rfancella Posted March 6, 2014 Posted March 6, 2014 Hello all, So, you have an Amiga? Disc's have gone bad or your floppy is not so floppy any more?? Stumbled across this article and thought it was interesting... http://amigadrive.blogspot.ca/2013/11/how-use-raspberry-pi-as-amiga-floppy.html Allows you to use a Raspberry Pi as a floppy drive emulator. Total cost (including the RPI) around $50.00. Thoughts? Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Agrajag Posted March 6, 2014 Posted March 6, 2014 I don't have an Amiga, but I'm impressed nonetheless! Is there anything that can't be done with a Raspberry Pi and a bit of ingenuity??? HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
KlopjerO Posted March 6, 2014 Posted March 6, 2014 Everything is possible with the power of the pi! Sent from my Nexus 7 using Tapatalk | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
rfancella Posted March 6, 2014 Author Posted March 6, 2014 Everything is possible with the power of the pi! Sent from my Nexus 7 using Tapatalk Right? It does seem like a little overkill, but it's still cheaper than buying new floppies or a new floppy drive. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
KlopjerO Posted March 6, 2014 Posted March 6, 2014 Right? It does seem like a little overkill, but it's still cheaper than buying new floppies or a new floppy drive.Thanks, Ron Better investment all around, once you're done with your amiga you pop in a different SD card and you could have a electron microscope, a media player, video editing station or hang it back into you're 3d printing rig. Pi rules!! Sent from my Nexus 7 using Tapatalk | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
zomboided Posted March 6, 2014 Posted March 6, 2014 Hello all,So, you have an Amiga? Disc's have gone bad or your floppy is not so floppy any more?? Stumbled across this article and thought it was interesting... http://amigadrive.blogspot.ca/2013/11/how-use-raspberry-pi-as-amiga-floppy.html Allows you to use a Raspberry Pi as a floppy drive emulator. Total cost (including the RPI) around $50.00. Thoughts? Ron Great link, thanks...I had an Amiga for a few years and loved it. [sIGPIC][/sIGPIC]
dark13 Posted March 7, 2014 Posted March 7, 2014 Right now there's also a (relatively) cheap solution to use an SD as hard disk with amiga, ACA500 accelerator Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
