flippnswitchez Posted April 10, 2015 Posted April 10, 2015 I have the exact same setup. Thank you for the help. I actually have not even used the spinner yet. That will be my next thing.
Roc Posted April 23, 2015 Posted April 23, 2015 I'm trying to use my Aimtrak light gun with American laser games but the light gun only goes around the borders. Any ideas why?
rfancella Posted April 23, 2015 Author Posted April 23, 2015 Hi, Need a little more info. You probably need to run it in -fullscreen_window mode. Are you launching it through RocketLauncher/HyperLaunch3 or through bat files?  Thanks, Ron   I'm trying to use my Aimtrak light gun with American laser games but the light gun only goes around the borders. Any ideas why? Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
CroCop Posted May 14, 2015 Posted May 14, 2015 I have setup everything like your Guide and i can start every Game with the batch files like a charm. However when i try to start with Rocketlauncher / Hyperspin, only a black CMD Window is openening for a second and closes again. What im doing wrong?
rfancella Posted May 15, 2015 Author Posted May 15, 2015 Hi, please post your RocketLauncher log using code tags please.  Thanks, Ron   I have setup everything like your Guide and i can start every Game with the batch files like a charm. However when i try to start with Rocketlauncher / Hyperspin, only a black CMD Window is openening for a second and closes again. What im doing wrong? Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
evh347 Posted June 1, 2015 Posted June 1, 2015 I had to come here to chime to help anyone else who might run into this problem. All of my ALG games worked in Daphne Singe, but (recently) my ActionMax games started failing to load. Outside of RL/HS, the .bat file would launch the ActionMax game to a green screen and then it would crash. In review of the Daphne Log, it kept crashing on something about "Unable to Load Font". I landed on this helpful thread and it convinced me to re-download the ActionMax emulator. In the download, I located this folder: C:\Daphne\singe\ActionMaxI copied over all the contents into my respective folder. I didn't touch any of the video files and I didn't have to change any of my bat files. I guess something along the way got borked, because after I did this and re-launched one of the ActionMax bat files, the game launched with no issues.  They launch in RL/HS as well. Thanks for the great thread!
SamVSsami Posted June 2, 2015 Posted June 2, 2015 Thank you for another GREAT Guide Rfancella. Finally after Daphne I will get this one to work with your help ofcourse... It seem it is looking for video_ActionMaxIntro.m2v, but cant find it. I've checked the folders but it isnt there. Do I have to download this somewhere? I have redownloaded the EMU just to be sure but nothing. Please help!   --DAPHNE version 1.0.10--Command line is: D:\HyperSpin\Emulators\daphne_singe\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile D:\HyperSpin\Emulators\daphne_singe\singe/ActionMax/frame_38AmbushAlley.txt -script D:\HyperSpin\Emulators\daphne_singe\singe/ActionMax/38AmbushAlley.singe--CPU : AuthenticAMD 4000 MHz || Mem : 4096 megs--OS : Windows NT Derivative || Video : AMD Radeon R9 200 Series--OpenGL: Compiled In--RGB2YUV Function: MMX--Line Blending Function: MMX--Audio Mixing Function: MMXSetting screen width to 800Setting screen height to 600Set 1920x1080 at 32 bpp with flags: 20Initializing sound system ...Joystick #0 was successfully openedFramefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/daphne_singe/singe/ActionMax/./Could not open file : D:/HyperSpin/Emulators/daphne_singe/singe/ActionMax/./video_ActionMaxIntro.m2vCould not initialize laserdisc player!Shutting down sound system...Shutting down video display...  SOLVED: Downloaded the Torent and the files was in it Build your cabinet, conquer the codes, become a King of Chaos!
SamVSsami Posted June 2, 2015 Posted June 2, 2015 I have setup everything like your Guide and i can start every Game with the batch files like a charm. However when i try to start with Rocketlauncher / Hyperspin, only a black CMD Window is openening for a second and closes again. What im doing wrong?  Same problem here, please help!  00:39:18:902 | RL |    INFO | +N/A  | Main - RocketLauncher v1.0.0.1 (www.rlauncher.com) 00:39:18:949 | RL |    INFO | +47   | Main - System Specs:                RocketLauncher Dir: C:\HyperSpin\RocketLauncher                RocketLauncher is: 32-bit                OS: Microsoft Windows 8.1 Pro                SKU: Professional                Total Memory: 8148.37 MB                Free Memory: 5804.75 MB                Used Memory: 2343.621 MB                SystemType: 64-bit                Physical Processors: 1                Logical Processors: 8                GPU 1 Name: AMD Radeon R9 200 Series                GPU 1 RAM: -1.00 MB                GPU 1 Driver Version: 14.501.1003.0                Sound 1 Device: AMD High Definition Audio Device                Sound 1 Status: Enabled                Sound 2 Device: Realtek High Definition Audio                Sound 2 Status: Enabled                OS Language: Dutch_Standard                OS Admin Status: No                Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)                Monitor #1 Orientation: Landscape                Current AHK Desktop Width: 1920                Current AHK Desktop Height: 1080                AutoHotkey Path:                AHK Version: 1.1.09.04                Unicode: No 00:39:18:949 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\RocketLauncher.exe exists 00:39:18:949 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           RocketLauncher                FileVersion               1.0.0.1                LegalCopyright            �2015 RocketLauncher                ProductName               djvj's one swell guy!                ProductVersion            1.1.9.4                CompanyName               Your favorite Front End companion! Visit us @ www.rlauncher.com                File Size:         2084352 bytes                Created:         5/3/2015 - 10:35:42                Modified:         5/31/2015 - 3:31:01 00:39:18:949 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\BinHexRW.ahk exists 00:39:18:965 | RL |  DEBUG1 | +15   | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:965 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         4961 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:965 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\BlockInput.exe exists 00:39:18:965 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription                FileVersion               1.1.09.04                InternalName                OriginalFilename                ProductName                ProductVersion            1.1.09.04                File Size:         657920 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:965 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\CLR.ahk exists 00:39:18:965 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:965 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         10586 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:965 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\COM.ahk exists 00:39:18:965 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:965 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         26342 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:965 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Control_AniGif.ahk exists 00:39:18:965 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:965 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         5716 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:965 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gdip.ahk exists 00:39:18:980 | RL |  DEBUG1 | +16   | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         88789 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gdip_alt.ahk exists 00:39:18:980 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         3394 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:18:980 | RL |  DEBUG1 | +0    | gdip_alt.ahk Version: 1.0.1 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gsdll32.dll exists 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         13090816 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\itextsharp.dll exists 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           iTextSharp                FileVersion               5.4.2.0                InternalName              itextsharp.dll                LegalCopyright            Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.                OriginalFilename          itextsharp.dll                ProductName               iTextSharp                ProductVersion            5.4.2.0                CompanyName               1T3XT BVBA                File Size:         3743744 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Java.ahk exists 00:39:18:980 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         7841 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:980 | RL |  DEBUG1 | +0    | Java.ahk Version: 1.0.0 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\JSON.ahk exists 00:39:18:980 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         9203 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Origin.ahk exists 00:39:18:980 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:980 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         4904 bytes                Created:         3/24/2015 - 11:37:22                Modified:         5/21/2015 - 2:23:25 00:39:18:980 | RL |  DEBUG1 | +0    | Origin.ahk Version: 1.0.2 00:39:18:980 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\RegRW64.ahk exists 00:39:18:996 | RL |  DEBUG1 | +16   | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         6915 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\RIni.ahk exists 00:39:18:996 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         67561 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           SevenZipSharp                FileVersion               0.64.4841.31212                InternalName              SevenZipSharp.dll                LegalCopyright            Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3                OriginalFilename          SevenZipSharp.dll                ProductName               SevenZipSharp                ProductVersion            0.64.4841.31212                CompanyName               Markovtsev Vadim                File Size:         165888 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Steam.ahk exists 00:39:18:996 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         5347 bytes                Created:         3/24/2015 - 11:37:22                Modified:         5/21/2015 - 2:22:57 00:39:18:996 | RL |  DEBUG1 | +0    | Steam.ahk Version: 1.0.2 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\VA.ahk exists 00:39:18:996 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Extension. 