Taito Type X Files
gigapig
Are you using "Game Loader All RH" for any other game? If so, check a folder called sv inside that game. I can't remember the name of the file, but there is a controller config file in there. Just copy that one over to the new games. I don't remember how to config that file. Sorry, it's been awhile since I set this up.
  • Replies 369
I figured out how to set up the controls when using that specific loader, but it did nothing to help with the exit shortcut issues, unfortunately. The game doesn't seem to recognize my Start + Select method of exiting the emulator. I'll try asking over at the HyperLaunch forums too...
All I can suggest at the moment is to try each of the different exit methods. You may need Appwait.exe or fadetitle for it to work.
Changed them both to Process Close AppWaitExe and my exit shortcuts work now :)
I've solved all my other problems with Type X games too - all except for Shikigami no Shiro. No matter what I do, whether it's using Shikigami no Shiro III.exe or Game Loader All RH.exe, I need to run this game with only one monitor attached to my computer.
If someone is running this game with Game Loader All RH.exe on a dual monitor system, I'd be interested to see your TTX.ini config.
  • 3 weeks later...
Has anyone you put together launcher game specific Rom Settings for Deathsmiles II?
I have the game launching outside of HS, but I'm having trouble getting it set up for HyperSpin
When I exit the game, the loading screen is still there and doesn't go away until I press Q+S to force close
  gigapig said:
I'll send you something for your troubles.
Seriously pulling my hair out on this setup. Excellent video gigapig - I've followed your instructions to the letter but I'm having no luck. I keep getting an "error waiting for the window" message now, and that's after the game.exe issue described on pg 15. I'm running win 8.1 and I tried setting the game.exe file to run as admin, then tried setting it to run in win 7 compatibility mode. Still not working. I permanently disabled my bluetooth drivers as well since the disablebluetooth.exe file was also knocking down my wifi adapter.
Any ideas? So far I've tried BlazBlue continuum, KOF XIII and Battle Fantasia all with the same results. FTP files are merged properly, TTX ini and PClauncher ini are in place.
Question I have pclauncher ahk module as a virtual console with no rom or emu path. When I try to run a game it says there is no rom or emu path :-) in hyperhq I have the game ini set up already. Does the module need anything other then virtual checked and name?
I haven't touched Tayto's Type X games for some time. Hope they still work in my arcade setup with all the HL updates and what not. I saw a LOT of new games for the "system" are out... man, this is what I hate about this lol ...
I will be asking giga again when times come... poor giga, lol
All you need do is check the virtual emulator box, no need to fill anything in.
You can try what Connersdad mentioned on the other thread, but the PCLauncher ini should have those all set.
Also try removing the Fadetitle and just have the appwait set to Game.exe.
Interesting. Removed the fadetitle and getting a new error message.
"PCLauncher - There was an error getting a process ID from your AppWaitExe for "BattleArcania". Please try setting a FadeTitle instead"
What? That's weird. With the fade off I can see there's a very brief dos prompt popup, but it vanishes too quick to read - I'm assuming thats the .bat at work though.
Even worse is that I just got out of bed and had a fantastic dream that all of my TTX games started working miraculously and my troubles with it were over. It was a huge feeling of relief and satisfaction. Then I woke up. And here I am on my laptop at 6:00am at it again lol.
Thanks for your help on this Gigapig! Great community here.
  gigapig said:
Are the games starting?
I wish! Still nothing - that error persists with the fadetitle field blank: "PCLauncher - There was an error getting a process ID from your AppWaitExe for "BattleArcania". Please try setting a FadeTitle instead"
With the FadeTitle field filled here's the error I'm getting:
"There was an error waiting for the window "BattleFantasia". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your frontend first. Also turn off Fade to see if you are hiding your problem."
My c++ version is up to date. I'm running net framework 4.5.1 and directx 11. Dx 9.0c couldn't install on my win 8.1 of course. Other than that I followed your video up to the 16 minute mark where you start going through each game individually.
The FTP files I tried first were from langers folder, but I noticed a zip in your folder with the TTX files as well. Tried yours instead and I'm getting the same results. My TTX files are from bg - I hope those are ok.
For BattleFantasia I just have the path set and the fadetitle which is "BattleFantasia" that's all.
Make sure all the games work outside of HyperWhatever first.
About 2/3 of the games work flawlessly. I have some general questions, resolution questions and mapping questions on a few games. Gigas guide was amazing but it didn't answer the few questions I have below. Do you have the answers? Thanks
Battle Fantasia runs but after character select the resolution is too big where I can't see below the waist. I tried pressing f1 or f3 and I see screen ratio option but I can't figure it out. How do I adjust the resolution?
