How does one use a custom letter pack?
I downloaded a custom letters pack and I put the .png files inside the correct /Images/Letters/ directory but I'm not seeing this font used when I load up Hyperspin. What else do I need to do for HS to utilize these new letters?
Thanks in advance.
Letyers are for the letter skip function.
Not sure what button it is on PC but on my Shield I hold down trigger and the letters pop up. Then scroll through the letters and it takes me to the corresponding letter in the games list.
Your database must habe the index and image tags set correctly (any you get from here should be ok)
I believe theres also an use idecies box in HyperHQ but cant remember the exact use for it now.
If you what to change the font of the games list its set in HyperHQ under the relevent wheel
Hey w8sted,
Dropping the pngs in the Letters folder should be enough for them to show up.
Do you have another system that the letters are showing up? If so, copy/paste that Letters folder and paste it inside the images folder from the affected system, and see if they appear. If they do, then the problem is the png files you extracted there, if they do not show up, then something with the path for that folder is not ok.
Let me know how it goes and if the issue persist, share with me the letter pack and I will test it on my end.
Edit; I just re read your post and maybe you are mixing up the letters concept for choosing where to skip to, with the font type used for titles and stuff.