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         34688 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\VA_Extension.ahk exists 00:39:18:996 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:18:996 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         3833 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:03:00 00:39:18:996 | RL |  DEBUG1 | +0    | VA_Extension.ahk Version: 1.0.1 00:39:18:996 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\7z.ahk exists 00:39:18:011 | RL |  DEBUG1 | +15   | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:011 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         29133 bytes                Created:         5/31/2015 - 3:30:41                Modified:         5/31/2015 - 3:30:41 00:39:19:011 | RL |  DEBUG1 | +0    | 7z.ahk Version: 1.0.0 00:39:19:011 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Bezel.ahk exists 00:39:19:011 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:011 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         101747 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:10 00:39:19:011 | RL |  DEBUG1 | +0    | Bezel.ahk Version: 1.1.0 00:39:19:011 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade.ahk exists 00:39:19:011 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:011 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         36786 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:23 00:39:19:011 | RL |  DEBUG1 | +0    | Fade.ahk Version: 1.0.10 00:39:19:011 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade Init.ahk exists 00:39:19:011 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:011 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         999 bytes                Created:         3/24/2015 - 11:37:21                Modified:         2/17/2015 - 5:02:59 00:39:19:011 | RL |  DEBUG1 | +0    | Fade Init.ahk Version: 1.0.1 00:39:19:011 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade Animations.ahk exists 00:39:19:027 | RL |  DEBUG1 | +16   | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:027 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         79822 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:31 00:39:19:027 | RL |  DEBUG1 | +0    | Fade Animations.ahk Version: 1.1.6 00:39:19:027 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Pause.ahk exists 00:39:19:027 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:027 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         379298 bytes                Created:         5/21/2015 - 2:22:58                Modified:         5/31/2015 - 3:30:57 00:39:19:027 | RL |  DEBUG1 | +0    | Pause.ahk Version: 1.1.0 00:39:19:027 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Pause Init.ahk exists 00:39:19:027 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:027 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         590 bytes                Created:         5/21/2015 - 2:22:53                Modified:         5/21/2015 - 2:22:54 00:39:19:043 | RL |  DEBUG1 | +16   | Pause Init.ahk Version: 1.0.2 00:39:19:043 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Keymapper.ahk exists 00:39:19:043 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:043 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         33453 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/22/2015 - 12:12:24 00:39:19:043 | RL |  DEBUG1 | +0    | Keymapper.ahk Version: 1.1.2 00:39:19:043 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Keymapper Init.ahk exists 00:39:19:043 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:043 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         3461 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/22/2015 - 12:12:22 00:39:19:043 | RL |  DEBUG1 | +0    | Keymapper Init.ahk Version: 1.0.4 00:39:19:043 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiGame.ahk exists 00:39:19:043 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:043 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         40639 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:01 00:39:19:043 | RL |  DEBUG1 | +0    | MultiGame.ahk Version: 1.0.6 00:39:19:043 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiGame Init.ahk exists 00:39:19:043 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:043 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         161 bytes                Created:         3/24/2015 - 11:37:21                Modified:         2/17/2015 - 5:02:59 00:39:19:043 | RL |  DEBUG1 | +0    | MultiGame Init.ahk Version: 1.0.0 00:39:19:043 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiPlayer.ahk exists 00:39:19:043 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:058 | RL |  DEBUG1 | +15   | CheckFile - Attributes:                File Size:         58641 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:09 00:39:19:058 | RL |  DEBUG1 | +0    | MultiPlayer.ahk Version: 1.0.5 00:39:19:058 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Password.ahk exists 00:39:19:058 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:058 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         10040 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:14 00:39:19:058 | RL |  DEBUG1 | +0    | Password.ahk Version: 1.0.1 00:39:19:058 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists 00:39:19:058 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:058 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         73587 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:12 00:39:19:058 | RL |  DEBUG1 | +0    | Rom Mapping Launch Menu.ahk Version: 1.0.4 00:39:19:058 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Shared.ahk exists 00:39:19:058 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:058 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         110446 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/31/2015 - 3:30:57 00:39:19:058 | RL |  DEBUG1 | +0    | Shared.ahk Version: 1.2.6 00:39:19:058 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Statistics.ahk exists 00:39:19:058 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:074 | RL |  DEBUG1 | +16   | CheckFile - Attributes:                File Size:         26143 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:22:59 00:39:19:074 | RL |  DEBUG1 | +0    | Statistics.ahk Version: 1.0.3 00:39:19:074 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Statistics Init.ahk exists 00:39:19:074 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:074 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         33 bytes                Created:         3/24/2015 - 11:37:21                Modified:         2/17/2015 - 5:02:59 00:39:19:074 | RL |  DEBUG1 | +0    | Statistics Init.ahk Version: 1.0.1 00:39:19:074 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Virtual Drive.ahk exists 00:39:19:074 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:074 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         17072 bytes                Created:         5/31/2015 - 3:30:41                Modified:         5/31/2015 - 3:30:41 00:39:19:074 | RL |  DEBUG1 | +0    | Virtual Drive.ahk Version: 1.0.0 00:39:19:074 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\XHotkey.ahk exists 00:39:19:074 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:074 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         29626 bytes                Created:         3/24/2015 - 11:37:21                Modified:         5/21/2015 - 2:23:31 00:39:19:074 | RL |  DEBUG1 | +0    | XHotkey.ahk Version: 1.0.3 00:39:19:074 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\XHotkey Init.ahk exists 00:39:19:074 | RL |  DEBUG1 | +0    | CRC Check - CRC matches, this is an official unedited Library. 00:39:19:074 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         1236 bytes                Created:         3/24/2015 - 11:37:21                Modified:         2/17/2015 - 5:02:59 00:39:19:074 | RL |  DEBUG1 | +0    | XHotkey Init.ahk Version: 1.0.0 00:39:19:074 | RL |  DEBUG1 | +0    | Main - Raw CLI received: "-s WoW Action Max -r PopsGhostly -f C:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1" 00:39:19:074 | RL |  DEBUG1 | +0    | Main - Received this dbName with no path via CLI: "PopsGhostly" 00:39:19:074 | RL |  DEBUG1 | +0    | Main - dbName: PopsGhostly 00:39:19:074 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Plugins\HyperSpin.plugin exists 00:39:19:074 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         8969 bytes                Created:         3/24/2015 - 11:37:23                Modified:         5/21/2015 - 2:23:28 00:39:19:089 | RL |    INFO | +15   | Main - Loading Front End Plugin: "HyperSpin" 00:39:19:089 | RL |    INFO | +0    | Main - RocketLauncher received "WoW Action Max" and "PopsGhostly" 00:39:19:089 | RL |    INFO | +0    | Main - Did not find a "C:\HyperSpin\RocketLauncher\Settings\WoW Action Max\Game Options.ini" file, skipping any game-specific options. 00:39:19:089 | RL |    INFO | +0    | Main - PopsGhostly is using the default emulator: Daphne Singe 00:39:19:089 | RL |    INFO | +0    | Main - Checking for a [Daphne Singe] section in C:\HyperSpin\RocketLauncher\Settings\WoW Action Max\Emulators.ini 00:39:19:089 | RL |    INFO | +0    | Main - Checking for a [Daphne Singe] section in C:\HyperSpin\RocketLauncher\Settings\Global Emulators.ini 00:39:19:089 | RL |    INFO | +0    | Main - Found [Daphne Singe] in C:\HyperSpin\RocketLauncher\Settings\Global Emulators.ini 00:39:19:089 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk exists 00:39:19:089 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         10056 bytes                Created:         3/24/2015 - 11:37:22                Modified:         5/21/2015 - 2:23:33 00:39:19:089 | RL |    INFO | +0    | Main - CRC Check - CRC matches, this is an official unedited module. 00:39:19:089 | RL |    INFO | +0    | Main - PopsGhostly will use module: C:\HyperSpin\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk 00:39:19:105 | RL |    INFO | +16   | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 00:39:19:105 | RL |    INFO | +0    | CheckFile - Checking if D:\HyperSpin\Emulators\daphne_singe\daphne.exe exists 00:39:19:105 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           DAPHNE, a Laserdisc Arcade Game Emulator                FileVersion               0, 1, 0, 10                InternalName              daphne                LegalCopyright            Copyright (C) 1999-2010 Matt Ownby                OriginalFilename          daphne.exe                ProductName               daphne Application                ProductVersion            0, 1, 0, 10                File Size:         643072 bytes                Created:         12/22/2010 - 5:50:16                Modified:         6/2/2015 - 9:47:30 00:39:19:105 | RL |    INFO | +0    | Main - INI Keys read 00:39:19:105 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\7z.exe exists 00:39:19:105 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           7-Zip Console                FileVersion               9.20                InternalName              7z                LegalCopyright            Copyright (c) 1999-2010 Igor Pavlov                OriginalFilename          7z.exe                ProductName               7-Zip                ProductVersion            9.20                CompanyName               Igor Pavlov                File Size:         163840 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:19:121 | RL |    INFO | +16   | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\7z.dll exists 00:39:19:121 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           7z Standalone Plugin                FileVersion               9.20                InternalName              7za                LegalCopyright            Copyright (c) 1999-2010 Igor Pavlov                OriginalFilename          7za.dll                ProductName               7-Zip                ProductVersion            9.20                CompanyName               Igor Pavlov                File Size:         914432 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:19:121 