Hi you can filter parents from lists with HyperHQ application --> wheel settings --> Navigation/Themes --> check "Parents only".
r0man0
yes, i know that, but rpcketluncher shows all, and is insane number of files, and this afer filtering some genres like majhong.
In any case, your program is awesome, one of the most useful for mame without a doubt.
Thanks , i will add your request for a future update , if you like this app , a small donation will be appreciated.
r0man0
r0man0
Add a +1 to Dunkler2Engel request's
By the way , i've tried to create mame 0.199 xml file with your program (upgraded my romset to the latest version as well) and there are some games that are missing , plus i cant get the "new.xml" file . Any ideas why is this happening ?
Thanks.
Until catver.ini v0.199 is not released. Mame XML generator doesn't create new.xml , and some new games added in this version will missing.
thanks for the reply, I forgot that MAME XML Generator needed an updated version of the catver.ini file
  • 3 months later...
I need your support with the last Tab 'Extras' in your app at Files section;
What do I select here if I want to include options like 'No CHD'? Do I just check the box? But leaving everything else blank will that be excluded than?
And my final question; What means the 'Folder' section on the right in each Tab?
If you let me know how I can donate you. I will do that right away. Because your app is amazing!
Regards,
Richard
Regards,
Richard
Hi , to get No CHD mame games list you have to check the "file" checkbox , the list will be placed on extras folder from the mame folder created by the app.
If you select No CHD folder , that will create a dedicated folder based from all No CHD mame games
ex : No CHD Folder with All genres files checked , will give you all genres lists from games that are listed in NO CHD.(so a game with CHD will be not present on Baseball.xml,Beat-em All.xml...etc...)
To donate use button "Donate" in tab "About" , thx
Thank you so much for your clear explanation. Just made a donation to you! ;)
Regards,
Richard
  • 2 months later...
hi hyperspin community , i wish you an happy new year , and to begin this new year : the last release of Mame XML full lists generator ?
Here is the changelog :
2019-01-07 - Fixed - Bug for "Go" button when none lists are selected
2019-01-07 - Fixed - Best compatibility for screens with small resolution (640x480)
2018-11-16 - Added - No clones option ( to exclude clones games )
2018-11-16 - Added - Lists filtered option ( to exclude games from unchecked boxes )
2018-11-16 - Fixed - Sports file was created when sports file checkbox was unchecked.
Enjoy !
  • 4 months later...
I think this is a very useful tool if I understand how it works, but I think it needs some better documentation. If I understand correctly, this will generate a MAME.xml database file for the version of the mame executable I supply it correct? And depending on what other options I select in the tabs genre and other filters will be created? What is the option on the first page with the checkbox "Mame XL ... 0." what is the purpose of this? Also, what is the purpose of the "Lists filtered" option? While I'm at it, what is the purpose of the folders options? I'm sorry but some of this is really unclear. I am really hoping this helps me generate the proper mame.xml hyperlist source xml file... But I'm having problems! A few times after running, the directories have been left empty like nothing has happened. Can you advise? I'm assuming after this runs and I have the file "mame 209.xml" this can just be renamed as "mame.xml" and put in the Hyperspin\Databases\MAME\ directory for RL to read?
I'm not trying to be critical, I think this is an invaluable tool I just want some clarity on functionality :)
Hi , yes this app generate XML lists for mame.exe.
firstselect your Mame executable (wait a moment to extract list)
Then select your destination for XML lists generated.
Then use options to personalize XML lists generated.
This option is set automaticly to the version number of Mame executable used , but you can set this to another version number (for example if you have an old rom set)
in this case your XML lists generated will only contains games from version selected.
This option will filter list XML generated with only filters selected on others tabs.
Ex : if i select on first tab Mame 0.209 / working / lists filtered , then on genre tab working / baseball / basketball ,
The mame 0.209.xml will contains only games working with genre baseball & basketball.
You Can filter lists with all nacessary filters availlable on tabs.
Folders will create lists dedicated for thé option selected.
Ex : if i select on years tab 1990-1999 folder working , then on genre tabs : all / working ,
app will generate 1990-1999.xml working list , and its own genre list that contains only games from 1990 to 1999.
You need tout select at least one filter to get a list. Because all tabs options are set by default to "None" , if you don't select an option all games genre/years/manufacturers... will be filtered and you get nothing.
Exact. ?
Of course , i Hope that i have clarify some points about this tool. ?
R0MAN0
Hi Everyone..
Hi Romano,  thanks for this utility, it makes our lives ALOT easier...
