Hydro Posted May 23, 2019 Posted May 23, 2019 hello, is there any Arcade Cabinet - 2 Player Semi Pre Configured Hyperspin Build ? like in platinum section ....etc
adamg Posted May 23, 2019 Posted May 23, 2019 There is. Gigapig supports it and it works fairly decently. It does not have roms or media (not 100% on the media) so you will need to fill everything out but the emulators and setup are pretty much done.
thatman84 Posted May 23, 2019 Posted May 23, 2019 It’s 63 systems from memory with rocket launcher configured. Default controls are set but will need adjusting to your controls. iirc the main menu has media but not all the system games. And of course no Roms/bios Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted May 23, 2019 Posted May 23, 2019 HFS Box 15k You'll have to jump through some hoops to get it. As it's hosted on a French forum and you'll need to change the Hyperspin special artwork files so they're English. However it's very arcadecentric. With Capcom, Cave, mame, schmups, even polygame masters. The artwork is very good and much of it is not available here to my knowledge. I used it as a base pack for my Hyperspin Shield TV setup and added more systems over time from my PC configuration. All the best with it. "There is so much more and beckons me. To look through to these, infinite possibilities..."
