(Tutorial) 16x9 Theme Conversion For Android
thatman84
ds works better on tablet so i may delete it off my pc build as it requires a mouse for a majority of the games iv got a "free ds for android 6" emulator wish i could get it set up with hyperspin.
sound just added loads of ps1 games bet they also need sorting and renaming to work with retroarch i also need to sort out my ini files so special art works too but thats a job for 2moz if i get round to it ill check back in tomorrow
@viper360 it's attached here
i think this has the borders and such with it but I just use the buttons which are special B.
you will need to adjust your .ini file special artwork screen position to get them to fit though or even show up!. I disable A&C.
these are static so they won't fade in and out.
Fotosizer degrades the image quality. I noticed this as I used it for box art, to then use as wheel art for some systems. The image lost clarity once resized, I'm pretty sure a forum member has posted on here showing exactly what I am talking about (in the useful tools thread perhaps?)
I'm sure people will say Fotosizer works OK, just wanted to point it out as some people are more "fussy" than others.
Yeah fotosizer does reduce the quality but I believe what your referring to is Dark 13's flash scripts which convert the art. Not the best option for Android.
if someone can point out a valid alternative I will happily update the guide.
Updated guide with this note
Note, fotosizer does cause a reduction in artwork quality. If your sensitive to this you may want to use another method. (If you know of a better program please comment) I only run a 37' screen and don't mind myself.
Found it! The post shows examples of the image degradation and an alternative tool to use. I don't want to take credit for IceLancer's advice but I knew Fotosizer did F' up .png images.
Good find Hono,
Updated the guide with  the recommendations. This guide is now F'd with all the missing screenshots and wrong program for resizing!
Has a little value still (just) but with the limited users needing it it not really worth updating properly until I have more time