Issue #1:  I'm going through the process and select the mame64 executable (watching all the little birdies).  After it reads the DB, I make my selections and point it to a folder (example: c:\myxmls).  I click on GO and after 25-30 minutes, it completes BUT no file is generated.  I'm working with mame .208.  Please let me know what I'm doing wrong.
Issue #2 (not so much an issue):  Can you please give me or lead me to game examples of your Genre categories since I can't match them up on my hyperspin?  For example:  Mini-Games, Utility, Platform, Card Battle, New...etc.  Do you have a list or is there a list somewhere i can reference?
Thanks in advance!
-Dedos
Update:
I'm testing again, it seems to have created the folders this time.   I'll keep everyone posted.
20190522092129 : #Generating lists for Mame 0.208...
20190522092127 : #Check Destination Dir...OK
20190522092118 : #Check Destination Dir...
20190522092118 : #Downloading nplayers.ini...OK
20190522092116 : #Downloading nplayers.ini...
20190522092116 : #Downloading catver.ini...OK
20190522092112 : #Downloading catver.ini...
20190522092112 : #Geting lists...OK
20190522092112 : #Starting process...
"We were all newbies once...."
Welp, after 1.5 hours, it finished BUT seems that ALL the genres i checked off were on the XML and the ones that were checked on were not.  What did i do wrong?
thx.
Hi dedos , for some reasons sometimes nothing is writed on destination folder , that could be necessary to use same folder as mame generator app as destination folder  and also run this app as admin.
this app is based from files from http://www.progettosnaps.net/index.php
for genres & version the file is catver.ini mame generator auto-download necessary files for generating lists from this web-site.
to filter genre that are not checked from generated main list you need to check the box "lists filtered" located on main tab.
Thank you r0man0!, Sorry for the late reply.  I ended extracting the games i didnt want manually for a quick release but i dont want to give up on the generator so I'm going to go back and perform your suggestions.
Thank you again and I will report back with my findings for others to use.
  • 4 weeks later...
Hi
I think im trying to generate xml for 0.211 but it keeps on generating a folder that is empty. What do I need to do?
And what is that catver.ini error?
20190708004104 : #Ending...
20190708004104 : #done in 1sec
20190708004104 : #Check lists for Mame 0.211...OK
20190708004104 : #Generating lists for Mame 0.211...OK
20190708004103 : #Create Destination Dir...OK
20190708004103 : #Downloading catver.ini...Error
20190708004102 : #Downloading catver.ini...
20190708004102 : #Geting lists...OK
20190708004102 : #Starting process...
20190708004047 : #Ending...
20190708004047 : #None list selected...
20190708004047 : #Geting lists...OK
20190708004047 : #Starting process...
20190708004039 : #Ending...
20190708004039 : #None list selected...
20190708004039 : #Geting lists...OK
20190708004039 : #Starting process...
20190708004000 : #Ending...
20190708004000 : #done in 1sec
20190708004000 : #Check lists for Mame 0.211...OK
20190708004000 : #Generating lists for Mame 0.211...OK
20190708003959 : #Check Destination Dir...OK
20190708003952 : #Check Destination Dir...
20190708003952 : #Downloading catver.ini...Error
20190708003950 : #Downloading catver.ini...
20190708003950 : #Geting lists...OK
20190708003950 : #Starting process...
20190708003903 : #Ending...
20190708003903 : #done in 1sec
20190708003903 : #Check lists for Mame 0.211...OK
20190708003903 : #Generating lists for Mame 0.211...OK
20190708003902 : #Check Destination Dir...OK
20190708003852 : #Check Destination Dir...
20190708003852 : #Downloading catver.ini...Error
20190708003850 : #Downloading catver.ini...
20190708003850 : #Geting lists...OK
20190708003850 : #Starting process...
20190708003724 : #Ending...
20190708003724 : #done in 1sec
20190708003724 : #Check lists for Mame 0.211...OK
20190708003724 : #Generating lists for Mame 0.211...OK
20190708003723 : #Create Destination Dir...OK
20190708003723 : #Downloading catver.ini...Error
20190708003721 : #Downloading catver.ini...
20190708003721 : #Geting lists...OK
20190708003721 : #Starting process...
Thank you for the reply. How long can it take? I know it's a stupid question, but an estimate from experience if that happened before. Can anyone be notified? Can I supply that file myself somehow?
  • 5 weeks later...
  • 3 months later...
File shows updated "Updated
However, there is no download for this... Is this app still being developed and if so where to download it from?  Links on the site that the .txt file point to seem to be dead.
Hi dazz , this app still being developed , of course !
i've tested successfully links at
http://r0man0.free.fr/
and all is ok.
Application is in the download / mame section.
Sorry for the advertising steps for the download but it is necessary because there was too few donations for the content and applications that I develop.
r0man0
