DATA PARANOIA/ backing up Hyperspin
xHyperSteve
Hey guys,
Losing all your Hyperspin data can be a scary thought.
I have been backing up my Hyperspin folder religiously. it's about 300gigs without disc games. It takes so long to backup.....
What is your method for backing up your data? Is it Fast and efficient? Any program you use?
I use sync toy but lately I have been having errors with it and my MyCloudEx4 NAS.
Thoughts?
Thanks
Steve
Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve:D
https://twitter.com/HyperSteveShow
My setup: 1 x 250gb Boot drive. 1 x 4tb Roms drive. I use a Synology DS414 with 4 x 3tb drives in Raid 5 for my backups. I backup my boot drive to they Synology every Sunday over 10/100/1000 lan. Keep my roms zipped and archived on the synology as well. I am thinking of adding a USB 4tb drive to keep everything off site as well once my config is finalized. Been working on this since August 2013 and I am not going to reset it all up.
Yeah, I bought the MyCloudEx4 and it is damn slow! I use the Ethernet LAN cable to transfer and it just turtles along sometimes and then reaches a point where it just does not work. I tried to upgrade the firmware manually for it and it was problem after problem with the web browser interface.
Anyone else have a quick method or program they use?
Sorry I got a DS412+. That My Cloud EX4 seems like a decent devices. I generally get 158.33MB/sec with my Synology. I don't really care about it because It backs up Sunday night while I am sleeping, so I do not watch it.
I bought a 4Tb hard drive and a hard drive dock. Cost me just over $150.00 for everything. Every time I finalize a system, I zip it and copy it over. Once I finish everything I will buy another hard drive and make a second copy of everything again and keep it at my desk at work. If all else fails, I can always buy a complete setup from guys on e-bay (last resort)
I kind of cheat when it comes to this as I am a software engineer lol, I wrote my own programs to create 1:1 images of all my drives and store them on my raid array in the basement. Its 25TB all on fiber I have wired through the house. Also have an off site backup that saves important folders.
Hey guys,
Thoughts?
Thanks
Steve
Steve, are you doing a full backup (overwrite unchanged files) every time?
I have a 2TB WD External USB drive I store everything on. I did the backup of everything when I originally set it up. Took about an hour. Now, as I add games I simply add them to the external drive - game, XML, themes, media, etc. I usually wait until I have a few done. All of the games I also have an a separate 2TB drive on my main/personal PC. At work we get "awards" for doing a good job. I am up to $500 this year. I am looking to get a few 4TB drives and parts for a new PC, using that money to supplement it. I am running out of space!
njgsx96 : I'm confused. Were you offering a solution to Steve's problem? :dong:
I was. get a USB backup drive (or 2) and use that to back up the Hyperspin folder. You may have to reinstall a few games, but should be good. OR image the drive so no reinstall necessary. Store that file on the USB hard drive.
Without sync toy, I simply drag and drop the "hyperspin" folder into the same directory. So yes I sort of an overwriting unchanged files because it takes time for windows to recognized unchanged files and prompt me to do otherwise.
Synctoy, was supposed to help that problem by searching for changes first than overwriting only changes. But MyCloudEx4 NAS is plagued with errors and speed issues....this has been documented in amazon reviews.
I do not do a full backup of my stuff. I have all my roms and media on anther computer. But I do a manual backup of all my settings and database files. This includes the following directories:
Databases
Settings
HyperLaunch\Data
HyperLaunch\Modules
HyperLaunch\Profiles
HyperLaunch\Settings
Any time I make a change to my setup, I run a batch script that uses RoboCopy:
@ECHO OFF
SETLOCAL
rmdir /s /q Backups\HSBackup6
Echo Backup #6 Deleted
move Backups\HSBackup5 Backups\HSBackup6
Echo Moved Backup 5 to 6
move Backups\HSBackup4 Backups\HSBackup5
Echo Moved Backup 4 to 5
move Backups\HSBackup3 Backups\HSBackup4
Echo Moved Backup 3 to 4
move Backups\HSBackup2 Backups\HSBackup3
Echo Moved Backup 2 to 3
move Backups\HSBackup1 Backups\HSBackup2
Echo Moved Backup 1 to 2
mkdir Backups\HSBackup1
SET _source=Settings
SET _dest=Backups\HSBackup1\Settings
SET _options=/R:0 /W:0 /LOG:Backups\HSBackup1\MyHSBackup.txt /NFL /NDL
:: /R:n :: number of Retries
:: /W:n :: Wait time between retries
:: /LOG :: Output log file
:: /NFL :: No file logging
:: /NDL :: No dir logging
CALL :RUN
Echo HS Settings Done
SET _options=/R:0 /W:0 /LOG+:Backups\HSBackup1\MyHSBackup.txt /NFL /NDL
SET _source=Databases
SET _dest=Backups\HSBackup1\Databases
CALL :RUN
Echo HS Databases Done
SET _source=HyperLaunch\Settings
SET _dest=Backups\HSBackup1\HyperLaunch\Settings
CALL :RUN
Echo HL Settings Done
SET _source=HyperLaunch\Modules
SET _dest=Backups\HSBackup1\HyperLaunch\Modules
CALL :RUN
Echo HL Modules Done
SET _source=HyperLaunch\Profiles
SET _dest=Backups\HSBackup1\HyperLaunch\Profiles
CALL :RUN
Echo HL Profiles Done
SET _source=HyperLaunch\Data
SET _dest=Backups\HSBackup1\HyperLaunch\Data
CALL :RUN
Echo HL Data Done
GOTO :EOF
:RUN
SET _what=/COPYALL /B /SEC /MIR
:: /COPYALL :: COPY ALL file info
:: /B :: copy files in Backup mode.