Blaze blue calamity is funky. Screen shows up but colors and graphics are weird. I think I need to change the resolution. When I push f3 I see configures but it's black and can't decide options. How do I change resolution within the folders
Blaze blue continuum is slow. How do you change resolution?
Daemon bride shows up in a tiny screen, how do I change the resolution? I don't think f3 has it
King of fighters x3 seems to start the loader bat but after a black screen, game exe crashes. I get passes hyperlaunch loading but crashes. Maybe a resolution thing?
Samurai showdown doesn't have a pad.exe. How do I set up the controls?
optomedius never gets past the loading screen and is mapped to otmd_launcher. If I change it to the otomedius exe it runs but I get a black screen with red Japanese error after it says initializing
Arcana heart 2.1 is mapped to arcana heart 2.1 exe. When I start it it loads like 2 k sound each time and runs. Is there a way around that? Also what the difference between the game and suggio arcana heart 2
Contra AND silent hill arcade--how do I set up the controls? It looks like just an hd version of the original but 2gb! I may delete for space
The king of fighters sky stage game exe says the version is not compatible with the version of windows you're running. Check your computer system information to see if you need x86 32 bit or x64 bit and I have to press ok
Street fighter 2012 edition. I have the original one player working great but I'd like two player. I have the patch, I can run the two player exe but I can't figure out how to modify the controls like I have on the one players exe. Also is like to change the resolution for the 2 player exe. The mapping has .bat to launch player one exe. Can I do something to launch the player two exe as a bat? Would it matter or I could just launch the exe from hyperlaunch
You can change resolution by editing either of these files "settings.arc" or "gameres.dat" depending on the game, and it doesn't always work or look much different. I tried BF and BBCS and they can both be changed.
Are you using an AMD gpu? that can cause issue with a few games. Maybe "Game Loader All RH" can fix that?
See above.
There is a check box to set full screen when you use xb_config.exe
Not sure at the moment.
No the controls for this game and contra are locked, you need to use a keymapper. A list of keys are included with the Taito Type X files.
You'll need to watch my separate Otomedius guide and you will also need an F drive on the machine unless you can map a drive.
Not sure what you mean or what the difference is.
See above, Silent Hill has a basic keymapper, you need to run Config.bat.
This game has an encrypted exe and can be run at this time.
Did I give you the fix for this game which unlocks some characters? If I did, you just run the bat file and it should just work.
update of games that still don't run:
Blaze blue calamity:I have a radeon 4200 graphic card, AMD gpu. I added the game loader and already looks 100% better. Now I'm trying to set up the controls using ttx_config2.0. How do you actually map the buttons? All I can do is double click on say Up and it only reads my double click.
Blaze blue continuum is a little slow. Should I try game loader all hr too?
King of fighters x3 seems to start the loader bat but after a black screen, game exe crashes. I get passes hyperlaunch loading but crashes. Maybe a resolution thing? I have the bat application and app wait game exe mapped. I tried the game loader too but it crashed. I played with the resolution and it doesn't work still. I have windows 7 64 bit. Am I able to run it?
optomedius never gets past the loading screen and is mapped to otmd_launcher but I get a black screen with red Japanese error after it says initializing. I watched the video, does it HAVE to be on F drive? I have everything on E drive. I push f6 where it shows press service or test and i get the red error message instead of the options
Street fighter 2012 edition. Whats the preferred mapping here? I have a game exe, launcher exe, super street fighter arcaded 2012.exe, super street fighter arcade 2012 (2).exe. then I have a bat and old bat. Basically if I set up the application to map just to the street fighter 2012 (2) exe two players works. I can't find any other combo. Now to make things more hairy, my keyboard works but xpadder does not. I have two ps3 controllers plugged in but I have a blue tooth adapter ready so I can play wirelessly. Is this why xpadder isn't picking up through hyperspin? The key strokes seem to work. I have read something about a blue tooth patch, whats that all about? What are the steps to get blue tooth controllers working?
  jedfactor said:
Anyone else had problems launching kofXIII in windows 8.1? mine says game.exe stopped working.
Also with Deamon Bride and Arcana heart 3, the music starts but then quickly stops.
+1 on this. Game.exe failure on windows 8.1. Seems to be a common issue - what's the fix?
Have you tried different compatibility modes or setting it to run as admin?
Try the config files from here. TTX_config is most of the games XB_config will be for things like Arcana hearts, Daemon Bride etc
You can try different loader modes, the default is Loader -1 but you can try anything up to 6. 3 is a good one to try as it use transform and lighting (TNL) Each loader mode has it's own settings which you can work out from the TTX.ini even through it's in foreign.
