jdsabin1 Posted May 15, 2011 Posted May 15, 2011 Thanks man - much appreciated. Gonna go fire it up this afternoon . 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
jdsabin1 Posted May 16, 2011 Posted May 16, 2011 I only ran across one question/problem so far that hopefully someone can help with: I have the hotkey application itself installed and I created a executable (plaved in my startup folder so it would be alive all the time) that essentially allows me to re-start Hyperpin upon a few button presses on my cab (left ctrl + G actually). The reason I did this was becaue some of the heavy hitter FP tables like Three Angels hogs memory and won't give it back. Eventually a table will open up that won't have any textures showing and when it does that I wanted to exit HyperPin (release the memory) and reopen it with an easy button stroke like I mention above. The problem though is that this creates problems with HyperPin itself when I exit tables that I am playing in HyperPin. There are times when I will exit a table and I will see a large empty window over HyperPin and in the title bar it is referencing the hotkey program I compiled and put in my startup folder. I can esc out of that and the window will disappear and HyperPin works fine but obviously I don't want to do that. Any ideas? Perhaps there is another 'hot key' like program that will do something similar. I do know I need something because there are times when I need to restart HyperPin for whatever reason. Thanks in advance. 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
blur Posted May 18, 2011 Posted May 18, 2011 (edited) i have new version of fplaunch manual on first page, second post everybody please check it for errors jdsabin if you need this hotkey only in tables and not in hyperpin you can add it to fplaunch script and have only one ahk script running but i dont see how restart of hyperpin.exe could help with releasing memory taken by future pinbal.exe? Edited May 18, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
me-mike Posted May 19, 2011 Posted May 19, 2011 Thanks for the latest release, and the updated instructions for us nanotech/pinball wizard folks. I'll download the new version tomorrow and let you know if I encounter any issues. Thanks for all of your help in the past, it was greatly appreciated Blur!
jdsabin1 Posted May 19, 2011 Posted May 19, 2011 i have new version of fplaunch manual on first page, second posteverybody please check it for errors jdsabin if you need this hotkey only in tables and not in hyperpin you can add it to fplaunch script and have only one ahk script running but i dont see how restart of hyperpin.exe could help with releasing memory taken by future pinbal.exe? You have a valid point blur. FP actually completely exits upon exiting a table and going back to Hyperpin right? 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
blur Posted May 19, 2011 Posted May 19, 2011 thanks mike jdsabin yes fp and vp exit completely, you can check it with task manager even if it doesn't you have some other problem there are cases when fp and vp don't exit immediately - you can see this by slow hyperpin - but then what i do is - I just go left and right in hyperpin until i see that HP is fast again and that means that vp/fp is finally closed and released all it's memory. I get this only on some tables, and on that tables i get this after every exit of the table. You could even think oh no hp is doing something and it is slow again - BUT this has nothing to do with HP. It is just that vp closes some tables very slow on exit. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
jdsabin1 Posted May 20, 2011 Posted May 20, 2011 There is definitely something wrong with this script as it relates to Big Score. I can get the game to load, the coin and start remappings work, but I was getting erratic behavior using the right and left ctrl keys being remapped to enter. I do have a button on the cab mapped to the '2' key so I mapped that to enter instead (and commented out the right and left ctrl keys and recompiled) to see if it was just the ctrl keys that created the problem. I did get farther in the game, up to the point of starting the game but the ball never does load. The table is just stuck on start waiting to plunge the ball but the ball isn't there. The game works perfectly fine when launched natively. Any ideas? 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
blur Posted May 20, 2011 Posted May 20, 2011 well i didn't play much on big score, i tried once and the view and perspective is little awkward (there is no true arcade mode), i don't like it keys are working fine for me, but keys are something everybody should fix for them self, and experiment what's best depending on what keys you have on your cab did you used 5 and 1 to start the game? did you selected the role - game will not start if you don't select the role with flippers and then enter (L/R control) My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
jdsabin1 Posted May 20, 2011 Posted May 20, 2011 well i didn't play much on big score, i tried once and the view and perspective is little awkward (there is no true arcade mode), i don't like itkeys are working fine for me, but keys are something everybody should fix for them self, and experiment what's best depending on what keys you have on your cab did you used 5 and 1 to start the game? did you selected the role - game will not start if you don't select the role with flippers and then enter (L/R control) Thanks blur. I know this feature isn't something that you spent much time on and that's cool. It's great that this is in there at all . Yeah I did select the player and press enter but the ball never loads. I am next going to try your suggestion using the '~' to have the enter key do double duty and see if that helps at all. 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
HyphyCus Posted May 21, 2011 Posted May 21, 2011 (edited) I'm still having that issue apparently with the DMD. I made a short video (FS and 720p you can see it good) so I can show you what is going on. No audio though, and not the best quality but I hope it conveys the message still. I tried it with the wip3 after (found it while browsing through the posts) and it's still the same. Just tested with the old 1.1 and the DMD shows up fine. http://youtu.be/mjJ2DjhmLmo Edited May 21, 2011 by HyphyCus
blur Posted May 21, 2011 Posted May 21, 2011 try to change WinWaitActive, ahk_class VPPlayer with WinWait, ahk_class VPPlayer My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
HyphyCus Posted May 21, 2011 Posted May 21, 2011 I tried 10 different tables and it only worked on the 2nd try, but once I reloaded that table it didn't work again.