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\FontReg.exe exists 00:39:19:121 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           Font Registration Utility (x86-32)                FileVersion               2.1.3.0                OriginalFilename          FontReg.exe                File Size:         6144 bytes                Created:         3/24/2015 - 11:37:22                Modified:         2/17/2015 - 5:02:59 00:39:19:121 | RL |    INFO | +0    | Main - "PopsGhostly" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 00:39:19:121 | RL |    INFO | +0    | CheckPaths - Started 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Looking for rom: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.singe 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Looking for rom by name in subfolder: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly\PopsGhostly.singe 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Rom not found 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Looking for rom: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.bat 00:39:19:121 | RL |    INFO | +0    | CheckPaths - Found rom: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.bat 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Current romName: PopsGhostly 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Current romPath: D:\HyperSpin\Emulators\daphne_singe\AMframefile 00:39:19:121 | RL |  DEBUG1 | +0    | CheckPaths - Current romExtension: .bat 00:39:19:121 | RL |    INFO | +0    | CheckPaths - Ended 00:39:19:121 | RL |    INFO | +0    | BuildScript - User Variables:                ;----------------------------------------------------------------------------                ; INJECTED VARIABLES                ;----------------------------------------------------------------------------                #NoTrayIcon                #InstallKeybdHook                DetectHiddenWindows, ON                SetTitleMatchMode, 2                SendMode, Event                0 = 10                pluginPath = C:\HyperSpin\RocketLauncher\Plugins                pluginName = HyperSpin                pluginExt = .plugin                contextOnExit = 1                rlMode =                rlTitle = RocketLauncher                rlVersion = 1.0.0.1                rlAuthor = djvj                rlURL = www.rlauncher.com                langFile = C:\HyperSpin\RocketLauncher\Data\Language\Localization.ini                frontendPID =                frontendPath = C:\HyperSpin                frontendExe = HyperSpin.exe                frontendExt = exe                frontendName = HyperSpin                frontendDrive = C:                exitEmulatorKey = ~Esc                exitEmulatorKeyWait = 0                forceHoldKey = ~Esc                restoreFE = false                exitScriptKey = ~q & ~s                toggleCursorKey = ~e & ~t                emuFullPath = D:\HyperSpin\Emulators\daphne_singe\daphne.exe                emuPath = D:\HyperSpin\Emulators\daphne_singe                emuName = Daphne Singe                emuExt = exe                romPath = D:\HyperSpin\Emulators\daphne_singe\AMframefile                romPathFromIni = D:\HyperSpin\Emulators\daphne_singe\AMframefile                romExtension = .bat                romExtensionOrig = .bat                romExtensions = singe|bat                executable = daphne.exe                systemDbName = WoW Action Max                systemName = WoW Action Max                dbPath =                dbName = PopsGhostly                dbExt =                romName = PopsGhostly                romMapPath =                romMappingEnabled = false                romMappingLaunchMenuEnabled = false                romMappingFirstMatchingExt = false                romMappingShowAllRomsInArchive = true                romMappingNumberOfGamesByScreen = 7                romMappingMenuWidth = 400                romMappingMenuMargin = 65                romMappingTextFont = Bebas Neue                romMappingTextOptions = cFFFFFFFF r4 s60 Bold                romMappingDisabledTextColor = ff888888                romMappingTextSizeDifference = 7                romMappingTextMargin = 15                romMappingTitleTextFont = Bebas Neue                romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold                romMappingTitle2TextFont = Bebas Neue                romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold                romMappingGameInfoTextFont = Bebas Neue                romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular                romMappingBackgroundBrush = aa000000                romMappingColumnBrush = 33000000                romMappingButtonBrush1 = 6f000000                romMappingButtonBrush2 = 33000000                romMappingBackgroundAlign = Stretch and Lose Aspect                romMappingMenuFlagWidth = 55                romMappingMenuFlagSeparation = 7                romMappingDefaultMenuList = FullList                romMappingSingleFilteredRomAutomaticLaunch = false                altArchiveNameOnly =                altRomNameOnly =                altArchiveAndRomName =                altArchiveAndManyRomNames =                altRomNamesOnly =                romMapScenario =                skipchecks = false                romMatchExt = false                blockInputTime = 0                blockInputFile = C:\HyperSpin\RocketLauncher\Module Extensions\BlockInput.exe                errorLevelReporting = false                lockLaunch = false                lockLaunchGame =                screenRotationAngle = 0                screenRotationAngleGame =                logFile = C:\HyperSpin\RocketLauncher\RocketLauncher.log                logLabel := ["   INFO"," WARNING","  ERROR"," DEBUG1"," DEBUG2"]                logLevel = 10                logShowDebugConsole = false                logIncludeModule = true                logIncludeFileProperties = true                logShowCommandWindow = false                logCommandWindow = false                rlDebugConsoleStdout =                sysLang = Dutch_Standard                sysType = 64-bit                navUpKey = Up                navDownKey = Down                navLeftKey = Left                navRightKey = Right                navSelectKey = Enter                navP2UpKey = Numpad8                navP2DownKey = Numpad2                navP2LeftKey = Numpad4                navP2RightKey = Numpad6                navP2SelectKey = NumpadEnter                originalWidth = 1920                originalHeight = 1080                vdEnabled = false                vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\daemon.exe                vdUseSCSI = true                vdDriveLetter =                vdAddDrive = true                servoStikEnabled = false                ledblinkyEnabled = false                ledblinkyFullPath =                ledblinkyProfilePath = C:\HyperSpin\RocketLauncher\Profiles\LEDBlinky                ledblinkyRLProfile = C:\HyperSpin\RocketLauncher\Profiles\LEDBlinky\RocketLauncher                emuIdleShutdown = 0                launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==                hideCursor = false                hideEmu = false                hideFE = false                fadeIn = true                fadeInDuration = 750                fadeInTransitionAnimation = DefaultAnimateFadeIn                fadeInDelay = 0                fadeInExitDelay = 0                fadeOutExitDelay = 0                fadeOut = true                fadeOutExtraScreen = false                fadeOutDuration = 500                fadeOutTransitionAnimation = DefaultAnimateFadeOut                fadeOutDelay = 0                fadeLyrInterpolation = 7                fadeMuteEmulator = false                fadeUseBackgrounds = true                fadeWidthBaseRes = 1920                fadeHeightBaseRes = 1080                fadeLyr1Color = FF000000                fadeLyr1AlignImage = Stretch and Lose Aspect                fadeLyr2Pos = Top Center                fadeLyr2X = 0                fadeLyr2Y = 0                fadeLyr2W =                fadeLyr2H =                fadeLyr2Adjust = 1                fadeLyr2PicPad = 0                fadeLyr2Prefix = Layer 2                fadeLyr3Pos = Center                fadeLyr3X = 450                fadeLyr3Y = 450                fadeLyr3W =                fadeLyr3H =                fadeLyr3Adjust = 1                fadeLyr3PicPad = 0                fadeLyr3Speed = 750                fadeLyr3Animation = DefaultFadeAnimation                fadeLyr37zAnimation = DefaultFadeAnimation                fadeLyr3Type = imageandbar                fadeLyr3ImgFollow7zProgress = true                fadeLyr3Repeat = 1                fadeLyr3BackImageTransparency = 30                fadeLyr3StaticPos = No Alignment                fadeLyr3StaticX = 0                fadeLyr3StaticY = 870|1575                fadeLyr3StaticW =                fadeLyr3StaticH =                fadeLyr3StaticAdjust = 1                fadeLyr3StaticPicPad = 0                fadeLyr3StaticPrefix = Info Bar                fadeLyr4Adjust = 1                fadeLyr4X = 1792|952                fadeLyr4Y = 891|1596                fadeLyr4W = 128                fadeLyr4H =                fadeLyr4Pos = No Alignment                fadeLyr4FPS = 50                fadeLyr4PicPad = 0                fadeTranspGifColor = FFFFFF                fadeBarWindow = Image                fadeBarWindowX =                fadeBarWindowY =                fadeBarWindowW = 900                fadeBarWindowH =                fadeBarWindowR = 30                fadeBarWindowM = 30                fadeBarWindowHatchStyle = 8                fadeBar = 7zOnly                fadeBarNon7zProgressTime = 0                fadeBarBack = true                fadeBarBackColor = FF555555                fadeBarH = 30                fadeBarR = 10                fadeBarColor = DD00BFFF                fadeBarHatchStyle = 8                fadeBarPercentageText = true                fadeBarInfoText = true                fadeBarXOffset = 0                fadeBarYOffset = 150                fadeRomInfoDescription = filtered text                fadeRomInfoSystemName = image                fadeRomInfoYear = text with label                fadeRomInfoManufacturer = text with label                fadeRomInfoGenre = disabled                fadeRomInfoRating = image                fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating                fadeRomInfoTextPlacement = User Defined                fadeRomInfoTextMargin = 7                fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular                fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold                fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular                fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular                fadeRomInfoText5Options = cFF555555 r4 s42 Bold                fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular                fadeStats_Number_of_Times_Played = text with label                fadeStats_Last_Time_Played = text with label                fadeStats_Average_Time_Played = text with label                fadeStats_Total_Time_Played = text with label                fadeStats_System_Total_Played_Time = text with label                fadeStats_Total_Global_Played_Time = text with label                fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time                fadeStatsInfoTextPlacement = topRight                