lilcza Posted June 6, 2016 Posted June 6, 2016 Quick update. I use the Nvidia Shield TV for my emus. I meant to include that earlier. Also maybe we should include our application names for certian apps that arent on the main page? Wii Ware works fantastic with Dolphin Nightly, i recommend getting a Mayfair Dolphinbar to use real wii controllers. Im testing to see if the wiimotes can be used in Mame for shooters like on a pc. uoYabause from the play store is WAY better than the Yabause core in retroarch, but you will have to change the JIT compiler from fast(dynamic) to standard(i forget the name of it) as it wont run many games unless you do that. For doom PRboom is good, but it doesn't support the GZdoom mods. like Brutal Doom, Russian Overkill and ProDoomer. I recommend Beloko's Doom Touch. It wont launch wheel games from Hyperspin, but it has its own frontend when launched, and plays everything perfectly in HD. That includes the mods too. I'll be working on Amiga items all this week to get it working in a simple fashion, and i'll post my walk thru here, unless someone else has one already? Also i wish there was a way to launch emus or apps straight from the main menu. As in, not having to go into a sub wheel to run a single application. i.e. Doom(Main Wheel) - Doom Touch(Subwheel)
thatman84 Posted June 6, 2016 Author Posted June 6, 2016 Quick update. I use the Nvidia Shield TV for my emus. I meant to include that earlier. Also maybe we should include our application names for certian apps that arent on the main page? Wii Ware works fantastic with Dolphin Nightly, i recommend getting a Mayfair Dolphinbar to use real wii controllers. Im testing to see if the wiimotes can be used in Mame for shooters like on a pc. uoYabause from the play store is WAY better than the Yabause core in retroarch, but you will have to change the JIT compiler from fast(dynamic) to standard(i forget the name of it) as it wont run many games unless you do that. For doom PRboom is good, but it doesn't support the GZdoom mods. like Brutal Doom, Russian Overkill and ProDoomer. I recommend Beloko's Doom Touch. It wont launch wheel games from Hyperspin, but it has its own frontend when launched, and plays everything perfectly in HD. That includes the mods too. I'll be working on Amiga items all this week to get it working in a simple fashion, and i'll post my walk thru here, unless someone else has one already? Also i wish there was a way to launch emus or apps straight from the main menu. As in, not having to go into a sub wheel to run a single application. i.e. Doom(Main Wheel) - Doom Touch(Subwheel) All sounds good Im a bit behind with updating this but I will do it at the end of the week Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted June 8, 2016 Author Posted June 8, 2016 Updated with additions from the last few post. Thanks for all the information chaps Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
lilcza Posted June 9, 2016 Posted June 9, 2016 Psp minis work great in ppsspp nightly released. P-UAE in retroarch seems broken for amiga, even putting in the kick file didnt help, but uae4all works great.
Henderson33 Posted June 9, 2016 Posted June 9, 2016 Psp minis work great in ppsspp nightly released. P-UAE in retroarch seems broken for amiga, even putting in the kick file didnt help, but uae4all works great. Must of recently broke as this was posted 6 days ago https://www.youtube.com/watch?v=gKDI6dMvRow
thatman84 Posted June 9, 2016 Author Posted June 9, 2016 Must of recently broke as this was posted 6 days ago https://www.youtube.com/watch?v=gKDI6dMvRow I come across this guy, he has a cool setup with Kodi/SPMC I believe his setup is a recompiled retroarch.apk he has done himself. Not sure if it includes the cores. If it does he may be using an older core. (Didn't watch the vid, zombie mode!) Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted June 15, 2016 Posted June 15, 2016 Openbor is running in hyperspin Openbor 1.4.2 Parameter is org.openbor.engine/org.libsdl.app.SDLActivity Ext is pak,PAK
thatman84 Posted June 15, 2016 Author Posted June 15, 2016 Openbor is running in hyperspin Openbor 1.4.2 Parameter is org.openbor.engine/org.libsdl.app.SDLActivity Ext is pak,PAK Does it launch straight to games? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted June 15, 2016 Posted June 15, 2016 Does it launch straight to games?no but getting close
lilcza Posted June 15, 2016 Posted June 15, 2016 Ok i can confirm .chd do work on mame4droid, as i ran Killer instinct, and it was slow but ran. You need to have the bios files in your arcade rom sets for it to work correctly. I'll test this in Retroarch's Mame Git today, Amiga works with UAE4ALL just fine, i havent tried loading game from the Hyperspin wheel yet, but it may require some configuring.
mihaliousa Posted June 15, 2016 Posted June 15, 2016 You could instead use the android versions of killer instinct and killer instinct gold. Thing is though the first one is an snes port of the game and the other a n64 port - that is not the actual arcade classics.
badhemi Posted June 15, 2016 Posted June 15, 2016 Ok i can confirm .chd do work on mame4droid, as i ran Killer instinct, and it was slow but ran. You need to have the bios files in your arcade rom sets for it to work correctly. I'll test this in Retroarch's Mame Git today, Amiga works with UAE4ALL just fine, i havent tried loading game from the Hyperspin wheel yet, but it may require some configuring. how did you set folders for chd and zip file. ?
badhemi Posted June 16, 2016 Posted June 16, 2016 Does it launch straight to games?I got beats of rage to load directly from hyperspin but if you load more than one game in pack folder then you have a list of games and you have to choose. In the pc version I just create shorcuts to the exe and renamed roms. Trying to figure out how to do it in android
badhemi Posted June 17, 2016 Posted June 17, 2016 How are you getting amstrad cpc to play using mame? I tried with mame git using cpc464 and no go
thatman84 Posted June 17, 2016 Author Posted June 17, 2016 Um just had a scan through the threads on my phone and not sure where the Amstrad CPC confirmation came from... Maybe it was a mistake Have you tried droidcpc? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted June 19, 2016 Author Posted June 19, 2016 Cool I'm taking a few weeks out of updating this to actually get my personal setup how I want with al the right art, settings and databases!! Not even got MAME setup properly yet Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted June 19, 2016 Posted June 19, 2016 I'm doing nintendo Wii now and don't know what you can use for controllers
thatman84 Posted June 19, 2016 Author Posted June 19, 2016 Was it lilcza that recommended the Mayflash Dolphin bar? Someone said it works great I probably won't ever set Wii up, maybe just to launch a see but that's about it. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted June 19, 2016 Posted June 19, 2016 Was it lilcza that recommended the Mayflash Dolphin bar? Someone said it works great Thanks I probably won't ever set Wii up, maybe just to launch a see but that's about it. thanks
lilcza Posted June 20, 2016 Posted June 20, 2016 Yeah the Mayflash dolphin bar is fantastic, it even lets you use your wii remote as an air mouse. It provides perfect Wii emulation with dolphin, including speaker and vibrations.. and its only $20 bucks.
badhemi Posted July 3, 2016 Posted July 3, 2016 Sega model 1 and 2 has slow emulation Cave loads game then kicks out when loading memory
sevenseal Posted July 3, 2016 Posted July 3, 2016 Sega model 1 and 2 has slow emulation Cave loads game then kicks out when loading memory have you tried the fba core for them?
