Creezz67 Posted March 12, 2018 Posted March 12, 2018 Hi, Has anyone experienced JOY2KEY not working on certain keys ? example, I have setup a game profile for a game and left & right are set ok, but it just won't work with up & down Up & down both work on the keyboard and also when playing the game, but for some reason Joy2Key just won't allow control of these keys. All other buttons work fine. I had to set left and right to use number pad 4 & 6 for left and right, unfortunately numpad 8 & 4 down't work for up and down. Any ideas, is there a setting in Joy2Key I am missing as I have had this issue on a few ancient systems previously? ps, I have set JOY2KEY to use admin rights and also the emulator of the game (its an old apogee gameset)
Spawk Posted March 12, 2018 Posted March 12, 2018 Is that a different program than JoyToKey? You meant 8 and 2 right? The numpad numbers need the numlock on to work... but I guess 4 and 6 wouldn't work either if it was off... 8 and 2 do work when pressing them on keyboard? Is there a reason why you need to use the numpad numbers? You could always make P1 WASD, and P2 regular arrow keys.
Creezz67 Posted March 13, 2018 Author Posted March 13, 2018 Hi, Unfortunately these settings seem to be hard coded into the old emulator it uses and it has no ini file to edit or anything, so I need to use up & down. It basically was a question of finding the keyboard keys that worked for each game and then mapping to Joy2Key. I was saying that even though left & right arrows worked on the keyboard in game , it didn't on Joy2Key so I tried numpad 4 & 6 on Joy2Key and it worked (yes number lock on) The set I downloaded came with xpadder settings previously and worked fine, but I was trying to get all my setup set for Joy2Key. Not the end of the world as Apogee is an old system with 6 games, but each one works fine on all keys except up & down, very odd !!
artman999999 Posted March 13, 2018 Posted March 13, 2018 Makes sense to just have a program profile set up in J2K for that emu and you're done. Provided the background process is properly set up in J2K, it's pretty much guaranteed to work. If it's a multi-system emu (MAME, for example) where this mapping would overlap other machines, you could set up system-specific key remapping in Rocketlauncher and that might work. I've found this doesn't ALWAYS work though, especially for PCLoader games that seem to completely override the remapping .ahk. I hear a lot of people bail on J2K, but it's always worked great for me, and it's not like you NEED to use it for very many emus.
Creezz67 Posted March 14, 2018 Author Posted March 14, 2018 Yes, I also find that MAME is ok to map except the start and coin buttons (5 & 1) Again for some reason 5 & 1 work on keyboard, but even though they are set on Joy2Key they don't respond.
Kondorito Posted March 14, 2018 Posted March 14, 2018 I had a similar issue some time ago with MAME and JoyToKey. I learned that MAME uses rawinput as default to read multiple devices and to reduce lag, and since JoyToKey emulates strokes per assignation, MAME was not recognizing them. Solved it by opening mame.ini, finding the line " keyboardprovider auto" (without the quotes), and changing "auto" for "dinput" to force it. Hope this helps.
Creezz67 Posted March 15, 2018 Author Posted March 15, 2018 I had a similar issue some time ago with MAME and JoyToKey. I learned that MAME uses rawinput as default to read multiple devices and to reduce lag, and since JoyToKey emulates strokes per assignation, MAME was not recognizing them. Solved it by opening mame.ini, finding the line " keyboardprovider auto" (without the quotes), and changing "auto" for "dinput" to force it. Hope this helps. Nice one Kondorito, that worked perfectly. Such a simple change, so much for auto meaning auto
Kondorito Posted March 15, 2018 Posted March 15, 2018 Indeed, it makes no sense. Glad you sorted it out
Creezz67 Posted March 15, 2018 Author Posted March 15, 2018 Similar issue on RocketLauncher with default. If you set global default to true for say bezels it does not always work, so you then have to set the actual system to true and hey presto it works !! Very strange.
