Pedestal Super Arcade 100” screen LED Buttons
guitarman84
I moved houses and sold my old arcade cabinet.  This time I decided to go with a pedestal build.  I have built a hyperpin cab and helped friends with some smaller 2 player builds but I wanted to go all out on this so I started with a new design I worked on digitally and then worked from there.  This post will show the progression of the design and build:
Specs:
Computer:
Gigabyte mobo Intel I3 16gigs of ram 500 gig ssd paired with 2 Terabyte hdd
EVGA GTX 580 card from old PC Running Win 7
AC Infinity cabinet fan and temperature control system with Tstat
LED Buttons and Joysticks all custom animated
Optoma HD27 Projector
100" Screen
Can link with smaller 2 Player arcade controller and 2 Xbox 360 controllers for 8 Player Bomberman
Other Details:
Step 1: Planning and software
Software basically ported everything I had from my old setup on an external HDD
Upgraded with adding some new systems and getting rocket launcher
Rocket launcher is awesome when I first started with hyperspin with the exception of my Mame artwork I had to manually re-label my entire art video and rom library which took part of my soul now everything is so much easier so big shout out to all these guys
Step 2: Construction
I used a basically table saw router jig saw circular saw and drill will get you where you need to go
I highly recommend lots of large wood clamps and pick up a forstner bit and a step bit
For the trackball I needed a hole saw
For the sides I clamped the 2 boards together and used a jigsaw to cut them both at the same tim to insure symmetry the rest of the pieces with were square cuts for the base
For the CP I cut the plexi and the wood together slowly with a plexi specific bit using the jigsaw
Anything I didn’t know I would do a test run cutting plexi, routing for the tmolding drilling buttons etc I did it a few times on a test piece before I worked on the main project
Step 3: Finish work graphics and Paint
Not much to say take everything apart and spray paint it
Put it all back together and apply the vinyl graphics
For the vinyl use blue tape to secure it peal up one side and cut the backing off then stick that piece of the vinyl down pull of the blue tape and fold the entire piece back with the exception of the
Step 4: Wiring dear god so much wiring
Step 5: Finished Playing and debugging
What went right:
Extremely happy with the overall look and graphics
Very happy with the plexiglass since this is my first time really working with plexi
Also first time using t molding trim
There are no screws that go from the outside of the body in everything is internal (yes I could have used bondo etc) I wanted a perfect smooth surface for the graphics
The AC Finity temp sensor and fan control system is awesome I highly recommend that for any cabinet it keeps things nice and cool
Things I would have done differently:
Include a sub inside the the cab (still might do that down the road) the system uses external in room speakers off of a surround sound receiver so no need but standalone it has no sound
The plexiglass has a 16” reveal  above the tmolding if sitting in front of the panel and with your hand at just the right angle that can get a little irritating
Vinyl that I used to print the graphics was a little thin and not as easy to work with
Might have planned to go with smaller wheel casters
Want to add an analog flight stick
Links to Misc Products I used:
Projector:
Optoma HD26 Projector https://www.amazon.com/gp/product/B00LL2SHK6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Most all of my arcade hardware came from Groovy Game Gear (love this website all of my projects have parts from Randy highly recommend anything there)
http://groovygamegear.com/webstore/
A few things he does not carry I picked up at Paradise Arcade Shop Specifically the LED Joystick hardware
https://paradisearcadeshop.com/
Everything else is from Amazon and Home Depot
AC Infinity System 2x T7 fans and a Thermostat
https://www.amazon.com/AC-Infinity-AIRPLATE-Thermostat-Cabinets/dp/B00QFWWZQO/ref=sr_1_1?ie=UTF8&qid=1479312158&sr=8-1&keywords=ac+infinity
Ethernet Jack
https://www.amazon.com/gp/product/B00DJ4Q5NA/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Casters
https://www.amazon.com/gp/product/B012ER7HHU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
