StyleMaster Posted March 7, 2020 Posted March 7, 2020 Hello im a total newb when it comes too swf editing i know how to use photoshop 6.0 but not the later editions i have a few GIF files that i want to use as a animated WHeel image , i already tried GIF to .SWF conversion. But the swf image is out of position on the wheel & also displays white borders around the image whats the best way to do the editing any recommendations Thanks the Swf support makes hyperspin really stand out
dark13 Posted March 7, 2020 Posted March 7, 2020 You need flash professional or animate cc, document resolution must be 1*1 and the gif must be centered, if it's 500*500 position will be -250, -250. Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
StyleMaster Posted March 8, 2020 Author Posted March 8, 2020 Thanks for the reply! im going to work with this
StyleMaster Posted March 10, 2020 Author Posted March 10, 2020 On 3/7/2020 at 6:56 PM, dark13 said: You need flash professional or animate cc, document resolution must be 1*1 and the gif must be centered, if it's 500*500 position will be -250, -250. Wow ive been trying all day to get this to appear right in HyperSpin , im afraid its going to take months before i get this right Ive added the gif here which is the one i like to appear in the Main menu i dont know if youre able to position this one for me one time
StyleMaster Posted March 11, 2020 Author Posted March 11, 2020 On 3/7/2020 at 6:56 PM, dark13 said: You need flash professional or animate cc, document resolution must be 1*1 and the gif must be centered, if it's 500*500 position will be -250, -250. so if i understand right width & height resolution must be 100 X 100
thatman84 Posted March 11, 2020 Posted March 11, 2020 Here are the official instructions for creating animated wheels. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
StyleMaster Posted March 24, 2020 Author Posted March 24, 2020 I still cant get the swf to appear right in the HyperSpin menu wheel , I did exact what is in the instruction 1 x 1 resolution , and then the half of the width & height of the swf both negative the swf appears to be out of position not even displaying at all ?
dark13 Posted March 24, 2020 Posted March 24, 2020 1 hour ago, StyleMaster said: I still cant get the swf to appear right in the HyperSpin menu wheel , I did exact what is in the instruction 1 x 1 resolution , and then the half of the width & height of the swf both negative the swf appears to be out of position not even displaying at all ? If it's a gif you need to change position in every keyframes Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
StyleMaster Posted March 25, 2020 Author Posted March 25, 2020 12 hours ago, dark13 said: If it's a gif you need to change position in every keyframes yes i select all layers and even dragged the gif to center position , previewed the gif to make sure all the layers maintain the same position then after i make it 1 x 1 & adjust the x y coordinates but then it doenst appear in the wheel i uploaded the gif in the post above me
StyleMaster Posted May 12, 2020 Author Posted May 12, 2020 THis is how it appears @thatman84 after i used Adobe Animate with positioning https://ibb.co/CKZ01Ym Hope you guys can help me fix this
