thatman84 Posted September 1, 2016 Posted September 1, 2016 Is there any apps for renaming bin and cue files? Problem being on Android mostly all the files have to be unzipped in one folder. So you have to rename all the Track01 files etc and the. The cue file entries. I have not come across program that does this yet Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
epayson85 Posted September 1, 2016 Posted September 1, 2016 Just being honest... it will probably be easier to find a better set of files. The tracks should absolutely match the name of the cue file with track 1,2,3 and so forth at the end of the file name. I had to rename my ps2 collection a while back and luckily I was able to leave all the bin files as is and just had to rename the cue file to match media / my database. I can't even imagine if I had to rename the bins and get the cue file data to match the new bin names.
thatman84 Posted September 1, 2016 Author Posted September 1, 2016 I find getting the files one of the hardest and time consuming things to do. Also if you have 2 or more games with bin files named track01 then they have to be changed because they all go in same folder! Although I don't remember to many problems sorting my PS1 files but I only have about 20 games like I did when I had a PS1 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ci2own Posted February 24, 2017 Posted February 24, 2017 On 1/9/2016 at 8:46 PM, thatman84 said: Is there any apps for renaming bin and cue files? Problem being on Android mostly all the files have to be unzipped in one folder. So you have to rename all the Track01 files etc and the. The cue file entries. I have not come across program that does this yet Did you find something to solve your problem? I'm trying to rename my PS1 Games and HyperSpinb Cue Renamer doesn't seems to work. It asks me for every Track* file of each game.
badboo Posted February 24, 2017 Posted February 24, 2017 31 minutes ago, ci2own said: Did you find something to solve your problem? I'm trying to rename my PS1 Games and HyperSpinb Cue Renamer doesn't seems to work. It asks me for every Track* file of each game. Tio, why don't you try to create the .cue files with a batch? that's what I did and it worked amazing because I didn't have any .cue file in my rom set for my PSX roms check this batch: @echo off cls set extension_origen=bin set extension_final=cue FOR /F "tokens=1,2 delims='.'" %%l IN ('dir /b *.%extension_origen%') DO ( @echo FILE "%%l.%extension_origen%" BINARY > %%l.%extension_final% @echo TRACK 01 MODE2/2352 >> %%l.%extension_final% @echo INDEX 01 00:00:00 >> %%l.%extension_final% ) .... and change the extension "bin" to the one you have, if it is different. Of course, save your current cue files and try the batch. as a note, if you don't have special characters like ~ !!!, etc, then it should work great. This batch was given to me from another forum, so it is not my creation.
ci2own Posted February 24, 2017 Posted February 24, 2017 2 minutes ago, badboo said: Tio, why don't you try to create the .cue files with a batch? that's what I did and it worked amazing because I didn't have any .cue file in my rom set for my PSX roms check this batch: @echo off cls set extension_origen=bin set extension_final=cue FOR /F "tokens=1,2 delims='.'" %%l IN ('dir /b *.%extension_origen%') DO ( @echo FILE "%%l.%extension_origen%" BINARY > %%l.%extension_final% @echo TRACK 01 MODE2/2352 >> %%l.%extension_final% @echo INDEX 01 00:00:00 >> %%l.%extension_final% ) .... and change the extension "bin" to the one you have, if it is different. Of course, save your current cue files and try the batch. as a note, if you don't have special characters like ~ !!!, etc, then it should work great. This batch was given to me from another forum, so it is not my creation. Thanks for your fast response. The problem is i have each .cue in his folder. And if i delete them and after that i need it again i would have to add manually to each folder. So don't want to take that risk.
thatman84 Posted February 25, 2017 Author Posted February 25, 2017 @ci2own what do you need exactly? i have crude program a guy made for me assuming you have run your games through Don's renamer it will spit out a (gamename).cue & Track##.bin files in a folder The program will add the game name to the track files and rename the internals of the cue sheet to match. So every cue file and bin file for all games will have a unique name and the cue files will be correct. it is crude though but works a treat. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ci2own Posted February 25, 2017 Posted February 25, 2017 22 minutes ago, thatman84 said: @ci2own what do you need exactly? i have crude program a guy made for me assuming you have run your games through Don's renamer it will spit out a (gamename).cue & Track##.bin files in a folder The program will add the game name to the track files and rename the internals of the cue sheet to match. So every cue file and bin file for all games will have a unique name and the cue files will be correct. it is crude though but works a treat. I solved it with a script. All is explained here: Thank you very much!
thatman84 Posted February 25, 2017 Author Posted February 25, 2017 @ci2own here's that thread Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