fadeStatsInfoTextMargin = 7                fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold                fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold                fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold                fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold                fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold                fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold                fadeText1X = 0                fadeText1Y = 0                fadeText1Options = cFFB4B4B4 r4 s30 Right Bold                fadeText1 = Loading Game                fadeText2X = 0                fadeText2Y = 0                fadeText2Options = cFFB4B4B4 r4 s30 Right Bold                fadeText2 = Extraction Complete, Ready                fadeText3 = Loading Game                fadeText4 = Loading Complete                fadeFont = Segoe UI Symbol                fadeSystemAndRomLayersOnly = true                fadeExtractionTime = disabled                fadeExtractionTimeTextX = 0                fadeExtractionTimeTextY = 0                fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold                fadeInterruptKey =                detectFadeErrorEnabled = true                fadeImgPath = C:\HyperSpin\RocketLauncher\Media\Fade                RLDataPath = C:\HyperSpin\RocketLauncher\Data                RLMediaPath = C:\HyperSpin\RocketLauncher\Media                RLErrSoundPath = C:\HyperSpin\RocketLauncher\Media\Sounds\Error                modulesPath = C:\HyperSpin\RocketLauncher\Modules                moduleFullName = C:\HyperSpin\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk                moduleName = Daphne Singe                modulePath = C:\HyperSpin\RocketLauncher\Modules\Daphne Singe                moduleExtension = ahk                moduleExtensionsPath = C:\HyperSpin\RocketLauncher\Module Extensions                libPath = C:\HyperSpin\RocketLauncher\Lib                7zEnabled = true                7zPath = C:\HyperSpin\RocketLauncher\Module Extensions\7z.exe                7zDllPath = C:\HyperSpin\RocketLauncher\Module Extensions\7z.dll                7zExtractPath = C:\HyperSpin\Temp                7zExtractPathOrig =                7zAttachSystemName = true                7zDelTemp = true                7zSounds = true                7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar                7zFormatsNoP = zip,rar,7z,lzh,gzip,tar                mgEnabled = true                mgKey = ~NumpadSub                mgBackgroundColor = FF000000                mgSidePadding = 0.2                mgWidthBaseRes = 1920                mgHeightBaseRes = 1080                mgYOffset = 500|800                mgFont = Arial                mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic                mgText1Text = Please select a game                mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic                mgText2Offset = 100                mgUseSound = true                mgSoundfreq = 300                mgExitEffect = none                mgSelectedEffect = rotate                mgUseGameArt = true                mgCandidate =                mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side                mgOnLaunch = true                pauseEnabled = true                pauseKey = 5&1                pauseBackToMenuBarKey = D                pauseZoomInKey = A                pauseZoomOutKey = S                pauseScreenshotKey = ~PrintScreen                pauseHiToTextPath = C:\HyperSpin\RocketLauncher\Module Extensions\HiToText.exe                pauseSaveStateKeyCodes =                pauseLoadStateKeyCodes =                keymapperEnabled = false                keymapperAHKMethod = false                keymapper = xpadder                xpadderFullPath = C:\HyperSpin\Utilities\Xpadder.exe                joyToKeyFullPath = C:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe                keymapperProfilePath = C:\HyperSpin\RocketLauncher\Profiles\xpadder                keymapperFrontEndProfileName = HyperSpin                keymapperFrontEndProfile = false                keymapperRocketLauncherProfileEnabled = false                JoyIDsEnabled = false                JoyIDsPreferredControllersSystem = use_global                JoyIDsPreferredControllersGlobal = Controller (XBOX 360 For Windows)                CustomJoyNamesEnabled = false                CustomJoyNames =                rotateMethod = false                FEProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\HyperSpin                defaultProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\_Default                systemProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\WoW Action Max                xPadderSystemProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\WoW Action Max\_Default                emuProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\WoW Action Max\Daphne Singe                romProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\WoW Action Max\PopsGhostly                RocketLauncherProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\RocketLauncher                blankProfile = C:\HyperSpin\RocketLauncher\Profiles\xpadder\_Default\blank                ahkFEProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\HyperSpin                ahkDefaultProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\_Default                ahkSystemProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\WoW Action Max                ahkEmuProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\WoW Action Max\Daphne Singe                ahkRomProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\WoW Action Max\PopsGhostly                ahkRocketLauncherProfile = C:\HyperSpin\RocketLauncher\Profiles\AHK\RocketLauncher                bezelEnabled = true                bezelICEnabled = true                statisticsEnabled = true                pressDuration = -1                emuVolume = 1                dxwndIni = C:\HyperSpin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini                dxwndFullPath = C:\HyperSpin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe                mon1O = 0                pacDrivedllFile = C:\HyperSpin\RocketLauncher\Module Extensions\PacDrive32.dll                userFadeAnimIniFile = C:\HyperSpin\RocketLauncher\Lib\User Fade Animations.ini 00:39:19:121 | RL |    INFO | +0    | BuildScript - Loaded XHotkey Init.ahk scripts 00:39:19:121 | RL |    INFO | +0    | BuildScript - Loaded Fade Init.ahk scripts 00:39:19:121 | RL |    INFO | +0    | BuildScript - Loaded Pause Init.ahk scripts 00:39:19:121 | RL |    INFO | +0    | BuildScript - Loaded Statistics Init.ahk scripts 00:39:19:121 | RL |    INFO | +0    | BuildScript - Loaded MultiGame Init.ahk scripts 00:39:19:121 | RL | WARNING | +0    | BuildScript - "C:\HyperSpin\RocketLauncher\Lib\User Functions Init.ahk" not found 00:39:19:121 | RL |  DEBUG1 | +0    | BuildScript - Module starts on line: 2 00:39:19:121 | RL |    INFO | +0    | BuildScript - Validating module 00:39:19:136 | RL |    INFO | +15   | BuildScript - Validation complete 00:39:19:136 | RL |    INFO | +0    | BuildScript - Module:                MEmu = Daphne Singe                MEmuV = v1.14                MURL = http://www.singeengine.com/cms/                MAuthor = djvj                MVersion = 2.0.6                MCRC = 60C75E1                iCRC = 777E5B50                MID = 635038268880264228                MSystem = "American Laser Games","WoW Action Max"                ;----------------------------------------------------------------------------                ; Notes:                ; Rom_Extension should be singe                ; Your framefiles need to exist in the same dir as your Rom_Path, in each game's subfolder, and have a txt extension. The filename should match the name in your xml.                ; If you are upgrading from the old daphne-singe-v1.0 to 1.14, don't forget to copy the old singe dir to the new emu folder, it doesn't come with the contents of that folder that you need.                ; For this emu to work, paths need to be set in the singe files pointing to the movie files. The old method was done with manual file edits. The new method has the module do it for you automatically.                ;                ; NEW METHOD:                ; Do nothing!                ;                ; OLD METHOD:                ; American Laser Games                ; For example, If you rompath is C:Hyperspin\Games\American Laser Games\, the drugwars game would be found in C:Hyperspin\Games\American Laser Games\maddog\                ; and the framefile would be in C:Hyperspin\Games\American Laser Games\maddog\maddog.txt                ; To change the dir you want to run your games from:                ; 1. Backup all your /daphne/singe/ROMNAME/ROMNAME.singe, cdrom-globals.singe, and service.singe files, most games all three in each romdir                ; 2. Move all the folders in your /daphne/singe/ folder to the new location you want. You should have one folder for each game.                ; 3. Open each ROMNAME.singe, cdrom-globals.singe, and service.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:                ; Old                ; ("singe/                ; New:                ; ("//SERVER/Hyperspin/Games/American Laser Games/                ;                ; If using a local drive, it would look something like this C:/Hyperspin/Games/American Laser Games/                ; WoW Action Max                ; Emu_Path should be something like this C:\HyperSpin\Emulators\WoW Action Max\daphne-singe\                ; Rom_Path has to point to where all the m2v video files are kept                ; Rom_Extension should be singe                ; Your framefiles need to exist in the same dir as your rompath and all have txt extensions. The filename should match the name in your xml.                ; To change the dir you want to run your games from:                ; 1. Backup your /daphne/singe/Action Max/Emulator.singe file                ; 2. Move all the files (except Emulator.singe) in your /daphne/singe/Action Max/ folder to the new location you want.                ; 3. Open Emulator.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:                ; Old                ; "singe/Action Max/                ; New:                ; "//SERVER/Hyperspin/Games/WoW Action Max/                ;                ; If using a local drive, it would look something like this C:/Hyperspin/Games/WoW Action Max/                ;                ; There should be 18 instances that need replacing.                ; 4. The only file that should be in your /daphne/singe/Action Max/ dir should be the edited Emulator.singe file (and your backup).                ;----------------------------------------------------------------------------                StartModule()                BezelGUI()                FadeInStart()                settingsFile := modulePath . "\" . moduleName . ".ini"                fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1)                globalParams := IniReadCheck(settingsFile,"settings","globalParams","",,1)                daphneWidth := IniReadCheck(settingsFile, "settings", "daphneWidth","1024",,1)                daphneHeight := IniReadCheck(settingsFile, "settings", "daphneHeight","768",,1)                singePathUpdate := IniReadCheck(settingsFile, "settings", "SingePathUpdate","true",,1)                forcePathUpdate := IniReadCheck(settingsFile, "settings", "ForcePathUpdate","false",,1)                params := IniReadCheck(settingsFile,romName,"params","",,1)                params := " " . globalParams . " " . params                BezelStart()                ; Emptying variables If they are not set                fullscreen := If fullscreen = "true" ? " -fullscreen_window" : ""   ; fullscreen_window mode allows guncon and aimtraks to work                If bezelPath  ; this variable is only filled if bezel is enabled and a valid bezel image is found                {   params := params . " -ignore_aspect_ratio"                   daphneWidth := " -x " . Round(bezelScreenWidth) ;bezelScreenWidth variable is defined on the BezelStart function and it gives the desired width that your game screen should have while using this bezel                   daphneHeight := " -y " . Round(bezelScreenHeight) ;idem above                } Else {                   daphneWidth := " -x " . daphneWidth                   daphneHeight := " -y " . daphneHeight                }                hideEmuObj := Object("DAPHNE ahk_class SDL_app",1)   ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later                7z(romPath, romName, romExtension, 7zExtractPath)                If singePathUpdate = true                   SingePathUpdate()                HideEmuStart()   ; This fully ensures windows are completely hidden even faster than winwait                ; This allows us to send variables, that when empty, are not sent to the Run command                Run(executable . " singe vldp" . daphneWidth . daphneHeight . fullscreen . params . " -framefile """ . romPath . "\" . romName . ".txt"" -script """ . romPath . "\" . romName . ".singe""", emuPath)                WinWait("DAPHNE ahk_class SDL_app")                WinWaitActive("DAPHNE ahk_class SDL_app")                BezelDraw()                HideEmuEnd()                FadeInExit()                Process("WaitClose", executable)                7zCleanUp()                FadeOutExit()                ExitModule()                SingePathUpdate(){                   Global romPath,romName,updatedLines,forcePathUpdate,systemName,emuPath                   Log("SingePathUpdate - Started")                   FileFullPath := []                   updatedLines := 0                   singeData :=                   singeCount :=                   singeUpdateStrings := ["dofile(","spriteLoad","io.input","io.output","fontLoad","soundLoad"]   ; look for these strings in the singe files                   ; Check if paths have been updated prior                   romSingeFile := romPath . "\" . romName . ".singe"                   FileRead, romSingeData, %romSingeFile%                   StringReplace, rompathCommonSlash, romPath, \, /, all                   If InStr(romSingeData, rompathCommonSlash)                      If (forcePathUpdate = "false") {                         Log("SingePathUpdate - """ . romSingeFile . """ contains the current Rom Path. Skipping the SingePathUpdate function because your files appear to have the correct paths already set. If you want to force a path update, please set the ForcePathUpdate variable in the Daphne Singe module options in RocketLauncherUI to true.")                         Log("SingePathUpdate - Ended")                         Return                      }                   If InStr(systemName, "Action") {   ; WoW Action Max                      emuSingeFile := emuPath . "\singe\ActionMax\Emulator.singe"                      FileRead, emuSingeData, %emuSingeFile%                      FileFullPath[1,1] := emuSingeFile                      FileFullPath[1,2] := emuSingeData                      FileFullPath[2,1] := romSingeFile                      FileFullPath[2,2] := romSingeData                      Log("SingePathUpdate - Added the " . romName . ".singe and Emulator.singe to be updated",4)                   } Else {   ; basically only American Laser Games                      Loop, % romPath . "\*.singe"                      {   FileRead, singeData, %A_LoopFileFullPath%                         Loop % singeUpdateStrings.MaxIndex() {   ; for each string in the array                            If InStr(singeData, singeUpdateStrings[A_Index]) {   ; check each singe file for the strings                               singeCount++                               FileFullPath[singeCount,1] := A_LoopFileFullPath   ; building a table of each .singe file in the romPath and storing it in row 1                               FileFullPath[singeCount,2] := singeData      ; inserting the file data into row 2                               Log("SingePathUpdate - Found a file that needs to have its paths updated: " . A_LoopFileFullPath,4)                               Break   ; go to next file                            }                         }                      }                   }                   Log("SingePathUpdate - " . FileFullPath.MaxIndex() . " files will have their paths updated")                   Loop, % FileFullPath.MaxIndex()                   {                      currentSingeIndex := A_Index                      Log("SingePathUpdate - Now updating this singe file's paths: " . FileFullPath[currentSingeIndex,1],4)                      updatedText :=                      currentData := FileFullPath[currentSingeIndex,2]                      Loop, Parse, currentData, `n, `r                      {                         currentLine := A_Index                         oldSingeLine := A_LoopField                         lineUpdated :=                         Loop % singeUpdateStrings.MaxIndex()   ; for each string in the array                            If InStr(oldSingeLine, singeUpdateStrings[A_Index]) {   ; check each singe file for the strings                               updatedText .= (If currentLine = 1 ? "" : "`r`n") . UpdateLine(oldSingeLine, singeUpdateStrings[A_Index])                               lineUpdated := 1                            }                         If !lineUpdated   ; if line was not found above, just put the old line back                            updatedText .= (If currentLine = 1 ? "" : "`r`n") . A_LoopField                      }                      Log("SingePathUpdate - Deleting file: " . FileFullPath[currentSingeIndex,1],4)                      FileDelete, % FileFullPath[currentSingeIndex,1]                      Log("SingePathUpdate - Recreating file: " . FileFullPath[currentSingeIndex,1],4)                      FileAppend, %updatedText%, % FileFullPath[currentSingeIndex,1]                   }                   Log(updatedLines . " Singe paths updated by RocketLauncher.")                   Log("SingePathUpdate - Ended")                   exitapp                   Return                }                UpdateLine(oldLine, string) {                   Global rompath,emuPath,systemName,updatedLines                   StringReplace, rompathCommonSlash, romPath, \, /, all                   StringReplace, emupathCommonSlash, emuPath, \, /, all                   StringReplace, string2, string, ., \., all                   regex = i)%string2%.*/\K(?:.(?!/))+$|%string2%.*\\\K(?:.(?!\\))+$                   If RegExMatch(RegExReplace(oldLine,"\s*$",""), regex, matchedLine)                   {                      If (InStr(systemName, "Action") and InStr(matchedLine, "framework.singe"))                         Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/singe/" . matchedLine)                      Else If (InStr(systemName, "Action") and InStr(matchedLine, "emulator.singe"))                         Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/ActionMax/" . matchedLine)                      Else                         Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . rompathCommonSlash . "/" . matchedLine)                      updatedLines++                   } Else                      Line := oldLine                   Log("UpdateLine - " . line,4)                   Return Line                }                HaltEmu:                   Send, {P}                Return                RestoreEmu:                   Winrestore, AHK_class %EmulatorClass%                   Send, {P}                Return                CloseProcess:                   FadeOutStart()                   BezelExit()                   WinClose("DAPHNE ahk_class SDL_app")                   ;Process, Close, %executable% ; WoW Action Max module used this                Return 00:39:19:136 | RL |    INFO | +0    | BuildScript - Loaded Pause scripts 00:39:19:136 | RL |    INFO | +0    | BuildScript - Loaded MultiGame scripts 00:39:19:152 | RL |    INFO | +16   | BuildScript - Loaded Multi-Player scripts 00:39:19:152 | RL |    INFO | +0    | BuildScript - Loaded Statistics.ahk script 00:39:19:152 | RL | WARNING | +0    | BuildScript - "C:\HyperSpin\RocketLauncher\Lib\User Functions.ahk" not found 00:39:19:152 | RL |    INFO | +0    | BuildScript - Finished injecting functions into module 00:39:19:152 | RL |    INFO | +0    | Main - Module is built 00:39:19:152 | RL |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\RocketLauncher\AutoHotkey.dll exists 00:39:19:152 | RL |  DEBUG1 | +0    | CheckFile - Attributes:                FileDescription           AutoHotkey_H ANSI 32-bit                FileVersion               1.1.09.04                InternalName              AutoHotkey_H                LegalCopyright            Copyright (C) 2012                OriginalFilename          AutoHotkey.exe                ProductName               AutoHotkey_H                ProductVersion            1.1.09.04                File Size:         785408 bytes                Created:         3/24/2015 - 11:37:23                Modified:         2/17/2015 - 5:02:58 00:39:19:152 | RL |    INFO | +0    | Main - Running module 00:39:19:152 | RL |    INFO | +0    | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 00:39:19:371 | MD |    INFO | +N/A  | Module initialized 00:39:19:371 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 00:39:19:371 | MD |  DEBUG1 | +0    | fadeInTransitionAnimation: DefaultAnimateFadeIn 00:39:19:371 | MD |  DEBUG1 | +0    | fadeOutTransitionAnimation: DefaultAnimateFadeOut 00:39:19:371 | MD |  DEBUG1 | +0    | fadeLyr3Animation: DefaultFadeAnimation 00:39:19:371 | MD |  DEBUG1 | +0    | fadeLyr37zAnimation: DefaultFadeAnimation 00:39:19:371 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1 & ~5" to call label: "TogglePauseMenuStatus" 00:39:19:371 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot" 00:39:19:371 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadSub" to call label: "StartMulti" 00:39:19:371 | MD |    INFO | +0    | StartModule - Started 00:39:19:371 | MD |    INFO | +0    | StartModule - MEmu: Daphne Singe                MEmuV: v1.14                MURL: http://www.singeengine.com/cms/                MAuthor: djvj                MVersion: 2.0.6                MCRC: 60C75E1                iCRC: 777E5B50                MID:                MSystem: "American Laser Games","WoW Action Max" 00:39:19:371 | MD |    INFO | +0    | StartModule - You have a supported System Name for this module: "WoW Action Max" 00:39:19:371 | MD |    INFO | +0    | PluginInit - Started 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 00:39:19:371 | MD |    INFO | +0    | CheckFile - Checking if C:\HyperSpin\Databases\WoW Action Max\WoW Action Max.xml exists 00:39:19:371 | MD |  DEBUG1 | +0    | CheckFile - Attributes:                File Size:         1261 bytes                Created:         4/14/2015 - 9:11:01                Modified:         4/14/2015 - 6:24:06 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching for a "Game Name" in the database 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Found "Game Name" in the database! 