Anyone posted a MAMEUIFX 172 & XML yet?
Metalzoic
  • Replies 51
i feel lost.. when did 172 come out? I know I recently updated a few weeks back but mame changes so damn much it's hard to keep up.. and I just checked my torrent for the last update and I believe it was 170 to 171 so now I need to get 172..... off to pleasure dome I go...
A new version is released on the last Wednesday of every month.
Just updated it and ran it outside of HS... looks like they updated the user interface a bit.
Anyone else having trouble with the direct input?? the buttons I have setup for ESC, coins, player 1 and tab aren't working.
This one is quite a major update and they recommend you discard your old ini files and create new ones. I just pasted some old settings into the new ini files like the controller cfg and glsl settings.
Seems like normally someone busts one out by now, but I haven't seen any.
If I'm missing it can someone link it.
I'm still hoping for a 0.172 build with direct input... it's been a while since I compiled one myself and it'll take forever to figure it all out again.
everything seems to be good except direct input.. so I can't use any of the buttons I have setup with Xpadder such as holding my start button to ESC back to hyperspin... and the buttons I have set up for coins and player 1 as well as the button I use for TAB... other than that... the controls in mame work fine. I can obviously just set the player 1 and coins but within mame but hopefully I can figure out why direct input isn't working so I can use my assigned tab button and esc, etc
would you like me to compile a uifx 172 built?
That'd be great if you would!
Yep. Hoping for a no-nag UIFX for 172 myself. Can never remember what DirectInput is for or if I need it with an iPac though.
if anyone can compile a mame64 172.. that would be cool. the think I don't get is the versions I downloaded from Hyperspin and a less trustworthy site that shall remain anonymous both said direct input. from my understanding the direct input is what allows me to use my assigned buttons for TAB, ESC (when I hold a button), etc.
I don't know if anyone else has noticed this. I have downloaded the vanilla version of Mameuifx and there is no nag screen if your Rocklauncher has "Legacy" set to either Default or False. If it is set to true then you get the Nag screen.
Also Mameuifx already has AFAIK raw input and direct input, you just need to switch Direct input in.
If I am wrong the please correct me.
whats the difference between raw & direct input... all i know is with one of them I'm able to use my xpadder assigned buttons for TAB, ESC (when I hold a button), etc.
no, i havent notice that, i would have to give it a try... i wonder if it runs different in that mode
A regular MAME64 with raw input would be very much appreciated.
i will make a mame one today and along with a updated mameuifx to 172.1
Awesome. Thank you.
it will be ready in a hour, half the power in my house is out, so coding on your cellphone is no fun when rdp into the pc... had to move my pc some where with it just plugged in lol
they changed how the input stuff is coded so it going take me a moment to figure it out. but i think in the mame.ini you enable it on both mame and mameuifx in those areas. dont quote me on thats...
just looking in the code, look like enable in the ini file
Thanks, sevenseal! Any chance you could do a MAMEUIFX direct input as well?
tried the mame64 that was uploaded but still didn't work for me....
starting 172, you have to use a fresh install of mame and copy over the compiled mame... there are many changes that require that
did a full fresh install with a copy of 172 from mamedev's copied over the patched mame64 and did a -cc, still unable to use my xpadder assigned buttons that I have setup for TAB and ESC (when I hold the start button it triggers ESC which I use to exit back to hyperspin)
Has anyone been able to setup the new mame with their Xpadder and assigned buttons like ESC for exiting to Hyperspin?
Someone mentioned that we may have to change a line in the .ini but I've searched and can't find such a line. to be honest if there aren't any updates that affect SPEED and better GLSL/HLSL... I'll just go back to 171 until I can figure out the raw/direct input for 172. I will admit that running 172 from the comman line feels much better than previous versions.