It doesn't need to be on an F drive you just need an F drive on your machine. The settings are saved to that drive so it's probably complaining it can't be found. A solution is to us a USB stick, you can change the drive letter under Mange in Windows.
If you're using Bluetooth you will need to use the Game Loader All RH for all your games, perhaps someone has the TTX.ini's for all the games already??
Here is my TTX.ini if it's of any use.
[Arcana Heart 3]
Application=F:\Roms\Taito Type X\Arcana Heart 3\AH3_launcher.exe
FadeTitle=AH3
ExitMethod=WinClose Application
PreLaunch=.\TTX Bluetooth files\disable.exe
PreLaunchSleep=3000
PostExit=.\TTX Bluetooth files\enable.exe
HideCursor=true
[battle Fantasia]
Application=F:\Roms\Taito Type X\Battle Fantasia\Game Loader All RH.exe
AppWaitExe=game.exe
ExitMethod=WinClose AppWaitExe
PreLaunchSleep=3000
HideCursor=true
[blazBlue Calamity Trigger]
Application=F:\Roms\Taito Type X\BlazBlue Calamity Trigger\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (61fps) ahk_class Blaz Blue
ExitMethod=Process Close AppWaitExe
PreLaunchSleep=3000
HideCursor=true
[blazBlue Continuum Shift]
Application=F:\Roms\Taito Type X\BlazBlue Continuum Shift\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=Blaz Blue
PreLaunchSleep=3000
HideCursor=true
[Chaos Breaker]
Application=F:\Roms\Taito Type X\Chaos Breaker\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (59fps) ahk_class chaosbreaker
PreLaunchSleep=3000
HideCursor=true
[Daemon Bride]
Application=F:\Roms\Taito Type X\Daemon Bride\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=DB1 ahk_class DB1 CLASS
PreLaunchSleep=3000
HideCursor=true
[KOF - Maximum Impact Regulation A]
Application=F:\Roms\Taito Type X\KOF - Maximum Impact Regulation A\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=KOF@MAXIMUM@IMPACT@regulation gAh
PreLaunchSleep=3000
HideCursor=true
[King of Fighters '98, The Ultimate Match]
Application=F:\Roms\Taito Type X\King of Fighters '98, The Ultimate Match\Game Loader All RH.exe
AppWaitExe=game.exe
PreLaunchSleep=3000
FadeTitle=t (60fps) ahk_class Kof98
HideCursor=true
[King of Fighters XII, The]
Application=F:\Roms\Taito Type X\King of Fighters XII, The\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=ahk_class NGLU_CLASS
PreLaunchSleep=3000
HideCursor=true
[King of Fighters XIII, The]
Application=F:\Roms\Taito Type X\King of Fighters XIII, The\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (60fps) ahk_class F9D96469-6208-4609-AA55-1192042585C3
PreLaunchSleep=3000
HideCursor=true
[Power Instinct The Commemoration]
Application=F:\Roms\Taito Type X\Power Instinct The Commemoration\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (60fps) ahk_class tx_gouketu
PreLaunchSleep=3000
HideCursor=true
[samurai Shodown - Edge of Destiny]
Application=F:\Roms\Taito Type X\Samurai Shodown - Edge of Destiny\Samurai Shodown - Edge of Destiny.bat
AppWaitExe=game.exe
FadeTitle=Samurai Shodown 3D Ver[Mar 31 2008 15:23:19]
ExitMethod=Send Alt+F4
PreLaunchSleep=3000
HideCursor=true
[spica Adventure]
Application=F:\Roms\Taito Type X\Spica Adventure\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (60fps) ahk_class SpikaADV.