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Name 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Found "Name" with a value: "The Rescue of Pops Ghostly" 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Cloneof 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Could not find: Cloneof 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Manufacturer 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Found "Manufacturer" with a value: "CCR Video Corporation" 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Year 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Found "Year" with a value: "1987" 00:39:19:371 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Genre 00:39:19:386 | MD |  DEBUG1 | +15   | BuildDatabaseTable - Could not find: Genre 00:39:19:386 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Searching database for: Rating 00:39:19:386 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Could not find: Rating 00:39:19:386 | MD |  DEBUG2 | +0    | PluginInit - GameInfo:                GameInfo Label: Manufacturer | GameInfo Value:                GameInfo Label: Name | GameInfo Value:                GameInfo Label: Year | GameInfo Value: 00:39:19:386 | MD |  DEBUG1 | +0    | BuildDatabaseTable - Ended 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Game Logo: C:\HyperSpin\Media\WoW Action Max\Images\Wheel\PopsGhostly.png 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a System Logo: C:\HyperSpin\Media\Main Menu\Images\Wheel\WoW Action Max.png 00:39:19:386 | MD |  DEBUG2 | +0    | BuildAssetsTable - Media assets found:                Asset Label: Game Logo | Asset Path1: C:\HyperSpin\Media\WoW Action Max\Images\Wheel\PopsGhostly.png | Asset Extension1: png | Asset Type1: game                Asset Label: System Logo | Asset Path1: C:\HyperSpin\Media\Main Menu\Images\Wheel\WoW Action Max.png | Asset Extension1: png | Asset Type1: system 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Ended 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Artwork1: C:\HyperSpin\Media\WoW Action Max\Images\Artwork1\PopsGhostly.png 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Box Art: C:\HyperSpin\Media\WoW Action Max\Images\Artwork2\PopsGhostly.png 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Cartridge: C:\HyperSpin\Media\WoW Action Max\Images\Artwork3\PopsGhostly.png 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Flyers: C:\HyperSpin\Media\WoW Action Max\Images\Artwork4\PopsGhostly.png 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Letters: C:\HyperSpin\Media\WoW Action Max\Images\Letters 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a Other: C:\HyperSpin\Media\WoW Action Max\Images\Other 00:39:19:386 | MD |  DEBUG2 | +0    | BuildAssetsTable - Media assets found:                Asset Label: Cartridge | Asset Path1: C:\HyperSpin\Media\WoW Action Max\Images\Artwork3\PopsGhostly.png | Asset Extension1: png | Asset Type1: game 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Ended 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a MP4 Game Video: C:\HyperSpin\Media\WoW Action Max\Video\PopsGhostly.* 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Searching for a FLV Game Video: C:\HyperSpin\Media\Main Menu\Video\WoW Action Max.* 00:39:19:386 | MD |  DEBUG1 | +0    | BuildAssetsTable - Ended 00:39:19:386 | MD |    INFO | +0    | PluginInit - Ended 00:39:19:386 | MD |  DEBUG1 | +0    | StartModule - Setting romName to the dbName sent to RocketLauncher: PopsGhostly 00:39:19:386 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 00:39:19:386 | MD |    INFO | +0    | StartModule - Ended 00:39:19:386 | MD |    INFO | +0    | BezelGUI - Started 00:39:19:433 | MD |    INFO | +47   | BezelGUI - Ended 00:39:19:433 | MD |  DEBUG1 | +0    | FadeInStart - Started 00:39:19:433 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadSub" 00:39:19:433 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabling "StartMulti" standard Hotkey method for key(s): "~NumpadSub" 00:39:19:433 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabled Hotkey for: "~1 & ~5" 00:39:19:433 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~1 & ~5" 00:39:19:433 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 00:39:19:449 | MD |  DEBUG2 | +16   | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 00:39:19:449 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 00:39:19:449 | MD |  DEBUG2 | +0    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseFadeIn" 00:39:19:449 | MD |  DEBUG2 | +0    | Fade screen scale factor: X=1.000000, Y= 1.000000 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\PopsGhostly\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\PopsGhostly\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Horizontal\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\_Default\Horizontal\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\_Default\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.png 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Found Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1.png 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.gif 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.tif 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.bmp 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 1 pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1*.jpg 00:39:19:449 | MD |    INFO | +0    | GetFadePicFile - Randomized images and Fade will use C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Layer 1.png 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 2 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\PopsGhostly\Layer 2*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 2 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Horizontal\Layer 2*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 2 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.* 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.png 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Found Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2.png 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.gif 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.tif 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.bmp 00:39:19:449 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 2 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2*.jpg 00:39:19:449 | MD |    INFO | +0    | GetFadePicFile - Randomized images and Fade will use C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 2.png 00:39:19:543 | MD |    INFO | +94   | DefaultAnimateFadeIn - Started, direction is: in 00:39:19:543 | MD |    INFO | +0    | DefaultAnimateFadeIn - Drawing First FadeIn Image. 00:39:20:293 | MD |    INFO | +750  | DefaultAnimateFadeIn - Ended 00:39:20:324 | MD |  DEBUG1 | +31   | FadeInStart - Ended 00:39:20:324 | MD |  DEBUG1 | +0    | CoverFE - Started 00:39:20:324 | MD |  DEBUG1 | +0    | CoverFE - Ended 00:39:20:324 | MD |    INFO | +0    | Module Setting - [settings] - Fullscreen: true 00:39:20:324 | MD |    INFO | +0    | Module Setting - [settings] - globalParams: 00:39:20:339 | MD |    INFO | +15   | Module Setting - [settings] - daphneWidth: 1024 00:39:20:339 | MD |    INFO | +0    | Module Setting - [settings] - daphneHeight: 768 00:39:20:339 | MD |    INFO | +0    | Module Setting - [settings] - SingePathUpdate: true 00:39:20:339 | MD |    INFO | +0    | Module Setting - [settings] - ForcePathUpdate: false 00:39:20:339 | MD |    INFO | +0    | Module Setting - [PopsGhostly] - params: 00:39:20:339 | MD |    INFO | +0    | BezelStart - Started 00:39:20:339 | MD |  DEBUG1 | +0    | Bezel - Bezel mode Normal selected. 00:39:20:355 | MD |  DEBUG2 | +16   | Bezel variable values:                [Settings] Bezel_Supported_Image_Files = png|gif|tif|bmp|jpg                [Bezel Change] Bezel_Transition_Duration = 500                [Bezel Change] Bezel_Save_Selected = true                [Bezel Change] Extra_FullScreen_Bezel = true                [Background] Background_Change_Timer = 0                [Background] Background_Transition_Animation = fade                [Background] Background_Transition_Duration = 500                [Background] Use_Backgrounds = true                [Bezel Change Keys] Next_Bezel_Key = PgUp                [Bezel Change Keys] Previous_Bezel_Key = PgDn                [Instruction Cards General Settings] IC_Positions = topLeft|topRight|bottomLeft|bottomRight|topCenter|leftCenter|rightCenter|bottomCenter                [Instruction Cards General Settings] IC_Transition_Animation = fade                [Instruction Cards General Settings] IC_Transition_Duration = 500                [Instruction Cards General Settings] IC_Enable_Transition_Sound = true                [Instruction Cards General Settings] IC_Scale_Factor = ScreenHeight                [Instruction Cards General Settings] IC_Save_Selected = true                [Instruction Cards Menu] IC_Left_Menu_Positions = topLeft|leftCenter|bottomLeft|bottomCenter                [Instruction Cards Menu] IC_Left_Menu_Number_of_List_Items = 7                [Instruction Cards Menu] IC_Right_Menu_Positions = topRight|rightCenter|bottomRight|topCenter                [Instruction Cards Menu] IC_Right_Menu_Number_of_List_Items = 7                [Instruction Cards Visibility] IC_Display_Card_on_Startup = false                [Instruction Cards Visibility] IC_Random_Slide_Show_Timer = 0                [Instruction Cards Visibility] IC_Toggle_Visibility_Key =                [Instruction Cards Keys Change Mode 1] IC_Left_Menu_Key =                [Instruction Cards Keys Change Mode 1] IC_Right_Menu_Key =                [Instruction Cards Keys Change Mode 2] IC_Change_Active_Instruction_Card_Key =                [Instruction Cards Keys Change Mode 2] IC_Previous_Instruction_Card_Key =                [Instruction Cards Keys Change Mode 2] IC_Next_Instruction_Card_Key =                [Instruction Cards Keys Change Mode 3] IC_1_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_2_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_3_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_4_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_5_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_6_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_7_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_8_Previous_Key =                [Instruction Cards Keys Change Mode 3] IC_1_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_2_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_3_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_4_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_5_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_6_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_7_Next_Key =                [Instruction Cards Keys Change Mode 3] IC_8_Next_Key = 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Assuming that game has horizontal orientation. 