Hawkie316 Posted February 21, 2019 Posted February 21, 2019 Hey all Try to launch Final Fantasy VII through hyperspin and get the "select your disc" screen showing disc 1 to 3 but I cannot select or launch it. It let's me highlight the disc but cant seem to select any. Files seem to be names correctly (they are rar files) as per pics below. Any ideas?? Cheers in advance
griffin518 Posted February 21, 2019 Posted February 21, 2019 This is an emulator issue, not HyperSpin or RocketLauncher. That being said, which emulator are you using? Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Hawkie316 Posted February 21, 2019 Author Posted February 21, 2019 Hey @griffin518 am using epsxe 2.0.5
Creezz67 Posted February 22, 2019 Posted February 22, 2019 Try using RetroArch or PCSX, both much better IMO
dark13 Posted February 22, 2019 Posted February 22, 2019 As far as I know only RetroArch supports multidisk changing from RA gui. 1: change the database to have no disc title and remove the entry with disk number (es: "Final Fantasy VII (USA)" 2: decompress the zipped roms. Some sets have in every rom roms "track1.bin" so decompress one disc at time and rename disc 2 file "track02.bin", change the name also in the .cue 3: create the .m3u file , just open with notepad and change the name of the cue/ccd 4: compress everything ( the.cue, the .bin and the .m3u) in a single rar5 archive 5: add .m3u extension to RetroArch module in RocketLauncher Load the rom, you can manage disk changing in retroarch's gui (disc managment->cycle tray->change disk->cycle tray) Colony Wars (USA).m3uFetching info... Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Hawkie316 Posted February 25, 2019 Author Posted February 25, 2019 Thanks @cataclysm67 & @dark13 will give it a try and let you know
Hawkie316 Posted February 27, 2019 Author Posted February 27, 2019 On 2/22/2019 at 10:27 PM, dark13 said: As far as I know only RetroArch supports multidisk changing from RA gui. 1: change the database to have no disc title and remove the entry with disk number (es: "Final Fantasy VII (USA)" 2: decompress the zipped roms. Some sets have in every rom roms "track1.bin" so decompress one disc at time and rename disc 2 file "track02.bin", change the name also in the .cue 3: create the .m3u file , just open with notepad and change the name of the cue/ccd 4: compress everything ( the.cue, the .bin and the .m3u) in a single rar5 archive 5: add .m3u extension to RetroArch module in RocketLauncher Load the rom, you can manage disk changing in retroarch's gui (disc managment->cycle tray->change disk->cycle tray) Colony Wars (USA).m3uFetching info... Expand Hey @dark13 have decompressed the roms and created the m3u file and the file type the retroarch module. Just not sure about changing the database. Playing around with the X-Files just not sure how to do step 1. Attached is a copy from the database. Thanks multigame.txt
dark13 Posted February 27, 2019 Posted February 27, 2019 The name of the .cue/.ccd and the .rar must be X-Files, The (USA) multigame2.txt Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Hawkie316 Posted February 27, 2019 Author Posted February 27, 2019 On 2/27/2019 at 4:18 PM, dark13 said: The name of the .cue/.ccd and the .rar must be X-Files, The (USA) multigame2.txtFetching info... Expand Thanks @dark13 so I change the first entry and remove the rest?
dark13 Posted February 27, 2019 Posted February 27, 2019 Yeah. Databases are not rocket science, you must have the correct rom's name listed and be sure that all tags are closed Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Hawkie316 Posted February 28, 2019 Author Posted February 28, 2019 On 2/27/2019 at 9:34 PM, dark13 said: Yeah. Databases are not rocket science, you must have the correct rom's name listed and be sure that all tags are closed Expand Thanks mate will give it a go
braap Posted March 15, 2019 Posted March 15, 2019 Definitely use RetroArch. Multidisc games need to be UNZIPPED too. I have mine setup like so: Final Fantasy VIII (Disc 1) (USA) Final Fantasy VIII (Disc 1) (USA).bin Final Fantasy VIII (Disc 1) (USA).cue Final Fantasy VIII (Disc 2) (USA) Final Fantasy VIII (Disc 2) (USA).bin Final Fantasy VIII (Disc 2) (USA).cue Final Fantasy VIII (Disc 3) (USA) Final Fantasy VIII (Disc 3) (USA).bin Final Fantasy VIII (Disc 3) (USA).cue Final Fantasy VIII (Disc 4) (USA) Final Fantasy VIII (Disc 4) (USA).bin Final Fantasy VIII (Disc 4) (USA).cue RocketLauncher makes the .m3u automatically and places it in the directory. Add m3u to your RetroArch extensions.
Hawkie316 Posted March 16, 2019 Author Posted March 16, 2019 Thanks all, looks like I finally got it working....well they load now, haven't gotten far enough into it to have to change disks yet. Seems that I somehow missed there was no "select" button assigned in the rocketlauncher controls this has now also fixed my issue with pause.
