allanmark20 Posted May 3 Posted May 3 Many users have faced issues with Hyperspin not working after the Windows 11 24H2 update. At icd blog, we highlight how important it is to manage updates carefully, especially for software like Hyperspin—waiting for patches or exploring alternatives like LaunchBox can help keep your setup running smoothly. 1
rik81 Posted May 4 Posted May 4 Its the sxs.dll file... it got updated in the system32 folder... Which doesnt work with hyperspin. Needs to be replaced... but you cant just update the folder manually with the file as its protected.
floatingyeti Posted May 4 Posted May 4 6 minutes ago, rik81 said: Its the sxs.dll file... it got updated in the system32 folder... Which doesnt work with hyperspin. Needs to be replaced... but you cant just update the folder manually with the file as its protected. I've always placed the (compatible) sxx.dll file in the HyperSpin directory. Is that fix no longer working?
Agard Posted May 4 Posted May 4 They have released a windows 11 iot ltsc 24h2 but i don't know if hyperspin works on that version yet so i hope someone can test it as it might not have those updates in that break it. I'm on windows 11 pro & can't uninstall KB5055523 so how can i uninstall it as in my uninstall updates it's not listed to uninstall. That's why i was wondering if windows 11 iot ltsc 24h2 works & doesn't install that update as it's release was october 2024 & i think you don't get anymore cumulative updates which broke hypersin. https://www.microsoft.com/en-us/evalcenter/download-windows-11-iot-enterprise-ltsc-eval
jesfknkrys Posted May 5 Posted May 5 @Agard From the Windows icon, press and hold the Shift key while clicking Restart. In the Windows Recovery Options menu, click Troubleshoot, and then click Advanced Options. Click "Uninstall updates", and click "Uninstall latest quality update". Hopefully that works for you. 3
jh79 Posted May 8 Posted May 8 Unfortunately that does not work @Agard Any other ideas for KB5055523 that won't uninstall?
Agard Posted May 8 Posted May 8 @jh79 jesfknkrys is the 1 to ask I haven't tried yet myself as been downloading for days & don't want to stop it. 300GB left but will post here if it doesn't work
jesfknkrys Posted May 8 Posted May 8 @jh79It seems like there's a few users unable to uninstall update KB5055523. I will try to reinstall the update to check if I get the same result of being unable to uninstall it. Meanwhile try the following to uninstall: Open Command prompt as an administrator. copy the line below and press "Enter" wusa /uninstall /kb:5055523 Status: I just updated to KB5055523 and it does give me the option to uninstall. Edition Windows 11 Pro Version 24H2 Installed on 4/30/2025 OS build 26100.3775 Experience Windows Feature Experience Pack 1000.26100.66.0
jesfknkrys Posted May 8 Posted May 8 On 4/21/2025 at 6:53 AM, Dime333 said: The bottom screenshot is the update history and Hyperspin is not working. None of the two updates show up there. I downloaded Windows 11 from Microsoft's Web page. The update is probably already in that version, so I guess I'm fucked. I remember there was an older fix before to make Hyperspin work with Windows 11. I don't need that now, do I? It could be that you selected to downloaded the updates when you initially installed a Fresh copy of Windows. I installed the updates one at a time inside Windows. Try this in Command Line as an administrator: Replace "5055523" with the update you would like removed. The example below is to remove "KB5055523" wusa /uninstall /kb:5055523
Dime333 Posted May 8 Posted May 8 2 hours ago, jesfknkrys said: It could be that you selected to downloaded the updates when you initially installed a Fresh copy of Windows. I installed the updates one at a time inside Windows. Try this in Command Line as an administrator: Replace "5055523" with the update you would like removed. The example below is to remove "KB5055523" wusa /uninstall /kb:5055523 I reinstalled Windows and blocked 5055523. For the last few days, Windows has been saying that KB5055627 is available, but it has not been autoinstalled. So it seems to be good for now. If it will be installed eventually, I can just uninstall it. At least I could do that the last time. It's just a shame that it can't be blocked. 2
jesfknkrys Posted May 8 Posted May 8 In addition to blocking the update, delete the contents of the SoftwareDistribution folder.
