StevieMac Posted July 12, 2018 Posted July 12, 2018 Hey Guys I know this isn't really a Hyperspin problem but I was hopeing someone has set up their PS3 controller on the shield without the problems I'm having. I can get the pad working fine with everything plugged in or using Bluetooth (HyperSpin, KODI, etc) but the red lights are constantly flashing (trying to link to something?) if I turn off my Shiled the lights carry on flashing until the battery dies in the controller. Is this normal? When I turn on the Shield TV after the lights go out (the following day) I have to re plug in the controller using the USB & re connect it all over again which is a pain each time I want to use it as a normal navigation control. Thanks for the help
reznnate Posted July 12, 2018 Posted July 12, 2018 I'm not sure why the PS3 controller does this but I've definitely seen this behavior as well. On Shield, it's been the consistent behavior across Android L->M->N and now Android O. It would be interesting to note if it's different on Windows, Mac, or other Android devices.
thatman84 Posted July 12, 2018 Posted July 12, 2018 I did setup my PS3 controller on the Shield natively recently and noticed the lights flash all the time. its not my main controller and I always turn it off not not caused me any issues. I have been busy with other stuff recently so not had the Shield on for a couple of weeks will be off for a while yet I expect Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
StevieMac Posted July 17, 2018 Author Posted July 17, 2018 thatman - what do you mean by ' and I always turn it off not not caused me any issues. ' Do you mean turn the pad off? How do you turn it off the little button underneath? Thanks
thatman84 Posted July 17, 2018 Posted July 17, 2018 I just hold the PS button down until the lights go off. But actually just testing it the 1 LED came on solid. (My shield is probably the only thing on right now, kid is watching TV though so cant check connection) so maybe I dont have the flaahing issue. I update to Oreo a couple of days ago Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
StevieMac Posted July 17, 2018 Author Posted July 17, 2018 Ah so Oreo might fix this as that's how it should work! When you get the TV back can you check please mate as I haven't updated yet.
thatman84 Posted July 17, 2018 Posted July 17, 2018 Just had it on and confirmed number 1 led is solid for the pad. I am almost certain all lights flashed constantly before the update. also I read with Shield experience 7 that they worked on ds4 compatibility so could be an upshot of that work Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
StevieMac Posted July 17, 2018 Author Posted July 17, 2018 Great then I'll upate later this week then, & confirm this works. Thanks for the info
StevieMac Posted July 18, 2018 Author Posted July 18, 2018 Ok I updated to Oreo (poo new layout). I tried to install my PS3 pad & got the same result of the 4 flashing lights so I tried my other pad. This time the other pad worked & conected but the name wasn't Playstation3(sixaxis) it was just conected where the other pad came up with a full name but didn't work! So a bit confusing but it seems to be working with the other pad fine now although no lights come up on the working pad but I guess thats ok. I just renamed the working pad to PS3_1 but I still couldn't connect the old pad correctly. I tried resetting it & connecting back to my PS3 but still the same result so no idea. At least one is working now. Thanks
thatman84 Posted July 18, 2018 Posted July 18, 2018 Weird what was your process of connecting. I think i had to connect with usb to pair 1st time Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
StevieMac Posted July 18, 2018 Author Posted July 18, 2018 Yeah you have to go to Settings - Add accessory - then hit the PS button on the pad to get it into Blutooth search - then I plugged it in & it connected. But doing it various other ways on the old pad I've been asked for a PS number for the pad or it works plugged in then works through bluetooth but when you restart it disapears from the list & you have to re pair it. Sometimes the full name comes up or just says connected sometimes it comes up on the list of things to connect soemtimes it just works even though it never appears on the connection list.
StevieMac Posted July 18, 2018 Author Posted July 18, 2018 Actually I've just tried the pad & the one that is working now has the flashing 4 lights again so I've no idea what I'm doing wrong it was working this morning!
thatman84 Posted July 18, 2018 Posted July 18, 2018 I would probably put it down to buggy android/shield handeling of PS3 pads Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
