well yeah but I was trying to give the guy hope lol.
gigapig Posted February 16, 2016 Posted February 16, 2016 Well yeah but I was trying to give the guy hope lol. If I know those module guys you have two hopes. Bob Hope and No hope
xbboyx101 Posted February 18, 2016 Author Posted February 18, 2016 So I have new games and Cue Files now but my Problem is when I run cd Rom with Damen tools the screen is black and nothing happened. .. In cd Rom config i coole the daemon tools drive i dont know i try to mount some DiffereNT Cue Files than the sound tracks from the game Disk Starts in windows but when I Lunch psx emulator and start run cd Rom i have black screen and nothing happened ....
Avar Posted February 19, 2016 Posted February 19, 2016 Do your cue files point to the correct locations? Right click them end open with notepad to check.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 In the Cue File in the First line is the Same Name from the Data the bin File ....
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 When There is something wrong i cant mount the File in daemon tools There wouöd ve error unable to mount These Image ....
Spawk Posted February 19, 2016 Posted February 19, 2016 Can you please explain again why you want to use dtools? You do NOT need it. Epsxe plays them fine doing its own mounting. What are trying to do here? Sent from my SGH-I337M using Tapatalk
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 I just need daemon tools to play some games with more Audio tracks when I only load the ISO File i have some games with out game Music i just want to mount a game with the Cue File in daemon tools and want to play this run cd Rom in the psx emulator but when I Do this it dosent work ... I dont know .... what happened Maybe regionale Code or bios dont know I need help
Spawk Posted February 19, 2016 Posted February 19, 2016 Ah, I see what you say now. You should still be able to load the cue file without dtools. One thing to note is that the extensions in RL are loaded in the order they are listed there. So make sure the cue extension is listed before the bin extension. This way the cue is sent to the emulator, not the bin. I can check more into this when I get home in about 4 hrs. Just for quick reference, what game has cd audio that I can test? Sent from my SGH-I337M using Tapatalk
Avar Posted February 19, 2016 Posted February 19, 2016 I just need daemon tools to play some games with more Audio tracks when I only load the ISO File i have some games with out game Music i just want to mount a game with the Cue File in daemon tools and want to play this run cd Rom in the psx emulator but when I Do this it dosent work ... I dont know .... what happened Maybe regionale Code or bios dont know I need help No, PSX will run games with CUE files just fine, even if zipped.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 I offen try to run the Cue File in the emulator but the game dont work 100% for example tomb raider 1 when I only load ISO an put the bin File or Cue the Music Files dosent load and in the menu i Presse start game There is black screen ... because the Sun Chanel Data is Not load es ...
Avar Posted February 19, 2016 Posted February 19, 2016 If some work and others don't that's a good indication the rom may be bad. A few games have quirks but Tomb Raider should play fine. Fault's gotta be in the rom itself or in the emu settings.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 So back to topic ... how can I start a game in psx emulator but with a Cue File that is mounted on daemon tools when I start ever game is black screen nothing happened ....
Spawk Posted February 19, 2016 Posted February 19, 2016 LOL, turn off dtools! The cue files load fine without it. Tomb Raider in particular is not great compatibility wise. Many people used to just get a blank screen with it, here is what was suggested (2 years ago): For ePSXe 1.9.0 try this... 1. Use Mooby2 2.8 cdrom plugin, uncheck 'subchannel reading' in the settings of that plugin. (Just in case: also make sure 'repeat all cdda' is checked, and 'cdda volume' is set to something like 50 or 60. Or else you won't hear anything.) 2. Launch the game with File -> Run CDrom (browse, select your cd image.) It's recommended to use Eternal 1.41 sound plugin with default settings along with this. So your issue is probably not with the way it's loading at all. Test with some different games.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 But when I use this plugin how can I write this in the module becase this plugin is run cd Rom ....
Avar Posted February 19, 2016 Posted February 19, 2016 But when I use this plugin how can I write this in the module becase this plugin is run cd Rom .... What version of HyperSpin and RocketLauncher are you using? It sounds like it's very out of date.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 I dont know I need to update the module ...
Avar Posted February 19, 2016 Posted February 19, 2016 I dont know I need to update the module ... Manual module updates haven't been a thing for a loooooong time though =/ When did you initially install HyperSpin? Will give us an idea as to where you're at.
xbboyx101 Posted February 19, 2016 Author Posted February 19, 2016 I am a hyperspin newbie... Van someone help me by teamvieqer or something ?