PreLaunchSleep=3000
HideCursor=true
[street Fighter IV]
Application=F:\Roms\Taito Type X\Street Fighter IV\Game Loader All RH.exe
FadeTitle=Street Fighter 4 ahk_class Street Fighter 4
PreLaunchSleep=3000
AppWaitExe=game.exe
HideCursor=true
[super Street Fighter IV Arcade edition 2012]
Application=.\Emulators\Taito Type X\Super Street Fighter IV Arcade edition 2012\Super Street Fighter IV Arcade Edition Ver. 2012.bat
AppWaitExe=game.exe
FadeTitle=FadeTitle=SF41 - Nov 4 2010 14:01:12 ahk_class SF41
[Tetris The Grand Master 3 Terror Instinct]
Application=F:\Roms\Taito Type X\Tetris The Grand Master 3 Terror Instinct\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=TGM3 - Copyright © Arika Co., Ltd - 2004-2005 (Jan 30 2005 17:52:56)
PreLaunchSleep=3000
HideCursor=true
[Trouble Witches AC]
Application=F:\Roms\Taito Type X\Paradise Lost\FarCry_r.exe
AppWaitExe=game.exe
FadeTitle=
PreLaunchSleep=3000
HideCursor=true
[Raiden III]
Application=F:\Roms\Taito Type X\Raiden III\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (60fps) ahk_class JJ9X
PreLaunchSleep=3000
HideCursor=true
[Homura]
Application=F:\Roms\Taito Type X\Homura\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=t (60fps) ahk_class BASE
PostExit=.\Modules\PCLauncher\Game Scripts\TTX exit & click mouse.ahk
PreLaunchSleep=3000
HideCursor=true
[shikigami no Shiro III]
Application=F:\Roms\Taito Type X\Shikigami no Shiro III\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=SHIKIGAMI NO SHIRO3
PreLaunchSleep=3000
HideCursor=true
[Raiden IV]
Application=F:\Roms\Taito Type X\Raiden IV\Game Loader All RH.exe
AppWaitExe=game.exe
PreLaunchSleep=3000
HideCursor=true
[GigaWing Generations]
Application=F:\Roms\Taito Type X\GigaWing Generations\Game Loader All RH.exe
AppWaitExe=game.exe
FadeTitle=YOKUSHIN
PreLaunchSleep=3000
HideCursor=true
[suggoi! Arcana Heart 2]
Application=F:\Roms\Taito Type X\Suggoi! Arcana Heart 2\Suggoi! Arcana Heart 2.bat
AppWaitExe=game.exe
FadeTitle=AH2
PreLaunchSleep=3000
HideCursor=true
[Otomedius]
Application=F:\Roms\Taito Type X\Otomedius\OTMD_Launcher.exe
AppWaitExe=otomedius.exe
PreLaunchSleep=3000
FadeTitle=ahk_class OTOMEDIUS
HideCursor=false
[Contra - Evolution Revolution]
Application=F:\Roms\Taito Type X\Contra Evolution Revolution\AMContra_full.exe
FadeTitle=AMCONTRA ahk_class AMCONTRA
HideCursor=true
[Taisen Hot Gimmick 5]
Application=F:\Roms\Taito Type X\Taisen Hot Gimmick 5\Game Loader All RH.exe
PreLaunchSleep=3000
AppWaitExe=game.exe
FadeTitle=‘ÎíƒzƒbƒgƒMƒ~ƒbƒN‚T ahk_class ‘ÎíƒzƒbƒgƒMƒ~ƒbƒN‚T
HideCursor=true
[silent Hill The Arcade]
Application=F:\Roms\Taito Type X\Silent Hill The Arcade\Game Loader All RH.exe
AppWaitExe=KSHG_no_cursor.exe
FadeTitle=KSHG ahk_class CWindow
HideCursor=true
[Half-Life 2 - Survivor Ver 2.0]
Application=F:\Roms\Taito Type X\Half-Life 2 - Survivor\HL2Survivor_RunMe.bat
AppWaitExe=hl2.exe
PreLaunch=.\Modules\PCLauncher\Game Scripts\Half-Life 2 - Survivor.ahk
PreLaunchSleep=3000
FadeTitle=Half-Life 2 DM ahk_class Valve001
HideCursor=true
[Deathsmiles II]
Application=F:\Roms\Taito Type X\Deathsmiles II\ds2_loader.exe
HideCursor=true
FadeTitle= ahk_class GMLIB
[battle Gear 4 Tuned]
Application=F:\Roms\Taito Type X\Battle Gear 4 Tuned\bg4.bat
HideCursor=true
FadeTitle=‚a‚`‚s‚s‚k‚d@‚f‚d‚`‚q@‚S ahk_class ‚a‚`‚s‚s‚k‚d@‚f‚d‚`‚q@‚S
AppWaitExe=game4.exe
[Paradise Lost]
Application=F:\Roms\Taito Type X\Paradise Lost\RunMe.bat
AppWaitExe=FarCry_r.exe
HideCursor=true
[super Street Fighter IV Arcade Edition]
AppWaitExe=game.exe
Application=F:\Roms\Taito Type X\Super Street Fighter IV Arcade Edition\Game Loader All RH.exe
PreLaunchSleep=3000
HideCursor=true
Dime, that's the PCLauncher.ini, I was thinking more of the TTX.ini which Game Loader All RH creates. I'm not sure it's possible to use someone else's, but can't see why not?
Actually, your PCLauncher is very helpful because you have the correct Fadetitles for Game Loader.
Thanks.
Thanks.
No prob. Let me know if someone needs a ttx.ini for a specific game. I use several different versions of the game loader so I could pack it up with the ini and exe together.