T-molding
https://www.amazon.com/gp/product/B00KWBL8JY/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
External USB Ports
https://www.amazon.com/gp/product/B003VSXQVI/ref=oh_aui_detailpage_o07_s02?ie=UTF8&psc=1
Volume Knob
https://www.amazon.com/gp/product/B016U2KXCG/ref=oh_aui_detailpage_o09_s02?ie=UTF8&psc=1
Power  Switch
https://www.amazon.com/gp/product/B00N41D5Z4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Gas Strut Lid Stay
https://www.amazon.com/gp/product/B01909AHZY/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Resistors for Joystick LEDs (you will thank me later on this one I burned through several LEDs before I read that you need to install Resistors)
https://www.amazon.com/gp/product/B00SWKBOXC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Illuminated Player 1-4 Buttons
https://www.amazon.com/gp/product/B00F1YQK6S/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
X-Box 360 LED controllers
https://www.amazon.com/gp/product/B00EZKNT5O/ref=oh_aui_detailpage_o09_s02?ie=UTF8&th=1
Acrylic Plexiglass ¼” 24 x 48
https://www.amazon.com/gp/product/B00AI13E0O/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Plastic for Rear Power and HDMI system Ports
https://www.amazon.com/gp/product/B00AKJA6SM/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Part
Description
Computer
500
Craiglist and old parts Amazon Case
Plywood
66
Pine 3/4"  x 3
Misc Trim
100
plastic etc
Misc Hardware
100
paint screws L brackets tape hinges
vinyl graphics
235
custom graphics design fee
print cost
100
print fee
arcade controls
800
Groovy Game Gear
RGB joystick
200
led joystick and hollow shaft upgrade Paradise Arcade
PC
400
craigslist build
ventilation system
150
ac infinity system fans and tstat
volume knob
30
Amazon
USB and HDMI ports
100
Amazon
Projector Screen
150
Buddy was throwing it away
Optoma Projector
600
Amazon
TOTAL
2931
Thanks for the positive feedback guys.  I added some wiring pics since I always appreciate looking at what everyone else does to manage all the chaos underneath the buttons.
Blimey what a super detailed build thread, really enjoyed looking through.
You need to get rid of the old HS joystick animations and is your spinner weighted top and bottom? I have the token top which is weighted so I never bothered with the bottom one.
Cute children too, they must love it.
Some quality workmanship there!
On 11/23/2016 at 4:49 AM, ninja2bceen said:
Looks great. What are those two black buttons for within the cabinet next to the temp?
Regarding the black buttons next to the temperature control one turns on the LEDs that light up the wiring when the top is up.  The other one is a spare for future I was going to do some undecab LEDs later.  The star wars game is Battlefront I have the controls for flight mapped to the arcade so you can fly an xwing on the projector.
Thanks for all the positive feedback guys!
I just have the weight on the bottom and I replaced the topper the thing spins really well.  I don't think you need both but I really wanted a different topper than what it came with.  Never payed attention to the joystick animations how do I go about changing those?
Thanks 3 kids keeps this thing used constantly
Looks great! I just finished my first build but looking at this, i'm planning on getting some of the External USB ports.
I happen to work for an electrical distributor, and i just checked and my company sells the ones you listed for cheaper than Amazon: Neutrik USB ports
That's cool those little parts add up
  • 2 months later...
I have that identical pedestal design. I love it. Do you happen to have the template design for the sides of the pedestal? I want to change out my artwork. Would love to just create my own artwork on photoshop and have a local business print it for me. Just don't have the template.
Wow, this makes me want to build a pedestal for my den even more.
Super sweet!
I never thought about using surround sound for the audio. I have an old stereo from College with 2 MTX 10" floor speakers powered by a 460watt amp that might work nicely. :D
I see you listed a pc and computer on your cost list twice. Any reason?
You don't have exact measurements in a digital format do you? I love your design!
Keep up the good work. Those kids have a pretty cool Dad!