jdsabin1 Posted May 21, 2011 Posted May 21, 2011 The Big Score functionality problem is definitely in either HyperPin or fplaunch. If I load the table outside of those, it works fine (using the keys on the cabinet that correspond to the default keys in the game). It just never loads the ball in HyperPin/fplaunch even though the game is sitting there waiting for the game to start (and DMD reads 0, etc). Strange. 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
blur Posted May 22, 2011 Posted May 22, 2011 I tried 10 different tables and it only worked on the 2nd try, but once I reloaded that table it didn't work again. you have nt4sp5 comp mode set? i've heard from some people that remove of nvram also helps, even with original wip3 script My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
HyphyCus Posted May 22, 2011 Posted May 22, 2011 you have nt4sp5 comp mode set?i've heard from some people that remove of nvram also helps, even with original wip3 script Ya, I have VP, HP, and FPLaunch set to NT4 compat. One thing I found out was once I'm in the table, and the DMD isn't showing I can F3 and refresh and it will pop back to the front, and I can play the table. I'm wondering if there is something you can put in the ahk to make it auto reset once the table is loaded. So it's pretty much instant and you don't even notice it, but for a split second.
blur Posted May 22, 2011 Posted May 22, 2011 (edited) Ya, I have VP, HP, and FPLaunch set to NT4 compat. One thing I found out was once I'm in the table, and the DMD isn't showing I can F3 and refresh and it will pop back to the front, and I can play the table. I'm wondering if there is something you can put in the ahk to make it auto reset once the table is loaded. So it's pretty much instant and you don't even notice it, but for a split second. i've found the source of the problem this happens because vp is started minimized and vp is started minimized to be hidden if i do winactivate of vpplayer early enough in the script then dmd will show up still have to test it a little bit more to see how it influences no-nag part of the script and everything else Edited May 22, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted May 22, 2011 Posted May 22, 2011 (edited) The Big Score functionality problem is definitely in either HyperPin or fplaunch. If I load the table outside of those, it works fine (using the keys on the cabinet that correspond to the default keys in the game). It just never loads the ball in HyperPin/fplaunch even though the game is sitting there waiting for the game to start (and DMD reads 0, etc). Strange. I tried again and everything works 5 mapped to 1 1 to s enter to down controls to enter mapping enter with ~ did not help much cause on the menu for example you get down key sent first and then enter and you end up entering second menu item instead of first one Edited May 22, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
jdsabin1 Posted May 22, 2011 Posted May 22, 2011 (edited) I tried again and everything works5 mapped to 1 1 to s enter to down controls to enter mapping enter with ~ did not help much cause on the menu for example you get down key sent first and then enter you end up on the second option instead of first one Thanks for validating. Are the keys mapped in the order that they appear in the download of fplaunch then? And do you use an ipac2? Would hyperpin have anything to do with this at all? There *has* to be something I am missing and it's in the way that fplaunch is remapping the keys. On my cab, Big Score is confused about something. Perhaps it is Windows 7 64 bit? Grasping at straws I know .... Edited May 22, 2011 by jdsabin1 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
blur Posted May 22, 2011 Posted May 22, 2011 This is the order: RControl::Enter LControl::Enter Enter::down 5::1 1::s what keys do you use? you can always map it different ipac and win7 can both be source of the problems make one ahk file with only key mappings and see if it works My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
jdsabin1 Posted May 23, 2011 Posted May 23, 2011 This is the order: RControl::Enter LControl::Enter Enter::down 5::1 1::s what keys do you use? you can always map it different ipac and win7 can both be source of the problems make one ahk file with only key mappings and see if it works Great idea. I created a file with these key remappings in it: RControl::Enter LControl::Enter Enter::down 5::1 1::s Compiled it and then ran the game outside of HyperPin using the cabinet buttons. It worked perfectly. There is something amiss in either the FPLAUNCH file or in HyperPin itself. Not sure what to do next but it feels good to at least be narrowing it down some. 'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
Guest tornado Posted May 23, 2011 Posted May 23, 2011 i dont see blue text on screen only in wheel menu
blur Posted May 23, 2011 Posted May 23, 2011 This is complete source for bigscore, so there is not much that can be wrong: if(tableName = "BigScore") { Hotkey, $%exitEmulatorKey%, CloseSlam ;Remap some keys (enter to down arrow for plunger, 1 to s for start, 2 to 1 for insert coin, both ctrl to enter. ;setworkingdir, "..\SlamIt\BigScore.exe" Run, "..\slamit\go.bat", "..\SlamIt" WinWait, ahk_class SlamIt Pinball - Big Score Gui, destroy #IfWinActive ahk_class SlamIt Pinball - Big Score RControl::Enter LControl::Enter ~Enter::down 5::1 1::s #IfWinActive Process, WaitClose, BigScore.exe } else { try to put all this to your new small script (remove if, add closeslam code), and see if it works if it doesn't maybe remove blanks from the beginning of lines My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted May 23, 2011 Posted May 23, 2011 i dont see blue text on screen only in wheel menu yeah, and during the night is colder then outside did you checked manual? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted May 23, 2011 Posted May 23, 2011 (edited) Ya, I have VP, HP, and FPLaunch set to NT4 compat. One thing I found out was once I'm in the table, and the DMD isn't showing I can F3 and refresh and it will pop back to the front, and I can play the table. I'm wondering if there is something you can put in the ahk to make it auto reset once the table is loaded. So it's pretty much instant and you don't even notice it, but for a split second. Hipi this is a great find and it works. Check you code and after: WinWaitActive, ahk_class VPPlayer ;Wait for vp to be Ready before killing Gui blackScreen just add: Send {F3} I've tried to add winactivate of vpplayer in loading screen loop but it completely breaks nag screen removal functionality. I've tried also clicking on mame window and on vpplayer but it is so unreliable So try this and let me know if it works on all tables, and i will put it in next release. Edited May 23, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Create an account
Register a new accountSign in
Sign In Now
