Hyperspeech issues- Voices
Hi. It's been a while since I've needed help! My cabinet has worked flawlessly since 2014. Now, my Ivona voice has expired and I was getting popups to go to their website to purchase a new license. I'm using windows 7 64 bit. Not connected to the internet. I only have Microsoft Anna on my PC. She sounds horrible. I downloaded Balabolka free software and the Daniel voice. He sounds great. But I can't get him to show as a default voice in windows. However. It shows (and speaks) in the ledblinky config program via the test button. So, currently what is happening is, Microsoft Anna does all of the main talking, BUT, when you select a game to play, it's DANIEL'S voice that speaks what the various buttons do as they light up! (Jump, left kick, right kick, etc.). So, somehow, both voices are being triggered for different tasks? Anyone know why? And of course how can I get Daniel to be the only voice? Or for that matter, any other voices in windows 7?
The only way I know is to get the Run box up and enter the cpl which you can find in the one of the Hyper speech text files.
I still use Ivona Amy but that needs to be reinstalled on occasion, sometimes after a windows update.
  • 1 month later...
1 minute ago, richie_jones said:
Whats CPL...come on guys don`t talk riddles!!!!!
It's this place where you can find your voice. :rofl:
"I still use Ivona Amy but that needs to be reinstalled on occasion, sometimes after a windows update. "
I like this giga, my subs just run out to!!!!!!!!!!!!!!!!
6 hours ago, ninja2bceen said:
Where do I find this Amy? I see Zoe’s, Mark and Dave
Under English voices.
3 hours ago, ninja2bceen said:
Hmmm maybe I have a different thing then you all do. Where is English voices?
Unfortunately you have to be English. :P
If you have the same as mine it should be under British English.
On 20-6-2018 at 4:33 PM, Natdiamond said:
Hey guys,
My 50 cents:
All the voices you possibly need can be downloaded/purchased from the offical harposoftware website.
You can download all the voices as 30 days trial version to try them out, minispeech is included in every download.
If you need a longer period than 30 days to evaluate the voices, before puchase you might want to look for a keygen for MiniSpeech somewhere on the Internetz.
  • 3 months later...
Hyperspeech- Voces, puede ser usado en diferentes idiomas.
Instalar esto:
- Runtime 32bits & 64bits
- History.dat 0.204
- Handle & Handle64
- Activador de voces
- Voces de Microsoft:
Alemán (Alemania)
Catalán (España)
Chino (China)
Chino (Hong Kong)
Chino (Taiwán)
Coreano (Corea)
Danés (Dinamarca)
Español (España)
Español (Mexico)
Finlandés (Finlandia)
Francés (Canadá)
Francés (Francia)
Holandés (Países Bajos)
Inglés (Australia)
Inglés (Canadá)
Inglés (Estados Unidos)
Inglés (Gran Bretaña)
Inglés (Inglaterra)
Italiano (Italia)
Japonés (Japón)
Noruego (Noruega)
Polaco (Polonia)
Portugués (Brasil)
Portugués (Portugal)
Ruso (Rusia)
Sueco (Suecia)
_____________________
Instrucciones:
1.- Descargar el archivo HyperSpeech dentro de la carpeta raíz donde tenga a HS.
2.- Modificar el ini de HyperSpeech en concordancia  a su configuración
Ejemplo
MAMEHistoryDatPath=D:\RHS\HyperSpeech\history.dat
3.- Modifique su Setting o por HQ adicionando la ruta del HyperSpeech y active LEDBlinky y asignarle la carpeta HyperSpeech.
Ejemplo
[Startup Program]
Executable=HyperSpeech.exe
Paramaters=
Working_Directory=D:\RHS\HyperSpeech\
WinState=HIDDEN
[Exit Program]
Executable=
Paramaters=
Working_Directory=
WinState=HIDDEN
[LEDBlinky]
Active=true
4.- Instale según su arquitectura los rumtimes en mi caso es de 64 Bits reiniciar el equipo (importante). Como administrador ejecutar el activador e instale cualquiera de los paquetes de voces que quiera y luego activelo uno a uno luego cierre el activador.
5.- A continuación...
