Hyper Control (Main Menu Config & Apps Wheel)
Bungles
51 minutes ago, Kondorito said:
About the wheels, I recommend always storing unframed versions for future usage variants.
Yep I am trying my best to keep all the media I am using so that people can tinker with their own versions.
I will be sure to upload it somewhere so people can start changing once released.
Not much to go, just some themes for the wheel items and a Pointer I guess.
Other than that I might also include a "Reset Hyperspin" Button which can launch a simple batch to taskkill and then re-launch Hyperspin and/or extra application(s).
That way any System changes that don't update on refresh can also just be re-loaded.
Once that is ready I will release a pack for people to make it easier and then just tinker further with Emulator Wheels and Other Applications that come to mind.
Question, Whats the best Sync too for Hyperspin Members at the current? Hypersync, Hyperbase Live.. HyperAI??
I don't use them personally but will setup a button for those that do/will in the future.
The current one is HSync. HAI if Im not mistaken is the rebranding of HBL, so they are the same development (which is not completely deployed yet).
One wheel left for now which I will set as a Restart Hyperspin as I will remove the test emulator from the database and work on a small pack for them.
Just need the themes done and a pointer then we should have a complete pack to go. :)
Ok I have decided to use default theme instead as its just easier and smoother overall.
One issue, I decided on the animated background from the main menu theme...
It seems to work ok but on changing item the animation stops and only resumes when I alt-tab away and back into hyperspin.
I can however add a copy of the background for each item in the backgrounds folder but its 14mb and would like to avoid duplication if possible and it restarts the animation from the start on change of item so I dun like that.
It was all going so well.
:unknown:
Well I am happy with it as a release.
Edit: Just realized I missed a preview picture for Smart Defrag.. and its uploading..
Oh Well.. Separate Download Patch 1.1.1 to include it I guess.
