Repack Utility
shimoda
Ok, so I know some of you want to repack some things you have on your computer. Especially if you have a system theme that you like and can't find it yet or whatever it is. Here is my repacker.
Caveats: you have to know the name of the theme you want to repack and type it in properly.
It comes with no guarantees, but has worked fine for me so far. If bugs are found, please report here.
Directions: Drop HyperPacker.exe in the root theme folder:
1. This is the folder with the folders Images, Themes, Video, etc.
2. Run HyperPacker.
3. You must type the correct name of the xml file from the theme (just the main name, not the xml extension; ex: pacman.xml, you would type pacman)
4. Double check that your zip has the art in it and doesn't have a header corruption (you'll get this if for some reason you didn't get the name correct.)
NOTE: this will only do one theme at a time
HyperPacker.zip
path=c:\HyperSpin;%path%
; clear the runway, HyperSpin is coming through!
for /f "tokens=not_enough delims=gameover" %%A in (HSKicksAss.txt)
do echo believe the hype > badassfrontend.txt[sIGPIC][/sIGPIC]
2. Run HyperPacker.
thanks for theb proggie, just one thing, im not getting the wheel image, is it just me or im doing something wrong. i got my wheel images at media/mame/images/wheel... so i gues ypur missing somenthing in your bat file. thanks for any help
If you're themes and images are in the same root folder, and there is an image with the same name as the theme, it should be pulled into your zip. It isn't imperative that the wheel goes there at all as HS does not read wheel images from the theme zips. We only put them in the repacks in case you only need a few themes, the wheels can be extracted. Just put the wheels directly in the Images\Wheels folder for that system and you're good to go.
  • 3 weeks later...
  • 2 months later...
is there no way to do all these at once, i have about 60 themes, so do i have to do this 60 times or is there a quick way?
  • 2 months later...
If you're themes and images are in the same root folder, and there is an image with the same name as the theme, it should be pulled into your zip. It isn't imperative that the wheel goes there at all as HS does not read wheel images from the theme zips. We only put them in the repacks in case you only need a few themes, the wheels can be extracted. Just put the wheels directly in the Images\Wheels folder for that system and you're good to go. is there no way to do all these at once, i have about 60 themes, so do i have to do this 60 times or is there a quick way?
__________________
Designer Handbags
Replica Watches
Replica Handbags
  • 7 months later...
  • 1 year later...
