d8thstar Posted August 17, 2018 Posted August 17, 2018 hi guys, is it possible to have the wheel always be the top layer? some of the themes are really busy and when idle, the wheel all but disappears. thanks
Bungles Posted August 17, 2018 Posted August 17, 2018 Don't think its possible in the current version. Might be something they consider in 2.0 The ability to set alpha layers etc. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
thatman84 Posted August 17, 2018 Posted August 17, 2018 If you can still just see the wheel then try turning up the alpha setting for the wheel. It stops it fading away. either in HYperHQ on in the settings ini files there’s a wheel alpha line iirc set it to 1 the dial it back. i can’t remeber the actual layers off hand but maybe other artworks can sit on top of it regardless of Alpha setting Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Bungles Posted August 17, 2018 Posted August 17, 2018 Layers 1-4 and Video+Frame I think.... Only background layers behind the wheel. So if you can embed all graphics in the background and make it an SWF etc for animations.. solved. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Andyman Posted August 17, 2018 Posted August 17, 2018 4 hours ago, thatman84 said: If you can still just see the wheel then try turning up the alpha setting for the wheel. It stops it fading away. either in HYperHQ on in the settings ini files there’s a wheel alpha line iirc set it to 1 the dial it back. i can’t remeber the actual layers off hand but maybe other artworks can sit on top of it regardless of Alpha setting I do this in my Pure theme - credit to dark13 and his Aeon Nox theme for the idea!
dark13 Posted August 17, 2018 Posted August 17, 2018 The only layers rendered behind the wheel are "background" and "pointer". The idea behind "default" HS theme is to have fullscreen arcade-like animations with wheel fading off, other themes are conceived to always show the wheel. Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
