doohan Posted December 11, 2017 Posted December 11, 2017 Hello, I've made a script to launch 1/Xpadder then 2/a Game & Watch game and it runs and close perfect.The only thing I'd like to do is to minimize the Xpadder window in the taskbar or hide it (depending on how long it takes to minimize, I prefer the window of Xpadder to be invisible Here is the script:Run, Xpadder.exeSleep, 500Run, Banana.exeEsc::Process, Close, Banana.exeProcess, Close, Xpadder.exeExitAPPreturnCan someone help me?Thanks and regards,
gigapig Posted December 11, 2017 Posted December 11, 2017 You would use the PCLauncher module or the Retroarch module if you use the Retroarch ROM set for G&W.
jackhammersalm Posted December 11, 2017 Posted December 11, 2017 gig its in the latest mame version The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
gigapig Posted December 11, 2017 Posted December 11, 2017 14 minutes ago, jackhammersalm said: gig its in the latest mame version Thanks. Even if you are using the exe versions of Game & Watch from MADRigal?
jackhammersalm Posted December 11, 2017 Posted December 11, 2017 MADrigal work is the most accomplished atm The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
fire10 Posted December 11, 2017 Posted December 11, 2017 Yep im using PCLauncher for my MADRigal game and watch games
doohan Posted December 12, 2017 Author Posted December 12, 2017 Hi all I have a module for PCLauncher or similars, so I try to use it for Game and Watch.... I follow step by step and have a question that can look silly: *Make a file called PCLAUNCHER.ahk (or whatever you want to call it, so in my case, Game and Watch.ahk), right click and compile it. Set this as your emu exe. Ok. but do I have to write something in this ahk file like this or is it supposed to be empty? ----------------------------------------------------------------------- IniRead, gamePath, %A_Scriptdir%\Modules\%systemName%\settings.ini, %romName%, gamePath IniRead, params, %A_Scriptdir%\Modules\%systemName%\settings.ini, %romName%, params RunWait, %romPath%%romName%%romExtension% %params% WinActivate, HyperSpin ExitApp CloseProcess: return ---------------------------------------------------------------------- Thanks and regards,
doohan Posted December 12, 2017 Author Posted December 12, 2017 I'v tried something simple nearly working: In the same folder than the games: a ahk script by game: Run, E:\Nintendo\Game & Watch\Jeux\Banana\Banana.exe Esc:: Process, Close, Banana.exe ExitAPP return But I got his message "sound folder unproperly installed. Please reinstall the game." I don't need to reinstall the game, only to start the exe out of the ahk script. No problem with 95Popeye and popeye2....something to do with Madrigals games and the folder "Sounds"... Anyone an idea why I got this message with the launching of the exe with the script? Thanks and regards,
gigapig Posted December 12, 2017 Posted December 12, 2017 If you are using rocketlauncher you should not need to do anything like that. Follow this, its old but may help.
doohan Posted December 12, 2017 Author Posted December 12, 2017 Hi Gigapig, Problem is that I'v never used RocketLauncher, I don't like it and all is working fine with Hyperspin except that I would like to launch Xpadder with Game and Watch only, so if my script to launch a Game and Watch.exe succeeds, I would only have to add a "Run Xpadder"....
doohan Posted December 12, 2017 Author Posted December 12, 2017 Solved, I had to launch the ahk from the folder of the game itself... Anyone knows how to add run Xpadder before launching the game and close Xpadder after closing the game? Maybe Runwait? Thanks and regards,
doohan Posted December 13, 2017 Author Posted December 13, 2017 Done, The Minimize is an option in Xpadder config lol
doohan Posted December 15, 2017 Author Posted December 15, 2017 Hello, I made a .ahk which works perfect: Run, E:\Nintendo\Game & Watch\xpadder_gamepad_profiler\Buttons.xpadderprofile (charge"Buttons.xpadder profile"with the one you want to activate for each game) Sleep, 500 (wait till Xpadder profile is active) Run, HandheldQuake.exe Sleep, 500 MouseMove, 0, 1200 (get rid of the mouse pointer as it is not a Hyperlaunch) Send {Return} (access the game) Send {Return} Esc:: Process, Close, HandheldQuake.exe Process, Close, Xpadder.exe ExitAPP return Create a folder with the name of the game and erase all games in the folder "Games" from the HandheldQuake folder except the one you want to launch. The command "Click x, y" can be good if needed to bypass some screens or select actions to click to access the game by example to open the double screens Donkey Kong. I've just one question. The script works for all games but for HandeldQuake games, it works fullscreen outside HyperSpin but the windows of the exe of HandeldQuake goes in background in HyperSin. Only works if the settings in the program is not in fullscreen but then, I'm not fulscreen anymore... I'v heard that there is a command like 'Winset, Alwaysontop' but when I write it, the command doens't seem to understand what window has to go on top of screen, in this case, the HandeldQuake.exe Does someone know about this command line? Thanks and regards,
