So I had a hard drive die on me and now I have to rebuild my arcade machine.
Unfortunately, I loaded up windows 10 so now my hyperspin wont load and I'm having troubles finding the fixed files (assuming thats my issue).
Does anybody out there have a link to the repaired files?
Thanks.
Jimbo6
I copied the sxs.dll from my windows/system32 directory and that didnt help. I thought that there was a fix to the hyperspin.exe or something after a win10 patch.
This is what I get for upgrading the OS.. lol.
I'll give it a try just incase theres something wrong with my sxs.dll.
Thanks for helping out, dude.
--Jimbo6
--Jimbo6
Because the sxs.dll in Windows 10's system32/syswow64 is not compatible with Hyperspin. There is no patch on HS exe, you only need to download the posted dll and put it in the same folder of hyperspin.exe. It's the dll used in windows7, if a dll is included in the same folder of the exe, the exe will use that dll instead of using the one in system32/syswow64. It's an old school trick 😛
OMG.  so I had tried the one from my windows/system32 folder and it didn't work.   I just tried the file you sent and *FIXED*!  Thank you FY!  you RULE!
And I appreicate the added explanation Dark13!
--Jimbo6
  • 2 months later...
I downloaded the sxs.dll uploaded on this forum and placed in the same folder of hyperspin.exe (run as admin) but it didn't work for me. I have Windows 10 Pro, version 22h2, build 19045.3803. Hope it could be fixed soon!
thanks!!
Can anyone help me out with this?  I've been waiting for the downloads to come back online to get the dll file to fix win 10 but it has been over a month now.  Any chance someone could share it with me?
  • 1 year later...
  • 2 months later...
Please help. Still not working. I copied the .dll file and made sure windows defender was not blocking anything. I also ran as admin. no luck. nothing happens
@Winamp920 What Windows version are you on?
Things to try:
1. Try downloading and installing Hyperspin in a different location from your original install to check if your original Hyperspin install is the issue. Don’t forget to place the sxs.dll file in the root of your Hyperspin folder, only if your on Windows 10 or above.
2. Run sfc /cannow from a command prompt.  Run it as an Administrator.  It will attempt to to repair any missing or corrupted system files.
