Inho Posted January 12 Posted January 12 Hi Guys. Just installed to a custom drive, works fine. Then a pop said update so i did. It reinstalled hyperhq in c/:programdata/. The original location then was taken over. I have done this twice now and the same happens. Inho 2
fr0stbyt3 Posted January 12 Posted January 12 This should be fixed in the latest version, but it requires a reinstall. The installer itself needed an update. Pull the latest from the download link at the top and let me know what you think!
Fursphere Posted January 12 Posted January 12 I just noticed I have this same issue. Originally installed HyperHQ to d:\hyperspin\hyperhq\ Update to HyperHQ moved to it c:\Program Files\hyperhq\ 1
fr0stbyt3 Posted January 12 Posted January 12 I have another build coming today to tomorrow. Install the latest today and we'll see if it happens again with the next build. 2
Fursphere Posted January 13 Posted January 13 Just updated to v2.0.32 HyperHQ moved itself back to the C:\ drive.
SubRetro Posted January 13 Posted January 13 I just experienced the same thing as my custom folder HyperHQ.exe is version 30 so the past two versions are now in C:\Program Files\HyperHQ\. your saying to reinstall so will that blow away the systems and media that I setup?
zillion23 Posted January 13 Posted January 13 I can confirm this same issue as above. I installed HyperHQ and Hyperspin on another drive that is not the C drive but both programs installed folders in my C drive users, appdata and Program Files folder on my C drive. I have a shortcut to HyperHQ.exe pinned to my taskbar and every time I update HyperHQ it deletes the shortcut because I guess it is installing it in the C Program Files folder again.
Creezz67 Posted January 13 Posted January 13 HyperHQ keeps asking me to update, now it has been 10 times in a row and still it keeps asking ? I am assuming this is a bug ?
Creezz67 Posted January 13 Posted January 13 11 minutes ago, dreamw said: Hellow Bro! Reboot hyperHQ not help? No, as soon as I reload it asks me again. Also HyperHQ will not exit correctly and can only be rebooted if I close it down in Task Manager Same with Hyperspin.exe (won't exit correctly)
Creezz67 Posted January 13 Posted January 13 Now I know why it keeps asking me to update over and over, even though I am using HyperHQ on D:\ when it updated it kept updating and copying to C:\ So it seems to think it's not updated and then asks over and over to update, all the while sending it to C:\ Once I copied the C:\ files back to D:\ it then stops asking me to update. Update: Once I did this, HyperHQ works fine but now Hyperspin will not load at all.
thatman84 Posted January 13 Posted January 13 Moved to HyperHQ Support forum Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
CydXero Posted January 13 Posted January 13 HyperHQ is designed to actually stay on, but in your tray. RIght click quit. If that doesn't work, kill the task. Also, clear all cache in the HS settings. That might help. 1 CydXero
fr0stbyt3 Posted January 14 Posted January 14 Please uninstall HyperHQ and Reinstall it with the latest installer 2.0.33 Here it'll keep your settings and it should stop having this issue.
fr0stbyt3 Posted January 14 Posted January 14 On 1/13/2025 at 3:24 AM, Creezz67 said: HyperHQ keeps asking me to update, now it has been 10 times in a row and still it keeps asking ? I am assuming this is a bug ? It seems like a few of your bugs are related to the system not installing in the correct path. Uninstall and reinstall the latest and it should fix you up. Report back and let me know!
Creezz67 Posted January 14 Posted January 14 23 minutes ago, fr0stbyt3 said: It seems like a few of your bugs are related to the system not installing in the correct path. Uninstall and reinstall the latest and it should fix you up. Report back and let me know! I updated from 31 to 33 and it installed into C:\ instead of D\ once I moved the new HyperHQ folder onto my D:\ and then added a new system all the media it downloaded was added to the correct location (D:\ drive) for the first time 1
zillion23 Posted January 14 Posted January 14 2 hours ago, fr0stbyt3 said: Please uninstall HyperHQ and Reinstall it with the latest installer 2.0.33 Here it'll keep your settings and it should stop having this issue. Actually that installer link is directing to HyperHQ_2.0.31.exe.
Fursphere Posted January 14 Posted January 14 22 minutes ago, zillion23 said: Actually that installer link is directing to HyperHQ_2.0.31.exe. here is .33 - https://hyperai.s3.amazonaws.com/HyperHQ_2.0.33.exe
zillion23 Posted January 15 Posted January 15 @fr0stbyt3 The updater is still installing the updates to the C Program Files folder. I was on HyperHQ 2.0.33.0 and have it installed on my G drive. There was no HyperHQ folder on my C Program Files folder before I updated to 2.0.34.0. After the update it created a HyperHQ folder in my C Program Files folder and installed the update in that folder and left the HyperHQ.exe on my G drive the 2.0.33.0 version. 1
Creezz67 Posted January 16 Posted January 16 On 1/14/2025 at 4:26 PM, fr0stbyt3 said: It seems like a few of your bugs are related to the system not installing in the correct path. Uninstall and reinstall the latest and it should fix you up. Report back and let me know! HyperHQ is still not installing in the correct place when updating from v2.0.33 to v2.0.34 My setup is located in D:\Arcade\HyperHQ and it installed automatically to C:\Program Files\HyperHQ Why not have an option box to ask where you want it to be installed ?
Circo Posted January 16 Posted January 16 Merged Reports ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