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Bezel in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\PopsGhostly 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Bezel in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default\Horizontal 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Bezel in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Found Bezel art in folder: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default 00:39:20:355 | MD |    INFO | +0    | Bezel - Loading Bezel image: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default\Bezel - 16x9 ActionMax Clean (Grizz).png 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\PopsGhostly 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\PopsGhostly 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default\Horizontal 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\_Default\Horizontal 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Backgrounds\WoW Action Max\_Default 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Background in: C:\HyperSpin\RocketLauncher\Media\Bezels\_Default\Horizontal 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Found Background art in folder: C:\HyperSpin\RocketLauncher\Media\Bezels\_Default\Horizontal 00:39:20:355 | MD |    INFO | +0    | Bezel - Loading Background image: C:\HyperSpin\RocketLauncher\Media\Bezels\_Default\Horizontal\Background.png 00:39:20:355 | MD |    INFO | +0    | Adding extra fullscreen fake bezel image 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Instruction Card in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\PopsGhostly 00:39:20:355 | MD |  DEBUG1 | +0    | Bezel - Looking for Instruction Card in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default\Horizontal 00:39:20:371 | MD |  DEBUG1 | +0    | Bezel - Looking for Instruction Card in: C:\HyperSpin\RocketLauncher\Media\Bezels\WoW Action Max\_Default 00:39:20:371 | MD |  DEBUG1 | +0    | Bezel - Looking for Instruction Card in: C:\HyperSpin\RocketLauncher\Media\Bezels\_Default\Horizontal 00:39:20:371 | MD |  DEBUG1 | +0    | Bezel - Looking for Instruction Card in: C:\HyperSpin\RocketLauncher\Media\Bezels\_Default 00:39:20:371 | MD | WARNING | +0    | Bezel - Bezels are enabled, however none of the Instruction Card files, with extensions png|gif|tif|bmp|jpg exist on the bezel folders. 00:39:20:371 | MD |  DEBUG2 | +0    | Bezel - Bezel ini file found. Defined screen positions: X1=321 Y1=61 X2=1596 Y2=1017 00:39:20:402 | MD |  DEBUG2 | +31   | Bezel - Background Screen Position: BezelImage left=0 top=0 right=1920 bottom=1080 00:39:20:402 | MD |    INFO | +0    | BezelStart - Ended 00:39:20:402 | MD |    INFO | +0    | 7z - Started, received D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.bat. If rom is an archive, it will extract to C:\HyperSpin\Temp 00:39:20:402 | MD |    INFO | +0    | 7z - This rom type does not need 7z: ".bat" 00:39:20:402 | MD |  DEBUG1 | +0    | 7z - Starting non-7z FadeIn animation. 00:39:20:402 | MD |    INFO | +0    | DefaultFadeAnimation - Started 00:39:20:402 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Info Bar images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\PopsGhostly\Info Bar*.* 00:39:20:402 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Info Bar images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Horizontal\Info Bar*.* 00:39:20:402 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Info Bar images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Info Bar*.* 00:39:20:418 | MD |  DEBUG1 | +16   | GetFadePicFile - Checking if any Fade Info Bar images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.* 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Info Bar images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.* 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.png 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Found Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar.png 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Info Bar pic: C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg 00:39:20:418 | MD |    INFO | +0    | GetFadePicFile - Randomized images and Fade will use C:\HyperSpin\RocketLauncher\Media\Fade\_Default\Info Bar.png 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\PopsGhostly\Layer 3*.* 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Horizontal\Layer 3*.* 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.* 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.png 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Found Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3.png 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.gif 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.tif 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.bmp 00:39:20:418 | MD |  DEBUG1 | +0    | GetFadePicFile - Looking for Fade Layer 3 pic: C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3*.jpg 00:39:20:418 | MD |    INFO | +0    | GetFadePicFile - Randomized images and Fade will use C:\HyperSpin\RocketLauncher\Media\Fade\WoW Action Max\_Default\Layer 3.png 00:39:20:449 | MD |  DEBUG1 | +31   | FadeInDelay - Started 00:39:20:449 | MD |  DEBUG1 | +0    | FadeInDelay - Ended 00:39:20:449 | MD |    INFO | +0    | DefaultFadeAnimation - Ended 00:39:20:449 | MD |  DEBUG1 | +0    | 7z - romPath changed from "D:\HyperSpin\Emulators\daphne_singe\AMframefile" to "D:\HyperSpin\Emulators\daphne_singe\AMframefile" 00:39:20:449 | MD |  DEBUG1 | +0    | 7z - romName changed from "PopsGhostly" to "PopsGhostly" 00:39:20:449 | MD |  DEBUG1 | +0    | 7z - romExtension changed from ".bat" to ".bat" 00:39:20:449 | MD |    INFO | +0    | 7z - Ended 00:39:20:449 | MD |    INFO | +0    | SingePathUpdate - Started 00:39:20:449 | MD |  DEBUG1 | +0    | SingePathUpdate - Added the PopsGhostly.singe and Emulator.singe to be updated 00:39:20:449 | MD |    INFO | +0    | SingePathUpdate - 2 files will have their paths updated 00:39:20:449 | MD |  DEBUG1 | +0    | SingePathUpdate - Now updating this singe file's paths: D:\HyperSpin\Emulators\daphne_singe\singe\ActionMax\Emulator.singe 00:39:20:449 | MD |  DEBUG1 | +0    | UpdateLine - dofile("singe/Singe/Framework.singe") 00:39:20:449 | MD |  DEBUG1 | +0    | UpdateLine - sprLightOn  = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_LightOn.png") 00:39:20:449 | MD |  DEBUG1 | +0    | UpdateLine - sprLightOff = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_LightOff.png") 00:39:20:464 | MD |  DEBUG1 | +15   | UpdateLine - sprActionMax = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_ActionMax.png") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sprCrosshair = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_Crosshair.png") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sprBullet   = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_Bullet.png") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sprBoxArt   = spriteLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sprite_" .. gameID .. ".png") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndActionMax = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_ActionMax.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndSteadyAim = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_ASteadyAimIsCritical.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndGetReady = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_GetReadyForAction.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndGunShot  = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_Gunshot.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndGoodHit  = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_GoodHit.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndBadHit   = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_BadHit.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - sndGameOver = soundLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/sound_GameOver.wav") 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - fntBlueStone20 = fontLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/font_BlueStone.ttf", 20) 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - fntChemRea16  = fontLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/font_chemrea.ttf", 16) 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - fntChemRea32  = fontLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/font_chemrea.ttf", 32) 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - fntChemRea48  = fontLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/font_chemrea.ttf", 48) 00:39:20:464 | MD |  DEBUG1 | +0    | UpdateLine - fntLEDReal32  = fontLoad("D:/HyperSpin/Emulators/daphne_singe/AMframefile/font_LED_Real.ttf", 32) 00:39:20:464 | MD |  DEBUG1 | +0    | SingePathUpdate - Deleting file: D:\HyperSpin\Emulators\daphne_singe\singe\ActionMax\Emulator.singe 00:39:20:464 | MD |  DEBUG1 | +0    | SingePathUpdate - Recreating file: D:\HyperSpin\Emulators\daphne_singe\singe\ActionMax\Emulator.singe 00:39:20:464 | MD |  DEBUG1 | +0    | SingePathUpdate - Now updating this singe file's paths: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.singe 00:39:20:464 | MD |  DEBUG1 | +0    | SingePathUpdate - Deleting file: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.singe 00:39:20:480 | MD |  DEBUG1 | +16   | SingePathUpdate - Recreating file: D:\HyperSpin\Emulators\daphne_singe\AMframefile\PopsGhostly.singe 00:39:20:480 | MD |    INFO | +0    | 18 Singe paths updated by RocketLauncher. 00:39:20:480 | MD |    INFO | +0    | SingePathUpdate - Ended 00:39:20:558 | RL |    INFO | +1406 | Main - Module ended, exiting RocketLauncher normally 00:39:20:558 | RL |    INFO | +0    | ExitScript - Started 00:39:20:578 | RL |    INFO | +16   | SystemCursor - Restoring mouse cursor 00:39:20:589 | RL |    INFO | +15   | ExitScript - Ended Build your cabinet, conquer the codes, become a King of Chaos!
rfancella Posted June 4, 2015 Author Posted June 4, 2015 Hi Sam, Please post your Daphne log as well. That will tell us the error Daphne is running into. Thanks, Ron Same problem here, please help!  ...snip... Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
SamVSsami Posted June 4, 2015 Posted June 4, 2015 Hi Sam, Please post your Daphne log as well. That will tell us the error Daphne is running into. Thanks, Ron  Hi Ron,  Thank you for your reply here is the daphne log   --DAPHNE version 1.0.10 --Command line is: D:\HyperSpin\Emulators\daphne_singe\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile D:\HyperSpin\Emulators\daphne_singe\singe/ActionMax/frame_BlueThunder.txt -script D:\HyperSpin\Emulators\daphne_singe\singe/ActionMax/BlueThunder.singe --CPU : AuthenticAMD 4000 MHz || Mem : 4096 megs --OS : Windows NT Derivative || Video : AMD Radeon R9 200 Series --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting screen width to 800 Setting screen height to 600 Set 1920x1080 at 32 bpp with flags: 20 Initializing sound system ... Joystick #0 was successfully opened Framefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/daphne_singe/singe/ActionMax/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... Starting Singe version 1.14 Search to 1 received [blocking] Search to 2453 received [blocking] Freeing memory used to store audio stream... Search to 27950 received [blocking] Freeing memory used to store audio stream... ov_open_callbacks failed! Error code is -132 OV_EREAD=-128 OV_ENOTVORBIS=-132 OV_EVERSION=-134 OV_EBADHEADER=-133 OV_EFAULT=-129 Play Search to 1 received [blocking] Play Stop Freeing memory used to store audio stream... Shutting down sound system... Shutting down video display...  Build your cabinet, conquer the codes, become a King of Chaos!
rfancella Posted June 9, 2015 Author Posted June 9, 2015 Hmmm.. Not sure what is going on here. Try going to the module settings and turn off both SingePathUpdate and ForcePathUpdate and test again. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
Metalzoic Posted June 9, 2015 Posted June 9, 2015 Now that I have Daphne set up and running perfectly I will try to set up Singe, but first I have to track down Time Gal and Ninja Hayate (so far zero luck...)