Panel de control >> Reconocimiento de Voz >> Texto a Voz >> Seleccione la voz que instalo Aplicar y aceptar eso es todo.
6.- Listo.
_______________________
Nota 1:
No funciono
Texto a Voz >> Seleccione pero no encuentro la voz instalada.
Solución:
Según su arquitectura
32Bits
C:\Windows\System32\Speech\SpeechUX
Ejecute el sapi.cpl como administrador y lo reconocerá aplicar y aceptar.
64Bits
C:\Windows\SysWOW64\Speech\SpeechUX
Nota 2:
En otra oportunidad ahora no tengo tiempo
Si realmente desea agregar a HyperSpeech con efectos seria a través de un software modificador de voz.
Nota 3
Si usted desea modificarlo a su idioma busque la voz adecuada y modifique el ini  a su idioma con estas expresiones o haga usted mismo otras
Ejemplo:
Elija en español.
MSSpeech_TTS_es-MX_Hilda
Modifique por esto en el ini de HyperSpeech
[HSStart]
Iniciandose..
Hola amigos...
[HSEnd]
Regresando al menu principal en unos segundos, En breve que estoy cargando las listas...
[HSGameStart]
Empieza en un momento
Espera, En breve que estoy cargando las listas...
Cargando la lista...
Lanzando en un momento ...
¡Prepararate!, Que estoy cargando las listas...
Ok, lanzando en un momento las listas ...
Aquí vamos... Ok, lanzando en un momento las listas ...
[HSGameEnd]
Eso se veía tan divertido ...
Seleccione otro juego ...
Elige otro juego ...
[HSAttractStart]
HyperSpin activado.
Elegiré algo más ...
Vamos a elegir algo más, entonces
Girando la rueda...
Deje que el destino decida el próximo
Ok, siguiente elección
[HSAttractEnd]
HyperSpin desactivado
Ok, veamos qué salió aquí.
¡Bonito!.
El siguiente es
Mira esto:.
Mira este.
Qué tal si:.
Bueno.
Estupendo.
Excelente.
[HSSystemSelect]
Cambiar el sistema
Este sistema es una excelente elección ...
Buscar su sistema o juego,
Selecciona un juego de la rueda
Bien ... cambiando a la rueda
Cargando sistema.
De acuerdo, cargando la rueda
Muy bien, cargando la rueda
[HSMainSelect]
Elige tu sistema o juego.
[HSMainReturn]
Ok, el próximo sistema ...
¿Tal vez le gustaría jugar un sistema diferente ahora?
Ok ... Volviendo a la Rueda del Menú Principal ...
Volviendo a la rueda del menú principal ..
Vamos a elegir un sistema diferente ...
Elija un sistema de la rueda ..
Ahora ha vuelto al menú principal de Hyper Spin.
¿Qué te gustaría elegir ahora?
Rueda principal Hyper Spin cargada ..
De vuelta a los sistemas ...
Derecha ... Volviendo ...
Volviendo a la rueda principal ..
Rueda principal ..
Aburrido con el sistema ya?
Muchos otros sistemas para elegir ...
¿El sistema siguiente entonces?
¿Qué es lo siguiente?..
De acuerdo, volviendo ...
Regresemos entonces ...
Cargando la rueda principal ..
Tal vez un sistema diferente, entonces?
Si insistes..
Al salir de la rueda del sistema, seleccione otro sistema.
[HSSystemReturn]
Volviendo a la rueda nuevamente.
Sistema nuevamente ...
Tanto para elegir otro sistema ...
Tienes razón, vamos a elegir un juego nuevamente ...
Tengo un deja vu ...
Decídete por favor ...
Regresando al sistema
¿Te gustaría jugar un juego nuevamente?
Nota 4
SpeakBioHotkey=F3
Con la asignación de F3 usted podrá escuchar la bio predeterminada que usted creo en su idioma.
A continuación:
Cree usted
[Handhelds Bio], [xxxxxxxx Bio]
Todas las que guste.
Ejemplo
[Handhelds Bio]
Una videoconsola portátil es un dispositivo electrónico ligero que permite jugar videojuegos y en el que, a diferencia de una videoconsola de sobremesa, los controles, la pantalla, los altavoces y la alimentación........