Agard Posted May 11 Posted May 11 What I want to know will 25h2 fix it when available to all but I got a friend who has all the updates & hyperspin still works so why does it work for some & not others?
jh79 Posted May 12 Posted May 12 @jesfknkrys Thanks for helping, I did have an option to uninstall it but after I hit uninstall it goes about 20% and quits. Did you actually go through with the uninstall, if so did it uninstall completely? If it does uninstall completely on yours and not mine maybe it's because mine doesn't have anything to revert to? Like missing files or something? I will try those commands you suggested ASAP and report back...
jh79 Posted May 12 Posted May 12 @Dime333 Can't it be hidden with that program posted earlier on this thread. I believe The post said something like Windows won't install hidden updates. 1
jesfknkrys Posted May 12 Posted May 12 27 minutes ago, jh79 said: @jesfknkrys Thanks for helping, I did have an option to uninstall it but after I hit uninstall it goes about 20% and quits. Did you actually go through with the uninstall, if so did it uninstall completely? If it does uninstall completely on yours and not mine maybe it's because mine doesn't have anything to revert to? Like missing files or something? I will try those commands you suggested ASAP and report back... @jh79 Try checking for Windows corrupted files first. In an elevated command type the below from line 1 and wait for it to complete. Then try uninstalling the update using the command on line 2. If it doesn’t work we can try repairing your Windows files using DISM commands. Let us know your result. 1. sfc /scannow 2. wusa /uninstall /kb:5055523
jesfknkrys Posted May 12 Posted May 12 2 hours ago, Agard said: What I want to know will 25h2 fix it when available to all but I got a friend who has all the updates & hyperspin still works so why does it work for some & not others? @AgardI’m not sure if 25h2 would fix the issues. It’s something we would have to test once available. Can you confirm that he does have the problematic updates installed? Also, what version(education, home, pro, enterprise, lot enterprise) of Windows 11 and build is he on?
jh79 Posted Monday at 06:39 AM Posted Monday at 06:39 AM I was able to uninstall kb:5055523 and get my Hyperspin working again. The only thing that worked for me was right click Start on your taskbar and click System. Then click System again in the top left menu. Look for Recovery in the middle panel and click "Fix Problems using Windows Update". Click Reinstall Now. Just let it do it's thing and reboot when asked. I was able to delete kb:5055523 and get HS working. I'm going to try and hide it now with that tool jesfknkrys suggested, thanks for that hope this helps someone cuz that sucked. You can also do this to disable Windows Updates: 2. Disabling Automatic Updates (Permanent): Method 1: Using Services: Open Run dialog (Windows Key + R) and type services.msc. Find "Windows Update" in the list, right-click, and select "Properties". Change the Startup type to "Disabled" and click "Stop" if it's running. Apply the changes and click OK.
shredder Posted Monday at 08:34 AM Posted Monday at 08:34 AM Posting a comment here, I'm having this issue just recently after some updates applied. I have tried searching for 5055523 to remove as previous suggestions have recommended doing so. I don't see that update installed at all, but still my Hyperspin, I can see it launch in task manager and close immediately. I've tried removing other updates, but nothing has worked thus far.
jesfknkrys Posted Monday at 01:00 PM Posted Monday at 01:00 PM @shredder Have you tried removing the other 2 updates as well?
Agard Posted Monday at 02:49 PM Posted Monday at 02:49 PM I have all the updates installed on windows 11 pro & just found out that when you run HyperSpin the first time with all the updates it deletes some files as I put in my windows 10 pc & it wouldn't work so replaced the files & added an exclusion in windows 11 pro & wow HyperSpin satrted working again. Whats installed am I missing any that causes the problems as exluded entire drive & HyperSpin Works. https://postimg.cc/G8kwWf7z 1
Agard Posted Monday at 05:20 PM Posted Monday at 05:20 PM I don't see this update in my list but it says up to date when i click on check for updates. (KB5053598) when did above update come out ?
Dime333 Posted Monday at 05:53 PM Posted Monday at 05:53 PM 16 hours ago, jh79 said: @Dime333 Can't it be hidden with that program posted earlier on this thread. I believe The post said something like Windows won't install hidden updates. No. I haven't been able to block this specific update.
jesfknkrys Posted Monday at 08:37 PM Posted Monday at 08:37 PM 3 hours ago, Agard said: I don't see this update in my list but it says up to date when i click on check for updates. (KB5053598) when did above update come out ? @Agard - It might have been an update from a previous Windows 11 Build. No need to worry about it if Hyperspin is currently working.
Agard Posted Monday at 11:10 PM Posted Monday at 11:10 PM 2 hours ago, jesfknkrys said: @Agard - It might have been an update from a previous Windows 11 Build. No need to worry about it if Hyperspin is currently working. Is your windows 11 all up to date & HyperSpin working ?