:: /SEC :: copy files with SECurity
:: /MIR :: MIRror a directory tree
ROBOCOPY %_source% %_dest% %_what% %_options%
:EOF
Save this file as Backup.cmd in your HyperSpin folder.
I'm sure there is a better way to do it, but this works fine.
It keeps a total of 6 backups and each time it's run, it rotates them up.
I wrote this for myself and another user that keeps having settings files disappear from their system Hope this helps someone.
Thanks,
Ron
Databases
Settings
HyperLaunch\Data
HyperLaunch\Modules
@ECHO OFF
SETLOCAL
CALL :RUN
CALL :RUN
CALL :RUN
CALL :RUN
CALL :RUN
CALL :RUN
Echo HL Data Done
GOTO :EOF
:RUN
:EOF
Thanks,
Ron
This looks promising man! What directory does it save the backups to?
If I do this it should be simple to just back up each new batch of roms and games separately.
Before I was just interested I. Creating a drag and drop hyperspin folder that I can move to any system in the event of nuclear meltdown.
The problem with that is the slowness of my NAS. A bad buy from WD.
It just copies the folders into ...\HyperSpin\Backups
And creates the folder HSBackup1, HSBackup2, etc.
Thanks,
Ron
Thanks,
Ron
Hee hee....good ole batch file programming :) Remember had to do this stuff at my previous position in my company.
[sIGPIC][/sIGPIC]
Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
Rfancella is there a way to create a batch file to robocopy the entire hyperspin folder to drive letter z? I like this batch file stuff,
Do you want to just copy the files that are different?
If so, just:
RoboCopy c:\hyperspin z:\hyperspin /copyall /b /sec /mir
should do it.
Thanks,
Ron
Hi Ron, great info!
Robocopy is great for Windows. I use Rsync : http://rsync.samba.org/
It's similar to Robocopy except for it only copies over bit changes. So if you have large file it will not copy the whole thing again, it will only copy that bytes that have changed. Very fast and effective!
Hi Ron, great info!
:D
Yea, I use Rsync to backup my Linux servers. But for Windows, RoboCopy does the same thing, and it's included with windows. ;)
Thanks,
Ron
Ron :
Yes to Robocopy being included with windows :)
No to "they do the same thing". I might be wrong but as I understand it, Robocopy will copy an entire file if there is any sort of change in it. Rsync will only copy over the bit changes instead of copying the entire file which results in much faster sync process. Does that make sense?
I might be wrong about the Robocopy not doing bit changes as well but that is how I understand it. Correct me if I'm wrong.
Kudos to your linux boxes :D
I <3 the linny
Yes to Robocopy include with windows :)
No to "they do the same thing" I might be wrong but as I understand it. Robocopy will copy an entire file if there is any sort of change in it. Rsync will only copy over the bit changes which results in much faster sync process. Does that make sense?
I <3 the linny
Yes you are correct. Robocopy will copy the entire file if it changes. Not just the parts of the files that are different. I thought Rsync copies the entire file also, at least thats what I see in my logs. Unless i'm missing a switch?
Me also, I have three running CentOS 5.10 on all three. Two web and email servers and one backup server. :D And I work on a bunch of EL6 boxes at work.
Thanks,
Ron
  • 2 years later...
Curious if anyone has had a similar issue.  I am doing test backup and restores going between two internal drives in the same system.  At this time just coping the folders to an external “connected” drive.  When restoring the two folders (rocket launcher and hyperspin) to the new drive I get the “error waiting for the window ahk_class emulator name” but the games still loads in a windowed background, this is both direct from rocket launcher and hyperspin.  Go back to the drive that the backup was made from and it works fine.
