Wotto Posted July 25, 2018 Posted July 25, 2018 So - tonight - I am going to attempt to add Bezels - which I am reading could be a lil ole nightmare. I have read some threads and watched a video... Can someone just clarify that I have my thoughts correct. I have downloaded the Mame Unified Bezel Pack ( Rocket Launcher - Metalzoic ) Zip File from EmuMovies I go to Rocket Launcher / Media / Bezel / Mame - and I paste all the individual zip files in that Mame directory. I then make sure that for the games I want to have Bezels - that I ‘re-name’ each individual zip file to be the same as my actual Mame Rom. For example - Pacman Rom is on my D Drive in Mame/ Roms directory - named Pacmanb - so I go to the Bezel Zip file currently named Pacman - and rename it to Pacmanb Rinse and repeat for all my games/ roms/ bezel zips. I then go to Rocket Launcher Global Settings Bezels tab Bezels = True Then , still in RL I then go to my Mame Emulator - Modules - Select Edit Global etc - and then select Bezels - use RL Bezels and also make Mame Bezels = True. That about it ?? I try and do all of this without bothering you all too much - but would appreciate some assistance on this bit please Cheers
Spawk Posted July 25, 2018 Posted July 25, 2018 I dont think you use make mame bezel option unless you have dl'd the mame "extras" stuff.Also just to let you know, metalzoics pack is not for everyones taste. They are all configured for maximum playing screen size... meaning the bezel artwork is cut off in a whole lot of them.Phulshof, a member here and developer of retrofe also maintains a pack of unedited bezels on his site. In many cases these are the exact bezels that metalzoic includes in his but the artwork is not cut off here. Plus metalzoics has not been updated in some time.Sent from my SM-A520W using Tapatalk
Wotto Posted July 25, 2018 Author Posted July 25, 2018 Thanks for that - I am grabbing Phulshof files right now My 'directory' theory is correct however - yes ?
Spawk Posted July 25, 2018 Posted July 25, 2018 Yep, and with his pack you should not have to rename anything Thanks for that - I am grabbing Phulshof files right now My 'directory' theory is correct however - yes ? Sent from my SM-A520W using Tapatalk
Spawk Posted July 25, 2018 Posted July 25, 2018 33 minutes ago, Spawk said: Yep, and with his pack you should not have to rename anything Sent from my SM-A520W using Tapatalk Sorry I was too quick with my reply, Phulshof's pack is actually for Mame itself, not RL. So they go in ../Mame/Artwork/ folder. They contain Mame "extras" stuff as well as user created stuff. All config for this set is done within Mame so leave bezels off in RL.
Wotto Posted July 25, 2018 Author Posted July 25, 2018 Thanks Spawk - will try this all soon - appreciated
thatman84 Posted July 25, 2018 Posted July 25, 2018 @Wotto Read the 1st post here bezel packs are usually plug and play. Just put them in the right folder. Metalzoics are for RL and Phulshofs are for mame emulator. Some names may be off in metalzoics as its an older mame set but not many Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Wotto Posted July 25, 2018 Author Posted July 25, 2018 Thanks again - all is "ok" I have a couple of games ( Pacman for example ) where the bezel loads in standalone Mame wonderfully - yet when launched thru HS - the Pacman Bexel doesnt appear at all - and if I TAB to see the menu there are no options for different bezels in the listing , like there is in the other games where bezels do appear and I am able to choose from the list of available options Thoughts on that ?
thatman84 Posted July 25, 2018 Posted July 25, 2018 Could be a different version of the game your launching maybe. I'm not to hot on mame If HS is using RL for launching mame I woukd say its a RL setting. RL forum may have the answer in that case. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Wotto Posted July 25, 2018 Author Posted July 25, 2018 Thanks guys - managed to get all running apart from a couple , which I will persist with. Help appreciated
Wotto Posted July 26, 2018 Author Posted July 26, 2018 MsPAcman is the ONLY Bezel for the life of me that I cannot get to run. I have the game running in HS no issues , with theme and video in theme - To further test it I have renamed it all various times to match/ run the various rom versions of MsPAcman I have ( mspacman, mspacii etc ) and all the roms work - yet all of the roms have NO bezels available from the Video Options tab within the game other than 3:4 , cocktail and Debug ( standard ) I have opened the MsPacman Bezel zip/ folder and all the images and .Lay files are there. Any other thoughts?
phulshof Posted July 26, 2018 Posted July 26, 2018 5 hours ago, Wotto said: MsPAcman is the ONLY Bezel for the life of me that I cannot get to run. Any other thoughts? Unfortunately, yes. If you're running my bezel set, I'm afraid I may have accidentally put the same layout twice in the .lay file, and MAME doesn't like that too much. I haven't found time to update it yet, but if you open the .lay file you should be able to detect the double entry rather easily.
fire10 Posted July 26, 2018 Posted July 26, 2018 Ah I have this problem too, I've looked through the. Lay file but cannot pinpoint the error, any guidance would be most appreciated mate, cheers
Wotto Posted July 26, 2018 Author Posted July 26, 2018 Thanks Phulshof Can I also ask what program best opens a .Lay file - I tried Notepad ++ and it didnt open it. Cheers
phulshof Posted July 26, 2018 Posted July 26, 2018 Notepad++ should work fine after you unpack the zip file, but here you go. mspacman.zip
fire10 Posted July 26, 2018 Posted July 26, 2018 Thankyou phulshof ill get this tomorrow, yep notepad works