SamVSsami Posted June 9, 2015 Posted June 9, 2015 Hmmm.. Not sure what is going on here. Try going to the module settings and turn off both SingePathUpdate and ForcePathUpdate and test again. Thanks, Ron  Thank You Thank You and thank you!!!!!!!!!!!!!!!! That did the trick, now I can finally play them within HS THANKS RON!!!! Build your cabinet, conquer the codes, become a King of Chaos!
rfancella Posted June 23, 2015 Author Posted June 23, 2015 Hi guys, I edited the first post in this thread with updated links. Some of them are dead, most likley pruned. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
maabus Posted June 26, 2015 Posted June 26, 2015 Hi rfancella, Â I am having trouble with ALG games. I am able to run all of the games outside hyper spin through the bat files, and i am able to run all of them through rocket launcher from launching it from the games tab. When i try to run the games from hyperspin itself it just freezes and doesn't do anything. Â I am also trying to get Time Gal, and Hayate to work, and have them working through the bat files, but when I try to run them through rocketlauncher nothing happes. I checked the .singe file for Time Gal and Hayate, and it is all gibberish compared to the ALG singe files. I am also able to run Time Traveler through rocketlauncher and bat files, but nothing happens when I try in hyperspin. Â I think other emulaters are freezing and not doing anything when launched from hyperspin, BUT I have Daphne working perfectly through hyperspin.... all games work correctly. Â Any thoughts?
rfancella Posted June 26, 2015 Author Posted June 26, 2015 Hi, Be sure that you go into the global module settings and set both SingPathUpdate and ForcePathUpdate to False.  If this does not help any, please post your RocketLauncher.log file. With your Logging Level set to Troubleshooting.  Thanks, Ron   Hi rfancella,  I am having trouble with ALG games. I am able to run all of the games outside hyper spin through the bat files, and i am able to run all of them through rocket launcher from launching it from the games tab. When i try to run the games from hyperspin itself it just freezes and doesn't do anything.  I am also trying to get Time Gal, and Hayate to work, and have them working through the bat files, but when I try to run them through rocketlauncher nothing happes. I checked the .singe file for Time Gal and Hayate, and it is all gibberish compared to the ALG singe files. I am also able to run Time Traveler through rocketlauncher and bat files, but nothing happens when I try in hyperspin.  I think other emulaters are freezing and not doing anything when launched from hyperspin, BUT I have Daphne working perfectly through hyperspin.... all games work correctly.  Any thoughts? Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
Metalzoic Posted June 27, 2015 Posted June 27, 2015 What is Time Traveller? Is it a cartoon style Laserdisc game I've just never heard of?
dougan78 Posted June 27, 2015 Posted June 27, 2015 No it's a 3d hologram laser disc game. With real terrible actors. It is awesome. If you saw it in person ever it was a neat gimmicky mirror trick and if you were a kid you had to play it.
maabus Posted June 27, 2015 Posted June 27, 2015 Thanks rfancella that fixed Time Gal and Hayate in rocketlauncher, but i still can't run it from Hyperspin. I checked the log for hyperspin, and it is not loading the emulator.  You can see in the log that it loads the emulator for Daphne, but nothing for the Singe games. it doesnt know what the executable is.  Actually i just checked in Hyper HQ that Daphne had the path to rocket launcher in its executable path. I tried adding the path to the alg wheel emulator tab. Now when i try running alg it launches the rocketlauncher test program instead of launching the game. here is the line from the log after adding the path. Command Line is: "E:\Hyperspin\RocketLauncher\RocketLauncher.exe" crimepatrol.  Why isnt the path filled in for the other systems, but its filled in for Daphne. I never added it myself. I hope i explained it ok.  Here is my log without adding the path to the HyperHQ wheels emulators tab. 03:03:34 PM | HyperSpin Started 03:03:34 PM | Going windowed mode 03:03:34 PM | Checking for updates 03:03:34 PM | Update Check Complete 03:03:34 PM | Startup program unavailable 03:03:34 PM | Playing intro video 03:03:37 PM | Error intializing joysticks 03:03:37 PM | Menu Mode is multi 03:03:37 PM | Loading Main Menu.xml 03:03:37 PM | Main Menu.xml successfully loaded 03:03:37 PM | Main Menu wheel loaded successfully 03:03:41 PM | Loading Daphne.xml 03:03:41 PM | Main Menu.xml successfully loaded 03:03:42 PM | Daphne wheel loaded successfully 03:03:45 PM | Launching Game 03:03:45 PM | Not using HyperLaunch 03:03:45 PM | Running in normal rom mode 03:03:45 PM | Excecutable is RocketLauncher.exe 03:03:45 PM | Command Line is: "E:\Hyperspin\RocketLauncher\RocketLauncher.exe" "lair." "Daphne" -f "E:\Hyperspin\HyperSpin.exe" -p "HyperSpin" 03:04:00 PM | Loading Main Menu.xml 03:04:00 PM | Main Menu.xml successfully loaded 03:04:00 PM | Main Menu wheel loaded successfully 03:04:04 PM | Loading American Laser Games.xml 03:04:04 PM | Main Menu.xml successfully loaded 03:04:05 PM | American Laser Games wheel loaded successfully 03:04:07 PM | Launching Game 03:04:07 PM | Not using HyperLaunch 03:04:07 PM | Running in normal rom mode 03:04:07 PM | Excecutable is 03:04:07 PM | Command Line is: "" crimepatrol. 03:05:02 PM | Loading Main Menu.xml 03:05:02 PM | Main Menu.xml successfully loaded 03:05:02 PM | Main Menu wheel loaded successfully 03:08:54 PM | Loading American Laser Games.xml 03:08:54 PM | Main Menu.xml successfully loaded 03:08:54 PM | American Laser Games wheel loaded successfully 03:09:00 PM | Launching Game 03:09:00 PM | Not using HyperLaunch 03:09:00 PM | Running in normal rom mode 03:09:00 PM | Excecutable is 03:09:00 PM | Command Line is: "" maddog. 03:09:54 PM | Loading Main Menu.xml 03:09:54 PM | Main Menu.xml successfully loaded 03:09:54 PM | Main Menu wheel loaded successfully 03:10:40 PM | Exit program unavailable 03:10:40 PM | Quiting Hyperspin 03:10:40 PM | Bye!
rfancella Posted June 29, 2015 Author Posted June 29, 2015 Hi,You do need to setup American Laser Games in HyperHQ. That is why nothing is being sent when you select Crimepatrol.Take a look at Section 3 - B in this link:http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3  Thanks, Ron    Thanks rfancella that fixed Time Gal and Hayate in rocketlauncher, but i still can't run it from Hyperspin. I checked the log for hyperspin, and it is not loading the emulator. You can see in the log that it loads the emulator for Daphne, but nothing for the Singe games. it doesnt know what the executable is. Actually i just checked in Hyper HQ that Daphne had the path to rocket launcher in its executable path. I tried adding the path to the alg wheel emulator tab. Now when i try running alg it launches the rocketlauncher test program instead of launching the game. here is the line from the log after adding the path. Command Line is: "E:\Hyperspin\RocketLauncher\RocketLauncher.exe" crimepatrol. Why isnt the path filled in for the other systems, but its filled in for Daphne. I never added it myself. I hope i explained it ok. Here is my log without adding the path to the HyperHQ wheels emulators tab. ...snip... Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
maabus Posted June 29, 2015 Posted June 29, 2015 Ok I think I figured out what my problem is when running ALG games through hyperspin, but i dont know how to fix it. Â I deleted my ALG system, and added it back in rocketlauncherUI. Now it says it is launching hyperlaunch in the command line, but it still does not load anything. It is trying to run hyperlaunch, but I am using RocketLauncher. If i manually set hyperhq to use rocketlauncher for the ALG wheel it runs hyperlaunch with out a rom so it only shows that test program. I have Daphne runing fine, and i tried to copy the settings for Daphne in the hyperhq wheel settings, but it still does not work. Â I am not sure why Rocketlauncher was removed, and why it is no longer the default launcher when adding systems. hyperspin is set as active and default in rocketlauncherUI Â Â Â EDIT: i typed this as you were typing i guess... Â I did run the transition tool... I'll manually edit the ini... thanks!
maabus Posted June 30, 2015 Posted June 30, 2015 I just reinstalled Hyperspin, and RocketLauncher and everything is working now. I'm not sure what happens, but it is the 3rd time i reinstalled. Something keeps happneing where it changes the launcher to use hyperlaunch instead of rocket launcher. The second time i added ALG and it worked fine... I closed RocketlauncherUI, and hyperspin. Opened RocketlauncherUI... i think it updated, I then added Action Max, and it stopped working again and tried to use hyperlauncher again. This third time I added both at the same time and both of them worked. So I'm not sure what happened. Â Â Anyways... thanks for your help rfancella! Both systems are now working.
rfancella Posted June 30, 2015 Author Posted June 30, 2015 Wow... Trial by fire! lol  Glad it's sorted now.  Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
mikea213 Posted September 20, 2015 Posted September 20, 2015 Hey Ron,  Im getting the 404 error can you help out??  Thanks,
rfancella Posted October 5, 2015 Author Posted October 5, 2015 HI Mike, PM Sent.  Thanks, Ron   Hey Ron,  Im getting the 404 error can you help out??  Thanks, Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!  Â
